Date/Time: Sat, 11 Jan 2025 04:46:03 +0000
MultCore Computer Usage
View Count: 650
[2016-11-02 18:52:00]
User28914 - Posts: 87
How many cores does the platform/charts use if its being run on a multi-core computer?
[2016-11-02 21:50:29]
We updated the documentation about this:
CPU multi-core support for increased performance with historical data downloading, Chartbook loading, and market data processing. A CPU core can run one or two threads. It will run two threads if it supports hyperthreading.
When Intraday data downloading is being done, this is performed on a separate thread. When Intraday chart data is being loaded in a chart, it runs on a separate thread. For some services, market data feed processing is performed on a separate thread and is an ongoing task when connected to the data feed. Intraday chart data file updating is done on a separate thread and is an ongoing task when connected to the data feed. The primary processing of each instance of Sierra Chart, also runs on a separate thread. Therefore, it is advantageous to have a minimum of a quad core system when using Sierra Chart.
This information can be found on the Features page:
http://www.sierrachart.com/index.php?page=doc/Features.php
