Date/Time: Thu, 09 Jan 2025 19:43:55 +0000
Several thoughts/questions/suggestions
View Count: 799
[2016-08-11 19:39:29]
User976133 - Posts: 38
Good afternoon.
1) I have a study I have added to several charts based on the slope of the MACD and resembles a MACD histogram. All that I have done except the last two the color is as expected. The last two the color is darker than the others despite being made in the same way as the ones colored correctly. It is as if the last, the light behind the lens is not turned on. You can tell it is red/green, nut intensity and brightness is way off.
2) I would like to create an alert when the MACD slope from # 1 above turns green on multiple time frames or turns red. All three timeframes are green where the bar before was not, same for red. I know the slope is MACD>MACD[-1] to turn green. Is there a way to access the current bar on timeframe1 (TF1) as well as TF2 and TF3 and by color instead of writing out the formula for each?
3) Is there a basic tutorial for newbies like me? Something like many spreadsheet programs where they guide you through building spreadsheet while showing off some of the major features. Here is a chartbook. Next you add a chart. Modify it like this. Copy it and change time frames. Link them together. A basic step by step can be as basic, or as advanced as desired, from really basic, to coding ASCIL.
Thanks for any thoughts or suggestions
[2016-08-12 05:06:03]
1. We do not know what the question is and from our perspective we have no idea why you see what you do. If you have a question for us you need to be very specific.
Here is the documentation for Chart Studies:
Chart Studies
2. Refer to:
Study/Price Overlay Study
Study/Chart Alerts And Scanning
3. We do not know specifically what you want to do. Refer to the documentation:
https://www.sierrachart.com/index.php?page=doc/Contents.php
However, you probably are interested in this page:
Getting Started, Opening Charts and Basic Trading
Date Time Of Last Edit: 2016-08-12 05:07:10
[2016-08-12 15:18:32]
1) Color wrong - I pick Hue - 0 Sat - 240 Lum - 129 RGB 255.0.0
I get something that resembles 0.240.96 204.0.0
I am guessing because the color chosen does not represent the color displayed and have to eyeball it.
[2016-08-12 16:55:10]
There is no way we can answer this question from our perspective. We have no clear context whatsoever.
