Date/Time: Sun, 12 Jan 2025 04:19:41 +0000
Missing decimal on the mini euro
View Count: 866
[2017-02-03 01:52:20] |
User157806 - Posts: 71 |
From my understanding the mini Euro now has half tick increment however within sierra charts it is missing is there a fix for this?
mini euro missing last digit.jpg / V - Attached On 2017-02-03 01:51:54 UTC - Size: 291.85 KB - 245 views |
[2017-02-03 02:27:56] |
The .00005 is just for spreads for that symbol. But the symbol you are using is not a spread symbol. Otherwise, in that case you should see the Tick Size get set correctly automatically. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-03 02:35:51] |
Thank you for the prompt response do you happen to know where to locate the symbol from "Find Symbol" for the spread? I found the micro euro/usd but it still displays the same but i do not think that is what the customer is trying view. Subject - 66 and e7 Euro/USD CQG price discrepancies Here is the exact inquiry from customer. The problem is that CQG / Sierra is showing the price (Charts and DOM) at the Tick eg 1.0801. But the real price (TDAM) can be anywhere from 1.08010 to 1.08019 within that $6.25 Tick. This makes entering a trade more difficult. There should not be any truncation of the last digit. The price should show the last digit without moving the DOM or the chart. Meaning that a DOM at ($6.25 - 1 Tick) could be stable but the last digit could be changing. |
[2017-02-03 04:51:59] |
In the case of CQG spreads, refer to the documentation here for the symbol format: CQG Trading Platform Service: CQG Symbol Format The first thing we want them to do is to set Chart >> Chart Settings >> Price Display Format: Chart Settings: Price Display Format (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) to .00001 See if they then see the additional precision they are looking for. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
