Date/Time: Thu, 24 Sep 2026 06:54:16 +0000
v1004: Error creating Alert Manager window
View Count: 2164
| [2013-08-05 04:13:18] |
| joshtrader - Posts: 569 |
When I open my chartbook, I get "Initialization error: Error creating the Alert Manager window. If you need more help please contact Sierra Chart Support for assistance." Please note, this is only on 1 of my 3 installed copies of SC, so it is something specific to the chartbook apparently. It contains only built-in studies, no external ones. I do not get this error on 1003, only 1004. Date Time Of Last Edit: 2013-08-05 04:17:56
| [2013-08-05 04:36:32] |
We will look into this.
| [2013-08-05 16:42:02] |
| User14266 - Posts: 225 |
I'm having this same problem. Everything is fine when transferring account settings, global setting, etc. It's after I transfer my saved chartbook file and try to open SC when I get the same error. Even after deleting the chartbook from the data folder, it continues to give this error and shuts down SC rendering it unusable. I can no longer use 997 because of the CTS/FIX update. And now I can not use the pre-release. A quick fix would be greatly appreciated.
| [2013-08-05 16:51:01] |
We do apologize for this. Could you please update again by selecting Help >> Download Prerelease and let us know if you still see the problem or not. We have put out a new revision. Our initial testing show the problem is resolved.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-08-05 16:51:24
| [2013-08-05 16:51:16] |
Disregard the part of post #3 regarding the CTS/FIX and 997 now being unusable. It is working now. User error.
| [2013-08-05 17:03:34] |
Pre-release is now working great. Thank you for the quick fix!
