Date/Time: Mon, 13 Jan 2025 11:57:16 +0000
XP update support
View Count: 1156
[2017-02-24 20:11:06]
User981981 - Posts: 1
I updated to "latest version" and the software crashed. When I logged on to support, it said that you are no longer going to support Windows XP and to do a "rollback" to a previous version that worked. I did that. It didn't. I tried downloading several other previous versions; none worked. I lost $2000 on open trades. I called. I emailed. No one has returned my call or helped. Frustrated, I tried uninstalling and reinstalling; I tried deleting and reinstalling. Nothing works. The computer gives and error when I start Sierra Charts of "The Procedure Entry Point CancelIoEx could not be located in the dynamic link library KERNEL32.dll." Please help me with this.
Kaylan Holmes
801-503-6492
[2017-02-24 21:41:20]
For the record, there was no call from you to Sierra Chart. And this is the first we are hearing from you about this. The other messages must have been to Green Chart which is separate from us.
Would you be available in about 30 minutes for the call? We will call you at the number given here.
Date Time Of Last Edit: 2017-02-24 21:58:24
[2017-02-24 22:02:02]
Will be calling in about 10 minutes.
We will need to use this installer:
https://www.sierrachart.com/downloads/SierraChartFileDownloader_WindowsXP.exe
[2017-02-24 22:07:04]
We have restored Windows XP support on prerelease version 1524.
We tried calling in response to your Telephone and Remote Assistance Support request and could not reach you. We left you a message. Please let us know when is a good time to call back.
[2017-02-24 22:45:28]
We have made this easy for you.
We customized the Windows XP installer to install the proper version of Sierra Chart compatible with Windows XP
Simply run this program:
And press the "Install" button.
[2017-02-25 07:43:15]
Lesmond - Posts: 22
Can you please keep Windows XP compatibility, if possible. I'm also using XP for the time being.
In my case XP is installed on a dedicated PC that is only used to run Sierra and IB TWS. For anything else I have a few Linux distros multibooted on another machine (Arch, Debian, Linux Lite, Manjaro, Xubuntu). I just didn't have time to figure out how to run Sierra on Wine. Btw, life without Windows is a real pleasure.
Date Time Of Last Edit: 2017-02-25 08:48:11
[2017-02-25 11:15:13]
There is a function that Sierra Chart needs to use which is not supported on Windows XP.
[2017-04-25 22:55:46]
Windows XP support has been restored in the newer versions of Sierra Chart. So it is supported again.
