Date/Time: Sun, 12 Jan 2025 09:34:05 +0000
Spreadsheet flatten position at certain time
View Count: 1710
[2017-02-12 18:45:12]
User170575 - Posts: 221
Good afternoon,
So I have J88 on "True" and J89 at "15:55:00" but the position will not
execute on the sell---your thoughts very much appreciated.
Image included.
Many thanks,
Cy
imageflatten.jpg / V - Attached On 2017-02-12 18:44:02 UTC - Size: 79.74 KB - 276 views
[2017-02-12 20:42:37]
We want you to test this during a replay.
Start a replay before that time, and manually establish a Position. Do not use any buy or sell formulas to enter or exit a position.
Once that time is encountered or passed over, the Position should be flattened.
Date Time Of Last Edit: 2017-02-14 17:36:22
[2017-02-14 14:21:33]
Good morning,
Yes, Auto is enabled.
I tried the replay and it does work---but found this issue(see image)---not sure why it would
take a double position when the formula is "=AND($J$5=0,CK3>0)"? And the second order is the one that
did not sell at 3:55.
=AND($J$5=0,CK3>0)---this is sheet2--cell K3.
http://www.sierrachart.com/image.php?Image=1487081868365.png
Here is the sell formula: =AND($J$10>1000)
Flatten Postitions is set to TRUE
at 15:55:00
Thanks for all your help,
Cy
[2017-02-14 17:35:16]
Post #3 is outside the scope of our support.
Refer to:
http://www.sierrachart.com/index.php?page=doc/AutoTradeManagment.php#TroubleshootingAutoTradingSystemBehavior
