Date/Time: Tue, 04 Nov 2025 07:50:49 +0000
[Programming Help] - Array Looping
View Count: 1703
[2016-09-27 09:40:01]
User103305 - Posts: 8
I wanted to ask something about the looping. I have a loop like this:
for (int i = 0; i < 50; ++i)
      if (sc.Subgraph[3] != 0)
etc....
First index of the Array is 0 isn´t it?? Why then the loop start to iterate from the last value on the chart and not from the first one??
Thx.
Best regards,
[2016-09-27 09:47:38]
This is wrong:
should be:
if (sc.Subgraph[3][Index] != 0)
Date Time Of Last Edit: 2016-09-27 09:49:51
[2016-09-27 09:49:39]
The prior post has been corrected.
[2016-09-27 09:53:16]
Sorry error on copy and paste.
Yes I have it so:
for (int Index = 0; Index < 100; ++Index)
Thx.
Best
Date Time Of Last Edit: 2016-09-27 16:58:13
[2016-09-27 09:56:57]
Doesn't not display the i after the [3]!!!
I dont know why...but I have it there.
[2016-09-27 16:57:25]
Use Index instead of i. That solves the display problem.
We have corrected it for you.
Yes this is correct. The indexing is from the first Subgraph value in the chart. That is definitive. So any conclusion otherwise is incorrect.
[2016-09-27 18:29:04]
thx for your answer.
Can you give me some example?
how to iterate from first value on the chart to last one ?
And
how to iterate from last value on the chart to first one ?
Thx.
Best,
[2016-09-27 23:46:18]
Refer to:
http://www.sierrachart.com/index.php?page=doc/ACS_ArraysAndLooping.html
C++ Control Structures: The for loop
[2016-09-28 17:45:28]
Only to be 100% sure.
Can you confirm that the most current not closed bar on the right side of the Sierra Chart have the Index value of 0 ?
In this case if the chart settings are set to 1-30.9.2016:
1.9.2016 has the index(first on the right side) value [0]
and the 30.9.2016 hast the index(last on the left side) value [29]
Correct??
Best,
[2016-09-28 18:02:56]
We will start with this:
The last bar in the chart on the right side is at index sc.ArraySize -1.
[2016-09-28 18:59:38]
Then the second bar on the right side has the index value of 0 ?
Best,
[2016-09-28 19:23:59]
No that is not correct either.
The index will be sc.ArraySize-2
[2016-09-28 20:40:44]
Then the example below will populate the arrays from right to left??? Does it mean that the sc.UpdateStartIndex hold the value -1?
This function demonstrates manual looping using a for loop.
SCSFExport scsf_ManualLoopExample(SCStudyInterfaceRef sc)
if (sc.SetDefaults)
// Set the configuration and defaults
sc.GraphName = "Manual Loop Example";
sc.StudyDescription = "This is an example of using manual looping.";
sc.AutoLoop = 0; // 0 is the default: there is no auto-looping
sc.Subgraph[0].Name = "High Low Difference";
sc.Subgraph[1].Name = "High - Low Average";
sc.Subgraph[2].Name = "Back Reference Example";
sc.Subgraph[3].Name = "Forward Reference Example";
return;
// Do data processing
for (int Index = sc.UpdateStartIndex; Index < sc.ArraySize; Index++)
// Calculate the difference between the high and the low
sc.Subgraph[0][Index] = sc.BaseData[SC_HIGH][Index] - sc.BaseData[SC_LOW][Index];
// SimpleMovAvg will fill in the data element in sc.Subgraph[1] at index Index.
sc.SimpleMovAvg(sc.Subgraph[0], sc.Subgraph[1], Index, 10);
// Copy the previous last price (Index-1) to subgraph array number 3
sc.Subgraph[2][Index] = sc.BaseData[SC_LAST][Index - 1];
// Copy the next last price (Index+1) to subgraph array number 4
sc.Subgraph[3][Index] = sc.BaseData[SC_LAST][Index + 1];
Date Time Of Last Edit: 2016-09-28 23:55:01
[2016-09-28 23:53:55]
The order will be from left to right from the perspective of the chart bars.
sc.UpdateStartIndex will never be a negative value.
