Date/Time: Sat, 11 Jan 2025 09:45:15 +0000
Sierra ChartDTCBridge has stopped working - OS. Vista Service pack 2
View Count: 800
[2016-11-22 15:53:15]
User426450 - Posts: 15
Sierra chart has been working fine since installation in October 2015 until I upgraded to version 1488 on Saturday night. After the installation I get a windows popup windows with the message on the title of this post. I had installed previous versions of sierra chart and I don't get the dtcbridge error window but I am not able to connect neither and the program automatically ask me to upgrade to the latest version. I would really appreciate your help in resolving this issue.
Sincerely
Rafael
[2016-11-22 17:41:37]
We cannot solve this. This is due to a Rithmic API software compatibility issue with Vista. The minimum operating system supported is Windows 7. This is stated very clearly here:
http://www.sierrachart.com/index.php?page=doc/Rithmic.php
You must get off of Vista. Or go back to the previous version of Sierra Chart:
http://www.sierrachart.com/index.php?page=doc/download.php#Rollback
But you are taking a chance running Rithmic on Vista. They have declared it as incompatible for years now.
[2016-11-22 17:54:14]
Thank you for the feedback. I was looking for the answers in sierra chart but I did not think the issue will be with Rithmic since I was only getting the data. I have not choice but too buy a laptop with windows 10.
