Date/Time: Sat, 11 Jan 2025 17:52:37 +0000
data not coming in SC DATA
View Count: 1155
[2016-12-30 07:43:21]
User21339 - Posts: 61
Data is very erratic and unable to trade these last two days off SC
Im using SC DATA - All Services
also tried Forexdata (FXCM)
gappy charts all over the place.
Internet connection is fine as im able to connnect to any website.
I am in mainland china though and certain internet sites are an issue.
I dont see how they will block the data feed or interfere with it though.
Currently using ver. 1500
tried downloading the latest version but getting ERROR as in failed to establish a connection.
[2016-12-30 10:03:10]
Tell us one of the symbols there is a problem with.
Restart Sierra Chart and then follow the instructions here to download the missing data:
If there still is missing data, provide a copy of the Message Log following these instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2016-12-31 05:59:38]
message log below.
SC doesnt update the data. constant yellow 'waiting to donwload historical data' or blue 'downloading historical data' banners appear but nothing happens for hours and hours.
Reading Internal Order ID file. | 2016-12-31 05:38:53
Reading Trade Orders file. | 2016-12-31 05:38:53
Reading Trade Positions file. | 2016-12-31 05:38:53
Software version: 1504 | 2016-12-31 05:38:53
Uses New Spreadsheets | 2016-12-31 05:38:53
Usage end date: 2017-09-20 | 2016-12-31 05:38:53
Enabled for: Advanced Features. | 2016-12-31 05:38:53
Enabled for: Advanced Features 2. | 2016-12-31 05:38:53
Enabled for: Sierra Chart Historical Data Service. | 2016-12-31 05:38:53
Allow Support for Sierra Chart Data Feeds is enabled. | 2016-12-31 05:38:53
Current selected Data/Trading service: SC Data - All Services | 2016-12-31 05:38:53
Chart Update Interval: 500 | 2016-12-31 05:38:53
Time Zone: +00:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) | 2016-12-31 05:38:53
2016-12-31 13:39:10 Local computer time | 2016-12-31 05:38:53
2016-12-31 05:39:10 Local computer time in UTC | 2016-12-31 05:38:53
2016-12-31 05:39:10 Local computer time in SC Time Zone | 2016-12-31 05:38:53
2016-12-31 05:39:08 Server time in UTC | 2016-12-31 05:38:53
Local computer UTC time and Server UTC time difference: 2 seconds. | 2016-12-31 05:38:53
Program path: C:\SierraChart\ | 2016-12-31 05:38:53
Data Files path: C:\SierraChart\Data\ | 2016-12-31 05:38:53
OS Version Number: 6.2 | 2016-12-31 05:38:53
Locale Setting: C | 2016-12-31 05:38:53
Created the DTC Protocol server. | 2016-12-31 05:38:53
DTC Protocol Server listening on port 11099. | 2016-12-31 05:38:53
Created the DTC Protocol historical data server. | 2016-12-31 05:38:53
HD Server Manager | Listening on port 11098 | 2016-12-31 05:38:53
Checking for new symbol settings for scdataallservices | 2016-12-31 05:38:53
HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-12-31 05:38:53
HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-12-31 05:38:53
HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-12-31 05:38:53
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-12-31 05:39:13
SC Data - All Services | Connected to data server. | 2016-12-31 05:39:15
Symbol settings are up-to-date for scdataallservices | 2016-12-31 05:39:17
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-12-31 05:39:22
HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-12-31 05:39:22
HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-12-31 05:39:22
HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-12-31 05:39:22
DYH17 5 Min #7 | Reloading chart. | 2016-12-31 05:39:36
GER30 #16 | Reloading chart. | 2016-12-31 05:39:36
XAUUSD Daily #38 | Reloading chart. | 2016-12-31 05:39:36
NZDUSD Daily #17 | Reloading chart. | 2016-12-31 05:39:36
AUDJPY Daily #18 | Reloading chart. | 2016-12-31 05:39:36
GER30 #25 | Reloading chart. | 2016-12-31 05:39:36
EURJPY 60 Min #19 | Reloading chart. | 2016-12-31 05:39:36
AUDJPY 240 Min #41 | Reloading chart. | 2016-12-31 05:39:36
UKOIL Daily #15 | Reloading chart. | 2016-12-31 05:39:36
GER30 4 Min #33 | Reloading chart. | 2016-12-31 05:39:36
GER30 60 Min #34 | Reloading chart. | 2016-12-31 05:39:36
GER30 60 Min #55 | Reloading chart. | 2016-12-31 05:39:36
DYH17 240 Min #48 | Reloading chart. | 2016-12-31 05:39:36
GER30 60 Min #63 | Reloading chart. | 2016-12-31 05:39:36
GER30 4 Min #65 | Reloading chart. | 2016-12-31 05:39:36
GER30 1 Min #53 | Reloading chart. | 2016-12-31 05:39:36
US30 60 Min #44 | Reloading chart. | 2016-12-31 05:39:36
GCQ16 240 Min #21 | Reloading chart. | 2016-12-31 05:39:36
GER30 60 Min #67 | Reloading chart. | 2016-12-31 05:39:36
EUSTX50 20 Min #6 | Reloading chart. | 2016-12-31 05:39:36
GER30 300 Trades #12 | Reloading chart. | 2016-12-31 05:39:36
GER30 Daily #13 | Reloading chart. | 2016-12-31 05:39:36
GER30 Weekly #26 | Reloading chart. | 2016-12-31 05:39:36
GER30 4 Min #1 | Reloading chart. | 2016-12-31 05:39:36
GER30 4 Min #3 | Reloading chart. | 2016-12-31 05:39:36
GER30 20 Min #24 | Reloading chart. | 2016-12-31 05:39:36
GER30 10 Min #14 | Reloading chart. | 2016-12-31 05:39:36
GER30 60 Min #2 | Reloading chart. | 2016-12-31 05:39:36
PSN.LS Daily #42 | Reloading chart. | 2016-12-31 05:39:36
GER30 Weekly #45 | Reloading chart. | 2016-12-31 05:39:36
GER30 240 Min #5 | Reloading chart. | 2016-12-31 05:39:36
GER30 4 Min #11 | Reloading chart. | 2016-12-31 05:39:36
USDOLLAR 60 Min #4 | Reloading chart. | 2016-12-31 05:39:36
DYH17 5 Min #7 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\DYH17.scid | 2016-12-31 05:39:36
DYH17 240 Min #48 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\DYH17.scid | 2016-12-31 05:39:36
GCQ16 240 Min #21 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\GCQ16.scid | 2016-12-31 05:39:36
Using Bid/Ask average for last trade price for GER30 | 2016-12-31 05:40:04
SC DTC Data | Starting real-time market data updates for: GER30. ID: 1 | 2016-12-31 05:40:04
SC DTC Data | Connecting to the server ds4.sierracharts.com. Port 443 | 2016-12-31 05:40:04
SC DTC Data | Requesting security definition data for: GER30. ID: 1 | 2016-12-31 05:40:04
Intraday data recording state for symbol GER30 is set to download 'Pending'. | 2016-12-31 05:40:04
DTC Client (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-12-31 05:40:04
Market data subscription status is not known while delaying historical data download for symbol: GER30 | 2016-12-31 05:40:04
Delaying start of download for GER30 | 2016-12-31 05:40:04
SC Data - All Services | Starting real-time market data updates for: DYH17. ID: 2 | 2016-12-31 05:40:04
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: DYH17 | 2016-12-31 05:40:04
SC Data - All Services | Requesting security definition data for: DYH17. ID: 2 | 2016-12-31 05:40:04
Intraday data recording state for symbol DYH17 is set to download 'Pending'. | 2016-12-31 05:40:04
Using Bid/Ask average for last trade price for XAUUSD | 2016-12-31 05:40:04
SC DTC Data | Starting real-time market data updates for: XAUUSD. ID: 3 | 2016-12-31 05:40:04
SC DTC Data | Requesting security definition data for: XAUUSD. ID: 3 | 2016-12-31 05:40:04
Using Bid/Ask average for last trade price for NZDUSD | 2016-12-31 05:40:04
SC DTC Data | Starting real-time market data updates for: NZDUSD. ID: 4 | 2016-12-31 05:40:04
SC DTC Data | Requesting security definition data for: NZDUSD. ID: 4 | 2016-12-31 05:40:04
Using Bid/Ask average for last trade price for AUDJPY | 2016-12-31 05:40:04
SC DTC Data | Starting real-time market data updates for: AUDJPY. ID: 5 | 2016-12-31 05:40:04
SC DTC Data | Requesting security definition data for: AUDJPY. ID: 5 | 2016-12-31 05:40:04
Using Bid/Ask average for last trade price for EURJPY | 2016-12-31 05:40:04
SC DTC Data | Starting real-time market data updates for: EURJPY. ID: 6 | 2016-12-31 05:40:04
SC DTC Data | Requesting security definition data for: EURJPY. ID: 6 | 2016-12-31 05:40:04
Intraday data recording state for symbol EURJPY is set to download 'Pending'. | 2016-12-31 05:40:04
Intraday data recording state for symbol AUDJPY is set to download 'Pending'. | 2016-12-31 05:40:04
Using Bid/Ask average for last trade price for UKOIL | 2016-12-31 05:40:04
SC DTC Data | Starting real-time market data updates for: UKOIL. ID: 7 | 2016-12-31 05:40:04
SC DTC Data | Requesting security definition data for: UKOIL. ID: 7 | 2016-12-31 05:40:04
Using Bid/Ask average for last trade price for US30 | 2016-12-31 05:40:04
SC DTC Data | Starting real-time market data updates for: US30. ID: 8 | 2016-12-31 05:40:04
SC DTC Data | Requesting security definition data for: US30. ID: 8 | 2016-12-31 05:40:04
Intraday data recording state for symbol US30 is set to download 'Pending'. | 2016-12-31 05:40:04
SC Data - All Services | Starting real-time market data updates for: GCQ16. ID: 9 | 2016-12-31 05:40:04
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: GCQ16 | 2016-12-31 05:40:04
SC Data - All Services | Requesting security definition data for: GCQ16. ID: 9 | 2016-12-31 05:40:04
Intraday data recording state for symbol GCQ16 is set to download 'Pending'. | 2016-12-31 05:40:04
Using Bid/Ask average for last trade price for EUSTX50 | 2016-12-31 05:40:04
SC DTC Data | Starting real-time market data updates for: EUSTX50. ID: 10 | 2016-12-31 05:40:04
SC DTC Data | Requesting security definition data for: EUSTX50. ID: 10 | 2016-12-31 05:40:04
Intraday data recording state for symbol EUSTX50 is set to download 'Pending'. | 2016-12-31 05:40:04
Requesting market depth updates for: GER30 if supported. | 2016-12-31 05:40:04
SC Data - All Services | Starting real-time market data updates for: PSN.LS. ID: 11 | 2016-12-31 05:40:04
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: PSN.LS | 2016-12-31 05:40:04
SC Data - All Services | Requesting security definition data for: PSN.LS. ID: 11 | 2016-12-31 05:40:04
Using Bid/Ask average for last trade price for USDOLLAR | 2016-12-31 05:40:04
SC DTC Data | Starting real-time market data updates for: USDOLLAR. ID: 12 | 2016-12-31 05:40:04
SC DTC Data | Requesting security definition data for: USDOLLAR. ID: 12 | 2016-12-31 05:40:04
Intraday data recording state for symbol USDOLLAR is set to download 'Pending'. | 2016-12-31 05:40:04
Market data subscription status is not known while delaying historical data download for symbol: GER30 | 2016-12-31 05:40:13
DTC Client (4) | Connected. | 2016-12-31 05:40:13
SC DTC Data | Connected to server. | 2016-12-31 05:40:13
SC DTC Data | Sending Encoding Request to server | 2016-12-31 05:40:13
HD Request # 2 | Downloading Historical Daily chart data for PSN.LS. Starting date: 2004-08-05. Service: scdataallservices | 2016-12-31 05:40:13
Historical data download counter reset. | 2016-12-31 05:40:13
HD Request # 2 | Requesting historical Daily data for PSN.LS starting at 2004-08-04 | 2016-12-31 05:40:13
SC DTC Data | Setting DTC encoding to Binary VLS | 2016-12-31 05:40:13
SC DTC Data | Sending logon request message. | 2016-12-31 05:40:13
HTTP connection to ds01.ddfplus.com:80 (0) | Resolved address ds01.ddfplus.com to IP 8.18.161.123. | 2016-12-31 05:40:13
HTTP connection to ds01.ddfplus.com:80 (5) | Connected. | 2016-12-31 05:40:14
Market data subscription status is not known while delaying historical data download for symbol: GER30 | 2016-12-31 05:40:14
SC DTC Data | Received logon response. | 2016-12-31 05:40:14
SC DTC Data | Server Name: SC Realtime Server. | 2016-12-31 05:40:14
SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2016-12-31 05:40:14
SC DTC Data | Successfully connected. | 2016-12-31 05:40:14
SC DTC Data | Trading is not supported. | 2016-12-31 05:40:14
SC DTC Data | Restarting real-time data updates for symbol: AUDJPY | 2016-12-31 05:40:14
SC DTC Data | Restarting real-time data updates for symbol: EURJPY | 2016-12-31 05:40:14
SC DTC Data | Restarting real-time data updates for symbol: EUSTX50 | 2016-12-31 05:40:14
SC DTC Data | Restarting real-time data updates for symbol: GER30 | 2016-12-31 05:40:14
SC DTC Data | Restarting real-time data updates for symbol: NZDUSD | 2016-12-31 05:40:14
SC DTC Data | Restarting real-time data updates for symbol: UKOIL | 2016-12-31 05:40:14
SC DTC Data | Restarting real-time data updates for symbol: US30 | 2016-12-31 05:40:14
SC DTC Data | Restarting real-time data updates for symbol: USDOLLAR | 2016-12-31 05:40:14
SC DTC Data | Restarting real-time data updates for symbol: XAUUSD | 2016-12-31 05:40:14
Market data subscription status is not known while delaying historical data download for symbol: GER30 | 2016-12-31 05:40:15
SC DTC Data | Received security definition for symbol AUDJPY | 2016-12-31 05:40:15
SC DTC Data | Real-time data for symbol AUDJPY is currently unavailable. | 2016-12-31 05:40:15
SC DTC Data | Received security definition for symbol EURJPY | 2016-12-31 05:40:15
SC DTC Data | Real-time data for symbol EURJPY is currently unavailable. | 2016-12-31 05:40:15
SC DTC Data | Received security definition for symbol EUSTX50 | 2016-12-31 05:40:15
SC DTC Data | Real-time data for symbol EUSTX50 is currently unavailable. | 2016-12-31 05:40:15
SC DTC Data | Received security definition for symbol GER30 | 2016-12-31 05:40:15
SC DTC Data | Real-time data for symbol GER30 is currently unavailable. | 2016-12-31 05:40:15
SC DTC Data | Received security definition for symbol NZDUSD | 2016-12-31 05:40:15
SC DTC Data | Real-time data for symbol NZDUSD is currently unavailable. | 2016-12-31 05:40:15
SC DTC Data | Received security definition for symbol UKOIL | 2016-12-31 05:40:15
SC DTC Data | Real-time data for symbol UKOIL is currently unavailable. | 2016-12-31 05:40:15
SC DTC Data | Received security definition for symbol US30 | 2016-12-31 05:40:15
SC DTC Data | Real-time data for symbol US30 is currently unavailable. | 2016-12-31 05:40:15
SC DTC Data | Received security definition for symbol USDOLLAR | 2016-12-31 05:40:15
SC DTC Data | Real-time data for symbol USDOLLAR is currently unavailable. | 2016-12-31 05:40:15
SC DTC Data | Received security definition for symbol XAUUSD | 2016-12-31 05:40:15
SC DTC Data | Real-time data for symbol XAUUSD is currently unavailable. | 2016-12-31 05:40:15
Chart #24 has tagged chart #6 for full recalculation. Chartbook: DAX + others.cht | 2016-12-31 05:40:15
EUSTX50 [M] 20 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: DAX + others.cht | 2016-12-31 05:40:16
HD Request # 2 | Receiving historical Daily data for PSN.LS starting at 2004-08-05 | 2016-12-31 05:40:16
HD Request # 2 | Writing historical Daily data to the file PSN.LS.dly | 2016-12-31 05:40:16
Delaying start of download for GER30 | 2016-12-31 05:40:16
HD Request # 3 | Downloading Intraday chart data for GER30 to the file GER30.scid. Service: fxcm | 2016-12-31 05:40:19
Compressing file: C:\SierraChart\Data\GER30.scid. This may take a while. | 2016-12-31 05:40:19 *
HD Request # 3 | Download start date-time: 2016-12-30 21:09:20.000 | 2016-12-31 05:40:19
HD Request # 3 | Using server: ds4.sierracharts.com port 10149 | 2016-12-31 05:40:19
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-12-31 05:40:19
Socket (6) | Connected. | 2016-12-31 05:40:40
HD Request # 3 | Sending historical data logon request message. | 2016-12-31 05:40:50
HD Request # 3 | Setting DTC encoding to Binary VLS | 2016-12-31 05:40:58
HD Request # 3 | Sending historical data logon request message. | 2016-12-31 05:40:58
Socket (6) | Closed. No error. | 2016-12-31 05:40:58
Socket (6) | Shutdown and closed. | 2016-12-31 05:40:58
HD Request # 3 | Error downloading historical Intraday data for GER30. The network socket has been closed. Retrying download. | 2016-12-31 05:40:58
HD Request # 3 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GER30 | 2016-12-31 05:40:58
HD Request # 4 | Downloading Intraday chart data for GER30 to the file GER30.scid. Service: fxcm | 2016-12-31 05:40:58
HD Request # 4 | Download start date-time: 2016-12-30 21:09:20.000 | 2016-12-31 05:40:58
HD Request # 4 | Using server: ds3.sierracharts.com port 10149 | 2016-12-31 05:40:58
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2016-12-31 05:40:58
Socket (7) | Shutdown and closed. | 2016-12-31 05:41:18
HD Request # 4 | Error downloading historical Intraday data for GER30. Timeout error connecting to server. | 2016-12-31 05:41:18
HD Request # 4 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GER30 | 2016-12-31 05:41:18
HD Request # 5 | Downloading Intraday chart data for GER30 to the file GER30.scid. Service: fxcm | 2016-12-31 05:41:18
HD Request # 5 | Download start date-time: 2016-12-30 21:09:20.000 | 2016-12-31 05:41:18
HD Request # 5 | Using server: ds4.sierracharts.com port 10149 | 2016-12-31 05:41:18
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-12-31 05:41:18
Socket (9) | Connected. | 2016-12-31 05:41:22
HD Request # 5 | Sending historical data logon request message. | 2016-12-31 05:41:32
Requesting symbol settings for scdataallservices. Overwrite = on. | 2016-12-31 05:41:35
HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-12-31 05:41:35
HTTPS connection to www.sierrachart.com:443 (10) | Connected. | 2016-12-31 05:41:35
HTTPS connection to www.sierrachart.com:443 (10) | Starting TLS 1.2 connection. | 2016-12-31 05:41:35
HTTPS connection to www.sierrachart.com:443 (10) | SSL connection established. | 2016-12-31 05:41:36
Symbol settings received. | 2016-12-31 05:41:46
Processed 5195 symbol settings. | 2016-12-31 05:41:46
It is recommended to reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed' | 2016-12-31 05:41:46
HTTPS connection to www.sierrachart.com:443 (10) | SSL connection closed by remote side. | 2016-12-31 05:41:50
HTTPS connection to www.sierrachart.com:443 (10) | Connection gracefully closed by remote side. | 2016-12-31 05:41:50
HTTPS connection to www.sierrachart.com:443 (10) | SSL object has been freed. SSL state is now disconnected. | 2016-12-31 05:41:50
HTTPS connection to www.sierrachart.com:443 (10) | Shutdown and closed. | 2016-12-31 05:41:50
File >> Disconnect selected. | 2016-12-31 05:42:10
HD Request # 2 | Download canceled. | 2016-12-31 05:42:10
HD Request # 2 | Received 87 records from 2004-08-05 00:00:00 to 2004-12-03 00:00:00 (121.0 days) and wrote 86 records for PSN.LS | 2016-12-31 05:42:10
HD Request # 2 | Daily download COMPLETE for PSN.LS. Completion time: 1m 58s. Unique request ID: 13 | 2016-12-31 05:42:10
Removed historical data download ID 13 | 2016-12-31 05:42:10
Canceling historical data download request for DYH17 Intraday data. | 2016-12-31 05:42:10
Removed historical data download ID 2 | 2016-12-31 05:42:10
Canceling historical data download request for XAUUSD Daily data. | 2016-12-31 05:42:10
Removed historical data download ID 3 | 2016-12-31 05:42:10
Canceling historical data download request for NZDUSD Daily data. | 2016-12-31 05:42:10
Removed historical data download ID 4 | 2016-12-31 05:42:10
Canceling historical data download request for AUDJPY Daily data. | 2016-12-31 05:42:10
Removed historical data download ID 5 | 2016-12-31 05:42:10
Canceling historical data download request for EURJPY Intraday data. | 2016-12-31 05:42:10
Removed historical data download ID 6 | 2016-12-31 05:42:10
Canceling historical data download request for AUDJPY Intraday data. | 2016-12-31 05:42:10
Removed historical data download ID 7 | 2016-12-31 05:42:10
Canceling historical data download request for UKOIL Daily data. | 2016-12-31 05:42:10
Removed historical data download ID 8 | 2016-12-31 05:42:10
Canceling historical data download request for US30 Intraday data. | 2016-12-31 05:42:10
Removed historical data download ID 9 | 2016-12-31 05:42:10
Canceling historical data download request for GCQ16 Intraday data. | 2016-12-31 05:42:10
Removed historical data download ID 10 | 2016-12-31 05:42:10
Canceling historical data download request for EUSTX50 Intraday data. | 2016-12-31 05:42:10
Removed historical data download ID 11 | 2016-12-31 05:42:10
Canceling historical data download request for GER30 Daily data. | 2016-12-31 05:42:10
Removed historical data download ID 12 | 2016-12-31 05:42:10
Canceling historical data download request for USDOLLAR Intraday data. | 2016-12-31 05:42:10
Removed historical data download ID 14 | 2016-12-31 05:42:10
HD Request # 5 | Download canceled. | 2016-12-31 05:42:10
Socket (9) | Shutdown and closed. | 2016-12-31 05:42:10
HD Request # 5 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GER30 | 2016-12-31 05:42:10
HD Request # 5 | Intraday download COMPLETE for GER30. Completion time: 52s. Unique request ID: 1 | 2016-12-31 05:42:10
Removed historical data download ID 1 | 2016-12-31 05:42:10
DTC Client (4) | Shutdown and closed. | 2016-12-31 05:42:10
SC DTC Data | Disconnected from the server. | 2016-12-31 05:42:10
SC Data - All Services | Disconnected. | 2016-12-31 05:42:10
PSN.LS Daily #42 | Reloading chart. | 2016-12-31 05:42:10
Chart #24 has tagged chart #6 for full recalculation. Chartbook: DAX + others.cht | 2016-12-31 05:42:10
EUSTX50 [M] 20 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: DAX + others.cht | 2016-12-31 05:42:11
SC Data - All Services | Connected to data server. | 2016-12-31 05:42:13
SC Data - All Services | Starting real-time market data updates for: GCQ16. ID: 1 | 2016-12-31 05:42:13
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: GCQ16 | 2016-12-31 05:42:13
SC Data - All Services | Requesting security definition data for: GCQ16. ID: 1 | 2016-12-31 05:42:13
Intraday data recording state for symbol GCQ16 is set to download 'Pending'. | 2016-12-31 05:42:13
Delaying start of download for GCQ16 | 2016-12-31 05:42:13
Using Bid/Ask average for last trade price for AUDJPY | 2016-12-31 05:42:13
SC DTC Data | Starting real-time market data updates for: AUDJPY. ID: 2 | 2016-12-31 05:42:13
SC DTC Data | Connecting to the server ds3.sierracharts.com. Port 10048 | 2016-12-31 05:42:13
SC DTC Data | Requesting security definition data for: AUDJPY. ID: 2 | 2016-12-31 05:42:13
Intraday data recording state for symbol AUDJPY is set to download 'Pending'. | 2016-12-31 05:42:13
DTC Client (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2016-12-31 05:42:13
HD Request # 6 | Downloading Intraday chart data for GCQ16 to the file GCQ16.scid. Service: comex | 2016-12-31 05:42:13
Compressing file: C:\SierraChart\Data\GCQ16.scid. This may take a while. | 2016-12-31 05:42:13
HD Request # 6 | Download start date-time: 2016-05-24 00:59:59.000 | 2016-12-31 05:42:13
HD Request # 6 | Using server: ds6.sierracharts.com port 10149 | 2016-12-31 05:42:13
Using Bid/Ask average for last trade price for GER30 | 2016-12-31 05:42:13
SC DTC Data | Starting real-time market data updates for: GER30. ID: 3 | 2016-12-31 05:42:13
SC DTC Data | Requesting security definition data for: GER30. ID: 3 | 2016-12-31 05:42:13
Intraday data recording state for symbol GER30 is set to download 'Pending'. | 2016-12-31 05:42:13
SC Data - All Services | Starting real-time market data updates for: PSN.LS. ID: 4 | 2016-12-31 05:42:13
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: PSN.LS | 2016-12-31 05:42:13
SC Data - All Services | Requesting security definition data for: PSN.LS. ID: 4 | 2016-12-31 05:42:13
Using Bid/Ask average for last trade price for UKOIL | 2016-12-31 05:42:13
SC DTC Data | Starting real-time market data updates for: UKOIL. ID: 5 | 2016-12-31 05:42:13
SC DTC Data | Requesting security definition data for: UKOIL. ID: 5 | 2016-12-31 05:42:13
Using Bid/Ask average for last trade price for EUSTX50 | 2016-12-31 05:42:13
SC DTC Data | Starting real-time market data updates for: EUSTX50. ID: 6 | 2016-12-31 05:42:13
SC DTC Data | Requesting security definition data for: EUSTX50. ID: 6 | 2016-12-31 05:42:13
Intraday data recording state for symbol EUSTX50 is set to download 'Pending'. | 2016-12-31 05:42:13
Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-12-31 05:42:13
SC Data - All Services | Starting real-time market data updates for: DYH17. ID: 7 | 2016-12-31 05:42:13
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: DYH17 | 2016-12-31 05:42:13
SC Data - All Services | Requesting security definition data for: DYH17. ID: 7 | 2016-12-31 05:42:13
Intraday data recording state for symbol DYH17 is set to download 'Pending'. | 2016-12-31 05:42:13
Using Bid/Ask average for last trade price for XAUUSD | 2016-12-31 05:42:13
SC DTC Data | Starting real-time market data updates for: XAUUSD. ID: 8 | 2016-12-31 05:42:13
SC DTC Data | Requesting security definition data for: XAUUSD. ID: 8 | 2016-12-31 05:42:13
Using Bid/Ask average for last trade price for NZDUSD | 2016-12-31 05:42:13
SC DTC Data | Starting real-time market data updates for: NZDUSD. ID: 9 | 2016-12-31 05:42:13
SC DTC Data | Requesting security definition data for: NZDUSD. ID: 9 | 2016-12-31 05:42:13
Using Bid/Ask average for last trade price for EURJPY | 2016-12-31 05:42:13
SC DTC Data | Starting real-time market data updates for: EURJPY. ID: 10 | 2016-12-31 05:42:13
SC DTC Data | Requesting security definition data for: EURJPY. ID: 10 | 2016-12-31 05:42:13
Intraday data recording state for symbol EURJPY is set to download 'Pending'. | 2016-12-31 05:42:13
DTC Client (11) | Connected. | 2016-12-31 05:42:13
SC DTC Data | Connected to server. | 2016-12-31 05:42:13
SC DTC Data | Sending Encoding Request to server | 2016-12-31 05:42:13
Using Bid/Ask average for last trade price for USDOLLAR | 2016-12-31 05:42:13
SC DTC Data | Starting real-time market data updates for: USDOLLAR. ID: 11 | 2016-12-31 05:42:13
SC DTC Data | Requesting security definition data for: USDOLLAR. ID: 11 | 2016-12-31 05:42:13
Intraday data recording state for symbol USDOLLAR is set to download 'Pending'. | 2016-12-31 05:42:13
Using Bid/Ask average for last trade price for US30 | 2016-12-31 05:42:13
SC DTC Data | Starting real-time market data updates for: US30. ID: 12 | 2016-12-31 05:42:13
SC DTC Data | Requesting security definition data for: US30. ID: 12 | 2016-12-31 05:42:13
Intraday data recording state for symbol US30 is set to download 'Pending'. | 2016-12-31 05:42:13
SC DTC Data | Setting DTC encoding to Binary VLS | 2016-12-31 05:42:14
SC DTC Data | Sending logon request message. | 2016-12-31 05:42:14
SC DTC Data | Received logon response. | 2016-12-31 05:42:15
SC DTC Data | Server Name: SC Realtime Server. | 2016-12-31 05:42:15
SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2016-12-31 05:42:15
SC DTC Data | Successfully connected. | 2016-12-31 05:42:15
SC DTC Data | Trading is not supported. | 2016-12-31 05:42:15
SC DTC Data | Restarting real-time data updates for symbol: AUDJPY | 2016-12-31 05:42:15
SC DTC Data | Restarting real-time data updates for symbol: EURJPY | 2016-12-31 05:42:15
SC DTC Data | Restarting real-time data updates for symbol: EUSTX50 | 2016-12-31 05:42:15
SC DTC Data | Restarting real-time data updates for symbol: GER30 | 2016-12-31 05:42:15
SC DTC Data | Restarting real-time data updates for symbol: NZDUSD | 2016-12-31 05:42:15
SC DTC Data | Restarting real-time data updates for symbol: UKOIL | 2016-12-31 05:42:15
SC DTC Data | Restarting real-time data updates for symbol: US30 | 2016-12-31 05:42:15
SC DTC Data | Restarting real-time data updates for symbol: USDOLLAR | 2016-12-31 05:42:15
SC DTC Data | Restarting real-time data updates for symbol: XAUUSD | 2016-12-31 05:42:15
SC DTC Data | Received security definition for symbol AUDJPY | 2016-12-31 05:42:15
SC DTC Data | Real-time data for symbol AUDJPY is currently unavailable. | 2016-12-31 05:42:16
SC DTC Data | Received security definition for symbol EURJPY | 2016-12-31 05:42:16
SC DTC Data | Real-time data for symbol EURJPY is currently unavailable. | 2016-12-31 05:42:16
SC DTC Data | Received security definition for symbol EUSTX50 | 2016-12-31 05:42:16
SC DTC Data | Real-time data for symbol EUSTX50 is currently unavailable. | 2016-12-31 05:42:16
SC DTC Data | Received security definition for symbol GER30 | 2016-12-31 05:42:16
SC DTC Data | Real-time data for symbol GER30 is currently unavailable. | 2016-12-31 05:42:16
SC DTC Data | Received security definition for symbol NZDUSD | 2016-12-31 05:42:16
SC DTC Data | Real-time data for symbol NZDUSD is currently unavailable. | 2016-12-31 05:42:16
SC DTC Data | Received security definition for symbol UKOIL | 2016-12-31 05:42:16
SC DTC Data | Real-time data for symbol UKOIL is currently unavailable. | 2016-12-31 05:42:16
SC DTC Data | Received security definition for symbol US30 | 2016-12-31 05:42:16
Requesting market depth updates for: GER30 if supported. | 2016-12-31 05:42:18
SC DTC Data | Real-time data for symbol US30 is currently unavailable. | 2016-12-31 05:42:30
SC DTC Data | Received security definition for symbol USDOLLAR | 2016-12-31 05:42:30
SC DTC Data | Real-time data for symbol USDOLLAR is currently unavailable. | 2016-12-31 05:42:30
SC DTC Data | Received security definition for symbol XAUUSD | 2016-12-31 05:42:30
SC DTC Data | Real-time data for symbol XAUUSD is currently unavailable. | 2016-12-31 05:42:30
Socket (12) | Shutdown and closed. | 2016-12-31 05:42:33
HD Request # 6 | Error downloading historical Intraday data for GCQ16. Timeout error connecting to server. | 2016-12-31 05:42:33
HD Request # 6 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GCQ16 | 2016-12-31 05:42:33
HD Request # 7 | Downloading Intraday chart data for GCQ16 to the file GCQ16.scid. Service: comex | 2016-12-31 05:42:33
HD Request # 7 | Download start date-time: 2016-05-24 00:59:59.000 | 2016-12-31 05:42:33
HD Request # 7 | Using server: ds1.sierracharts.com port 10149 | 2016-12-31 05:42:33
Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-12-31 05:42:33
Socket (13) | Shutdown and closed. | 2016-12-31 05:42:53
HD Request # 7 | Error downloading historical Intraday data for GCQ16. Timeout error connecting to server. | 2016-12-31 05:42:53
HD Request # 7 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GCQ16 | 2016-12-31 05:42:53
HD Request # 8 | Downloading Intraday chart data for GCQ16 to the file GCQ16.scid. Service: comex | 2016-12-31 05:42:53
HD Request # 8 | Download start date-time: 2016-05-24 00:59:59.000 | 2016-12-31 05:42:53
HD Request # 8 | Using server: ds6.sierracharts.com port 10149 | 2016-12-31 05:42:53
Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-12-31 05:42:53
Socket (14) | Connected. | 2016-12-31 05:42:56
HD Request # 8 | Setting DTC encoding to Binary VLS | 2016-12-31 05:42:56
HD Request # 8 | Sending historical data logon request message. | 2016-12-31 05:42:56
HD Request # 8 | Requesting Intraday data. Start date-time: 2016-05-24 00:59:59. Record interval: 0. Symbol: GCQ16 | 2016-12-31 05:43:17
SC DTC Data | There has been no activity on the network socket for 40 seconds. Will reconnect. | 2016-12-31 05:43:33
DTC Client (11) | Shutdown and closed. | 2016-12-31 05:43:33
SC DTC Data | Disconnected from the server. | 2016-12-31 05:43:33
SC DTC Data | Data feed disconnected. Will reconnect in 2 seconds. | 2016-12-31 05:43:33
SC DTC Data | Connecting to the server ds4.sierracharts.com. Port 443 | 2016-12-31 05:43:35
DTC Client (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-12-31 05:43:35
HTTP connection to ds01.ddfplus.com:80 (5) | Shutdown and closed. | 2016-12-31 05:43:50
HD Request # 8 | Decompressing data. | 2016-12-31 05:43:51
HD Request # 8 | Receiving Intraday data for GCQ16 starting at 2016-05-24 01:00:04 | 2016-12-31 05:43:51
HD Request # 8 | Timestamp of first Intraday data file record written: 2016-05-24 01:00:04 | 2016-12-31 05:43:51
DTC Client (16) | Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2016-12-31 05:43:56
DTC Client (16) | Shutdown and closed. | 2016-12-31 05:43:56
SC DTC Data | Disconnected from the server. | 2016-12-31 05:43:56
SC DTC Data | Data feed disconnected. Will reconnect in 2 seconds. | 2016-12-31 05:43:56
SC DTC Data | Connecting to the server ds3.sierracharts.com. Port 10048 | 2016-12-31 05:43:58
DTC Client (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2016-12-31 05:43:58
DTC Client (17) | Connected. | 2016-12-31 05:44:01
SC DTC Data | Connected to server. | 2016-12-31 05:44:01
SC DTC Data | Sending Encoding Request to server | 2016-12-31 05:44:01
SC DTC Data | Setting DTC encoding to Binary VLS | 2016-12-31 05:44:05
SC DTC Data | Sending logon request message. | 2016-12-31 05:44:05
SC DTC Data | Received logon response. | 2016-12-31 05:44:05
SC DTC Data | Server Name: SC Realtime Server. | 2016-12-31 05:44:05
SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2016-12-31 05:44:05
SC DTC Data | Successfully connected. | 2016-12-31 05:44:05
SC DTC Data | Trading is not supported. | 2016-12-31 05:44:05
SC DTC Data | Restarting real-time data updates for symbol: AUDJPY | 2016-12-31 05:44:05
SC DTC Data | Restarting real-time data updates for symbol: EURJPY | 2016-12-31 05:44:05
SC DTC Data | Restarting real-time data updates for symbol: EUSTX50 | 2016-12-31 05:44:05
SC DTC Data | Restarting real-time data updates for symbol: GER30 | 2016-12-31 05:44:05
SC DTC Data | Restarting real-time data updates for symbol: NZDUSD | 2016-12-31 05:44:05
SC DTC Data | Restarting real-time data updates for symbol: UKOIL | 2016-12-31 05:44:05
SC DTC Data | Restarting real-time data updates for symbol: US30 | 2016-12-31 05:44:05
SC DTC Data | Restarting real-time data updates for symbol: USDOLLAR | 2016-12-31 05:44:05
SC DTC Data | Restarting real-time data updates for symbol: XAUUSD | 2016-12-31 05:44:05
SC DTC Data | Received security definition for symbol AUDJPY | 2016-12-31 05:44:05
SC DTC Data | Real-time data for symbol AUDJPY is currently unavailable. | 2016-12-31 05:44:06
SC DTC Data | Received security definition for symbol EURJPY | 2016-12-31 05:44:06
SC DTC Data | Real-time data for symbol EURJPY is currently unavailable. | 2016-12-31 05:44:06
SC DTC Data | Received security definition for symbol EUSTX50 | 2016-12-31 05:44:08
SC DTC Data | Real-time data for symbol EUSTX50 is currently unavailable. | 2016-12-31 05:44:08
SC DTC Data | Received security definition for symbol GER30 | 2016-12-31 05:44:08
SC DTC Data | Real-time data for symbol GER30 is currently unavailable. | 2016-12-31 05:44:08
SC DTC Data | Received security definition for symbol NZDUSD | 2016-12-31 05:44:08
SC DTC Data | Real-time data for symbol NZDUSD is currently unavailable. | 2016-12-31 05:44:09
SC DTC Data | Received security definition for symbol UKOIL | 2016-12-31 05:44:09
SC DTC Data | Real-time data for symbol UKOIL is currently unavailable. | 2016-12-31 05:44:09
SC DTC Data | Received security definition for symbol US30 | 2016-12-31 05:44:09
SC DTC Data | Real-time data for symbol US30 is currently unavailable. | 2016-12-31 05:44:09
SC DTC Data | Received security definition for symbol USDOLLAR | 2016-12-31 05:44:09
SC DTC Data | Real-time data for symbol USDOLLAR is currently unavailable. | 2016-12-31 05:44:09
SC DTC Data | Received security definition for symbol XAUUSD | 2016-12-31 05:44:09
SC DTC Data | Real-time data for symbol XAUUSD is currently unavailable. | 2016-12-31 05:44:09
Historical Daily data request for XAUUSD is discarded because a matching download is already pending and the new one is not for earlier data. | 2016-12-31 05:45:36
SC DTC Data | There has been no activity on the network socket for 40 seconds. Will reconnect. | 2016-12-31 05:47:58
DTC Client (17) | Shutdown and closed. | 2016-12-31 05:47:58
SC DTC Data | Disconnected from the server. | 2016-12-31 05:47:58
SC DTC Data | Data feed disconnected. Will reconnect in 2 seconds. | 2016-12-31 05:47:58
SC DTC Data | Connecting to the server ds4.sierracharts.com. Port 443 | 2016-12-31 05:48:00
DTC Client (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-12-31 05:48:00
DTC Client (20) | Connected. | 2016-12-31 05:48:00
SC DTC Data | Connected to server. | 2016-12-31 05:48:00
SC DTC Data | Sending Encoding Request to server | 2016-12-31 05:48:00
SC DTC Data | Setting DTC encoding to Binary VLS | 2016-12-31 05:48:07
SC DTC Data | Sending logon request message. | 2016-12-31 05:48:07
SC DTC Data | Server has requested a logoff. Reason: No Logon message received. | 2016-12-31 05:48:07
DTC Client (20) | Shutdown and closed. | 2016-12-31 05:48:07
SC DTC Data | Disconnected from the server. | 2016-12-31 05:48:07
SC DTC Data | Data feed disconnected. Will reconnect in 2 seconds. | 2016-12-31 05:48:07
SC DTC Data | Connecting to the server ds3.sierracharts.com. Port 10048 | 2016-12-31 05:48:09
DTC Client (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2016-12-31 05:48:09
DTC Client (21) | Connected. | 2016-12-31 05:48:13
SC DTC Data | Connected to server. | 2016-12-31 05:48:13
SC DTC Data | Sending Encoding Request to server | 2016-12-31 05:48:13
SC DTC Data | Setting DTC encoding to Binary VLS | 2016-12-31 05:48:16
SC DTC Data | Sending logon request message. | 2016-12-31 05:48:16
SC DTC Data | There has been no activity on the network socket for 40 seconds. Will reconnect. | 2016-12-31 05:49:29
DTC Client (21) | Shutdown and closed. | 2016-12-31 05:49:29
SC DTC Data | Disconnected from the server. | 2016-12-31 05:49:29
SC DTC Data | Data feed disconnected. Will reconnect in 2 seconds. | 2016-12-31 05:49:29
SC DTC Data | Connecting to the server ds4.sierracharts.com. Port 443 | 2016-12-31 05:49:31
DTC Client (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-12-31 05:49:31
DTC Client (23) | Connected. | 2016-12-31 05:49:32
SC DTC Data | Connected to server. | 2016-12-31 05:49:32
SC DTC Data | Sending Encoding Request to server | 2016-12-31 05:49:32
SC DTC Data | Setting DTC encoding to Binary VLS | 2016-12-31 05:49:32
SC DTC Data | Sending logon request message. | 2016-12-31 05:49:32
SC DTC Data | Received logon response. | 2016-12-31 05:49:34
SC DTC Data | Server Name: SC Realtime Server. | 2016-12-31 05:49:34
SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2016-12-31 05:49:34
SC DTC Data | Successfully connected. | 2016-12-31 05:49:34
SC DTC Data | Trading is not supported. | 2016-12-31 05:49:34
SC DTC Data | Restarting real-time data updates for symbol: AUDJPY | 2016-12-31 05:49:34
SC DTC Data | Restarting real-time data updates for symbol: EURJPY | 2016-12-31 05:49:34
SC DTC Data | Restarting real-time data updates for symbol: EUSTX50 | 2016-12-31 05:49:34
SC DTC Data | Restarting real-time data updates for symbol: GER30 | 2016-12-31 05:49:34
SC DTC Data | Restarting real-time data updates for symbol: NZDUSD | 2016-12-31 05:49:34
SC DTC Data | Restarting real-time data updates for symbol: UKOIL | 2016-12-31 05:49:34
SC DTC Data | Restarting real-time data updates for symbol: US30 | 2016-12-31 05:49:34
SC DTC Data | Restarting real-time data updates for symbol: USDOLLAR | 2016-12-31 05:49:34
SC DTC Data | Restarting real-time data updates for symbol: XAUUSD | 2016-12-31 05:49:34
SC DTC Data | Received security definition for symbol AUDJPY | 2016-12-31 05:49:44
SC DTC Data | Real-time data for symbol AUDJPY is currently unavailable. | 2016-12-31 05:49:44
SC DTC Data | Received security definition for symbol EURJPY | 2016-12-31 05:49:44
SC DTC Data | Real-time data for symbol EURJPY is currently unavailable. | 2016-12-31 05:49:45
SC DTC Data | Received security definition for symbol EUSTX50 | 2016-12-31 05:49:45
SC DTC Data | Real-time data for symbol EUSTX50 is currently unavailable. | 2016-12-31 05:49:45
SC DTC Data | Received security definition for symbol GER30 | 2016-12-31 05:49:45
SC DTC Data | Real-time data for symbol GER30 is currently unavailable. | 2016-12-31 05:49:45
SC DTC Data | Received security definition for symbol NZDUSD | 2016-12-31 05:49:45
SC DTC Data | Real-time data for symbol NZDUSD is currently unavailable. | 2016-12-31 05:49:45
SC DTC Data | Received security definition for symbol UKOIL | 2016-12-31 05:49:45
SC DTC Data | Real-time data for symbol UKOIL is currently unavailable. | 2016-12-31 05:49:45
SC DTC Data | Received security definition for symbol US30 | 2016-12-31 05:49:45
SC DTC Data | Real-time data for symbol US30 is currently unavailable. | 2016-12-31 05:49:45
SC DTC Data | Received security definition for symbol USDOLLAR | 2016-12-31 05:49:45
SC DTC Data | Real-time data for symbol USDOLLAR is currently unavailable. | 2016-12-31 05:49:45
SC DTC Data | Received security definition for symbol XAUUSD | 2016-12-31 05:49:45
SC DTC Data | Real-time data for symbol XAUUSD is currently unavailable. | 2016-12-31 05:49:45
Intraday data recording state for symbol GER30 is set to download 'Pending'. | 2016-12-31 05:50:39
Historical Intraday data request for GER30 is discarded because a matching download is already pending and the new one is not for earlier data. | 2016-12-31 05:50:39
Reloading all charts with filename: GER30.scid | 2016-12-31 05:50:39
GER30 [M] #16 | Reloading chart. | 2016-12-31 05:50:39
GER30 [M] 4 Min #65 | Reloading chart. | 2016-12-31 05:50:39
GER30 [M] 4 Min #65 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\GER30.scid | 2016-12-31 05:50:39
GER30 [M] #25 | Reloading chart. | 2016-12-31 05:50:39
GER30 [M] #25 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\GER30.scid | 2016-12-31 05:50:39
GER30 [M] 60 Min #55 | Reloading chart. | 2016-12-31 05:50:39
GER30 [M] 60 Min #55 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\GER30.scid | 2016-12-31 05:50:39
GER30 [M] 60 Min #34 | Reloading chart. | 2016-12-31 05:50:39
GER30 [M] 60 Min #34 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\GER30.scid | 2016-12-31 05:50:39
GER30 [M] 4 Min #3 | Reloading chart. | 2016-12-31 05:50:39
GER30 [M] 4 Min #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\GER30.scid | 2016-12-31 05:50:39
GER30 [M] 10 Min #14 | Reloading chart. | 2016-12-31 05:50:39
GER30 [M] 10 Min #14 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\GER30.scid | 2016-12-31 05:50:39
GER30 [M] 60 Min #2 | Reloading chart. | 2016-12-31 05:50:39
GER30 [M] 60 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\GER30.scid | 2016-12-31 05:50:39
GER30 [M] 4 Min #1 | Reloading chart. | 2016-12-31 05:50:39
GER30 [M] 4 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\GER30.scid | 2016-12-31 05:50:39
GER30 [M] 20 Min #24 | Reloading chart. | 2016-12-31 05:50:39
GER30 [M] 20 Min #24 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\GER30.scid | 2016-12-31 05:50:39
GER30 [M] 240 Min #5 | Reloading chart. | 2016-12-31 05:50:39
GER30 [M] 240 Min #5 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\GER30.scid | 2016-12-31 05:50:39
GER30 [M] 60 Min #67 | Reloading chart. | 2016-12-31 05:50:39
GER30 [M] 60 Min #67 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\GER30.scid | 2016-12-31 05:50:39
GER30 [M] 60 Min #63 | Reloading chart. | 2016-12-31 05:50:39
GER30 [M] 60 Min #63 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\GER30.scid | 2016-12-31 05:50:39
GER30 [M] 300 Trades #12 | Reloading chart. | 2016-12-31 05:50:39
GER30 [M] 300 Trades #12 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\GER30.scid | 2016-12-31 05:50:39
GER30 [M] 1 Min #53 | Reloading chart. | 2016-12-31 05:50:39
GER30 [M] 1 Min #53 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\GER30.scid | 2016-12-31 05:50:39
GER30 [M] 4 Min #11 | Reloading chart. | 2016-12-31 05:50:39
GER30 [M] 4 Min #11 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\GER30.scid | 2016-12-31 05:50:39
GER30 [M] 4 Min #33 | Reloading chart. | 2016-12-31 05:50:40
GER30 [M] 4 Min #33 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\GER30.scid | 2016-12-31 05:50:40
Historical Daily data request for XAUUSD matches existing queued download and replaces existing request since earlier data is requested. | 2016-12-31 05:51:14
Historical Daily data request for XAUUSD is discarded because a matching download is already pending and the new one is not for earlier data. | 2016-12-31 05:51:21
Socket (14) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-12-31 05:51:23
Socket (14) | Shutdown and closed. | 2016-12-31 05:51:23
HD Request # 8 | Error downloading historical Intraday data for GCQ16. The network socket has been closed. Retrying download. | 2016-12-31 05:51:23
HD Request # 8 | Received 50404 records from 2016-05-24 01:00:04 to 2016-05-26 12:15:05 (2.5 days) and wrote 50404 records for GCQ16 | 2016-12-31 05:51:23
HD Request # 8 | Intraday download COMPLETE for GCQ16. Completion time: 8m 30s. Unique request ID: 15 | 2016-12-31 05:51:23
Removed historical data download ID 15 | 2016-12-31 05:51:23
Real-time Intraday chart data file updates started for GCQ16 | 2016-12-31 05:51:23
Intraday chart data file opened for GCQ16 | 2016-12-31 05:51:23
HD Request # 9 | Downloading Intraday chart data for AUDJPY to the file AUDJPY.scid. Service: fxcm | 2016-12-31 05:51:23
Compressing file: C:\SierraChart\Data\AUDJPY.scid. This may take a while. | 2016-12-31 05:51:23 *
HD Request # 9 | Download start date-time: 2016-12-30 21:57:08.000 | 2016-12-31 05:51:23
HD Request # 9 | Using server: ds3.sierracharts.com port 10149 | 2016-12-31 05:51:23
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2016-12-31 05:51:23
Socket (25) | Connected. | 2016-12-31 05:51:36
HD Request # 9 | Setting DTC encoding to Binary VLS | 2016-12-31 05:51:45
HD Request # 9 | Sending historical data logon request message. | 2016-12-31 05:51:45
Socket (25) | Closed. No error. | 2016-12-31 05:51:45
Socket (25) | Shutdown and closed. | 2016-12-31 05:51:45
HD Request # 9 | Error downloading historical Intraday data for AUDJPY. The network socket has been closed. Retrying download. | 2016-12-31 05:51:45
HD Request # 9 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for AUDJPY | 2016-12-31 05:51:45
HD Request # 10 | Downloading Intraday chart data for AUDJPY to the file AUDJPY.scid. Service: fxcm | 2016-12-31 05:51:45
HD Request # 10 | Download start date-time: 2016-12-30 21:57:08.000 | 2016-12-31 05:51:45
HD Request # 10 | Using server: ds4.sierracharts.com port 10149 | 2016-12-31 05:51:45
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-12-31 05:51:45
Socket (26) | Connected. | 2016-12-31 05:51:46
HD Request # 10 | Setting DTC encoding to Binary VLS | 2016-12-31 05:51:47
HD Request # 10 | Sending historical data logon request message. | 2016-12-31 05:51:47
HD Request # 10 | Requesting Intraday data. Start date-time: 2016-12-30 21:57:08. Record interval: 0. Symbol: AUDJPY | 2016-12-31 05:51:48
HD Request # 10 | Decompressing data. | 2016-12-31 05:51:48
HD Request # 10 | Receiving Intraday data for AUDJPY starting at 2016-12-30 21:57:08 | 2016-12-31 05:52:06
Socket (26) | Shutdown and closed. | 2016-12-31 05:52:06
The network socket for historical data has been closed. | 2016-12-31 05:52:06
HD Request # 10 | Received 2 records from 2016-12-30 21:57:08 to 2016-12-30 21:57:08 (0.0 seconds) and wrote 0 records for AUDJPY | 2016-12-31 05:52:06
HD Request # 10 | Intraday download COMPLETE for AUDJPY. Completion time: 21s. Unique request ID: 16 | 2016-12-31 05:52:06
Removed historical data download ID 16 | 2016-12-31 05:52:06
Real-time Intraday chart data file updates started for AUDJPY | 2016-12-31 05:52:06
Intraday chart data file opened for AUDJPY | 2016-12-31 05:52:06
HD Request # 11 | Downloading Intraday chart data for GER30 to the file GER30.scid. Service: fxcm | 2016-12-31 05:52:06
HD Request # 11 | Download start date-time: 2016-06-28 06:52:06.000 | 2016-12-31 05:52:06
HD Request # 11 | Using server: ds3.sierracharts.com port 10149 | 2016-12-31 05:52:06
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2016-12-31 05:52:06
Socket (27) | Shutdown and closed. | 2016-12-31 05:52:27
HD Request # 11 | Error downloading historical Intraday data for GER30. Timeout error connecting to server. | 2016-12-31 05:52:27
HD Request # 11 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GER30 | 2016-12-31 05:52:27
HD Request # 12 | Downloading Intraday chart data for GER30 to the file GER30.scid. Service: fxcm | 2016-12-31 05:52:27
HD Request # 12 | Download start date-time: 2016-06-28 06:52:26.000 | 2016-12-31 05:52:27
HD Request # 12 | Using server: ds4.sierracharts.com port 10149 | 2016-12-31 05:52:27
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-12-31 05:52:27
Socket (28) | Connected. | 2016-12-31 05:52:36
HD Request # 12 | Setting DTC encoding to Binary VLS | 2016-12-31 05:52:45
HD Request # 12 | Sending historical data logon request message. | 2016-12-31 05:52:45
Socket (28) | Closed. No error. | 2016-12-31 05:52:45
Socket (28) | Shutdown and closed. | 2016-12-31 05:52:45
HD Request # 12 | Error downloading historical Intraday data for GER30. The network socket has been closed. Retrying download. | 2016-12-31 05:52:45
HD Request # 12 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GER30 | 2016-12-31 05:52:45
HD Request # 13 | Downloading Intraday chart data for GER30 to the file GER30.scid. Service: fxcm | 2016-12-31 05:52:45
HD Request # 13 | Download start date-time: 2016-06-28 06:52:45.000 | 2016-12-31 05:52:45
HD Request # 13 | Using server: ds3.sierracharts.com port 10149 | 2016-12-31 05:52:45
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2016-12-31 05:52:45
Socket (29) | Connected. | 2016-12-31 05:52:46
HD Request # 13 | Setting DTC encoding to Binary VLS | 2016-12-31 05:52:46
HD Request # 13 | Sending historical data logon request message. | 2016-12-31 05:52:46
HD Request # 13 | Requesting Intraday data. Start date-time: 2016-06-28 06:52:45. Record interval: 0. Symbol: GER30 | 2016-12-31 05:52:47
HD Request # 13 | Decompressing data. | 2016-12-31 05:52:47
HD Request # 13 | Receiving Intraday data for GER30 starting at 2016-06-28 07:00:06 | 2016-12-31 05:52:47
HD Request # 13 | Timestamp of first Intraday data file record written: 2016-06-28 07:00:06 | 2016-12-31 05:52:47
HD Request # 13 | Error downloading historical Intraday data for GER30. The download timed out. | 2016-12-31 05:55:54
Socket (29) | Shutdown and closed. | 2016-12-31 05:55:54
HD Request # 13 | Received 1739 records from 2016-06-28 07:00:06 to 2016-06-28 07:20:27 (20.4 minutes) and wrote 1739 records for GER30 | 2016-12-31 05:55:54
HD Request # 13 | Intraday download COMPLETE for GER30. Completion time: 3m 8s. Unique request ID: 17 | 2016-12-31 05:55:54
Removed historical data download ID 17 | 2016-12-31 05:55:54
Real-time Intraday chart data file updates started for GER30 | 2016-12-31 05:55:54
Intraday chart data file opened for GER30 | 2016-12-31 05:55:54
HD Request # 14 | Downloading Intraday chart data for EUSTX50 to the file EUSTX50.scid. Service: fxcm | 2016-12-31 05:55:54
Compressing file: C:\SierraChart\Data\EUSTX50.scid. This may take a while. | 2016-12-31 05:55:54 *
HD Request # 14 | Download start date-time: 2016-06-28 20:59:52.000 | 2016-12-31 05:55:54
HD Request # 14 | Using server: ds4.sierracharts.com port 10149 | 2016-12-31 05:55:54
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-12-31 05:55:54
Chart #24 has tagged chart #6 for full recalculation. Chartbook: DAX + others.cht | 2016-12-31 05:55:54
EUSTX50 [M] 20 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: DAX + others.cht | 2016-12-31 05:55:55
Socket (32) | Connected. | 2016-12-31 05:55:58
HD Request # 14 | Setting DTC encoding to Binary VLS | 2016-12-31 05:56:01
HD Request # 14 | Sending historical data logon request message. | 2016-12-31 05:56:01
HD Request # 14 | Requesting Intraday data. Start date-time: 2016-06-28 20:59:52. Record interval: 0. Symbol: EUSTX50 | 2016-12-31 05:56:02
HD Request # 14 | Decompressing data. | 2016-12-31 05:56:06
HD Request # 14 | Receiving Intraday data for EUSTX50 starting at 2016-06-28 20:59:52 | 2016-12-31 05:56:06
HD Request # 14 | Timestamp of first Intraday data file record written: 2016-06-29 07:00:04 | 2016-12-31 05:56:06
SC DTC Data | There has been no activity on the network socket for 40 seconds. Will reconnect. | 2016-12-31 05:56:51
DTC Client (23) | Shutdown and closed. | 2016-12-31 05:56:51
SC DTC Data | Disconnected from the server. | 2016-12-31 05:56:51
SC DTC Data | Data feed disconnected. Will reconnect in 2 seconds. | 2016-12-31 05:56:51
SC DTC Data | Connecting to the server ds3.sierracharts.com. Port 10048 | 2016-12-31 05:56:53
DTC Client (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2016-12-31 05:56:53
DTC Client (33) | Connected. | 2016-12-31 05:56:57
SC DTC Data | Connected to server. | 2016-12-31 05:56:57
SC DTC Data | Sending Encoding Request to server | 2016-12-31 05:56:57
SC DTC Data | Server has requested a logoff. Reason: No Logon message received. | 2016-12-31 05:57:02
DTC Client (33) | Shutdown and closed. | 2016-12-31 05:57:02
SC DTC Data | Disconnected from the server. | 2016-12-31 05:57:02
SC DTC Data | Data feed disconnected. Will reconnect in 2 seconds. | 2016-12-31 05:57:02
SC DTC Data | Connecting to the server ds4.sierracharts.com. Port 443 | 2016-12-31 05:57:04
DTC Client (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-12-31 05:57:04
DTC Client (34) | Connected. | 2016-12-31 05:57:04
SC DTC Data | Connected to server. | 2016-12-31 05:57:04
SC DTC Data | Sending Encoding Request to server | 2016-12-31 05:57:04
SC DTC Data | Setting DTC encoding to Binary VLS | 2016-12-31 05:57:05
SC DTC Data | Sending logon request message. | 2016-12-31 05:57:05
SC DTC Data | Received logon response. | 2016-12-31 05:57:07
SC DTC Data | Server Name: SC Realtime Server. | 2016-12-31 05:57:07
SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2016-12-31 05:57:07
SC DTC Data | Successfully connected. | 2016-12-31 05:57:07
SC DTC Data | Trading is not supported. | 2016-12-31 05:57:07
Intraday data recording state for symbol AUDJPY is set to download 'Pending'. | 2016-12-31 05:57:07
SC DTC Data | Restarting real-time data updates for symbol: AUDJPY | 2016-12-31 05:57:07
SC DTC Data | Restarting real-time data updates for symbol: EURJPY | 2016-12-31 05:57:07
SC DTC Data | Restarting real-time data updates for symbol: EUSTX50 | 2016-12-31 05:57:07
Intraday data recording state for symbol GER30 is set to download 'Pending'. | 2016-12-31 05:57:07
SC DTC Data | Restarting real-time data updates for symbol: GER30 | 2016-12-31 05:57:07
SC DTC Data | Restarting real-time data updates for symbol: NZDUSD | 2016-12-31 05:57:07
SC DTC Data | Restarting real-time data updates for symbol: UKOIL | 2016-12-31 05:57:07
SC DTC Data | Restarting real-time data updates for symbol: US30 | 2016-12-31 05:57:07
SC DTC Data | Restarting real-time data updates for symbol: USDOLLAR | 2016-12-31 05:57:07
SC DTC Data | Restarting real-time data updates for symbol: XAUUSD | 2016-12-31 05:57:07
SC DTC Data | Received security definition for symbol AUDJPY | 2016-12-31 05:57:08
SC DTC Data | Real-time data for symbol AUDJPY is currently unavailable. | 2016-12-31 05:57:09
SC DTC Data | Received security definition for symbol EURJPY | 2016-12-31 05:57:09
SC DTC Data | Real-time data for symbol EURJPY is currently unavailable. | 2016-12-31 05:57:09
SC DTC Data | Received security definition for symbol EUSTX50 | 2016-12-31 05:57:09
SC DTC Data | Real-time data for symbol EUSTX50 is currently unavailable. | 2016-12-31 05:57:09
SC DTC Data | Received security definition for symbol GER30 | 2016-12-31 05:57:09
SC DTC Data | Real-time data for symbol GER30 is currently unavailable. | 2016-12-31 05:57:09
SC DTC Data | Received security definition for symbol NZDUSD | 2016-12-31 05:57:09
SC DTC Data | Real-time data for symbol NZDUSD is currently unavailable. | 2016-12-31 05:57:09
SC DTC Data | Received security definition for symbol UKOIL | 2016-12-31 05:57:09
SC DTC Data | Real-time data for symbol UKOIL is currently unavailable. | 2016-12-31 05:57:09
SC DTC Data | Received security definition for symbol US30 | 2016-12-31 05:57:09
SC DTC Data | Real-time data for symbol US30 is currently unavailable. | 2016-12-31 05:57:11
SC DTC Data | Received security definition for symbol USDOLLAR | 2016-12-31 05:57:11
SC DTC Data | Real-time data for symbol USDOLLAR is currently unavailable. | 2016-12-31 05:57:11
SC DTC Data | Received security definition for symbol XAUUSD | 2016-12-31 05:57:11
SC DTC Data | Real-time data for symbol XAUUSD is currently unavailable. | 2016-12-31 05:57:11
[2017-01-03 02:16:57]
These are the relevant messages:
Based upon what we see there is a connectivity problem from your location. This connectivity problem is affecting historical data and real-time data.
Normally in the case of historical data we recommend using port 80:
http://www.sierrachart.com/index.php?page=doc/HistoricalIntradayData.html#UsingPort80
But we are not sure that is going to help in your case.
For the real-time data, we really do not know what to say because the port being used is 443. However, try unchecking this option :
Global Settings >> Data/Trade Service Settings >> SC Server Settings >>Always Use Port 443 for Real-time Data.
