Date/Time: Tue, 04 Nov 2025 14:58:05 +0000
What's the symbol of NASDAQ 100 index?
View Count: 3687
|   [2016-10-13 13:13:07]     |
| User349605 - Posts: 11 |
                I know SPX500, US30, but I can't find the symbol of NASDAQ 100 index. Please help, thanks.  |
|   [2016-10-13 17:24:16]     |
                The CFD symbol  for the Sierra Chart Real-time and Historical Forex/CFD Data Service is: NAS100 Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2021-06-27 20:17:24]     |
| User813804 - Posts: 1 |
                GOOD DAY I would like to subscribe for live real time data feed footprints for nasdaq.Therefore i wanted to find out how much is it on a monthly base as well as does one get a tutorial on it. Thank You Sullivan Date Time Of Last Edit: 2021-07-23 07:18:54
|   [2021-06-28 14:11:38]     |
| John - SC Support - Posts: 42750 |
                User813804: Which Nasdaq data are you wanting? The NAS100 is a CFD symbol and is an Index. That data is free with any Sierra Chart package. But, if you are wanting the Nasdaq Futures that are part of the CME Group, then you would need to use the Denali Exchange Data Feed. Refer to the information here: Denali Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
|   [2021-07-23 07:19:21]     |
                We recommend to get started with the Delayed Exchange Data Feed: Delayed Exchange Data Feed Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
