Date/Time: Sat, 19 Sep 2026 00:29:46 +0000
Addition of a saved study collection (single spreadsheet) is causing errors
View Count: 2041
[2013-07-25 14:09:13]
TheOddsAreYouDontKnowTheOdds - Posts: 29
Hi, I have sent you a message log about this as well.
Trying to set it up so I have a single spreadsheet with multiple sheets (tabs) showing data from a number of futures. So, I made the study for trading, set up the parameters, and save it as a collection. When I added the saved study to a new symbol, i get a continuous string of error messages about OTHER studies on my chart getting affected because they are now (suddenly) referencing a study subgraph that does not exist. Don't know why the new study affects the prior studies in this way. What study subgraph would cease to exist by my addition of this new saved study collection?
[2013-07-25 16:55:20]
Sierra Chart - Max - Posts: 5967
When the study collection was saved was the Prompt to Remove Existing Studies setting enabled?
https://www.sierrachart.com/index.php?l=doc/doc_StudyCollections.html#Adding
If not, then by applying the study collection will remove all existing studies from a chart.
Sierra Chart Support
Date Time Of Last Edit: 2013-07-28 23:35:15
[2013-07-25 17:37:23]
These are the messages you received:
Chart: ES-201309-CME 60 min #17 | Study: GSDiff 2:1 | Study Overlay - OHLC: Study references a study subgraph that does not exist. | 2013-07-25 09:05:52
Chart: ES-201309-CME 60 min #19 | Study: SI_m_HG | Study Overlay - OHLC: Study references a study subgraph that does not exist. | 2013-07-25 09:05:53
Are either of these 2 studies stated above, in the study collection that you created?
[2013-07-28 23:32:45]
No, they are not.
I played around with different settings and IT SEEMS that the trick is to check the box where you save the single study as a collection saying "Prompt to remove existing studies".
Once I did that the error messages stopped. It seems that the addition of the new saved study was clearing out the old ones, maybe?
Thanks.
(Still getting the hang of it...slow learner :-))
[2013-07-28 23:34:51]
Yes, this does make sense.
