Date/Time: Sat, 11 Jan 2025 06:56:39 +0000
Cannot connect SC (ver.1481) to TWS.
View Count: 1286
[2016-11-11 13:08:20]
User22085 - Posts: 11
I downloaded the latest SC version (1481) and after installation I cannot connect it to TWS data.
I got the following message in the log:
Reading Internal Order ID file. | 2016-11-11 14:56:34
Reading Trade Orders file. | 2016-11-11 14:56:34
Reading Trade Positions file. | 2016-11-11 14:56:34
Software version: 1481 | 2016-11-11 14:56:34
Uses New Spreadsheets | 2016-11-11 14:56:34
Usage end date: 2017-06-22 | 2016-11-11 14:56:34
Allow Support for Sierra Chart Data Feeds is enabled. | 2016-11-11 14:56:34
Current selected Data/Trading service: Interactive Brokers | 2016-11-11 14:56:34
Chart Update Interval: 500 | 2016-11-11 14:56:34
Time Zone: +02:00:00 (EET+02EEST+01,M3.5.0/03:00,M10.5.0/04:00) | 2016-11-11 14:56:34
2016-11-11 14:56:37 Local computer time | 2016-11-11 14:56:34
2016-11-11 12:56:37 Local computer time in UTC | 2016-11-11 14:56:34
2016-11-11 14:56:37 Local computer time in SC Time Zone | 2016-11-11 14:56:34
2016-11-11 12:56:35 Server time in UTC | 2016-11-11 14:56:34
Local computer UTC time and Server UTC time difference: 1 seconds. | 2016-11-11 14:56:34
Program path: D:\SierraChart\ | 2016-11-11 14:56:34
Data Files path: D:\SierraChart\Data\ | 2016-11-11 14:56:34
OS Version Number: 6.2 | 2016-11-11 14:56:34
Locale Setting: C | 2016-11-11 14:56:34
Checking for new symbol settings for ib | 2016-11-11 14:56:34
HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-11-11 14:56:34
HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-11-11 14:56:34
HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-11-11 14:56:34
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-11-11 14:56:34
Symbol settings are up-to-date for ib | 2016-11-11 14:56:34
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2016-11-11 14:56:41
Socket (4) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-11-11 14:56:42
Socket (4) | Shutdown and closed. | 2016-11-11 14:56:42
Interactive Brokers | Failed to connect to the data and trade server. | 2016-11-11 14:56:42 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-11-11 14:56:42 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-11-11 14:56:42
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-11-11 14:56:42
Interactive Brokers | Disconnected. | 2016-11-11 14:56:42
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-11-11 14:56:42
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-11-11 14:56:42
HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-11-11 14:56:42
HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-11-11 14:56:42
HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-11-11 14:56:42
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2016-11-11 14:56:45
Socket (5) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-11-11 14:56:46
Socket (5) | Shutdown and closed. | 2016-11-11 14:56:46
Interactive Brokers | Failed to connect to the data and trade server. | 2016-11-11 14:56:46 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-11-11 14:56:46 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-11-11 14:56:46
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-11-11 14:56:46
Interactive Brokers | Disconnected. | 2016-11-11 14:56:46
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-11-11 14:56:46
File >> Disconnect selected. | 2016-11-11 14:56:48
Interactive Brokers | Disconnected. | 2016-11-11 14:56:48
The above has been sent to support. | 2016-11-11 14:57:22 *
HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-11-11 14:57:22
HTTP connection to www.sierrachart.com:80 (6) | Connected. | 2016-11-11 14:57:22
Sending of the message log was completed. Please read the response that was received. The response was saved to D:\SierraChart\Data\MessageLogAnalysis.htm | 2016-11-11 14:57:23
HTTP connection to www.sierrachart.com:80 (6) | Closed. No error. | 2016-11-11 14:57:27
HTTP connection to www.sierrachart.com:80 (6) | Shutdown and closed. | 2016-11-11 14:57:27
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2016-11-11 14:58:34
Socket (7) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-11-11 14:58:35
Socket (7) | Shutdown and closed. | 2016-11-11 14:58:35
Interactive Brokers | Failed to connect to the data and trade server. | 2016-11-11 14:58:35 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-11-11 14:58:35 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-11-11 14:58:35
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-11-11 14:58:35
Interactive Brokers | Disconnected. | 2016-11-11 14:58:35
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-11-11 14:58:35
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2016-11-11 14:58:38
Socket (9) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-11-11 14:58:39
Socket (9) | Shutdown and closed. | 2016-11-11 14:58:39
Interactive Brokers | Failed to connect to the data and trade server. | 2016-11-11 14:58:39 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-11-11 14:58:39 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-11-11 14:58:39
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-11-11 14:58:39
Interactive Brokers | Disconnected. | 2016-11-11 14:58:39
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-11-11 14:58:39
File >> Disconnect selected. | 2016-11-11 14:58:42
Interactive Brokers | Disconnected. | 2016-11-11 14:58:42
The above has been sent to support. | 2016-11-11 15:03:32 *
HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-11-11 15:03:32
HTTP connection to www.sierrachart.com:80 (12) | Connected. | 2016-11-11 15:03:32
Sending of the message log was completed. Please read the response that was received. The response was saved to D:\SierraChart\Data\MessageLogAnalysis.htm | 2016-11-11 15:03:32
HTTP connection to www.sierrachart.com:80 (12) | Closed. No error. | 2016-11-11 15:03:37
HTTP connection to www.sierrachart.com:80 (12) | Shutdown and closed. | 2016-11-11 15:03:37
[2016-11-11 13:28:46]
Problems solved.
Changed address and pot setting to those that correspond to TWS.
[2016-11-11 17:16:08]
For future reference, refer to step 25 here:
Interactive Brokers Trading Service: Setup Instructions
