Date/Time: Tue, 04 Nov 2025 14:57:44 +0000
es daily data
View Count: 2626
|   [2013-04-02 11:00:52]     |
| dtl-saw - Posts: 79 |
                my es daily data has stopped updating at 3/14 any suggestions to get current data?  |
|   [2013-04-02 14:11:32]     |
                What is the exact symbol of the chart you are using?
                 Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2013-04-02 14:17:41]     |
                the continuous contract ES#  |
|   [2013-04-02 14:18:28]     |
                The DTS is "SC Historical data"
|   [2013-04-02 14:22:17]     |
                Please post a copy of the Message Log, by following these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
