Date/Time: Fri, 10 Jan 2025 20:12:43 +0000
account not loggin in
View Count: 882
[2016-10-03 07:18:22]
User597594 - Posts: 17
Hi my stage5 accoount is not connecting, please csan you help? log below
Reading Internal Order ID file. | 2016-10-03 08:12:12
Reading Trade Orders file. | 2016-10-03 08:12:12
Reading Trade Positions file. | 2016-10-03 08:12:12
Software version: 1466 | 2016-10-03 08:12:12
Uses New Spreadsheets | 2016-10-03 08:12:12
Usage end date: 2016-11-01 | 2016-10-03 08:12:12
Enabled for: Advanced Features. | 2016-10-03 08:12:12
Enabled for: Advanced Features 2. | 2016-10-03 08:12:12
Enabled for: Sierra Chart Historical Data Service. | 2016-10-03 08:12:12
Allow Support for Sierra Chart Data Feeds is enabled. | 2016-10-03 08:12:12
Current selected Data/Trading service: GAIN Capital/OEC | 2016-10-03 08:12:12
Chart Update Interval: 500 | 2016-10-03 08:12:12
Time Zone: +01:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) | 2016-10-03 08:12:12
2016-10-03 08:12:18 Local computer time | 2016-10-03 08:12:12
2016-10-03 07:12:18 Local computer time in UTC | 2016-10-03 08:12:12
2016-10-03 08:12:18 Local computer time in SC Time Zone | 2016-10-03 08:12:12
2016-10-03 07:12:16 Server time in UTC | 2016-10-03 08:12:12
Local computer UTC time and Server UTC time difference: 0 seconds. | 2016-10-03 08:12:12
Program path: C:\SierraChart\ | 2016-10-03 08:12:12
Data Files path: C:\SierraChart\Data\ | 2016-10-03 08:12:12
OS Version Number: 6.1 | 2016-10-03 08:12:12
Locale Setting: C | 2016-10-03 08:12:12
Checking for new symbol settings for oec | 2016-10-03 08:12:12
HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-10-03 08:12:12
HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-10-03 08:12:12
HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-10-03 08:12:12
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-10-03 08:12:12
Symbol settings are up-to-date for oec | 2016-10-03 08:12:12
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-10-03 08:12:23
GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-10-03 08:12:23
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-10-03 08:12:23
HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-10-03 08:12:23
HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-10-03 08:12:23
HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-10-03 08:12:23
GainCapital FIX Trading socket (4) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-10-03 08:12:24
GainCapital FIX Trading socket (4) | Shutdown and closed. | 2016-10-03 08:12:24
GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-10-03 08:12:24
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-10-03 08:12:24
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-10-03 08:12:24
GAIN Capital/OEC | Disconnected from the trading server. | 2016-10-03 08:12:24
GAIN Capital/OEC | Disconnected from the FAST market data server. | 2016-10-03 08:12:24
GAIN Capital/OEC | Disconnected. | 2016-10-03 08:12:24
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-10-03 08:12:24
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-10-03 08:12:27
GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-10-03 08:12:27
GainCapital FIX Trading socket (5) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-10-03 08:12:28
GainCapital FIX Trading socket (5) | Shutdown and closed. | 2016-10-03 08:12:28
GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-10-03 08:12:28
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-10-03 08:12:28
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-10-03 08:12:28
GAIN Capital/OEC | Disconnected from the trading server. | 2016-10-03 08:12:28
GAIN Capital/OEC | Disconnected. | 2016-10-03 08:12:28
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-10-03 08:12:28
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-10-03 08:12:31
GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-10-03 08:12:31
GainCapital FIX Trading socket (6) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-10-03 08:12:32
GainCapital FIX Trading socket (6) | Shutdown and closed. | 2016-10-03 08:12:32
GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-10-03 08:12:32
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-10-03 08:12:32
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-10-03 08:12:32
GAIN Capital/OEC | Disconnected from the trading server. | 2016-10-03 08:12:32
GAIN Capital/OEC | Disconnected. | 2016-10-03 08:12:32
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-10-03 08:12:32
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-10-03 08:12:35
GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-10-03 08:12:35
File >> Disconnect selected. | 2016-10-03 08:12:36
GainCapital FIX Trading: DisconnectFIX called. | 2016-10-03 08:12:36
GainCapital FIX Trading socket (7) | Shutdown and closed. | 2016-10-03 08:12:36
GAIN Capital/OEC | Disconnected from the trading server. | 2016-10-03 08:12:36
GAIN Capital/OEC | Disconnected. | 2016-10-03 08:12:36
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-10-03 08:13:50
GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-10-03 08:13:50
GainCapital FIX Trading socket (8) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-10-03 08:13:51
GainCapital FIX Trading socket (8) | Shutdown and closed. | 2016-10-03 08:13:51
GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-10-03 08:13:51
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-10-03 08:13:51
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-10-03 08:13:51
GAIN Capital/OEC | Disconnected from the trading server. | 2016-10-03 08:13:51
GAIN Capital/OEC | Disconnected. | 2016-10-03 08:13:51
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-10-03 08:13:51
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-10-03 08:13:54
GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-10-03 08:13:54
GainCapital FIX Trading socket (9) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-10-03 08:13:55
GainCapital FIX Trading socket (9) | Shutdown and closed. | 2016-10-03 08:13:55
GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-10-03 08:13:55
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-10-03 08:13:55
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-10-03 08:13:55
GAIN Capital/OEC | Disconnected from the trading server. | 2016-10-03 08:13:55
GAIN Capital/OEC | Disconnected. | 2016-10-03 08:13:55
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-10-03 08:13:55
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-10-03 08:13:58
GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-10-03 08:13:58
GainCapital FIX Trading socket (10) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-10-03 08:13:59
GainCapital FIX Trading socket (10) | Shutdown and closed. | 2016-10-03 08:13:59
GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-10-03 08:13:59
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-10-03 08:13:59
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-10-03 08:13:59
GAIN Capital/OEC | Disconnected from the trading server. | 2016-10-03 08:13:59
GAIN Capital/OEC | Disconnected. | 2016-10-03 08:13:59
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-10-03 08:13:59
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-10-03 08:14:03
GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-10-03 08:14:03
GainCapital FIX Trading socket (11) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-10-03 08:14:04
GainCapital FIX Trading socket (11) | Shutdown and closed. | 2016-10-03 08:14:04
GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-10-03 08:14:04
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-10-03 08:14:04
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-10-03 08:14:04
GAIN Capital/OEC | Disconnected from the trading server. | 2016-10-03 08:14:04
GAIN Capital/OEC | Disconnected. | 2016-10-03 08:14:04
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-10-03 08:14:04
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-10-03 08:14:07
GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-10-03 08:14:07
GainCapital FIX Trading socket (12) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-10-03 08:14:08
GainCapital FIX Trading socket (12) | Shutdown and closed. | 2016-10-03 08:14:08
GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-10-03 08:14:08
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-10-03 08:14:08
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-10-03 08:14:08
GAIN Capital/OEC | Disconnected from the trading server. | 2016-10-03 08:14:08
GAIN Capital/OEC | Disconnected. | 2016-10-03 08:14:08
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-10-03 08:14:08
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-10-03 08:14:11
GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-10-03 08:14:11
GainCapital FIX Trading socket (13) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-10-03 08:14:12
GainCapital FIX Trading socket (13) | Shutdown and closed. | 2016-10-03 08:14:12
GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-10-03 08:14:12
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-10-03 08:14:12
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-10-03 08:14:12
GAIN Capital/OEC | Disconnected from the trading server. | 2016-10-03 08:14:12
GAIN Capital/OEC | Disconnected. | 2016-10-03 08:14:12
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-10-03 08:14:12
File >> Disconnect selected. | 2016-10-03 08:14:12
[2016-10-03 08:48:16]
Based upon these messages:
It appears as though a firewall on your computer is blocking the connection. Refer to:
https://www.sierrachart.com/index.php?page=doc/helpdetails1.php#h1.2
[2016-10-03 08:55:39]
But it was doing it on a comp i always have used and then i tried another comp where it still is doing it, also the firewall is enabled to accept sierra?
[2016-10-03 09:00:00]
Have just spoken with IT and it could be the office firewall - so have sen tthem logs thanks
[2016-10-03 09:14:46]
OK they need to allow port 9400. There are other ports as well and they are all listed in the Message Log as the connections are being made.
Date Time Of Last Edit: 2016-10-03 09:15:42
[2016-10-03 09:49:52]
natanibz - Posts: 135
Hello, i have the same problem.
Reading Internal Order ID file. | 2016-10-03 04:46:24
Reading Trade Orders file. | 2016-10-03 04:46:24
Reading Trade Positions file. | 2016-10-03 04:46:24
Software version: 1460 | 2016-10-03 04:46:24
Uses New Spreadsheets | 2016-10-03 04:46:24
Usage end date: 2017-04-02 | 2016-10-03 04:46:24
Enabled for: Advanced Features. | 2016-10-03 04:46:24
Enabled for: Advanced Features 2. | 2016-10-03 04:46:24
Enabled for: Sierra Chart Historical Data Service. | 2016-10-03 04:46:24
Allow Support for Sierra Chart Data Feeds is enabled. | 2016-10-03 04:46:24
Current selected Data/Trading service: GAIN Capital/OEC | 2016-10-03 04:46:24
Chart Update Interval: 500 | 2016-10-03 04:46:24
Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-10-03 04:46:24
2016-10-03 11:46:26 Local computer time | 2016-10-03 04:46:24
2016-10-03 09:46:26 Local computer time in UTC | 2016-10-03 04:46:24
2016-10-03 04:46:26 Local computer time in SC Time Zone | 2016-10-03 04:46:24
2016-10-03 09:46:26 Server time in UTC | 2016-10-03 04:46:24
Local computer UTC time and Server UTC time difference: 0 seconds. | 2016-10-03 04:46:24
Program path: C:\SierraChart\ | 2016-10-03 04:46:24
Data Files path: C:\SierraChart\Data\ | 2016-10-03 04:46:24
OS Version Number: 6.1 | 2016-10-03 04:46:24
Locale Setting: C | 2016-10-03 04:46:24
GAIN Capital/OEC | Connecting to trading server prod.openecry.com. Port: 9400. | 2016-10-03 04:47:23
GainCapital FIX Trading socket (0) | Error on address resolution. Windows error code 11001: Host sconosciuto. | 2016-10-03 04:47:23
GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-10-03 04:47:23
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-10-03 04:47:23
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-10-03 04:47:23
GAIN Capital/OEC | Disconnected from the trading server. | 2016-10-03 04:47:23
GAIN Capital/OEC | Disconnected. | 2016-10-03 04:47:23
HTTP connection to ds01.ddfplus.com:80 (5) | Closed. No error. | 2016-10-03 04:47:44
HTTP connection to ds01.ddfplus.com:80 (5) | Shutdown and closed. | 2016-10-03 04:47:44
[2016-10-03 10:12:57]
The problem shown in the Message Log in post #6 is different.
Update Sierra Chart with Help >> Download Current Version.
[2016-10-03 10:46:44]
I have download the current version, but now all my charts are daily(i have changed them in intraday charts), but then the numbers bars and the volume profile are not correct. I mean the volume is not correct.
[2016-10-03 10:52:20]
See:
Footprint and volume profile not working after update
[2016-10-03 11:18:06]
We have determined the cause of the problem of Intraday charts changing to Historical charts. This is going to be resolved in 1467 which we are releasing now.
Date Time Of Last Edit: 2016-10-03 11:18:23
