Date/Time: Thu, 09 Jan 2025 08:43:22 +0000
Horizontral Lines Study doesnt work properly
View Count: 875
[2016-07-28 16:03:18] |
Crtfyd - Posts: 281 |
vs 1379 Horizontal Lines Study "Draw Style" doesn't work properly. Will only do solid and dot. Not Dash or any other. |
[2016-07-28 17:12:28] |
We do not understand what you mean by this. What is meant by "doesn't work properly". Be very clear and specific. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-28 19:26:37] |
I have the "Horizontal Lines Study" in Region 3 of my 1 second charts. In looking at it again, I've seen the problem more specifically. When choosing in the Study: Subgraphs>Draw Style>Line Style. I choose Line and Dash. Originally, when I sent this message, all that was seen was a "Solid" Line. On further inspection, I see that if I have the "Width/Size" more then "1", then it turns into a "Solid" line (obviously from the magnification). So really it doesn't "turn" into a line, it just appears that way. This is different then when I change the width on any other tool regarding line width/size. I would suppose that because its magnifying in a different way then other line/tools. Basically it makes the width/Size button useless because you only get the one size. I've only seen this on this study. Incidentally the "Dot" goes to 3 and you can still tell its a dot. So I imagine the answer is that when magnifying, they will inherently run together. Why then is it different for say a normal "Line" tool? Should the "dashes" be made less wide, so when magnifying, they don't run together? |
[2016-07-29 06:26:35] |
All of this is documented here: Chart Studies: Subgraphs Tab >> Line Style To save yourself time and our time, refer to the documentation first. It is very thorough. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
