Date/Time: Tue, 04 Nov 2025 10:44:13 +0000
Drawing a subgraph line on a study when using sc.GraphDrawType = GDT_CANDLESTICK_BODY_ONLY
View Count: 1056
[2017-01-31 20:47:07]
User484986 - Posts: 4
I've ran into this issue twice so I figured I would ask. I have a candle chart using specific values and I would like to add lines using subgraphs. They are visible in the settings, but not on the chart (they display in the charge values, headers, etc). Am I doing it wrong when using this Draw Type or do I need to do something special in order for it to render. It's weird because the value for the lines changes the scaling correctly, but you can't see them.
Thanks.
[2017-01-31 22:32:48]
When using this Graph Draw Type, only the first four Subgraphs are used for the candlestick only. The others are not drawn.
A separate study needs to be used.
