Date/Time: Sat, 04 Jan 2025 07:11:38 +0000
Symbol ZB.20160900.CME_F Not Updating..
View Count: 1296
[2016-06-06 13:49:58]
Meritus - Posts: 164
The ZB chart is not updating at all in the Sep contract. The expiring June ZB contract IS updating. Pls see below
http://www.sierrachart.com/image.php?Image=146522023627.png
http://www.sierrachart.com/image.php?Image=1465220908462.png
Also not updating is the previously mentioned TN.XCME chart in the Sep contract. In the screenshot you can see that there is data for the expiring June TN.XCME_F contract which updates in real time but not so for the Sep contract. After several attempts at deleting and downloading etc, the chart populated with data which did not update. After deleting and downloading again, no data displayed. The chart symbol appeared fine on Friday.
http://www.sierrachart.com/image.php?Image=14652206661.png
http://www.sierrachart.com/image.php?Image=1465220688373.png
[2016-06-06 16:49:04]
For an issue like this it is best to also contact CTS about it.
We need to see the Message Log to see if we can see a reason for not receiving real-time data for those symbols.
Provide a copy of the Message Log by following these instructions:
http://www.sierrachart.com/index.php?l=PostingInformation.php#MessageLog
[2016-06-06 16:57:36]
My trading DOM has up to date data and my CTS charts are also updating. The issue sems to be not with the data but somewhere between the data and SC.
The ZB symbol is now updating in real time but the TN.XCME_F is still not updating and appears to have frozen. Please see the image below which has not updated for over an hour.
http://www.sierrachart.com/image.php?Image=1465232127147.png
Below is the Message Log as requested which I am sending for the second time.
Reading Internal Order ID file. | 2016-06-06 10:36:59
Reading Trade Orders file. | 2016-06-06 10:36:59
Reading Trade Positions file. | 2016-06-06 10:36:59
Software version: 1420 | 2016-06-06 10:36:59
Uses New Spreadsheets | 2016-06-06 10:36:59
Usage end date: 2016-07-04 | 2016-06-06 10:36:59
Enabled for: Advanced Features. | 2016-06-06 10:36:59
Enabled for: Sierra Chart Historical Data Service. | 2016-06-06 10:36:59
Allow Support for Sierra Chart Data Feeds is disabled. | 2016-06-06 10:36:59
Current selected Data/Trading service: CTS T4 FIX | 2016-06-06 10:36:59
Chart Update Interval: 800 | 2016-06-06 10:36:59
Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-06-06 10:36:59
2016-06-06 16:37:04 Local computer time | 2016-06-06 10:36:59
2016-06-06 15:37:04 Local computer time in UTC | 2016-06-06 10:36:59
2016-06-06 10:37:04 Local computer time in SC Time Zone | 2016-06-06 10:36:59
2016-06-06 15:37:02 Server time in UTC | 2016-06-06 10:36:59
Local computer UTC time and Server UTC time difference: 1 seconds. | 2016-06-06 10:36:59
Program path: C:\SierraChart\ | 2016-06-06 10:36:59
Data Files path: C:\Users\capitaleast\Documents\New folder\SC2\ | 2016-06-06 10:36:59
OS Version Number: 6.2 | 2016-06-06 10:36:59
Locale Setting: C | 2016-06-06 10:36:59
Checking for new symbol settings for cts | 2016-06-06 10:36:59
HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-06-06 10:36:59
HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-06-06 10:36:59
HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-06-06 10:36:59
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-06-06 10:36:59
Symbol settings are up-to-date for cts | 2016-06-06 10:36:59
Files to Open on Start up | Opening file: bond spreads reverse.cht | 2016-06-06 10:37:07
CTS T4 FIX | Using primary service for historical data for ZN.20160900.CME_F | 2016-06-06 10:37:07
ZN.20160900.CME_F 30 Sec #5 | Reloading chart. | 2016-06-06 10:37:07
CTS T4 FIX | Using primary service for historical data for ZB.20160900.CME_F | 2016-06-06 10:37:07
ZB.20160900.CME_F 30 Sec #8 | Reloading chart. | 2016-06-06 10:37:07
ZB.20160900.CME_F Weekly #14 | Reloading chart. | 2016-06-06 10:37:07
Zb.20160900.CME_F Daily #1 | Reloading chart. | 2016-06-06 10:37:07
ZB.20160900.CME_F Weekly #2 | Reloading chart. | 2016-06-06 10:37:07
ZB.20160900.CME_F Daily #3 | Reloading chart. | 2016-06-06 10:37:07
ZB.20160900.CME_F 120 Min #4 | Reloading chart. | 2016-06-06 10:37:07
ZB.20160900.CME_F Daily #6 | Reloading chart. | 2016-06-06 10:37:07
GBPCAD Weekly #7 | Reloading chart. | 2016-06-06 10:37:07
ZB.20160900.CME_F Weekly #9 | Reloading chart. | 2016-06-06 10:37:07
ZB.20160900.CME_F 120 Min #10 | Reloading chart. | 2016-06-06 10:37:07
ZB.20160900.CME_F 30 Sec #11 | Reloading chart. | 2016-06-06 10:37:07
ZN.20160900.CME_F 30 Sec #12 | Reloading chart. | 2016-06-06 10:37:07
Zb.20160900.CME_F Weekly #16 | Reloading chart. | 2016-06-06 10:37:07
Files to Open on Start up | Opening file: bond spreads reverse and bonds.cht | 2016-06-06 10:37:07
Zb.20160900.CME_F Daily #13 | Reloading chart. | 2016-06-06 10:37:07
Zn.20160900.CME_F Daily #15 | Reloading chart. | 2016-06-06 10:37:07
Files to Open on Start up | Opening file: 10yr Ultra v 10yr.cht | 2016-06-06 10:37:07
CTS T4 FIX | Using primary service for historical data for TN.XCME_F TN (u16).CME_F | 2016-06-06 10:37:07
TN.XCME_F TN (u16).CME_F 30 Sec #1 | Reloading chart. | 2016-06-06 10:37:07
TN.XCME_F TN (u16).CME_F Daily #2 | Reloading chart. | 2016-06-06 10:37:07
ZN.20160900.CME_F 30 Sec #3 | Reloading chart. | 2016-06-06 10:37:07
TN.XCME_F TN (u16).CME_F Weekly #4 | Reloading chart. | 2016-06-06 10:37:07
TN.XCME_F TN (u16).CME_F 120 Min #10 | Reloading chart. | 2016-06-06 10:37:07
TN.XCME_F TN (u16).CME_F Daily #5 | Reloading chart. | 2016-06-06 10:37:07
CTS T4 FIX | Using primary service for historical data for TN.XCME_F TN (U16).CME_F | 2016-06-06 10:37:07
TN.XCME_F TN (U16).CME_F 30 Sec #6 | Reloading chart. | 2016-06-06 10:37:07
ZN.20160900.CME_F 30 Sec #7 | Reloading chart. | 2016-06-06 10:37:07
TN.XCME_F TN (u16).CME_F Weekly #8 | Reloading chart. | 2016-06-06 10:37:07
TN.XCME_F TN (u16).CME_F 120 Min #9 | Reloading chart. | 2016-06-06 10:37:07
Files to Open on Start up | Opening file: BoB.cht | 2016-06-06 10:37:07
ZB.20160900.CME_F 30 Sec #1 | Reloading chart. | 2016-06-06 10:37:07
CTS T4 FIX | Using primary service for historical data for UB.20160900.CME_F | 2016-06-06 10:37:07
UB.20160900.CME_F 30 Sec #2 | Reloading chart. | 2016-06-06 10:37:07
ZB.20160900.CME_F Weekly #4 | Reloading chart. | 2016-06-06 10:37:07
CTS T4 FIX | Using primary service for historical data for uB.20160900.CME_F | 2016-06-06 10:37:07
uB.20160900.CME_F 60 Min #6 | Reloading chart. | 2016-06-06 10:37:07
ZB.20160900.CME_F 30 Sec #5 | Reloading chart. | 2016-06-06 10:37:07
UB.20160900.CME_F 30 Sec #7 | Reloading chart. | 2016-06-06 10:37:07
ZB.20160900.CME_F Daily #8 | Reloading chart. | 2016-06-06 10:37:07
uB.20160900.CME_F 60 Min #10 | Reloading chart. | 2016-06-06 10:37:07
Files to Open on Start up | Opening file: M6 BoB.cht | 2016-06-06 10:37:07
ZB.20160600.CME_F 30 Sec #1 | Reloading chart. | 2016-06-06 10:37:07
CTS T4 FIX | Using primary service for historical data for UB.20160600.CME_F | 2016-06-06 10:37:07
UB.20160600.CME_F 30 Sec #2 | Reloading chart. | 2016-06-06 10:37:07
ZB.20160600.CME_F Daily #3 | Reloading chart. | 2016-06-06 10:37:07
ZB.20160600.CME_F Weekly #4 | Reloading chart. | 2016-06-06 10:37:07
CTS T4 FIX | Using primary service for historical data for uB.20160600.CME_F | 2016-06-06 10:37:07
uB.20160600.CME_F 60 Min #6 | Reloading chart. | 2016-06-06 10:37:07
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-06-06 10:37:07
HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-06-06 10:37:07
HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-06-06 10:37:07
HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-06-06 10:37:07
Chart #8 has tagged chart #14 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 10:37:07
Chart #8 has tagged chart #6 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 10:37:07
Chart #5 has tagged chart #8 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 10:37:07
Chart #11 has tagged chart #3 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 10:37:07
Chart #11 has tagged chart #4 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 10:37:07
Chart #11 has tagged chart #9 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 10:37:07
Chart #12 has tagged chart #11 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 10:37:07
Chart #8 has tagged chart #14 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:37:07
Chart #8 has tagged chart #6 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:37:07
Chart #5 has tagged chart #8 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:37:07
TN.XCME_F TN (u16).CME_F 30 Sec #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Users\capitaleast\Documents\New folder\SC2\TN.XCME_F TN (u16).CME_F.scid | 2016-06-06 10:37:07
Chart #11 has tagged chart #3 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:37:07
Chart #11 has tagged chart #4 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:37:07
Chart #11 has tagged chart #9 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:37:07
Chart #12 has tagged chart #11 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:37:07
TN.XCME_F TN (u16).CME_F 120 Min #10 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Users\capitaleast\Documents\New folder\SC2\TN.XCME_F TN (u16).CME_F.scid | 2016-06-06 10:37:07
TN.XCME_F TN (U16).CME_F 30 Sec #6 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Users\capitaleast\Documents\New folder\SC2\TN.XCME_F TN (U16).CME_F.scid | 2016-06-06 10:37:07
TN.XCME_F TN (u16).CME_F 120 Min #9 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Users\capitaleast\Documents\New folder\SC2\TN.XCME_F TN (u16).CME_F.scid | 2016-06-06 10:37:07
Chart #3 has tagged chart #2 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 10:37:07
Chart #3 has tagged chart #4 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 10:37:07
Chart #7 has tagged chart #5 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 10:37:07
Chart #7 has tagged chart #8 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 10:37:07
Chart #1 has tagged chart #3 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:37:07
Chart #1 has tagged chart #4 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:37:07
Chart #5 has tagged chart #10 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:37:07
Chart #5 has tagged chart #8 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:37:07
Chart #5 has tagged chart #9 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:37:07
ZB.20160900.CME_F 30 Sec #8 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 10:37:27
Chart #8 has tagged chart #10 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 10:37:27
Chart #8 has tagged chart #14 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 10:37:27
Chart #8 has tagged chart #6 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 10:37:27
ZB.20160900.CME_F Weekly #14 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 10:37:27
HD Request # 2 | Downloading Historical Daily chart data for ZB.20160900.CME_F. Starting date: 2016-06-03. Service: cts | 2016-06-06 10:37:27
HD Request # 2 | Requesting historical Daily data for ZBU16 starting at 2016-06-02 | 2016-06-06 10:37:27
HTTP connection to ds01.ddfplus.com:80 (0) | Resolved address ds01.ddfplus.com to IP 8.18.161.123. | 2016-06-06 10:37:27
ZB.20160900.CME_F Daily #3 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 10:37:27
ZB.20160900.CME_F 120 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 10:37:27
HTTP connection to ds01.ddfplus.com:80 (4) | Connected. | 2016-06-06 10:37:27
ZB.20160900.CME_F Daily #6 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 10:37:27
Using Bid/Ask average for last trade price for GBPCAD | 2016-06-06 10:37:27
HD Request # 3 | Downloading Historical Daily chart data for GBPCAD. Starting date: 2016-06-03. Service: fxcm | 2016-06-06 10:37:27
HD Request # 3 | Using server: ds4.sierracharts.com port 10149 | 2016-06-06 10:37:27
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-06-06 10:37:27
ZB.20160900.CME_F Weekly #9 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 10:37:27
ZB.20160900.CME_F 120 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 10:37:27
ZB.20160900.CME_F 30 Sec #11 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 10:37:27
Chart #11 has tagged chart #3 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 10:37:27
Chart #11 has tagged chart #4 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 10:37:27
Chart #11 has tagged chart #9 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 10:37:27
ZB.20160900.CME_F 30 Sec #8 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:37:27
Chart #8 has tagged chart #10 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:37:27
Chart #8 has tagged chart #14 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:37:27
Chart #8 has tagged chart #6 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:37:27
ZB.20160900.CME_F Weekly #14 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:37:27
ZB.20160900.CME_F Daily #3 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:37:27
ZB.20160900.CME_F 120 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:37:27
ZB.20160900.CME_F Daily #6 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:37:27
ZB.20160900.CME_F Weekly #9 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:37:27
ZB.20160900.CME_F 120 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:37:27
Socket (5) | Connected. | 2016-06-06 10:37:27
HD Request # 3 | Sending historical data logon request message. | 2016-06-06 10:37:27
ZB.20160900.CME_F 30 Sec #11 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:37:27
Chart #11 has tagged chart #3 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:37:27
Chart #11 has tagged chart #4 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:37:27
Chart #11 has tagged chart #9 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:37:27
HD Request # 3 | Requesting historical Daily data starting at 2016-06-03. | 2016-06-06 10:37:27
HD Request # 3 | Decompressing data. | 2016-06-06 10:37:27
HD Request # 3 | Receiving historical Daily data for GBPCAD starting at 2016-06-03 | 2016-06-06 10:37:27
HD Request # 3 | Writing historical Daily data to the file GBPCAD.dly | 2016-06-06 10:37:27
Socket (5) | Shutdown and closed. | 2016-06-06 10:37:27
The network socket for historical data has been closed. | 2016-06-06 10:37:27
HD Request # 3 | Received 2 records from 2016-06-03 00:00:00 to 2016-06-06 00:00:00 (4.0 days) and wrote 2 records for GBPCAD | 2016-06-06 10:37:27
HD Request # 3 | Daily download COMPLETE for GBPCAD. Completion time: 7s. Unique request ID: 2 | 2016-06-06 10:37:27
Removed historical data download ID 2 | 2016-06-06 10:37:27
HD Request # 2 | Receiving historical Daily data for ZB.20160900.CME_F starting at 2016-06-03 | 2016-06-06 10:37:27
HD Request # 2 | Writing historical Daily data to the file ZB.20160900.CME_F.dly | 2016-06-06 10:37:27
HD Request # 2 | Received 3 records from 2016-06-03 00:00:00 to 2016-06-06 00:00:00 (4.0 days) and wrote 2 records for ZB.20160900.CME_F | 2016-06-06 10:37:27
HD Request # 2 | Daily download COMPLETE for ZB.20160900.CME_F. Completion time: 7s. Unique request ID: 1 | 2016-06-06 10:37:27
Removed historical data download ID 1 | 2016-06-06 10:37:27
Zb.20160900.CME_F Weekly #16 | Reloading chart. | 2016-06-06 10:37:27
Zb.20160900.CME_F Daily #13 | Reloading chart. | 2016-06-06 10:37:27
HD Request # 4 | Downloading Historical Daily chart data for Zn.20160900.CME_F. Starting date: 2016-06-03. Service: cts | 2016-06-06 10:37:27
HD Request # 4 | Requesting historical Daily data for ZNU16 starting at 2016-06-02 | 2016-06-06 10:37:27
CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2016-06-06 10:37:27
CTS FIX - Firm: Dorman | 2016-06-06 10:37:27
CTS FIX socket (0) | Resolved address fix.t4login.com to IP 208.116.215.102. | 2016-06-06 10:37:27
HD Request # 4 | Receiving historical Daily data for Zn.20160900.CME_F starting at 2016-06-03 | 2016-06-06 10:37:27
HD Request # 4 | Writing historical Daily data to the file Zn.20160900.CME_F.dly | 2016-06-06 10:37:27
HD Request # 4 | Received 3 records from 2016-06-03 00:00:00 to 2016-06-06 00:00:00 (4.0 days) and wrote 2 records for Zn.20160900.CME_F | 2016-06-06 10:37:27
HD Request # 4 | Daily download COMPLETE for Zn.20160900.CME_F. Completion time: 3s. Unique request ID: 3 | 2016-06-06 10:37:27
Removed historical data download ID 3 | 2016-06-06 10:37:27
CTS FIX socket (6) | Connected. | 2016-06-06 10:37:27
CTS FIX socket (6) | Starting TLS 1.0 connection. | 2016-06-06 10:37:27
TN.XCME_F TN (u16).CME_F Daily #2 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 10:37:27
TN.XCME_F TN (u16).CME_F Weekly #4 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 10:37:27
TN.XCME_F TN (u16).CME_F Daily #5 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 10:37:27
TN.XCME_F TN (u16).CME_F Weekly #8 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 10:37:27
ZB.20160900.CME_F Daily #3 | Reloading chart. | 2016-06-06 10:37:27
ZB.20160900.CME_F Weekly #4 | Reloading chart. | 2016-06-06 10:37:27
ZB.20160900.CME_F Daily #8 | Reloading chart. | 2016-06-06 10:37:27
uB.20160900.CME_F 60 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:37:27
ZB.20160900.CME_F Weekly #9 | Reloading chart. | 2016-06-06 10:37:27
Intraday data recording state for symbol ZB.20160600.CME_F is set to download 'Pending'. | 2016-06-06 10:37:27
HD Request # 5 | Downloading Intraday chart data for ZB.20160600.CME_F to the file ZB.20160600.CME_F.scid. Service: cbot | 2016-06-06 10:37:27
HD Request # 5 | Download start Date-Time: 2016-06-06 10:00:06.000 | 2016-06-06 10:37:27
HD Request # 5 | Using server: scdf2.sierracharts.com port 10149 | 2016-06-06 10:37:27
Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133. | 2016-06-06 10:37:27
HD Request # 6 | Downloading Historical Daily chart data for ZB.20160600.CME_F. Starting date: 2016-06-03. Service: cts | 2016-06-06 10:37:27
HD Request # 6 | Requesting historical Daily data for ZBM16 starting at 2016-06-02 | 2016-06-06 10:37:27
ZB.20160900.CME_F Weekly #14 | Reloading chart. | 2016-06-06 10:37:42
Socket (7) | Connected. | 2016-06-06 10:37:42
HD Request # 5 | Sending historical data logon request message. | 2016-06-06 10:37:42
GBPCAD [M] Weekly #7 | Reloading chart. | 2016-06-06 10:37:42
ZB.20160900.CME_F Weekly #2 | Reloading chart. | 2016-06-06 10:37:42
ZB.20160900.CME_F Daily #3 | Reloading chart. | 2016-06-06 10:37:42
ZB.20160900.CME_F Weekly #9 | Reloading chart. | 2016-06-06 10:37:42
ZB.20160900.CME_F 120 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:37:42
Zb.20160900.CME_F Weekly #16 | Reloading chart. | 2016-06-06 10:37:42
ZB.20160900.CME_F 120 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 10:37:42
ZB.20160900.CME_F Daily #6 | Reloading chart. | 2016-06-06 10:37:42
Zb.20160900.CME_F Daily #1 | Reloading chart. | 2016-06-06 10:37:42
HD Request # 5 | Requesting Intraday data. Start Date-Time: 2016-06-06 10:00:06. Record interval: 1. Symbol: ZBM16 | 2016-06-06 10:37:42
Zn.20160900.CME_F Daily #15 | Reloading chart. | 2016-06-06 10:37:42
HD Request # 5 | Decompressing data. | 2016-06-06 10:37:42
HD Request # 5 | Receiving Intraday data for ZB.20160600.CME_F starting at 2016-06-06 10:00:06 | 2016-06-06 10:37:42
HD Request # 5 | Timestamp of first Intraday data file record written: 2016-06-06 10:00:06 | 2016-06-06 10:37:42
Socket (7) | Shutdown and closed. | 2016-06-06 10:37:42
The network socket for historical data has been closed. | 2016-06-06 10:37:42
HD Request # 5 | Historical data for ZB.20160600.CME_F is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-06-06 10:37:42
HD Request # 5 | Received 22 records from 2016-06-06 10:00:06 to 2016-06-06 10:26:13 (26.1 minutes) and wrote 22 records for ZB.20160600.CME_F | 2016-06-06 10:37:42
HD Request # 5 | Intraday download COMPLETE for ZB.20160600.CME_F. Completion time: 0s. Unique request ID: 4 | 2016-06-06 10:37:42
Removed historical data download ID 4 | 2016-06-06 10:37:42
CTS FIX socket (6) | SSL connection established. | 2016-06-06 10:37:42
HD Request # 6 | Receiving historical Daily data for ZB.20160600.CME_F starting at 2016-06-03 | 2016-06-06 10:37:42
HD Request # 6 | Writing historical Daily data to the file ZB.20160600.CME_F.dly | 2016-06-06 10:37:42
HD Request # 6 | Received 3 records from 2016-06-03 00:00:00 to 2016-06-06 00:00:00 (4.0 days) and wrote 2 records for ZB.20160600.CME_F | 2016-06-06 10:37:42
HD Request # 6 | Daily download COMPLETE for ZB.20160600.CME_F. Completion time: 0s. Unique request ID: 5 | 2016-06-06 10:37:42
Removed historical data download ID 5 | 2016-06-06 10:37:42
ZB.20160600.CME_F Daily #3 | Reloading chart. | 2016-06-06 10:37:42
ZB.20160600.CME_F Weekly #4 | Reloading chart. | 2016-06-06 10:37:43
CTS FIX: Sending the Logon message. | 2016-06-06 10:37:43
CTS FIX | FIX version: 4.3.55.2 | 2016-06-06 10:37:45
CTS T4 FIX | Connected to data and trading server. | 2016-06-06 10:37:45
CTS T4 FIX | Starting real-time market data updates for: ZB.20160900.CME_F. ID: 1 | 2016-06-06 10:37:45
CTS T4 FIX | Using primary service for historical data for ZB.20160900.CME_F | 2016-06-06 10:37:45
Intraday data recording state for symbol ZB.20160900.CME_F is set to download 'Pending'. | 2016-06-06 10:37:45
Market data subscription status is not known while delaying historical data download for symbol: ZB.20160900.CME_F | 2016-06-06 10:37:45
Delaying start of download for ZB.20160900.CME_F | 2016-06-06 10:37:45
CTS T4 FIX | Starting real-time market data updates for: UB.20160900.CME_F. ID: 2 | 2016-06-06 10:37:45
CTS T4 FIX | Using primary service for historical data for UB.20160900.CME_F | 2016-06-06 10:37:45
Intraday data recording state for symbol UB.20160900.CME_F is set to download 'Pending'. | 2016-06-06 10:37:45
CTS T4 FIX | Starting real-time market data updates for: TN.XCME_F TN (u16).CME_F. ID: 3 | 2016-06-06 10:37:45
CTS T4 FIX | Using primary service for historical data for TN.XCME_F TN (u16).CME_F | 2016-06-06 10:37:45
Intraday data recording state for symbol TN.XCME_F TN (u16).CME_F is set to download 'Pending'. | 2016-06-06 10:37:45
CTS T4 FIX | Starting real-time market data updates for: ZN.20160900.CME_F. ID: 4 | 2016-06-06 10:37:45
CTS T4 FIX | Using primary service for historical data for ZN.20160900.CME_F | 2016-06-06 10:37:45
Intraday data recording state for symbol ZN.20160900.CME_F is set to download 'Pending'. | 2016-06-06 10:37:45
CTS T4 FIX | Starting real-time market data updates for: uB.20160600.CME_F. ID: 5 | 2016-06-06 10:37:45
CTS T4 FIX | Using primary service for historical data for uB.20160600.CME_F | 2016-06-06 10:37:45
Intraday data recording state for symbol uB.20160600.CME_F is set to download 'Pending'. | 2016-06-06 10:37:45
CTS T4 FIX | Starting real-time market data updates for: ZB.20160600.CME_F. ID: 6 | 2016-06-06 10:37:48
CTS T4 FIX | Sending security definition request for symbol uB.20160600.CME_F | 2016-06-06 10:37:48
Chart #1 has tagged chart #3 for full recalculation. Chartbook: M6 BoB.cht | 2016-06-06 10:37:48
Chart #1 has tagged chart #4 for full recalculation. Chartbook: M6 BoB.cht | 2016-06-06 10:37:48
Chart #1 has tagged chart #6 for full recalculation. Chartbook: M6 BoB.cht | 2016-06-06 10:37:48
CTS FIX: Received Account List collateral report. | 2016-06-06 10:37:48
CTS FIX: Subscribing to account: 45* | 2016-06-06 10:37:48
Using Bid/Ask average for last trade price for GBPCAD | 2016-06-06 10:37:48
SC DTC Data | Starting real-time market data updates for: GBPCAD. ID: 7 | 2016-06-06 10:37:48
SC DTC Data | Connecting to the server ds5.sierracharts.com. Port 443 | 2016-06-06 10:37:48
Subscribing to common currency symbol for profit/loss currency calculations. Symbol: USDCAD | 2016-06-06 10:37:48
Using Bid/Ask average for last trade price for USDCAD | 2016-06-06 10:37:48
SC DTC Data | Starting real-time market data updates for: USDCAD. ID: 8 | 2016-06-06 10:37:48
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-06-06 10:37:48
Intraday data recording state for symbol ZB.20160600.CME_F is set to download 'Pending'. | 2016-06-06 10:37:48
HD Request # 7 | Downloading Intraday chart data for ZB.20160600.CME_F to the file ZB.20160600.CME_F.scid. Service: cbot | 2016-06-06 10:37:48
HD Request # 7 | Download start Date-Time: 2016-06-06 10:26:13.000 | 2016-06-06 10:37:48
HD Request # 7 | Using server: scdf1.sierracharts.com port 10149 | 2016-06-06 10:37:48
Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-06-06 10:37:48
uB.20160600.CME_F 60 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: M6 BoB.cht | 2016-06-06 10:37:48
ZB.20160600.CME_F Daily #3 | Performing a full recalculation because it has been tagged. Chartbook: M6 BoB.cht | 2016-06-06 10:37:48
ZB.20160600.CME_F Weekly #4 | Performing a full recalculation because it has been tagged. Chartbook: M6 BoB.cht | 2016-06-06 10:37:48
Socket (8) | Connected. | 2016-06-06 10:37:48
SC DTC Data | Connected to server. | 2016-06-06 10:37:48
SC DTC Data | Sending Encoding Request to server | 2016-06-06 10:37:48
Supported exchange: CME_HoOp (CME Housing Options) | 2016-06-06 10:37:48
Supported exchange: E_CUR (Eurex Currency Futures) | 2016-06-06 10:37:48
Supported exchange: ICE_CO (ICE US Commodity Futures) | 2016-06-06 10:37:48
Supported exchange: ICE_IN (ICE US Index Futures) | 2016-06-06 10:37:48
Supported exchange: ICE_COOp (ICE US Commodity Options) | 2016-06-06 10:37:48
Supported exchange: CME_COALOp (NYMEX Coal Options) | 2016-06-06 10:37:48
Supported exchange: CME_REF (NYMEX Refined Products Futures) | 2016-06-06 10:37:48
Supported exchange: ICE_WOp (ICE Canada Options) | 2016-06-06 10:37:48
Supported exchange: ICE_ICOp (ICE EU Options) | 2016-06-06 10:37:48
Supported exchange: CME_COOp (COMEX Options) | 2016-06-06 10:37:48
Supported exchange: ICE_IC (ICE EU Futures) | 2016-06-06 10:37:48
Supported exchange: CME_InOp (CME Interest Rate Options) | 2016-06-06 10:37:48
Supported exchange: CME_OOp (MGEX Options) | 2016-06-06 10:37:48
Supported exchange: CME_COp (CBOT Commodity Options) | 2016-06-06 10:37:48
Supported exchange: LME_ME (LME Metal Futures) | 2016-06-06 10:37:48
Supported exchange: E_INXOp (Eurex Index Options) | 2016-06-06 10:37:48
Supported exchange: CME_PETOp (NYMEX NGL/Petrochemicals Options) | 2016-06-06 10:37:48
Supported exchange: CME_Eq (CME Equity Futures) | 2016-06-06 10:37:48
Supported exchange: CME_ELE (NYMEX Power Futures) | 2016-06-06 10:37:48
Supported exchange: E_CUROp (Eurex Currency Options) | 2016-06-06 10:37:48
Supported exchange: CME_COAL (NYMEX Coal Futures) | 2016-06-06 10:37:48
Supported exchange: L_J (Euronext Index Futures) | 2016-06-06 10:37:48
Supported exchange: CME_EOp (CBOT Equity Options) | 2016-06-06 10:37:48
Supported exchange: ICE_MOp (ICE US Metals Options) | 2016-06-06 10:37:48
Supported exchange: L_Y (Euronext Commodity Futures) | 2016-06-06 10:37:48
Supported exchange: CME_EqOp (CME Equity Options) | 2016-06-06 10:37:48
Supported exchange: E_INX (Eurex Index Futures) | 2016-06-06 10:37:48
Supported exchange: CME_FOp (CBOT Financial Options) | 2016-06-06 10:37:48
Supported exchange: E_INT (Eurex Interest Rate Futures) | 2016-06-06 10:37:48
Supported exchange: CME_CLOp (NYMEX CrudeOil Options) | 2016-06-06 10:37:48
Supported exchange: CME_REFOp (NYMEX Refined Products Options) | 2016-06-06 10:37:48
Supported exchange: CME_Ag (CME Agricultural Futures) | 2016-06-06 10:37:48
Supported exchange: ICE_COp (ICE EU Commodity Options) | 2016-06-06 10:37:48
Supported exchange: CME_NG (NYMEX NatGas Futures) | 2016-06-06 10:37:48
Supported exchange: CME_AgOp (CME Agricultural Options) | 2016-06-06 10:37:48
Supported exchange: E_VOL (Eurex Volatility Futures) | 2016-06-06 10:37:48
Supported exchange: E_FBDOp (Eurex Fixed Income Options) | 2016-06-06 10:37:48
Supported exchange: CME_NYOp (NYMEX Options) | 2016-06-06 10:37:48
Supported exchange: CME_NY (NYMEX Futures) | 2016-06-06 10:37:48
Supported exchange: LME_PL (LME Plastic Futures) | 2016-06-06 10:37:48
Supported exchange: LME_IN (LME Index Futures) | 2016-06-06 10:37:48
Supported exchange: CBOE_CFE (CFE) | 2016-06-06 10:37:48
Supported exchange: L_YOp (Euronext Commodity Options) | 2016-06-06 10:37:48
Supported exchange: CME_ELEOp (NYMEX Power Options) | 2016-06-06 10:37:48
Supported exchange: CME_NGOp (NYMEX NatGas Options) | 2016-06-06 10:37:48
Supported exchange: ICE_M (ICE US Metals Futures) | 2016-06-06 10:37:48
Supported exchange: CME_We (CME Weather Futures) | 2016-06-06 10:37:48
Socket (9) | Connected. | 2016-06-06 10:37:49
HD Request # 7 | Sending historical data logon request message. | 2016-06-06 10:37:49
SC DTC Data | Setting DTC Encoding to Binary VLS | 2016-06-06 10:37:49
SC DTC Data | Sending logon request message. | 2016-06-06 10:37:49
HD Request # 7 | Requesting Intraday data. Start Date-Time: 2016-06-06 10:26:13. Record interval: 1. Symbol: ZBM16 | 2016-06-06 10:37:49
Supported exchange: ICE_C (ICE EU Commodity Futures) | 2016-06-06 10:37:49
Supported exchange: ICE_CU (ICE US Currency Futures) | 2016-06-06 10:37:49
Supported exchange: ICE_F (ICE EU Financial Futures) | 2016-06-06 10:37:49
Supported exchange: ICE_FOp (ICE EU Financial Options) | 2016-06-06 10:37:49
Supported exchange: CME_Fo (CME Foreign Exchange Futures) | 2016-06-06 10:37:49
Supported exchange: CME_FRE (NYMEX Freight Futures) | 2016-06-06 10:37:49
Supported exchange: ICE_W (ICE Canada Futures) | 2016-06-06 10:37:49
Supported exchange: ICE_INOp (ICE US Index Options) | 2016-06-06 10:37:49
Supported exchange: CME_Ho (CME Housing Futures) | 2016-06-06 10:37:49
Supported exchange: E_BND (Eurex Fixed Income Futures) | 2016-06-06 10:37:49
Supported exchange: CME_C (CBOT Commodity Futures) | 2016-06-06 10:37:49
Supported exchange: CME_FoOp (CME Foreign Exchange Options) | 2016-06-06 10:37:49
Supported exchange: CME_F (CBOT Financial Futures) | 2016-06-06 10:37:49
Supported exchange: CME_KOp (KCBT Options) | 2016-06-06 10:37:49
Supported exchange: CME_E (CBOT Equity Futures) | 2016-06-06 10:37:49
Supported exchange: CME_CO (COMEX Futures) | 2016-06-06 10:37:49
Supported exchange: CME_K (KCBT Futures) | 2016-06-06 10:37:49
Supported exchange: CME_O (MGEX Futures) | 2016-06-06 10:37:49
Supported exchange: E_FITOp (Eurex Interest Rate Options) | 2016-06-06 10:37:49
Supported exchange: CME_CL (NYMEX CrudeOil Futures) | 2016-06-06 10:37:49
Supported exchange: CME_PET (NYMEX NGL/Petrochemicals Futures) | 2016-06-06 10:37:49
Supported exchange: CME_In (CME Interest Rate Futures) | 2016-06-06 10:37:49
Symbol Error - TN.XCME_F TN (u16).CME_F is unknown, unavailable, or improperly formatted. CTS FIX: Received market data reject: (0) Market is not available | 2016-06-06 10:37:49
Symbol Error - uB.20160600.CME_F is unknown, unavailable, or improperly formatted. Security definition not found | 2016-06-06 10:37:49
CTS T4 FIX | Received 0 security definitions for underlying symbol uB | 2016-06-06 10:37:49
HD Request # 7 | Decompressing data. | 2016-06-06 10:37:49
HD Request # 7 | Receiving Intraday data for ZB.20160600.CME_F starting at 2016-06-06 10:26:13 | 2016-06-06 10:37:49
HD Request # 7 | Timestamp of first Intraday data file record written: 2016-06-06 10:26:13 | 2016-06-06 10:37:49
Socket (9) | Shutdown and closed. | 2016-06-06 10:37:49
The network socket for historical data has been closed. | 2016-06-06 10:37:49
HD Request # 7 | Received 1 record from 2016-06-06 10:26:13 to 2016-06-06 10:26:13 (0.0 seconds) and wrote 1 record for ZB.20160600.CME_F | 2016-06-06 10:37:49
HD Request # 7 | Intraday download COMPLETE for ZB.20160600.CME_F. Completion time: 0s. Unique request ID: 12 | 2016-06-06 10:37:49
Removed historical data download ID 12 | 2016-06-06 10:37:49
Real-time Intraday chart data file updates started for ZB.20160600.CME_F | 2016-06-06 10:37:49
Intraday chart data file opened for ZB.20160600.CME_F | 2016-06-06 10:37:49
CTS T4 FIX | Sending security definition request for symbol UB.20160900.CME_F | 2016-06-06 10:37:49
Market data subscription status is not known while delaying historical data download for symbol: ZB.20160900.CME_F | 2016-06-06 10:37:49
Chart #1 has tagged chart #3 for full recalculation. Chartbook: M6 BoB.cht | 2016-06-06 10:37:49
Chart #1 has tagged chart #4 for full recalculation. Chartbook: M6 BoB.cht | 2016-06-06 10:37:49
Chart #1 has tagged chart #6 for full recalculation. Chartbook: M6 BoB.cht | 2016-06-06 10:37:49
ZB.20160600.CME_F Daily #3 | Performing a full recalculation because it has been tagged. Chartbook: M6 BoB.cht | 2016-06-06 10:37:49
ZB.20160600.CME_F Weekly #4 | Performing a full recalculation because it has been tagged. Chartbook: M6 BoB.cht | 2016-06-06 10:37:49
CTS T4 FIX | Received matching security definition for symbol UB.20160900.CME_F. Subscribing to data. | 2016-06-06 10:37:49
CTS T4 FIX | Received 1 security definitions for underlying symbol UB | 2016-06-06 10:37:49
SC DTC Data | Received logon response. | 2016-06-06 10:37:49
SC DTC Data | Server Name: SC Realtime Server. | 2016-06-06 10:37:49
SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2016-06-06 10:37:49
SC DTC Data | Successfully connected. | 2016-06-06 10:37:49
SC DTC Data | Restarting real-time data updates for symbol: GBPCAD | 2016-06-06 10:37:49
SC DTC Data | Restarting real-time data updates for symbol: USDCAD | 2016-06-06 10:37:49
uB.20160600.CME_F 60 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: M6 BoB.cht | 2016-06-06 10:37:50
CTS FIX: Received 'Account Update/Balance Data' collateral report. | 2016-06-06 10:37:50
Market data subscription status is not known while delaying historical data download for symbol: ZB.20160900.CME_F | 2016-06-06 10:37:50
GBPCAD [M] Weekly #7 | Reloading chart. | 2016-06-06 10:37:50
CTS T4 FIX | Sending security definition request for symbol ZB.20160600.CME_F | 2016-06-06 10:37:50
CTS T4 FIX | Received matching security definition for symbol ZB.20160600.CME_F. Subscribing to data. | 2016-06-06 10:37:51
CTS T4 FIX | Received 1 security definitions for underlying symbol ZB | 2016-06-06 10:37:51
Market data subscription status is not known while delaying historical data download for symbol: ZB.20160900.CME_F | 2016-06-06 10:37:51
CTS T4 FIX | Sending security definition request for symbol ZB.20160900.CME_F | 2016-06-06 10:37:52
Market data subscription status is not known while delaying historical data download for symbol: ZB.20160900.CME_F | 2016-06-06 10:37:52
CTS T4 FIX | Received matching security definition for symbol ZB.20160900.CME_F. Subscribing to data. | 2016-06-06 10:37:52
CTS T4 FIX | Received 1 security definitions for underlying symbol ZB | 2016-06-06 10:37:52
CTS FIX: Requesting Open Orders for account: 45* | 2016-06-06 10:37:53
HD Request # 8 | Downloading Intraday chart data for ZB.20160900.CME_F to the file ZB.20160900.CME_F.scid. Service: cts | 2016-06-06 10:37:53
HD Request # 8 | Download start Date-Time: 2016-06-06 05:31:01.000 | 2016-06-06 10:37:53
CTS FIX Historical Data - Connecting to Historical data server fix-chart.t4login.com:10443 | 2016-06-06 10:37:53
CTS FIX: Received Account List collateral report. | 2016-06-06 10:37:53
CTS FIX Historical Data socket (0) | Resolved address fix-chart.t4login.com to IP 208.116.215.116. | 2016-06-06 10:37:53
CTS T4 FIX | Sending security definition request for symbol ZN.20160900.CME_F | 2016-06-06 10:37:53
CTS FIX Historical Data socket (10) | Connected. | 2016-06-06 10:37:53
CTS FIX Historical Data socket (10) | Starting TLS 1.0 connection. | 2016-06-06 10:37:53
CTS T4 FIX | Received matching security definition for symbol ZN.20160900.CME_F. Subscribing to data. | 2016-06-06 10:37:54
CTS T4 FIX | Received 1 security definitions for underlying symbol ZN | 2016-06-06 10:37:54
CTS FIX Historical Data socket (10) | SSL connection established. | 2016-06-06 10:37:54
CTS FIX Historical Data: Sending the Logon message. | 2016-06-06 10:37:54
Zn.20160900.CME_F Daily #15 | Reloading chart. | 2016-06-06 10:37:54
CTS FIX Historical Data: Connected to Historical data server. | 2016-06-06 10:37:55
HD Request # 8 | Requesting historical Tick data for ZB.20160900.CME_F from 2016-06-06 00:00:00 to 2016-06-06 00:00:00 (US Central Time). | 2016-06-06 10:37:55
ZB.20160900.CME_F Weekly #4 | Reloading chart. | 2016-06-06 10:37:55
ZB.20160900.CME_F Daily #3 | Reloading chart. | 2016-06-06 10:37:55
ZB.20160900.CME_F Daily #8 | Reloading chart. | 2016-06-06 10:37:55
ZB.20160900.CME_F Weekly #9 | Reloading chart. | 2016-06-06 10:37:55
ZB.20160900.CME_F Weekly #14 | Reloading chart. | 2016-06-06 10:37:55
ZB.20160900.CME_F Weekly #2 | Reloading chart. | 2016-06-06 10:37:55
Zb.20160900.CME_F Weekly #16 | Reloading chart. | 2016-06-06 10:37:55
ZB.20160900.CME_F Daily #6 | Reloading chart. | 2016-06-06 10:37:55
Zb.20160900.CME_F Daily #1 | Reloading chart. | 2016-06-06 10:37:55
Zb.20160900.CME_F Daily #13 | Reloading chart. | 2016-06-06 10:37:55
HD Request # 8 | Receiving Intraday data for ZB.20160900.CME_F starting at 2016-06-05 17:00:00 | 2016-06-06 10:37:56
HD Request # 8 | Timestamp of first Intraday data file record written: 2016-06-06 05:31:06 | 2016-06-06 10:37:56
HD Request # 8 | Total records received: 38493 | 2016-06-06 10:37:56
HD Request # 8 | Requesting historical Tick data for ZB.20160900.CME_F from 2016-06-07 00:00:00 to 2016-06-07 00:00:00 (US Central Time). | 2016-06-06 10:37:56
HD Request # 8 | Total records received: 38493 | 2016-06-06 10:37:57
HD Request # 8 | Requesting historical Tick data for ZB.20160900.CME_F from 2016-06-08 00:00:00 to 2016-06-08 00:00:00 (US Central Time). | 2016-06-06 10:37:57
HD Request # 8 | Received 38493 records from 2016-06-05 17:00:00 to 2016-06-06 10:37:56 (17.6 hours) and wrote 26516 records for ZB.20160900.CME_F | 2016-06-06 10:37:57
HD Request # 8 | Intraday download COMPLETE for ZB.20160900.CME_F. Completion time: 4s. Unique request ID: 6 | 2016-06-06 10:37:57
Removed historical data download ID 6 | 2016-06-06 10:37:57
Real-time Intraday chart data file updates started for ZB.20160900.CME_F | 2016-06-06 10:37:57
Intraday chart data file opened for ZB.20160900.CME_F | 2016-06-06 10:37:57
HD Request # 9 | Downloading Intraday chart data for UB.20160900.CME_F to the file UB.20160900.CME_F.scid. Service: cts | 2016-06-06 10:37:57
HD Request # 9 | Download start Date-Time: 2016-06-06 10:00:14.000 | 2016-06-06 10:37:57
HD Request # 9 | Requesting historical Tick data for UB.20160900.CME_F from 2016-06-06 00:00:00 to 2016-06-06 00:00:00 (US Central Time). | 2016-06-06 10:37:57
Chart #1 has tagged chart #3 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:37:57
Chart #1 has tagged chart #4 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:37:57
Chart #1 has tagged chart #6 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:37:57
Chart #8 has tagged chart #10 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 10:37:57
Chart #8 has tagged chart #14 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 10:37:57
Chart #8 has tagged chart #6 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 10:37:57
ZB.20160900.CME_F 120 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 10:37:57
Chart #11 has tagged chart #3 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 10:37:57
Chart #11 has tagged chart #4 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 10:37:57
Chart #11 has tagged chart #9 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 10:37:57
HD Request # 9 | Receiving Intraday data for UB.20160900.CME_F starting at 2016-06-05 17:00:00 | 2016-06-06 10:37:57
HD Request # 9 | Timestamp of first Intraday data file record written: 2016-06-06 10:00:30 | 2016-06-06 10:37:57
HD Request # 9 | Total records received: 16260 | 2016-06-06 10:37:57
HD Request # 9 | Requesting historical Tick data for UB.20160900.CME_F from 2016-06-07 00:00:00 to 2016-06-07 00:00:00 (US Central Time). | 2016-06-06 10:37:57
ZB.20160900.CME_F Weekly #4 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:37:57
ZB.20160900.CME_F 120 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 10:37:57
ZB.20160900.CME_F Daily #3 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:37:57
Chart #8 has tagged chart #10 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:37:58
Chart #8 has tagged chart #14 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:37:58
Chart #8 has tagged chart #6 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:37:58
ZB.20160900.CME_F 120 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:37:58
ZB.20160900.CME_F Weekly #14 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 10:37:58
Chart #5 has tagged chart #10 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:37:58
Chart #5 has tagged chart #8 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:37:58
Chart #5 has tagged chart #9 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:37:58
uB.20160900.CME_F 60 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:37:58
HD Request # 9 | Total records received: 16260 | 2016-06-06 10:37:58
HD Request # 9 | Requesting historical Tick data for UB.20160900.CME_F from 2016-06-08 00:00:00 to 2016-06-08 00:00:00 (US Central Time). | 2016-06-06 10:37:58
Chart #11 has tagged chart #3 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:37:58
Chart #11 has tagged chart #4 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:37:58
Chart #11 has tagged chart #9 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:37:58
uB.20160900.CME_F 60 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:37:58
ZB.20160900.CME_F Daily #3 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:37:58
HD Request # 9 | Received 16260 records from 2016-06-05 17:00:00 to 2016-06-06 10:37:52 (17.6 hours) and wrote 2359 records for UB.20160900.CME_F | 2016-06-06 10:37:58
Added 168 Time and Sales records to Intraday data file for UB.20160900.CME_F after download. | 2016-06-06 10:37:58
HD Request # 9 | Intraday download COMPLETE for UB.20160900.CME_F. Completion time: 1s. Unique request ID: 7 | 2016-06-06 10:37:58
Removed historical data download ID 7 | 2016-06-06 10:37:58
Real-time Intraday chart data file updates started for UB.20160900.CME_F | 2016-06-06 10:37:58
Intraday chart data file opened for UB.20160900.CME_F | 2016-06-06 10:37:58
HD Request # 10 | Downloading Intraday chart data for TN.XCME_F TN (u16).CME_F to the file TN.XCME_F TN (u16).CME_F.scid. Service: cts | 2016-06-06 10:37:58
HD Request # 10 | Download start Date-Time: 2016-05-06 10:37:58.000 | 2016-06-06 10:37:58
HD Request # 10 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-06 00:00:00 to 2016-05-06 00:00:00 (US Central Time). | 2016-06-06 10:37:58
ZB.20160900.CME_F Daily #6 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 10:37:58
ZB.20160900.CME_F Weekly #9 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 10:37:58
ZB.20160900.CME_F Daily #6 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:37:58
ZB.20160900.CME_F Daily #3 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 10:37:58
ZB.20160900.CME_F Weekly #9 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:37:58
ZB.20160900.CME_F Weekly #14 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:37:58
ZB.20160900.CME_F 120 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:37:58
ZB.20160600.CME_F Daily #3 | Reloading chart. | 2016-06-06 10:37:58
ZB.20160600.CME_F Weekly #4 | Reloading chart. | 2016-06-06 10:37:58
HD Request # 10 | Total records received: 0 | 2016-06-06 10:37:58
HD Request # 10 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-07 00:00:00 to 2016-05-07 00:00:00 (US Central Time). | 2016-06-06 10:37:58
ZB.20160900.CME_F Daily #8 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:37:58
ZB.20160900.CME_F Weekly #9 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:37:58
HD Request # 10 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-08 00:00:00 to 2016-05-08 00:00:00 (US Central Time). | 2016-06-06 10:37:58
Chart #7 has tagged chart #5 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:37:58
Chart #2 has tagged chart #1 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:37:59
HD Request # 10 | Total records received: 0 | 2016-06-06 10:37:59
HD Request # 10 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-09 00:00:00 to 2016-05-09 00:00:00 (US Central Time). | 2016-06-06 10:37:59
HD Request # 10 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-10 00:00:00 to 2016-05-10 00:00:00 (US Central Time). | 2016-06-06 10:37:59
HD Request # 10 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-11 00:00:00 to 2016-05-11 00:00:00 (US Central Time). | 2016-06-06 10:37:59
ZB.20160900.CME_F 30 Sec #5 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:37:59
Chart #5 has tagged chart #10 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:37:59
Chart #5 has tagged chart #8 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:37:59
Chart #5 has tagged chart #9 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:37:59
uB.20160900.CME_F 60 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:37:59
ZB.20160900.CME_F 30 Sec #1 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:37:59
Chart #1 has tagged chart #3 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:37:59
Chart #1 has tagged chart #4 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:37:59
Chart #1 has tagged chart #6 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:37:59
HD Request # 10 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-12 00:00:00 to 2016-05-12 00:00:00 (US Central Time). | 2016-06-06 10:37:59
HD Request # 10 | Total records received: 0 | 2016-06-06 10:38:00
HD Request # 10 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-13 00:00:00 to 2016-05-13 00:00:00 (US Central Time). | 2016-06-06 10:38:00
ZB.20160900.CME_F Weekly #4 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:38:00
ZB.20160900.CME_F Daily #3 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:38:00
ZB.20160900.CME_F Daily #8 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:38:00
HD Request # 10 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-14 00:00:00 to 2016-05-14 00:00:00 (US Central Time). | 2016-06-06 10:38:00
ZB.20160900.CME_F Weekly #9 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:38:00
uB.20160900.CME_F 60 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:38:00
HD Request # 10 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-15 00:00:00 to 2016-05-15 00:00:00 (US Central Time). | 2016-06-06 10:38:00
HD Request # 10 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-16 00:00:00 to 2016-05-16 00:00:00 (US Central Time). | 2016-06-06 10:38:00
HD Request # 10 | Total records received: 0 | 2016-06-06 10:38:01
HD Request # 10 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-17 00:00:00 to 2016-05-17 00:00:00 (US Central Time). | 2016-06-06 10:38:01
HD Request # 10 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-18 00:00:00 to 2016-05-18 00:00:00 (US Central Time). | 2016-06-06 10:38:01
HD Request # 10 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-19 00:00:00 to 2016-05-19 00:00:00 (US Central Time). | 2016-06-06 10:38:01
HD Request # 10 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-20 00:00:00 to 2016-05-20 00:00:00 (US Central Time). | 2016-06-06 10:38:01
HD Request # 10 | Total records received: 0 | 2016-06-06 10:38:02
HD Request # 10 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-21 00:00:00 to 2016-05-21 00:00:00 (US Central Time). | 2016-06-06 10:38:02
HD Request # 10 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-22 00:00:00 to 2016-05-22 00:00:00 (US Central Time). | 2016-06-06 10:38:02
HD Request # 10 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-23 00:00:00 to 2016-05-23 00:00:00 (US Central Time). | 2016-06-06 10:38:02
HD Request # 10 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-24 00:00:00 to 2016-05-24 00:00:00 (US Central Time). | 2016-06-06 10:38:02
HD Request # 10 | Total records received: 0 | 2016-06-06 10:38:03
HD Request # 10 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-25 00:00:00 to 2016-05-25 00:00:00 (US Central Time). | 2016-06-06 10:38:03
HD Request # 10 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-26 00:00:00 to 2016-05-26 00:00:00 (US Central Time). | 2016-06-06 10:38:03
HD Request # 10 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-27 00:00:00 to 2016-05-27 00:00:00 (US Central Time). | 2016-06-06 10:38:03
CTS FIX: Received Account List collateral report. | 2016-06-06 10:38:03
HD Request # 10 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-28 00:00:00 to 2016-05-28 00:00:00 (US Central Time). | 2016-06-06 10:38:03
HD Request # 10 | Total records received: 0 | 2016-06-06 10:38:04
HD Request # 10 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-29 00:00:00 to 2016-05-29 00:00:00 (US Central Time). | 2016-06-06 10:38:04
HD Request # 10 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-30 00:00:00 to 2016-05-30 00:00:00 (US Central Time). | 2016-06-06 10:38:04
Opened cached Intraday file: C:\Users\capitaleast\Documents\New folder\SC2\ZB.20160900.CME_F.scid | 2016-06-06 10:38:04
Opened cached Intraday file: C:\Users\capitaleast\Documents\New folder\SC2\UB.20160900.CME_F.scid | 2016-06-06 10:38:04
Opened cached Intraday file: C:\Users\capitaleast\Documents\New folder\SC2\ZB.20160600.CME_F.scid | 2016-06-06 10:38:04
HD Request # 10 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-31 00:00:00 to 2016-05-31 00:00:00 (US Central Time). | 2016-06-06 10:38:04
HD Request # 10 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-06-01 00:00:00 to 2016-06-01 00:00:00 (US Central Time). | 2016-06-06 10:38:04
HD Request # 10 | Total records received: 0 | 2016-06-06 10:38:05
HD Request # 10 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-06-02 00:00:00 to 2016-06-02 00:00:00 (US Central Time). | 2016-06-06 10:38:05
HD Request # 10 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-06-03 00:00:00 to 2016-06-03 00:00:00 (US Central Time). | 2016-06-06 10:38:05
HD Request # 10 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-06-04 00:00:00 to 2016-06-04 00:00:00 (US Central Time). | 2016-06-06 10:38:05
HD Request # 10 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-06-05 00:00:00 to 2016-06-05 00:00:00 (US Central Time). | 2016-06-06 10:38:05
HD Request # 10 | Total records received: 0 | 2016-06-06 10:38:06
HD Request # 10 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-06-06 00:00:00 to 2016-06-06 00:00:00 (US Central Time). | 2016-06-06 10:38:06
HD Request # 10 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-06-07 00:00:00 to 2016-06-07 00:00:00 (US Central Time). | 2016-06-06 10:38:06
HD Request # 10 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-06-08 00:00:00 to 2016-06-08 00:00:00 (US Central Time). | 2016-06-06 10:38:06
HD Request # 10 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TN.XCME_F TN (u16).CME_F | 2016-06-06 10:38:06
HD Request # 10 | Intraday download COMPLETE for TN.XCME_F TN (u16).CME_F. Completion time: 8s. Unique request ID: 8 | 2016-06-06 10:38:06
Removed historical data download ID 8 | 2016-06-06 10:38:06
Real-time Intraday chart data file updates started for TN.XCME_F TN (u16).CME_F | 2016-06-06 10:38:06
Intraday chart data file opened for TN.XCME_F TN (u16).CME_F | 2016-06-06 10:38:06
HD Request # 11 | Downloading Historical Daily chart data for TN.XCME_F TN (u16).CME_F. Starting date: 2016-06-03. Service: cts | 2016-06-06 10:38:06
HD Request # 11 | Requesting historical Daily data for TN.XCME_F TN (u16).CME_F from date 2016-06-03 to date 2016-06-07 | 2016-06-06 10:38:06
HD Request # 11 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TN.XCME_F TN (u16).CME_F | 2016-06-06 10:38:07
HD Request # 11 | Daily download COMPLETE for TN.XCME_F TN (u16).CME_F. Completion time: 0s. Unique request ID: 9 | 2016-06-06 10:38:07
Removed historical data download ID 9 | 2016-06-06 10:38:07
HD Request # 12 | Downloading Intraday chart data for ZN.20160900.CME_F to the file ZN.20160900.CME_F.scid. Service: cts | 2016-06-06 10:38:07
HD Request # 12 | Download start Date-Time: 2016-06-06 10:00:08.000 | 2016-06-06 10:38:07
HD Request # 12 | Requesting historical Tick data for ZN.20160900.CME_F from 2016-06-06 00:00:00 to 2016-06-06 00:00:00 (US Central Time). | 2016-06-06 10:38:07
CTS T4 FIX | Using primary service for historical data for TN.XCME_F TN (u16).CME_F | 2016-06-06 10:38:07
TN.XCME_F TN (u16).CME_F Daily #2 | Reloading chart. | 2016-06-06 10:38:07
TN.XCME_F TN (u16).CME_F Weekly #4 | Reloading chart. | 2016-06-06 10:38:07
TN.XCME_F TN (u16).CME_F Daily #5 | Reloading chart. | 2016-06-06 10:38:07
TN.XCME_F TN (u16).CME_F Weekly #8 | Reloading chart. | 2016-06-06 10:38:07
HD Request # 12 | Receiving Intraday data for ZN.20160900.CME_F starting at 2016-06-05 17:00:00 | 2016-06-06 10:38:08
HD Request # 12 | Timestamp of first Intraday data file record written: 2016-06-06 10:00:23 | 2016-06-06 10:38:08
HD Request # 12 | Total records received: 75756 | 2016-06-06 10:38:08
HD Request # 12 | Requesting historical Tick data for ZN.20160900.CME_F from 2016-06-07 00:00:00 to 2016-06-07 00:00:00 (US Central Time). | 2016-06-06 10:38:08
HD Request # 12 | Requesting historical Tick data for ZN.20160900.CME_F from 2016-06-08 00:00:00 to 2016-06-08 00:00:00 (US Central Time). | 2016-06-06 10:38:08
HD Request # 12 | Received 75756 records from 2016-06-05 17:00:00 to 2016-06-06 10:38:06 (17.6 hours) and wrote 6557 records for ZN.20160900.CME_F | 2016-06-06 10:38:08
Added 5 Time and Sales records to Intraday data file for ZN.20160900.CME_F after download. | 2016-06-06 10:38:08
HD Request # 12 | Intraday download COMPLETE for ZN.20160900.CME_F. Completion time: 2s. Unique request ID: 10 | 2016-06-06 10:38:08
Removed historical data download ID 10 | 2016-06-06 10:38:08
Real-time Intraday chart data file updates started for ZN.20160900.CME_F | 2016-06-06 10:38:08
Intraday chart data file opened for ZN.20160900.CME_F | 2016-06-06 10:38:08
HD Request # 13 | Downloading Intraday chart data for uB.20160600.CME_F to the file uB.20160600.CME_F.scid. Service: cts | 2016-06-06 10:38:08
HD Request # 13 | Download start Date-Time: 2016-06-06 09:55:10.000 | 2016-06-06 10:38:08
HD Request # 13 | Error downloading historical Intraday data for uB.20160600.CME_F. Security definition not found | 2016-06-06 10:38:08
HD Request # 13 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for uB.20160600.CME_F | 2016-06-06 10:38:08
HD Request # 13 | Intraday download COMPLETE for uB.20160600.CME_F. Completion time: 0s. Unique request ID: 11 | 2016-06-06 10:38:08
Removed historical data download ID 11 | 2016-06-06 10:38:08
Real-time Intraday chart data file updates started for uB.20160600.CME_F | 2016-06-06 10:38:08
Intraday chart data file opened for uB.20160600.CME_F | 2016-06-06 10:38:08
Chart #3 has tagged chart #2 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 10:38:09
Chart #3 has tagged chart #4 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 10:38:09
TN.XCME_F TN (u16).CME_F Weekly #4 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 10:38:09
Chart #12 has tagged chart #11 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 10:38:09
Chart #5 has tagged chart #8 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 10:38:09
Chart #5 has tagged chart #8 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:38:09
ZB.20160900.CME_F 30 Sec #8 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:38:09
Chart #8 has tagged chart #10 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:38:09
Chart #8 has tagged chart #14 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:38:09
Chart #8 has tagged chart #6 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:38:09
ZB.20160900.CME_F 120 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:38:09
Chart #7 has tagged chart #5 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 10:38:09
Chart #7 has tagged chart #8 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 10:38:09
Chart #2 has tagged chart #1 for full recalculation. Chartbook: M6 BoB.cht | 2016-06-06 10:38:09
TN.XCME_F TN (u16).CME_F Weekly #8 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 10:38:09
Chart #12 has tagged chart #11 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:38:09
ZB.20160900.CME_F Daily #6 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:38:09
ZB.20160900.CME_F Weekly #14 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:38:09
TN.XCME_F TN (u16).CME_F Daily #2 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 10:38:09
ZB.20160900.CME_F 30 Sec #8 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 10:38:09
Chart #8 has tagged chart #10 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 10:38:09
Chart #8 has tagged chart #14 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 10:38:09
Chart #8 has tagged chart #6 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 10:38:09
ZB.20160900.CME_F 120 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 10:38:09
ZB.20160600.CME_F 30 Sec #1 | Performing a full recalculation because it has been tagged. Chartbook: M6 BoB.cht | 2016-06-06 10:38:09
Chart #1 has tagged chart #3 for full recalculation. Chartbook: M6 BoB.cht | 2016-06-06 10:38:09
Chart #1 has tagged chart #4 for full recalculation. Chartbook: M6 BoB.cht | 2016-06-06 10:38:09
Chart #1 has tagged chart #6 for full recalculation. Chartbook: M6 BoB.cht | 2016-06-06 10:38:09
ZB.20160900.CME_F 30 Sec #11 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 10:38:09
Chart #11 has tagged chart #3 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 10:38:09
Chart #11 has tagged chart #4 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 10:38:09
Chart #11 has tagged chart #9 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 10:38:09
ZB.20160600.CME_F Daily #3 | Performing a full recalculation because it has been tagged. Chartbook: M6 BoB.cht | 2016-06-06 10:38:10
ZB.20160600.CME_F Weekly #4 | Performing a full recalculation because it has been tagged. Chartbook: M6 BoB.cht | 2016-06-06 10:38:10
ZB.20160900.CME_F 120 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 10:38:10
TN.XCME_F TN (u16).CME_F Daily #5 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 10:38:10
ZB.20160900.CME_F Weekly #14 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 10:38:10
ZB.20160900.CME_F 30 Sec #11 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:38:10
Chart #11 has tagged chart #3 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:38:10
Chart #11 has tagged chart #4 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:38:10
Chart #11 has tagged chart #9 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:38:10
ZB.20160900.CME_F Daily #3 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:38:10
ZB.20160900.CME_F Daily #6 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 10:38:10
ZB.20160900.CME_F Weekly #9 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 10:38:10
ZB.20160900.CME_F Daily #3 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 10:38:10
ZB.20160900.CME_F Weekly #9 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:38:10
uB.20160600.CME_F 60 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: M6 BoB.cht | 2016-06-06 10:38:10
ZB.20160900.CME_F 120 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 10:38:10
CTS T4 FIX | Using primary service for historical data for ZN.20160900.CME_F | 2016-06-06 10:38:44
ZN.20160900.CME_F 30 Sec #11 | Reloading chart. | 2016-06-06 10:38:44
HTTP connection to ds01.ddfplus.com:80 (4) | Closed. No error. | 2016-06-06 10:38:47
HTTP connection to ds01.ddfplus.com:80 (4) | Shutdown and closed. | 2016-06-06 10:38:47
CTS T4 FIX | Querying for all symbols for TN.~.CME_F. | 2016-06-06 10:38:58
CTS T4 FIX | Received 10 security definitions for symbols request. | 2016-06-06 10:38:59
Opened cached Intraday file: C:\Users\capitaleast\Documents\New folder\SC2\ZN.20160900.CME_F.scid | 2016-06-06 10:39:04
CTS T4 FIX | Using primary service for historical data for TN.XCME_F TN (U16).CME_F | 2016-06-06 10:39:07
TN.XCME_F TN (U16).CME_F 30 Sec #11 | Reloading chart. | 2016-06-06 10:39:07
TN.XCME_F TN (U16).CME_F 30 Sec #11 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Users\capitaleast\Documents\New folder\SC2\TN.XCME_F TN (U16).CME_F.scid | 2016-06-06 10:39:07
CTS FIX Historical Data socket (10) | Closed. No error. | 2016-06-06 10:39:08
CTS FIX Historical Data socket (10) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-06 10:39:08
CTS FIX Historical Data socket (10) | SSL has been shut down. | 2016-06-06 10:39:08
CTS FIX Historical Data socket (10) | SSL object has been freed. SSL state is now disconnected. | 2016-06-06 10:39:08
CTS FIX Historical Data socket (10) | Shutdown and closed. | 2016-06-06 10:39:08
CTS FIX Historical Data: Socket connection was closed without any logout messages sent or received. | 2016-06-06 10:39:08
CTS FIX Historical Data: Disconnected. | 2016-06-06 10:39:08
CTS T4 FIX | Using primary service for historical data for TN.XCME_F TN (U16).CME_F | 2016-06-06 10:39:21
TN.XCME_F TN (U16).CME_F 30 Sec #11 | Reloading chart. | 2016-06-06 10:39:21
TN.XCME_F TN (U16).CME_F 30 Sec #11 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Users\capitaleast\Documents\New folder\SC2\TN.XCME_F TN (U16).CME_F.scid | 2016-06-06 10:39:21
Chart #3 has tagged chart #2 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 10:39:32
Chart #3 has tagged chart #4 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 10:39:32
TN.XCME_F TN (u16).CME_F Daily #2 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 10:39:32
TN.XCME_F TN (u16).CME_F Weekly #4 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 10:39:32
CTS T4 FIX | Using primary service for historical data for uB.20160900.CME_F | 2016-06-06 10:49:55
uB.20160900.CME_F 60 Min #10 | Reloading chart. | 2016-06-06 10:49:55
CTS T4 FIX | Using primary service for historical data for UB.20160900.CME_F | 2016-06-06 10:50:12
UB.20160900.CME_F 30 Sec #2 | Reloading chart. | 2016-06-06 10:50:12
Chart #2 has tagged chart #1 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:50:12
ZB.20160900.CME_F 30 Sec #1 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:50:12
UB.20160900.CME_F 30 Sec #2 | Chart Settings have been synchronized between Destination chart number #1 and Source data chart number #2. Performing a chart reload of source data chart. | 2016-06-06 10:50:12
Chart #1 has tagged chart #3 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:50:12
Chart #1 has tagged chart #4 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:50:12
Chart #1 has tagged chart #6 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:50:12
ZB.20160900.CME_F Weekly #4 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:50:13
ZB.20160900.CME_F Daily #3 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:50:13
uB.20160900.CME_F 60 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:50:13
CTS T4 FIX | Using primary service for historical data for UB.20160900.CME_F | 2016-06-06 10:50:13
UB.20160900.CME_F 30 Sec #2 | Reloading chart. | 2016-06-06 10:50:13
Chart #2 has tagged chart #1 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:50:13
ZB.20160900.CME_F 30 Sec #1 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:50:13
UB.20160900.CME_F 30 Sec #2 | Chart Settings have been synchronized between Destination chart number #1 and Source data chart number #2. Performing a chart reload of source data chart. | 2016-06-06 10:50:13
Chart #1 has tagged chart #3 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:50:13
Chart #1 has tagged chart #4 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:50:13
Chart #1 has tagged chart #6 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:50:13
ZB.20160900.CME_F Weekly #4 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:50:14
ZB.20160900.CME_F Daily #3 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:50:14
uB.20160900.CME_F 60 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:50:14
ZB.20160900.CME_F 30 Sec #1 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:50:14
Chart #1 has tagged chart #3 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:50:14
Chart #1 has tagged chart #4 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:50:14
Chart #1 has tagged chart #6 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:50:14
uB.20160900.CME_F 60 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:50:15
CTS T4 FIX | Using primary service for historical data for ZB.20160900.CME_F | 2016-06-06 10:50:19
ZB.20160900.CME_F 30 Sec #1 | Reloading chart. | 2016-06-06 10:50:19
Chart #1 has tagged chart #3 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:50:19
Chart #1 has tagged chart #4 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:50:19
Chart #1 has tagged chart #6 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:50:19
ZB.20160900.CME_F Weekly #4 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:50:19
ZB.20160900.CME_F Daily #3 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:50:19
uB.20160900.CME_F 60 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:50:19
Chart #1 has tagged chart #3 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:50:22
Chart #1 has tagged chart #4 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:50:22
Chart #1 has tagged chart #6 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:50:22
ZB.20160900.CME_F Weekly #4 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:50:22
ZB.20160900.CME_F Daily #3 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:50:23
uB.20160900.CME_F 60 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:50:23
CTS T4 FIX | Using primary service for historical data for UB.20160900.CME_F | 2016-06-06 10:50:28
UB.20160900.CME_F 30 Sec #2 | Reloading chart. | 2016-06-06 10:50:28
Chart #2 has tagged chart #1 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:50:28
ZB.20160900.CME_F 30 Sec #1 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:50:28
Chart #1 has tagged chart #3 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:50:28
Chart #1 has tagged chart #4 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:50:28
Chart #1 has tagged chart #6 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:50:28
ZB.20160900.CME_F Weekly #4 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:50:29
ZB.20160900.CME_F Daily #3 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:50:29
uB.20160900.CME_F 60 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:50:29
Chart #2 has tagged chart #1 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:50:31
ZB.20160900.CME_F 30 Sec #1 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:50:32
Chart #1 has tagged chart #3 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:50:32
Chart #1 has tagged chart #4 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:50:32
Chart #1 has tagged chart #6 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:50:32
ZB.20160900.CME_F Weekly #4 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:50:32
ZB.20160900.CME_F Daily #3 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:50:32
uB.20160900.CME_F 60 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:50:32
Chart #1 has tagged chart #3 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:50:37
Chart #1 has tagged chart #4 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:50:37
Chart #1 has tagged chart #6 for full recalculation. Chartbook: BoB.cht | 2016-06-06 10:50:37
ZB.20160900.CME_F Weekly #4 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:50:37
ZB.20160900.CME_F Daily #3 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:50:37
uB.20160900.CME_F 60 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 10:50:37
CTS T4 FIX | Using primary service for historical data for uB.20160900.CME_F | 2016-06-06 10:50:46
uB.20160900.CME_F 60 Min #10 | Reloading chart. | 2016-06-06 10:50:46
CTS T4 FIX | Using primary service for historical data for uB.20160900.CME_F | 2016-06-06 10:51:20
uB.20160900.CME_F 120 Min #10 | Reloading chart. | 2016-06-06 10:51:20
CTS T4 FIX | Using primary service for historical data for uB.20160900.CME_F | 2016-06-06 10:51:24
uB.20160900.CME_F 60 Min #10 | Reloading chart. | 2016-06-06 10:51:24
Chart #1 has tagged chart #3 for full recalculation. Chartbook: M6 BoB.cht | 2016-06-06 10:52:46
Chart #1 has tagged chart #4 for full recalculation. Chartbook: M6 BoB.cht | 2016-06-06 10:52:46
Chart #1 has tagged chart #6 for full recalculation. Chartbook: M6 BoB.cht | 2016-06-06 10:52:46
uB.20160600.CME_F 60 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: M6 BoB.cht | 2016-06-06 10:52:46
ZB.20160600.CME_F Daily #3 | Performing a full recalculation because it has been tagged. Chartbook: M6 BoB.cht | 2016-06-06 10:52:46
ZB.20160600.CME_F Weekly #4 | Performing a full recalculation because it has been tagged. Chartbook: M6 BoB.cht | 2016-06-06 10:52:46
CTS T4 FIX | Querying for all symbols for TN.~.CME_F. | 2016-06-06 11:07:05
CTS T4 FIX | Received 10 security definitions for symbols request. | 2016-06-06 11:07:05
CTS T4 FIX | Using primary service for historical data for TN.XCME_F TN (U16).CME_F | 2016-06-06 11:07:15
TN.XCME_F TN (U16).CME_F Daily #11 | Reloading chart. | 2016-06-06 11:07:15
CTS T4 FIX | Using primary service for historical data for TN.XCME_F TN (U16).CME_F | 2016-06-06 11:07:23
TN.XCME_F TN (U16).CME_F 1 Min #12 | Reloading chart. | 2016-06-06 11:07:23
TN.XCME_F TN (U16).CME_F 1 Min #12 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Users\capitaleast\Documents\New folder\SC2\TN.XCME_F TN (U16).CME_F.scid | 2016-06-06 11:07:23
CTS T4 FIX | Using primary service for historical data for TN.XCME_F TN (U16).CME_F | 2016-06-06 11:07:53
TN.XCME_F TN (U16).CME_F 60 Min #11 | Reloading chart. | 2016-06-06 11:07:53
TN.XCME_F TN (U16).CME_F 60 Min #11 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Users\capitaleast\Documents\New folder\SC2\TN.XCME_F TN (U16).CME_F.scid | 2016-06-06 11:07:53
CTS T4 FIX | Using primary service for historical data for TN.XCME_F TN (U16).CME_F | 2016-06-06 11:08:07
Intraday data recording state for symbol TN.XCME_F TN (U16).CME_F is set to download 'Pending'. | 2016-06-06 11:08:07
Reloading all charts with filename: TN.XCME_F TN (U16).CME_F.scid | 2016-06-06 11:08:07
HD Request # 14 | Downloading Intraday chart data for TN.XCME_F TN (U16).CME_F to the file TN.XCME_F TN (U16).CME_F.scid. Service: cts | 2016-06-06 11:08:07
HD Request # 14 | Download start Date-Time: 2016-05-06 11:08:07.000 | 2016-06-06 11:08:07
CTS FIX Historical Data - Connecting to Historical data server fix-chart.t4login.com:10443 | 2016-06-06 11:08:07
CTS FIX Historical Data socket (0) | Resolved address fix-chart.t4login.com to IP 208.116.215.116. | 2016-06-06 11:08:07
CTS FIX Historical Data socket (26) | Connected. | 2016-06-06 11:08:08
CTS FIX Historical Data socket (26) | Starting TLS 1.0 connection. | 2016-06-06 11:08:08
CTS T4 FIX | Using primary service for historical data for TN.XCME_F TN (U16).CME_F | 2016-06-06 11:08:08
TN.XCME_F TN (U16).CME_F 30 Sec #11 | Reloading chart. | 2016-06-06 11:08:08
TN.XCME_F TN (U16).CME_F 30 Sec #11 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Users\capitaleast\Documents\New folder\SC2\TN.XCME_F TN (U16).CME_F.scid | 2016-06-06 11:08:08
TN.XCME_F TN (U16).CME_F 30 Sec #6 | Reloading chart. | 2016-06-06 11:08:08
TN.XCME_F TN (U16).CME_F 30 Sec #6 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Users\capitaleast\Documents\New folder\SC2\TN.XCME_F TN (U16).CME_F.scid | 2016-06-06 11:08:08
CTS T4 FIX | Using primary service for historical data for TN.XCME_F TN (u16).CME_F | 2016-06-06 11:08:08
TN.XCME_F TN (u16).CME_F 120 Min #9 | Reloading chart. | 2016-06-06 11:08:08
TN.XCME_F TN (u16).CME_F 120 Min #9 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Users\capitaleast\Documents\New folder\SC2\TN.XCME_F TN (u16).CME_F.scid | 2016-06-06 11:08:08
TN.XCME_F TN (u16).CME_F 30 Sec #1 | Reloading chart. | 2016-06-06 11:08:08
TN.XCME_F TN (u16).CME_F 30 Sec #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Users\capitaleast\Documents\New folder\SC2\TN.XCME_F TN (u16).CME_F.scid | 2016-06-06 11:08:08
TN.XCME_F TN (u16).CME_F 120 Min #10 | Reloading chart. | 2016-06-06 11:08:08
TN.XCME_F TN (U16).CME_F 60 Min #11 | Reloading chart. | 2016-06-06 11:08:08
TN.XCME_F TN (u16).CME_F 120 Min #10 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Users\capitaleast\Documents\New folder\SC2\TN.XCME_F TN (u16).CME_F.scid | 2016-06-06 11:08:08
TN.XCME_F TN (U16).CME_F 60 Min #11 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Users\capitaleast\Documents\New folder\SC2\TN.XCME_F TN (U16).CME_F.scid | 2016-06-06 11:08:08
CTS FIX Historical Data socket (26) | SSL connection established. | 2016-06-06 11:08:08
CTS FIX Historical Data: Sending the Logon message. | 2016-06-06 11:08:08
CTS FIX Historical Data: Connected to Historical data server. | 2016-06-06 11:08:09
HD Request # 14 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-06 00:00:00 to 2016-05-06 00:00:00 (US Central Time). | 2016-06-06 11:08:09
HD Request # 14 | Total records received: 0 | 2016-06-06 11:08:09
HD Request # 14 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-07 00:00:00 to 2016-05-07 00:00:00 (US Central Time). | 2016-06-06 11:08:09
HD Request # 14 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-08 00:00:00 to 2016-05-08 00:00:00 (US Central Time). | 2016-06-06 11:08:09
HD Request # 14 | Total records received: 0 | 2016-06-06 11:08:10
HD Request # 14 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-09 00:00:00 to 2016-05-09 00:00:00 (US Central Time). | 2016-06-06 11:08:10
HD Request # 14 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-10 00:00:00 to 2016-05-10 00:00:00 (US Central Time). | 2016-06-06 11:08:10
HD Request # 14 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-11 00:00:00 to 2016-05-11 00:00:00 (US Central Time). | 2016-06-06 11:08:10
HD Request # 14 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-12 00:00:00 to 2016-05-12 00:00:00 (US Central Time). | 2016-06-06 11:08:10
HD Request # 14 | Total records received: 0 | 2016-06-06 11:08:11
HD Request # 14 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-13 00:00:00 to 2016-05-13 00:00:00 (US Central Time). | 2016-06-06 11:08:11
HD Request # 14 | Receiving Intraday data for TN.XCME_F TN (U16).CME_F starting at 2016-05-13 14:56:29 | 2016-06-06 11:08:11
HD Request # 14 | Timestamp of first Intraday data file record written: 2016-05-13 14:56:29 | 2016-06-06 11:08:11
HD Request # 14 | Total records received: 2 | 2016-06-06 11:08:11
HD Request # 14 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-14 00:00:00 to 2016-05-14 00:00:00 (US Central Time). | 2016-06-06 11:08:11
HD Request # 14 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-15 00:00:00 to 2016-05-15 00:00:00 (US Central Time). | 2016-06-06 11:08:11
HD Request # 14 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-16 00:00:00 to 2016-05-16 00:00:00 (US Central Time). | 2016-06-06 11:08:11
HD Request # 14 | Total records received: 2 | 2016-06-06 11:08:12
HD Request # 14 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-17 00:00:00 to 2016-05-17 00:00:00 (US Central Time). | 2016-06-06 11:08:12
HD Request # 14 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-18 00:00:00 to 2016-05-18 00:00:00 (US Central Time). | 2016-06-06 11:08:12
HD Request # 14 | Total records received: 100 | 2016-06-06 11:08:12
HD Request # 14 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-19 00:00:00 to 2016-05-19 00:00:00 (US Central Time). | 2016-06-06 11:08:12
HD Request # 14 | Total records received: 241 | 2016-06-06 11:08:12
HD Request # 14 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-20 00:00:00 to 2016-05-20 00:00:00 (US Central Time). | 2016-06-06 11:08:12
HD Request # 14 | Total records received: 287 | 2016-06-06 11:08:13
HD Request # 14 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-21 00:00:00 to 2016-05-21 00:00:00 (US Central Time). | 2016-06-06 11:08:13
HD Request # 14 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-22 00:00:00 to 2016-05-22 00:00:00 (US Central Time). | 2016-06-06 11:08:13
HD Request # 14 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-23 00:00:00 to 2016-05-23 00:00:00 (US Central Time). | 2016-06-06 11:08:13
HD Request # 14 | Total records received: 464 | 2016-06-06 11:08:13
HD Request # 14 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-24 00:00:00 to 2016-05-24 00:00:00 (US Central Time). | 2016-06-06 11:08:13
HD Request # 14 | Total records received: 1397 | 2016-06-06 11:08:14
HD Request # 14 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-25 00:00:00 to 2016-05-25 00:00:00 (US Central Time). | 2016-06-06 11:08:14
HD Request # 14 | Total records received: 2978 | 2016-06-06 11:08:14
HD Request # 14 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-26 00:00:00 to 2016-05-26 00:00:00 (US Central Time). | 2016-06-06 11:08:14
HD Request # 14 | Total records received: 7569 | 2016-06-06 11:08:14
HD Request # 14 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-27 00:00:00 to 2016-05-27 00:00:00 (US Central Time). | 2016-06-06 11:08:14
HD Request # 14 | Total records received: 11419 | 2016-06-06 11:08:14
HD Request # 14 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-28 00:00:00 to 2016-05-28 00:00:00 (US Central Time). | 2016-06-06 11:08:14
HD Request # 14 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-29 00:00:00 to 2016-05-29 00:00:00 (US Central Time). | 2016-06-06 11:08:14
HD Request # 14 | Total records received: 11419 | 2016-06-06 11:08:15
HD Request # 14 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-30 00:00:00 to 2016-05-30 00:00:00 (US Central Time). | 2016-06-06 11:08:15
HD Request # 14 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-31 00:00:00 to 2016-05-31 00:00:00 (US Central Time). | 2016-06-06 11:08:15
HD Request # 14 | Total records received: 28199 | 2016-06-06 11:08:16
HD Request # 14 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-06-01 00:00:00 to 2016-06-01 00:00:00 (US Central Time). | 2016-06-06 11:08:16
HD Request # 14 | Total records received: 46545 | 2016-06-06 11:08:16
HD Request # 14 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-06-02 00:00:00 to 2016-06-02 00:00:00 (US Central Time). | 2016-06-06 11:08:16
HD Request # 14 | Total records received: 61700 | 2016-06-06 11:08:17
HD Request # 14 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-06-03 00:00:00 to 2016-06-03 00:00:00 (US Central Time). | 2016-06-06 11:08:17
Chart #6 has tagged chart #7 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:08:17
Chart #1 has tagged chart #11 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:08:17
Chart #1 has tagged chart #3 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:08:17
HD Request # 14 | Total records received: 83732 | 2016-06-06 11:08:17
HD Request # 14 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-06-04 00:00:00 to 2016-06-04 00:00:00 (US Central Time). | 2016-06-06 11:08:17
HD Request # 14 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-06-05 00:00:00 to 2016-06-05 00:00:00 (US Central Time). | 2016-06-06 11:08:17
ZN.20160900.CME_F 30 Sec #7 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:08:17
Chart #7 has tagged chart #10 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:08:17
Chart #7 has tagged chart #5 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:08:17
Chart #7 has tagged chart #8 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:08:17
ZN.20160900.CME_F 30 Sec #3 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:08:17
Chart #3 has tagged chart #2 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:08:17
Chart #3 has tagged chart #4 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:08:17
Chart #3 has tagged chart #9 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:08:17
TN.XCME_F TN (u16).CME_F Weekly #4 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:08:17
TN.XCME_F TN (U16).CME_F 30 Sec #11 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:08:17
HD Request # 14 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-06-06 00:00:00 to 2016-06-06 00:00:00 (US Central Time). | 2016-06-06 11:08:17
TN.XCME_F TN (u16).CME_F 120 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:08:18
TN.XCME_F TN (u16).CME_F 120 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:08:18
HD Request # 14 | Total records received: 92294 | 2016-06-06 11:08:18
HD Request # 14 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-06-07 00:00:00 to 2016-06-07 00:00:00 (US Central Time). | 2016-06-06 11:08:18
TN.XCME_F TN (u16).CME_F Weekly #8 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:08:18
TN.XCME_F TN (u16).CME_F Daily #5 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:08:18
TN.XCME_F TN (u16).CME_F Daily #2 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:08:18
HD Request # 14 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-06-08 00:00:00 to 2016-06-08 00:00:00 (US Central Time). | 2016-06-06 11:08:18
HD Request # 14 | Received 92294 records from 2016-05-13 14:56:29 to 2016-06-06 11:08:14 (23.8 days) and wrote 92294 records for TN.XCME_F TN (U16).CME_F | 2016-06-06 11:08:19
HD Request # 14 | Intraday download COMPLETE for TN.XCME_F TN (U16).CME_F. Completion time: 11s. Unique request ID: 13 | 2016-06-06 11:08:19
Removed historical data download ID 13 | 2016-06-06 11:08:19
Real-time Intraday chart data file updates started for TN.XCME_F TN (u16).CME_F | 2016-06-06 11:08:19
Intraday chart data file opened for TN.XCME_F TN (u16).CME_F | 2016-06-06 11:08:19
Chart #6 has tagged chart #7 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:08:19
Chart #1 has tagged chart #11 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:08:19
Chart #1 has tagged chart #3 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:08:19
ZN.20160900.CME_F 30 Sec #7 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:08:20
Chart #7 has tagged chart #10 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:08:20
Chart #7 has tagged chart #5 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:08:20
Chart #7 has tagged chart #8 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:08:20
ZN.20160900.CME_F 30 Sec #3 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:08:20
Chart #3 has tagged chart #2 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:08:20
Chart #3 has tagged chart #4 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:08:20
Chart #3 has tagged chart #9 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:08:20
TN.XCME_F TN (u16).CME_F Weekly #4 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:08:20
TN.XCME_F TN (U16).CME_F 30 Sec #11 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:08:20
TN.XCME_F TN (u16).CME_F 120 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:08:20
TN.XCME_F TN (u16).CME_F 120 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:08:20
TN.XCME_F TN (u16).CME_F Weekly #8 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:08:21
TN.XCME_F TN (u16).CME_F Daily #5 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:08:21
TN.XCME_F TN (u16).CME_F Daily #2 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:08:21
CTS T4 FIX | Using primary service for historical data for TN.XCME_F TN (U16).CME_F | 2016-06-06 11:09:03
TN.XCME_F TN (U16).CME_F 60 Min #11 | Reloading chart. | 2016-06-06 11:09:03
CTS T4 FIX | Using primary service for historical data for TN.XCME_F TN (U16).CME_F | 2016-06-06 11:09:11
TN.XCME_F TN (U16).CME_F 60 Min #11 | Reloading chart. | 2016-06-06 11:09:11
CTS FIX Historical Data socket (26) | Closed. No error. | 2016-06-06 11:09:19
CTS FIX Historical Data socket (26) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-06 11:09:19
CTS FIX Historical Data socket (26) | SSL has been shut down. | 2016-06-06 11:09:19
CTS FIX Historical Data socket (26) | SSL object has been freed. SSL state is now disconnected. | 2016-06-06 11:09:19
CTS FIX Historical Data socket (26) | Shutdown and closed. | 2016-06-06 11:09:19
CTS FIX Historical Data: Socket connection was closed without any logout messages sent or received. | 2016-06-06 11:09:19
CTS FIX Historical Data: Disconnected. | 2016-06-06 11:09:19
CTS T4 FIX | Using primary service for historical data for TN.XCME_F TN (U16).CME_F | 2016-06-06 11:09:23
TN.XCME_F TN (U16).CME_F 60 Min #11 | Reloading chart. | 2016-06-06 11:09:23
CTS T4 FIX | Using primary service for historical data for TN.XCME_F TN (U16).CME_F | 2016-06-06 11:09:56
TN.XCME_F TN (U16).CME_F 30 Sec #11 | Reloading chart. | 2016-06-06 11:09:56
Chart #1 has tagged chart #11 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:10:13
Chart #1 has tagged chart #3 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:10:13
ZN.20160900.CME_F 30 Sec #3 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:10:13
Chart #3 has tagged chart #2 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:10:13
Chart #3 has tagged chart #4 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:10:13
Chart #3 has tagged chart #9 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:10:13
TN.XCME_F TN (u16).CME_F Weekly #4 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:10:13
TN.XCME_F TN (u16).CME_F 120 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:10:13
TN.XCME_F TN (U16).CME_F 30 Sec #11 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:10:14
TN.XCME_F TN (u16).CME_F Daily #2 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:10:14
Chart #1 has tagged chart #11 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:10:14
Chart #1 has tagged chart #3 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:10:14
ZN.20160900.CME_F 30 Sec #3 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:10:14
Chart #3 has tagged chart #2 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:10:14
Chart #3 has tagged chart #4 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:10:14
Chart #3 has tagged chart #9 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:10:14
TN.XCME_F TN (u16).CME_F Weekly #4 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:10:14
TN.XCME_F TN (u16).CME_F 120 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:10:15
TN.XCME_F TN (u16).CME_F Daily #2 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 11:10:15
CTS T4 FIX | Using primary service for historical data for TN.XCME_F TN (U16).CME_F-baavg | 2016-06-06 11:12:31
TN.XCME_F TN (U16).CME_F-baavg 30 Sec #11 | Reloading chart. | 2016-06-06 11:12:31
TN.XCME_F TN (U16).CME_F-baavg 30 Sec #11 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Users\capitaleast\Documents\New folder\SC2\TN.XCME_F TN (U16).CME_F-baavg.scid | 2016-06-06 11:12:31
Starting updates for: TN.XCME_F TN (U16).CME_F-baavg | 2016-06-06 11:12:32
CTS T4 FIX | Using primary service for historical data for TN.XCME_F TN (U16).CME_F | 2016-06-06 11:12:32
Intraday data recording state for symbol TN.XCME_F TN (U16).CME_F-baavg is set to download 'Pending'. | 2016-06-06 11:12:32
Delaying start of download for TN.XCME_F TN (U16).CME_F-baavg | 2016-06-06 11:12:32
CTS T4 FIX | Using primary service for historical data for TN.XCME_F TN (U16).CME_F-baavg | 2016-06-06 11:12:36
TN.XCME_F TN (U16).CME_F-baavg 30 Sec #11 | Reloading chart. | 2016-06-06 11:12:36
TN.XCME_F TN (U16).CME_F-baavg 30 Sec #11 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Users\capitaleast\Documents\New folder\SC2\TN.XCME_F TN (U16).CME_F-baavg.scid | 2016-06-06 11:12:36
HD Request # 15 | Downloading Intraday chart data for TN.XCME_F TN (U16).CME_F-baavg to the file TN.XCME_F TN (U16).CME_F-baavg.scid. Service: cts | 2016-06-06 11:12:42
Compressing file: C:\Users\capitaleast\Documents\New folder\SC2\TN.XCME_F TN (U16).CME_F-baavg.scid. This may take a while. | 2016-06-06 11:12:42
HD Request # 15 | Download start Date-Time: 2016-05-06 11:12:42.000 | 2016-06-06 11:12:42
CTS FIX Historical Data - Connecting to Historical data server fix-chart.t4login.com:10443 | 2016-06-06 11:12:42
CTS FIX Historical Data socket (0) | Resolved address fix-chart.t4login.com to IP 208.116.215.116. | 2016-06-06 11:12:42
CTS FIX Historical Data socket (29) | Connected. | 2016-06-06 11:12:42
CTS FIX Historical Data socket (29) | Starting TLS 1.0 connection. | 2016-06-06 11:12:42
CTS FIX Historical Data socket (29) | SSL connection established. | 2016-06-06 11:12:43
CTS FIX Historical Data: Sending the Logon message. | 2016-06-06 11:12:43
CTS FIX Historical Data: Connected to Historical data server. | 2016-06-06 11:12:44
HD Request # 15 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-06 00:00:00 to 2016-05-06 00:00:00 (US Central Time). | 2016-06-06 11:12:44
HD Request # 15 | Total records received: 0 | 2016-06-06 11:12:44
HD Request # 15 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-07 00:00:00 to 2016-05-07 00:00:00 (US Central Time). | 2016-06-06 11:12:44
HD Request # 15 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-08 00:00:00 to 2016-05-08 00:00:00 (US Central Time). | 2016-06-06 11:12:44
HD Request # 15 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-09 00:00:00 to 2016-05-09 00:00:00 (US Central Time). | 2016-06-06 11:12:44
HD Request # 15 | Total records received: 0 | 2016-06-06 11:12:45
HD Request # 15 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-10 00:00:00 to 2016-05-10 00:00:00 (US Central Time). | 2016-06-06 11:12:45
HD Request # 15 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-11 00:00:00 to 2016-05-11 00:00:00 (US Central Time). | 2016-06-06 11:12:45
HD Request # 15 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-12 00:00:00 to 2016-05-12 00:00:00 (US Central Time). | 2016-06-06 11:12:45
HD Request # 15 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-13 00:00:00 to 2016-05-13 00:00:00 (US Central Time). | 2016-06-06 11:12:45
HD Request # 15 | Receiving Intraday data for TN.XCME_F TN (U16).CME_F-baavg starting at 2016-05-13 14:56:29 | 2016-06-06 11:12:46
HD Request # 15 | Timestamp of first Intraday data file record written: 2016-05-13 14:56:29 | 2016-06-06 11:12:46
HD Request # 15 | Total records received: 2 | 2016-06-06 11:12:46
HD Request # 15 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-14 00:00:00 to 2016-05-14 00:00:00 (US Central Time). | 2016-06-06 11:12:46
HD Request # 15 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-15 00:00:00 to 2016-05-15 00:00:00 (US Central Time). | 2016-06-06 11:12:46
HD Request # 15 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-16 00:00:00 to 2016-05-16 00:00:00 (US Central Time). | 2016-06-06 11:12:46
HD Request # 15 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-17 00:00:00 to 2016-05-17 00:00:00 (US Central Time). | 2016-06-06 11:12:46
HD Request # 15 | Total records received: 2 | 2016-06-06 11:12:47
HD Request # 15 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-18 00:00:00 to 2016-05-18 00:00:00 (US Central Time). | 2016-06-06 11:12:47
HD Request # 15 | Total records received: 100 | 2016-06-06 11:12:47
HD Request # 15 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-19 00:00:00 to 2016-05-19 00:00:00 (US Central Time). | 2016-06-06 11:12:47
HD Request # 15 | Total records received: 241 | 2016-06-06 11:12:47
HD Request # 15 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-20 00:00:00 to 2016-05-20 00:00:00 (US Central Time). | 2016-06-06 11:12:47
HD Request # 15 | Total records received: 287 | 2016-06-06 11:12:47
HD Request # 15 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-21 00:00:00 to 2016-05-21 00:00:00 (US Central Time). | 2016-06-06 11:12:47
HD Request # 15 | Total records received: 287 | 2016-06-06 11:12:48
HD Request # 15 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-22 00:00:00 to 2016-05-22 00:00:00 (US Central Time). | 2016-06-06 11:12:48
HD Request # 15 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-23 00:00:00 to 2016-05-23 00:00:00 (US Central Time). | 2016-06-06 11:12:48
HD Request # 15 | Total records received: 464 | 2016-06-06 11:12:48
HD Request # 15 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-24 00:00:00 to 2016-05-24 00:00:00 (US Central Time). | 2016-06-06 11:12:48
HD Request # 15 | Total records received: 1397 | 2016-06-06 11:12:48
HD Request # 15 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-25 00:00:00 to 2016-05-25 00:00:00 (US Central Time). | 2016-06-06 11:12:48
HD Request # 15 | Total records received: 2978 | 2016-06-06 11:12:49
HD Request # 15 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-26 00:00:00 to 2016-05-26 00:00:00 (US Central Time). | 2016-06-06 11:12:49
HD Request # 15 | Total records received: 7569 | 2016-06-06 11:12:49
HD Request # 15 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-27 00:00:00 to 2016-05-27 00:00:00 (US Central Time). | 2016-06-06 11:12:49
HD Request # 15 | Total records received: 11419 | 2016-06-06 11:12:49
HD Request # 15 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-28 00:00:00 to 2016-05-28 00:00:00 (US Central Time). | 2016-06-06 11:12:49
HD Request # 15 | Total records received: 11419 | 2016-06-06 11:12:50
HD Request # 15 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-29 00:00:00 to 2016-05-29 00:00:00 (US Central Time). | 2016-06-06 11:12:50
HD Request # 15 | Total records received: 11419 | 2016-06-06 11:12:51
HD Request # 15 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-30 00:00:00 to 2016-05-30 00:00:00 (US Central Time). | 2016-06-06 11:12:51
HD Request # 15 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-05-31 00:00:00 to 2016-05-31 00:00:00 (US Central Time). | 2016-06-06 11:12:51
HD Request # 15 | Total records received: 28199 | 2016-06-06 11:12:51
HD Request # 15 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-06-01 00:00:00 to 2016-06-01 00:00:00 (US Central Time). | 2016-06-06 11:12:51
HD Request # 15 | Total records received: 46545 | 2016-06-06 11:12:52
HD Request # 15 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-06-02 00:00:00 to 2016-06-02 00:00:00 (US Central Time). | 2016-06-06 11:12:52
HD Request # 15 | Total records received: 61700 | 2016-06-06 11:12:52
HD Request # 15 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-06-03 00:00:00 to 2016-06-03 00:00:00 (US Central Time). | 2016-06-06 11:12:52
HD Request # 15 | Total records received: 83732 | 2016-06-06 11:12:53
HD Request # 15 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-06-04 00:00:00 to 2016-06-04 00:00:00 (US Central Time). | 2016-06-06 11:12:53
HD Request # 15 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-06-05 00:00:00 to 2016-06-05 00:00:00 (US Central Time). | 2016-06-06 11:12:53
HD Request # 15 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-06-06 00:00:00 to 2016-06-06 00:00:00 (US Central Time). | 2016-06-06 11:12:53
HD Request # 15 | Total records received: 92355 | 2016-06-06 11:12:54
HD Request # 15 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-06-07 00:00:00 to 2016-06-07 00:00:00 (US Central Time). | 2016-06-06 11:12:54
HD Request # 15 | Requesting historical Tick data for TN.XCME_F TN (U16).CME_F from 2016-06-08 00:00:00 to 2016-06-08 00:00:00 (US Central Time). | 2016-06-06 11:12:54
HD Request # 15 | Received 92355 records from 2016-05-13 14:56:29 to 2016-06-06 11:12:00 (23.8 days) and wrote 92355 records for TN.XCME_F TN (U16).CME_F-baavg | 2016-06-06 11:12:54
HD Request # 15 | Intraday download COMPLETE for TN.XCME_F TN (U16).CME_F-baavg. Completion time: 12s. Unique request ID: 14 | 2016-06-06 11:12:54
Removed historical data download ID 14 | 2016-06-06 11:12:54
Real-time Intraday chart data file updates started for TN.XCME_F TN (U16).CME_F-baavg | 2016-06-06 11:12:54
Intraday chart data file opened for TN.XCME_F TN (U16).CME_F-baavg | 2016-06-06 11:12:54
CTS FIX Historical Data socket (29) | Closed. No error. | 2016-06-06 11:13:54
CTS FIX Historical Data socket (29) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-06 11:13:54
CTS FIX Historical Data socket (29) | SSL has been shut down. | 2016-06-06 11:13:54
CTS FIX Historical Data socket (29) | SSL object has been freed. SSL state is now disconnected. | 2016-06-06 11:13:54
CTS FIX Historical Data socket (29) | Shutdown and closed. | 2016-06-06 11:13:54
CTS FIX Historical Data: Socket connection was closed without any logout messages sent or received. | 2016-06-06 11:13:54
CTS FIX Historical Data: Disconnected. | 2016-06-06 11:13:54
Chart #1 has tagged chart #3 for full recalculation. Chartbook: M6 BoB.cht | 2016-06-06 11:18:44
Chart #1 has tagged chart #4 for full recalculation. Chartbook: M6 BoB.cht | 2016-06-06 11:18:44
Chart #1 has tagged chart #6 for full recalculation. Chartbook: M6 BoB.cht | 2016-06-06 11:18:44
uB.20160600.CME_F 60 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: M6 BoB.cht | 2016-06-06 11:18:45
ZB.20160600.CME_F Daily #3 | Performing a full recalculation because it has been tagged. Chartbook: M6 BoB.cht | 2016-06-06 11:18:45
ZB.20160600.CME_F Weekly #4 | Performing a full recalculation because it has been tagged. Chartbook: M6 BoB.cht | 2016-06-06 11:18:45
Chart #1 has tagged chart #3 for full recalculation. Chartbook: M6 BoB.cht | 2016-06-06 11:19:24
Chart #1 has tagged chart #4 for full recalculation. Chartbook: M6 BoB.cht | 2016-06-06 11:19:24
Chart #1 has tagged chart #6 for full recalculation. Chartbook: M6 BoB.cht | 2016-06-06 11:19:24
uB.20160600.CME_F 60 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: M6 BoB.cht | 2016-06-06 11:19:25
ZB.20160600.CME_F Daily #3 | Performing a full recalculation because it has been tagged. Chartbook: M6 BoB.cht | 2016-06-06 11:19:25
ZB.20160600.CME_F Weekly #4 | Performing a full recalculation because it has been tagged. Chartbook: M6 BoB.cht | 2016-06-06 11:19:25
Chart #1 has tagged chart #3 for full recalculation. Chartbook: M6 BoB.cht | 2016-06-06 11:19:32
Chart #1 has tagged chart #4 for full recalculation. Chartbook: M6 BoB.cht | 2016-06-06 11:19:32
Chart #1 has tagged chart #6 for full recalculation. Chartbook: M6 BoB.cht | 2016-06-06 11:19:32
uB.20160600.CME_F 60 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: M6 BoB.cht | 2016-06-06 11:19:32
ZB.20160600.CME_F Daily #3 | Performing a full recalculation because it has been tagged. Chartbook: M6 BoB.cht | 2016-06-06 11:19:32
ZB.20160600.CME_F Weekly #4 | Performing a full recalculation because it has been tagged. Chartbook: M6 BoB.cht | 2016-06-06 11:19:32
Chart #1 has tagged chart #3 for full recalculation. Chartbook: M6 BoB.cht | 2016-06-06 11:19:42
Chart #1 has tagged chart #4 for full recalculation. Chartbook: M6 BoB.cht | 2016-06-06 11:19:42
Chart #1 has tagged chart #6 for full recalculation. Chartbook: M6 BoB.cht | 2016-06-06 11:19:42
uB.20160600.CME_F 60 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: M6 BoB.cht | 2016-06-06 11:19:42
ZB.20160600.CME_F Daily #3 | Performing a full recalculation because it has been tagged. Chartbook: M6 BoB.cht | 2016-06-06 11:19:42
ZB.20160600.CME_F Weekly #4 | Performing a full recalculation because it has been tagged. Chartbook: M6 BoB.cht | 2016-06-06 11:19:42
Chart #1 has tagged chart #3 for full recalculation. Chartbook: M6 BoB.cht | 2016-06-06 11:20:16
Chart #1 has tagged chart #4 for full recalculation. Chartbook: M6 BoB.cht | 2016-06-06 11:20:16
Chart #1 has tagged chart #6 for full recalculation. Chartbook: M6 BoB.cht | 2016-06-06 11:20:16
ZB.20160600.CME_F Daily #3 | Performing a full recalculation because it has been tagged. Chartbook: M6 BoB.cht | 2016-06-06 11:20:16
ZB.20160600.CME_F Weekly #4 | Performing a full recalculation because it has been tagged. Chartbook: M6 BoB.cht | 2016-06-06 11:20:16
uB.20160600.CME_F 60 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: M6 BoB.cht | 2016-06-06 11:20:17
Chart #1 has tagged chart #3 for full recalculation. Chartbook: M6 BoB.cht | 2016-06-06 11:20:17
Chart #1 has tagged chart #4 for full recalculation. Chartbook: M6 BoB.cht | 2016-06-06 11:20:17
Chart #1 has tagged chart #6 for full recalculation. Chartbook: M6 BoB.cht | 2016-06-06 11:20:17
ZB.20160600.CME_F Daily #3 | Performing a full recalculation because it has been tagged. Chartbook: M6 BoB.cht | 2016-06-06 11:20:17
ZB.20160600.CME_F Weekly #4 | Performing a full recalculation because it has been tagged. Chartbook: M6 BoB.cht | 2016-06-06 11:20:17
CTS T4 FIX | Using primary service for historical data for uB.20160900.CME_F | 2016-06-06 11:46:07
uB.20160900.CME_F 120 Min #10 | Reloading chart. | 2016-06-06 11:46:07
CTS T4 FIX | Using primary service for historical data for uB.20160900.CME_F | 2016-06-06 11:46:11
uB.20160900.CME_F 240 Min #10 | Reloading chart. | 2016-06-06 11:46:11
CTS T4 FIX | Using primary service for historical data for uB.20160900.CME_F | 2016-06-06 11:46:15
uB.20160900.CME_F 120 Min #10 | Reloading chart. | 2016-06-06 11:46:15
Uploaded an image to the server. Request ID: 1 | 2016-06-06 11:55:26
HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-06-06 11:55:26
HTTP connection to www.sierrachart.com:80 (52) | Connected. | 2016-06-06 11:55:26
HTTP connection to www.sierrachart.com:80 (52) | Closed. No error. | 2016-06-06 11:55:31
HTTP connection to www.sierrachart.com:80 (52) | Shutdown and closed. | 2016-06-06 11:55:31
[2016-06-06 17:16:06]
My trading DOM has up to date data and my CTS charts are also updating. The issue sems to be not with the data but somewhere between the data and SC.
When you have a problem like this, first refer to help topic 3:
https://www.sierrachart.com/index.php?l=helpdetails3.html
Based upon the below messages you are still using the wrong symbol case at least for some charts. You must correct each and every single chart. Would also be best after you are done correcting the letter case, to restart Sierra Chart.
Follow the instructions here:
https://www.sierrachart.com/index.php?page=doc/doc_ChartDataFiles.html#CorrectingSymbolLetterCase
Symbol Error - TN.XCME_F TN (u16).CME_F is unknown, unavailable, or improperly formatted. CTS FIX: Received market data reject: (0) Market is not available | 2016-06-06 10:37:49
Symbol Error - uB.20160600.CME_F is unknown, unavailable, or improperly formatted. Security definition not found | 2016-06-06 10:37:49
CTS T4 FIX | Received 0 security definitions for underlying symbol uB | 2016-06-06 10:37:49
CTS T4 FIX | Using primary service for historical data for TN.XCME_F TN (u16).CME_F | 2016-06-06 10:37:07
TN.XCME_F TN (u16).CME_F 30 Sec #1 | Reloading chart. | 2016-06-06 10:37:07
TN.XCME_F TN (u16).CME_F Daily #2 | Reloading chart. | 2016-06-06 10:37:07
CTS T4 FIX | Using primary service for historical data for ZN.20160900.CME_F | 2016-06-06 10:37:07
ZN.20160900.CME_F 30 Sec #3 | Reloading chart. | 2016-06-06 10:37:07
TN.XCME_F TN (u16).CME_F Weekly #4 | Reloading chart. | 2016-06-06 10:37:07
TN.XCME_F TN (u16).CME_F 120 Min #10 | Reloading chart. | 2016-06-06 10:37:07
TN.XCME_F TN (u16).CME_F Daily #5 | Reloading chart. | 2016-06-06 10:37:07
CTS T4 FIX | Using primary service for historical data for TN.XCME_F TN (U16).CME_F | 2016-06-06 10:37:07
TN.XCME_F TN (U16).CME_F 30 Sec #6 | Reloading chart. | 2016-06-06 10:37:07
Date Time Of Last Edit: 2016-06-06 17:17:02
