Date/Time: Tue, 04 Nov 2025 14:58:15 +0000
Entry and Exit Prices (Order Fills on Chart)
View Count: 1806
[2016-10-25 16:12:57]
dBassFour - Posts: 16
I cannot find where to change the Order Exit and Entry Text color. I can find the background color, but I cannot find where to change the black to white in order fills on the chart as pictured.
thank you
image2016-10-25_1210.png / V - Attached On 2016-10-25 16:12:51 UTC - Size: 125.02 KB - 519 views
[2016-10-25 17:32:16]
The setting in Global Settings >> Graphics Settings is:
Chart Trading Order Line Text Color
[2017-07-18 05:45:45]
GordonT - Posts: 6
Does this solution work in Sim Mode? Tried the above solution. Even logged in and logged out to see if that would do the trick. I still have black text for the "Show Order Fills" labels.
http://www.sierrachart.com/image.php?Image=1500356507569.png
[2017-07-18 11:45:30]
We verified the correct setting is Global Settings >> Graphics Settings -Global >> Chart Trading Order Line Text Color.
But you may have to set this on the chart specific Graphics Settings window.
There are two Graphics Settings windows. Refer to:
Graphics Settings: Introduction
Date Time Of Last Edit: 2017-07-18 11:45:49
[2021-07-26 15:47:10]
User566250 - Posts: 37
I am looking to put a price label on the chart for active orders. I can't seem to be able to find any documentation on doing so.
Also, wondering if there is an easy way to "toggle on and off" the evening session for futures. I assume that would change the studies. Please advise.
Thank you
[2021-07-26 18:49:57]
John - SC Support - Posts: 42750
We are not sure exactly what you are are looking for in terms of a "price label on the chart for active orders" as you have the order lines that show your positions. But, if you are looking for the Fill Markers, then refer to the following:
Chart Trading and the Chart DOM: Displaying Order Fills on the Chart
To Toggle on/off the Evening Session, just select/deselect the option for Evening Session in the Chart Settings. Refer to the following:
Chart Session Times: Use Evening Session (optional) (Chart >> Chart Settings >> Session Times)
The documentation explains easy methods to do this as well.
Date Time Of Last Edit: 2021-08-05 04:13:34
