Date/Time: Sat, 26 Apr 2025 09:50:58 +0000
Trade window "Quantity" drop down field
View Count: 1199
[2016-08-05 08:48:23] |
Sporken - Posts: 82 |
Hi, The Chart Trade window has a drop down box for choosing the trade Quantity. I've uploaded an image of my window. http://sli.mg/1nDExx The entries put the top figure at the top, next to the mouse cursor location. I accidentally selected 22. I was completely unaware of my mistake. I think this behaviour is dangerous. My sim account just went short €5.25m worth of DAX futures. I never want to select a figure as high as 22. ((I'm going to start using the 4th tab - labelled "C" in order to avoid ever making this mistake again.)) I don't think that value field should be a drop-down selector at all. Or the values should be limited. Or something. It would be good if the trade window showed an approximate currency value of the trade - or for each entry in the drop down. Maybe it should warn and demand confirmation if it's above a certain figure. So in this case the total was €10,250 * 25 * 22 = €5.25m = (current contract price) * (contract lot size) * (trade size) My accidental loss from this trade would have been 121 * €25 = €3025. Lucky this was just a sim trade. I also have a feature request that you might consider. I use a simple calculation when buying shares. I think a lot of share traders use the same method. For each trade, I decide my quantity based on a fixed expected loss amount. I want my expected loss on a trade to be limited at a set figure. Maybe $250. So if the current share price is $100 and my stop loss is at $75, then that implies a purchase quantity of 10 shares. Calculation: $100 - $75 = $25. (current share price) - (stop loss price) $250/$25 = 10 shares. = It would be nice if this calculation was integrated. Maybe this could be another tab on that trade window. It would be nice if it suggested a trade quantity based on my parameters ($loss, share price, stop price) So if I open up a chart on a stock and nominate a stop price (or stop %) then it would show what my expected purchase quantity and $ value would be. And as I vary my stop position, it varies the text that shows the trade size and $ value. I think people would find this useful. I generally choose my expected loss value based on the stock. But it can be $250, $500, $1000 etc. I use fixed predefined values. Also, thanks for your help with my earlier issues, I now have super fast charts on one SC instance and super detailed charting on a secondary instance. SUPERB! Kind Regards, -Jason |
[2016-08-05 18:26:22] |
In version 1451 we reversed the order of the Order Quantities so the lowest quantity is at the top. We will see about your other suggestions. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
