Date/Time: Sun, 19 May 2024 13:39:02 +0000
FTSE 250 & FTSE350 - SC Data - All Services
View Count: 1122
[2016-07-05 06:38:18] |
CarlRostron - Posts: 80 |
Is there any chance that the FTSE 250 & FTSE 350 Data can be added to the SC Data - All Services feeds? I am interested in this End of Day data. Wasn't sure if it was straightforward for you to add this. Thanks |
[2016-07-05 07:03:18] |
You will see FTSE 250 Symbol: Y In File >> Find Symbol >>Futures - Indices The FTSE 350 we do not see as available. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-05 07:44:52] |
Thanks. Just so that I understand, symbol Y - is that the continuous contract? |
[2016-07-05 11:01:30] |
That is the underlying symbol. For a continuous futures contract chart, refer to: https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-12-27 21:05:54] |
Chad - Posts: 231 |
Hi SCE, I'm looking for FTSE 250 (Y) in v2017 in the Find Symbol menu (while connected Interactive Brokers as data source), and I don't see it, either under 'Futures' or 'IB Indexes' categories. And since there isn't a listing for the LIFFE exchange in this menu (but of course I see several of its markets listed under the 'Futures' category), can't check that either. Others I can't find: 1) 3-Month Euroswiss (F) on LIFFE, which has IB symbol 'S' 2) Mexico Bolsa Index on MEXDER (SC symbol OM; IB symbol IPC) 3) UK Natural Gas on ICE EU/NBP (SC symbol NF; IB symbol NGF) Date Time Of Last Edit: 2019-12-27 21:28:25
