Date/Time: Sun, 12 Jan 2025 12:49:01 +0000
SC failing to connect CQG datafeed
View Count: 674
[2017-02-19 09:54:03]
Bango - Posts: 76
noticed my different versions of SC (1518 and 1510) are failing to connect to CQG datafeed (tested on two different accounts) while other platforms (Multicharts and Ninjatrader are connecting as usual.
I will send the message log.
[2017-02-19 19:59:51]
This is the relevant message:
CQG WebAPI websocket (60) | Connect event error. Windows error code 10060: Impossibile stabilire la connessione. Risposta non corretta della parte connessa dopo l'intervallo di tempo oppure mancata risposta dall'host collegato. | 2017-02-19 10:42:21 *
If you are able to connect to the same CQG server from other programs, then this would indicate a firewall on your system is blocking Sierra Chart. In this particular case, refer to help topic 1.3:
https://www.sierrachart.com/index.php?page=doc/helpdetails1.php#h1.3
Date Time Of Last Edit: 2017-02-19 20:00:44
