Date/Time: Tue, 04 Nov 2025 08:38:39 +0000
Chart Replay - resets to current time when stop pressed
View Count: 1034
|   [2016-07-19 02:36:47]     |
| User100134 - Posts: 3 |
                First time using the Chart Replay feature. I'm using it to test a custom study I designed. I use GoTo a specific date (6-30) in this instance, then do a replay at a specific time. I only need it to replay 6 minutes of tick data so when finished I press stop. The problem is, as soon as I press stop, the chart goes to the current time, 7-18 @ 22:33 for example. How do I set the replay feature so it doesn't do this? There are multiple time periods on 6-30 I want to replay but I have to keep using GoTo each time after I hit replay-stop. Thanks  |
|   [2016-07-19 04:45:39]     |
                You have to use Pause and not Stop. There is no other way. Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2016-07-19 13:27:10]     |
                Roger. Thx for the quick reply.
