Date/Time: Sat, 11 Jan 2025 03:56:56 +0000
second instance of sierra charts has problems
View Count: 1185
[2016-10-31 18:35:40]
User443884 - Posts: 4
I just started using a second instance of Sierra but I am having problems with.
For instance, I have the second instance started upon startup.
then I go into File/Open Chartbook and pick the two chartbooks of my choice, e.g. GC and CL. CL will not display like it does in my first instance, I cannot change the time frame at all and it does not update the chart at all.
On GC it now does not allow me to place an order in the chart.
I do run in sim mode right now, no real money.
I need help with this as i want two active instances that fully work as I intend to go life soon.
Thank you.
Daniel
[2016-11-01 18:18:47]
Each instance of Sierra Chart has its own copy of files. So a Chartbook in one instance is not going to be the same as that in another instance using the Chartbook of the same name.
Refer to the instructions here:
http://www.sierrachart.com/index.php?page=doc/ChangingPeriodOfBars.php
What we want you to do is to restart that second instance and open just one chart and only one chart, and if it does not update provide a copy of the Message Log by following these instructions here:
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
Date Time Of Last Edit: 2016-11-01 18:19:41
[2016-11-02 05:32:12]
Regarding this error message:
TransAct Trading order update (Order reject). Info: Simulated Trade Account (Sim1) cannot be used when Trade Simulation Mode is disabled. Internal Order ID: 54934. Service Order ID: (none). Symbol: GCZ6 | 2016-11-01 08:19:00 *
The solution is documented here:
https://www.sierrachart.com/index.php?page=doc/DTCServer.php#UsingCorrectTradeAccount
