Date/Time: Fri, 10 Jan 2025 13:48:08 +0000
No data for ARRY and EXEL
View Count: 1264
[2016-09-14 13:39:55]
Stephan908 - Posts: 46
Hi, for some reason today I'm not getting data for ARRY, EXEL and AAPL stock symbols. Other symbols that I'm looking at are working fine. I'm using Sierra datafeed but I also tried switching to TDA but it's the same thing. I tried deleting all the scid and dly files in the data directory. Tried the 'delete and download' option also. Is there a way to fix this? Thanks!
Date Time Of Last Edit: 2016-09-14 13:47:11
[2016-09-14 13:54:08]
User900555 - Posts: 1
I came here to post this same exact issue. Other symbols are fine but no data for today on AAPL, ARRY, and EXEL. Can we get a fix for this asap? Thanks!
[2016-09-14 14:10:42]
Good to know I'm not the only one. I found a few more like that. COMM, PTX, LFVN, AGIO, CBRL... since I tried another datafeed, my guess is that the issue is not with the data. When I look at my chart settings, the 'date range in file' is not showing the most current date. The working symbols are showing 2016-09-14 but the ones that are not working are stuck on 2016-09-13. I tried changing the 'use data range' option to force it to go to 2016-09-14 but that didn't do anything. Thanks.
[2016-09-14 14:12:35]
User713273 - Posts: 409
NFLX also, using SC data feed
[2016-09-14 14:30:58]
We are checking on this.
[2016-09-14 14:44:54]
The NASDAQ data feed is now working again.
This was a Barchart data problem with NASDAQ stocks. We have contacted them about it for an explanation.
The data feed came back at 10:37 AM US Eastern time. There is missing Intraday data up until this time for today. Will patch the missing data as soon as is possible.
Date Time Of Last Edit: 2016-09-14 17:27:34
[2016-09-14 14:48:13]
Message from Barchart about this issue:
We are aware.
We switched to the backup.
We will fix the history.
We are still reviewing.
[2016-09-14 15:55:38]
Thank you for looking into the issue. I can confirm that data is coming in now but we are definitely missing data so hopefully they will fix that soon.
Earlier I tried to switch datafeed but I think I missed a step.. after switching to another datafeed under Data/Trade Service Settings - 'Service', do we need to uncheck 'Allow Support for Sierra Chart Data Feeds' in order to switch? I didn't uncheck it earlier because I thought I can leave that checked so I can still get historical data from SC. Thanks.
[2016-09-14 17:28:40]
Yes you would need to do this.
[2016-09-14 22:09:13]
Have you heard back concerning the data mishap from this AM? Thx
[2016-09-14 22:42:43]
yes. It still will be about two hours from now.
[2016-09-14 22:52:43]
OK, great. Has the root of the problem been established? thx
[2016-09-15 01:14:36]
We did not ask Barchart what the source of the problem was.
We are working on filling in the missing data now. Please allow about one hour to complete.
[2016-09-15 01:39:49]
The missing data has now been filled in.
Follow the instructions here to re-download the missing data:
http://www.sierrachart.com/index.php?page=doc/HistoricalIntradayData.html#RetryDownloadDataInChart
