Date/Time: Sun, 12 Jan 2025 09:43:27 +0000
User Email
View Count: 664
[2017-02-09 00:20:23]
Sierra Chart - Max - Posts: 5778
Our customer, volume trader, recently noticed a gigantic difference in the cumulative volume number (yellow arrow). Official volume for ex. on NQ was 140k and hsi SC showed only 104k....on the ES only 550k instead of 1.1 million.
I checked all settings and cannot figure out why...his connection is pretty good.
Sierra Chart Support
imagenasdaq volume error.png / V - Attached On 2017-02-09 00:20:18 UTC - Size: 206.24 KB - 276 views
[2017-02-09 18:16:01]
For NQH17 for 2017-22-8, we see a volume of 165710 using a starting time of 18:00 US Eastern.
Make sure there is no volume filtering set on the chart:
http://www.sierrachart.com/index.php?page=doc/ChartSettings.html#VolumeFilter
And follow the instructions in help topic 2.1.2 to re-download the data for the last few days:
http://www.sierrachart.com/index.php?page=doc/helpdetails2.html#h2.1.2
You also need to make certain that the chart Session Times are set correctly and match the session times the exchange uses:
http://www.sierrachart.com/index.php?page=doc/SessionTimes.php
The issue should be one of these.
Date Time Of Last Edit: 2017-02-09 18:16:31
