Date/Time: Sun, 12 Jan 2025 00:41:19 +0000
Problem with second instance of sierra missing tick data.
View Count: 614
[2017-01-24 16:09:05]
ivan100 - Posts: 2
Thank you for help from yesterday.Now is almost everything ok,but I set like you recommend,the main chart is ok,but when I set second Instance on second monitor I dont have tick data from sierra,that means I can not use second monitor for trading,because I need tick data for trading and there are only data from interactive brokers.Can you help me with this problem.Thank you.Bosela
[2017-01-24 17:54:06]
It is best that you use the New Instance feature which is documented here:
http://www.sierrachart.com/index.php?page=doc/DTCServer.php#UsingDTCServerForDataAndTradingInAnotherSCInstance
To make sure you have data in that instance which matches the main/server instance of Sierra Chart, re-download the data in the chart with Edit >> Delete All Data and Download.
Also make sure it is set to a tick by tick data configuration:
http://www.sierrachart.com/index.php?page=doc/TickbyTickDataConfiguration.php
Date Time Of Last Edit: 2017-01-24 17:54:47
