Date/Time: Tue, 04 Nov 2025 14:58:16 +0000
Volume Value Area lines
View Count: 2704
|   [2013-04-02 05:32:43]     |
| User54027 - Posts: 128 |
                Do these lines work on Forex or is it difficult to get accurate volume data on forex pairs? Thanks  |
|   [2013-04-02 06:02:01]     |
                Yes, you can use Volume Value Area lines on Forex symbols. It should work reasonably well.
                 Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
