Date/Time: Thu, 17 Sep 2026 00:09:46 +0000
Subgraph memory question
View Count: 967
[2016-11-10 05:48:23]
enemyspy - Posts: 307
Does the the sc.subgraph matrix take up the same amount of memory regardless of how many columns are referenced and unused?
for instance if I were to reference all 60 columns but not populate them with result - leave them all empty. Would it be taking up the same amount of space as if they were left un-referenced?
I am pretty sure If it is already there whether it is referenced does not impact memory use?
EDIT:
Therefore, Would it be wasteful to have a Subgraph that is 99% NULL values, or is every subgraph in sc.subgraph allocated based on the chart size ahead of time anyway?
Date Time Of Last Edit: 2016-11-10 06:01:37
[2016-11-10 08:55:56]
Whenever accessing an element of the Data array of the sc.Subgraph at index 1 or higher, then it is allocated. So this does increase memory use. So you should be careful with this.
[2016-11-11 00:08:07]
so In that case if a chart were doing a full recalculation but The elements of the the Data Array of the subgraph Are not accessed until sc.Index == sc.ArraySize-1 Then the memory would not get allocated until then is that correct?
[2016-11-11 00:58:29]
Yes, but once it is allocated it remains allocated unless there is a full reload of the chart data like through Chart >> Reload and Recalculate.
