Date/Time: Fri, 10 Jan 2025 04:47:11 +0000
Unable to connect to service
View Count: 833
[2016-08-21 16:29:17]
User600819 - Posts: 43
Software version: 1406 | 2016-08-19 08:50:36
Uses New Spreadsheets | 2016-08-19 08:50:36
Usage end date: 2016-09-18 | 2016-08-19 08:50:36
Enabled for: Advanced Features. | 2016-08-19 08:50:36
Enabled for: Sierra Chart Historical Data Service. | 2016-08-19 08:50:36
Allow Support for Sierra Chart Data Feeds is enabled. | 2016-08-19 08:50:36
Current selected Data/Trading service: CTS T4 FIX | 2016-08-19 08:50:36
Chart Update Interval: 500 | 2016-08-19 08:50:36
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-08-19 08:50:36
2016-08-19 08:51:43 Local computer time | 2016-08-19 08:50:36
2016-08-19 12:51:43 Local computer time in UTC | 2016-08-19 08:50:36
2016-08-19 08:51:43 Local computer time in SC Time Zone | 2016-08-19 08:50:36
2016-08-19 12:49:12 Server time in UTC | 2016-08-19 08:50:36
Local computer UTC time and Server UTC time difference: 147 seconds. | 2016-08-19 08:50:36
Notice: Your computer's clock is off by 147 seconds. For help with this, press the 'Send for Analysis' button. | 2016-08-19 08:50:36
Program path: C:\SierraChart\ | 2016-08-19 08:50:36
Data Files path: C:\SierraChart\Data\ | 2016-08-19 08:50:36
OS Version Number: 6.2 | 2016-08-19 08:50:36
Locale Setting: C | 2016-08-19 08:50:36
CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2016-08-21 12:27:14
CTS FIX - Firm: PTP | 2016-08-21 12:27:14
CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 69.44.110.200. | 2016-08-21 12:27:14
CTS FIX socket (528) | Connected. | 2016-08-21 12:27:14
CTS FIX socket (528) | Starting TLS 1.0 connection. | 2016-08-21 12:27:14
CTS FIX socket (528) | SSL connection established. | 2016-08-21 12:27:15
CTS FIX: Sending the Logon message. | 2016-08-21 12:27:15
CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2016-08-21 12:27:15 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20160821-16:24:46.28045=1372=A373=1058=Sending Time Accuracy problem10=197 | 2016-08-21 12:27:15 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2016-08-21 12:27:15 *
CTS FIX socket (528) | Closed. No error. | 2016-08-21 12:27:15
FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20160821-16:24:46.28058=FIXLogin Time Tag Accuracy Problem - Out of time window10=237 | 2016-08-21 12:27:15 *
CTS FIX socket (528) | SSL shutdown indicates not able to send 'close notify'. | 2016-08-21 12:27:15
CTS FIX socket (528) | SSL has been shut down. | 2016-08-21 12:27:15
CTS FIX socket (528) | SSL object has been freed. SSL state is now disconnected. | 2016-08-21 12:27:15
CTS FIX socket (528) | Shutdown and closed. | 2016-08-21 12:27:15
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2016-08-21 12:27:15
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-08-21 12:27:15
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-08-21 12:27:15
CTS T4 FIX | Disconnected. | 2016-08-21 12:27:15
CTS FIX: Disconnected. | 2016-08-21 12:27:15
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-08-21 12:27:15
Date Time Of Last Edit: 2016-08-21 20:31:08
[2016-08-21 20:31:46]
Your computer's clock is not set accurately.
This is the relevant message:
Refer to help topic 38:
Https://www.sierrachart.com/index.php?l=helpdetails38.html
You are also running an older version of Sierra Chart. Update to the new version with Help >> Download Current Version. This is important.
Date Time Of Last Edit: 2016-08-21 20:32:20
