Date/Time: Sun, 28 Apr 2024 09:33:24 +0000
[User Discussion] - Delta Ladder
View Count: 2926
[2013-07-16 12:13:01] |
User59821 - Posts: 6 |
Hi, is there a way to increase the font size of the numbers and the word 'start' on the Delta Ladder Custom study- as well as 'offset' the numbers so they stay visible on the chart-and not disapper as the chart moves-thanks in advance. |
[2013-07-17 07:40:02] |
This is marked as a User Discussion, since it is not a study that we developed.
[2013-07-18 19:35:24] |
WarriorTrader - Posts: 245 |
Hello, Lock the fill space: Chart--> Lock Fill Space so the fill space stays the same. Here is the old thread for that study: http://www.sierrachart.com/supportboard/showthread.php?t=31684&highlight=pullback You will have to edit the code for the study to change the font size of "start." The code is available in the C:\SierraChart\ACS_Source\UserContributedStudies.cpp It is nice to see someone using the study. If there is interest I have a better version of the study that I can post after I clean it up. -WT Date Time Of Last Edit: 2013-07-18 19:46:09
[2018-03-02 21:45:34] |
whats1thingnow - Posts: 407 |
great study! 2 questions: 1) is it possible to center the selling and buying pressure to the middle of the chart on the fillspace? i find when the numbers bar range is too large, the selling and buying pressure are pushed out of the screen and can no longer see it 2) is it difficult to modify this study to display it visually? something similar to jigsaw's strength meter ( https://www.youtube.com/watch?v=Lyv3-yerV54 ) |
[2018-03-03 05:12:46] |
Hello, The Jigsaw webinars are great. I always learn something from them and I have not seen the one you posted. This "Delta Ladder" study is pretty much a dead study. It was put out there when I did not know much. The source code is public so you can play around with it. In my opinion, understanding how to use Market Profile along with cumulative delta is far more important than anything this study can show you. I have developed a unique set of three principals to learn Jim Dalton's method as well as cumulative delta. Give me a private message (click on my user name) if you would like to talk offline. Good Trading --WT |
[2019-08-19 21:55:57] |
Eliazib - Posts: 1 |
Hi @WarriorTrader, I'd like to know more about the Dalton sets. Ty :)
