Date/Time: Fri, 10 Jan 2025 03:36:50 +0000
Lmax demo DTS not working
View Count: 784
[2016-08-26 17:13:52] |
You need to log into Sierra Chart using your 'chifounou' account. Here are instructions: Sierra Chart - Software Login Instructions: Login with a Different Sierra Chart Account Name Hello, A LMAX trading account has now been assigned to your Sierra Chart account. Refer to this page and confirm the account number is correct: https://www.sierrachart.com/usercp.php Update Sierra Chart to the current version following the instructions here: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Set "Global Settings >> Data/Trade Service Settings >> Service" to "LMAX Demo Trading - DTC". Connect to the server with "File >> Connect to Data Feed". Depending upon when you receive this message it may take up to two minutes for our server to receive the updated authorizations for you to be able to connect. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-26 17:33:07] |
chifounou1 - Posts: 13 |
Thank you. It works
