Date/Time: Sat, 11 Jan 2025 03:45:44 +0000
Multiple spreadsheets
View Count: 751
[2016-10-31 12:26:01] |
joer - Posts: 41 |
I have a chartbook with 2 5 minute charts, one for es and one for cl and both have the same 30 days of intraday data loaded. I created a spreadsheet system for trading that has 2 sheets, sheet1 for the es chart and sheet2 for the cl chart. I ran the Autotrade system replay backtest separately for each one and noted the results. When I ran the es backtest I disabled autotrading on sheet2 for the cl chart by setting cell J28 to 1 and did the reverse when I ran the cl test. Then I enabled autotrading on both sheet1 and sheet2, checked the replay box that enables the test "For all charts in chartbook", set the interval to 1 second and reran the backtest. The results were significantly different even though neither spreadsheet uses any information from the other. Can you tell me what causes this; are there any settings I need to change for this to work properly. My goal is to be able to autotrade multiple symbols simultaneously.
[2016-10-31 17:16:44] |
How did you do this?: I ran the Autotrade system replay backtest separately for each one
checked the replay box that enables the test "For all charts in chartbook", set the interval to 1 second and reran the backtest. This is a different type of back test.Also refer to: http://www.sierrachart.com/index.php?page=doc/Backtesting.php#BackTestingMultipleCharts http://www.sierrachart.com/index.php?page=doc/Backtesting.php#DifferencesBackTestRealTime Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
