Date/Time: Tue, 04 Nov 2025 09:19:29 +0000
Unable to set "Step amount" through ACSIL for Triggered step trail stop method
View Count: 973
[2016-12-24 16:55:54]
FerroTrader - Posts: 72
I am trying to use Step amount through ACSIL - but doesn't seem to work properly. I don't see the parameter not getting reflected in TradeWindow parameters (as in the image here attached).
Here attached, the code used to find this bug (there are lots of comments within the code).
s_SCNewOrder NewOrder;
NewOrder.Reset();
NewOrder.OrderQuantity = 1;
NewOrder.Price1 = sc.Close[sc.Index];
NewOrder.OrderType = SCT_ORDERTYPE_MARKET;
NewOrder.AttachedOrderStopAllType = SCT_ORDERTYPE_TRIGGERED_STEP_TRAILING_STOP;
NewOrder.Target1Offset = 15 * sc.TickSize;
NewOrder.Stop1Offset = 10 * sc.TickSize;
NewOrder.StopAllOffset = 10 * sc.TickSize;
//Trail Offset - Set Correctly in TradeWindow Parameters
NewOrder.TriggeredTrailStopTrailPriceOffset = 5 * sc.TickSize;
//Trigger Offset - Set Correctly in TradeWindow Parameters
NewOrder.TriggeredTrailStopTriggerPriceOffset = 3 * sc.TickSize;
//Step Amount - This DOESN't get Set Correctly in TradeWindow parameter
NewOrder.TrailStopStepPriceAmount = 1 * sc.TickSize;
Thank you and Merry Xmas
Andrew
Date Time Of Last Edit: 2016-12-24 17:07:24
imageSC_TradeWindow_Parameters.jpg / V - Attached On 2016-12-24 16:55:41 UTC - Size: 101.16 KB - 347 views
attachmentASCIL_Code_Trailing_Stop.txt - Attached On 2016-12-24 17:04:30 UTC - Size: 744 B - 431 views
[2016-12-27 09:02:55]
This is still pending.
[2016-12-28 03:15:13]
This problem has been determined and is resolved. We will have a new release out tomorrow.
