Date/Time: Sat, 04 Jan 2025 07:10:38 +0000
Error installing latest SierraChart on Linux (Ubuntu + Wine)
View Count: 1886
[2016-06-04 08:24:41]
JirkaEspace - Posts: 12
Ubuntu 14.04 LTS
A new Wine 1.9.11 installation, plus Winetricks, "vcrun2010" and "corefonts" - according the instructions in Help topic 56: Run Sierra Chart on GNU/Linux, BSD, Solaris and Mac OS X.
When installing the newest SierraChart version 1423 (June 3, 2016) there is an error:
Error starting C:\SierraChart\vcredist_x86_2010.exe. Windows error code 2: File was not found. | 2016-06-03 23:44:20
I have also tried to create the new wineprefix (to be sure having 32 bit Windows XP environment) & install SierraChart from the command line:
~$ WINEARCH=win32 WINEPREFIX=/home/<user>/.wine_XP_SierraChart winecfg
~$ WINEPREFIX=/home/<user>/.wine_XP_SierraChart wine start /unix /home/<user>/Plocha/SierraChartFileDownloader.exe
But the result is the same error...
It is interesting that only "SierraChart" directory and 1 subdirectory "Data" (both empty) are created within the "drive_c" in the wineprefix.
It's a pitty - my latest SierraChart version 1369 some month ago was working (installing) fine / without any problem.
Date Time Of Last Edit: 2016-06-04 08:25:49
[2016-06-04 17:12:04]
ganz - Posts: 1048
JirkaEspace
Yes, this new installer is not working on wine.
[2016-06-04 17:42:36]
And does anybody know whether is there any solution? Alternative way of installation?
[2016-06-04 18:47:26]
I've been experimenting but no success...
The installator creates the directory /SierraChart/DownloadedInstallationFiles/ and fills it by SierraChart app files during installation.
But after that the "Error starting C:\SierraChart\vcredist_x86_2010.exe. Windows error code 2: File was not found." appears.
It seems like there should be a step for copy the content /DownloadedInstallationFiles/ into directory /SierraChart/ after download of the files from SierraChart. But instead of that no copy performed and the directory /DownloadedInstallationFiles/ is deleted. And installation fails with above mentioned error.
[2016-06-04 21:45:59]
We are checking on this.
[2016-06-04 21:51:55]
We do not see any problem running on Windows, so we will have to examine this more closely next week and additional logging.
Date Time Of Last Edit: 2016-06-04 21:52:05
[2016-06-04 22:34:13]
ganz - Posts: 1048
SC Support
why just not using (s)ftp to share it?
4ex: ftp://ftp.sierrachart.com/downloads/1423/* using ro mode
ftp://ftp.sierrachart.com/downloads/1423/ACS_Source/scconstants.h
ftp://ftp.sierrachart.com/downloads/1423/ACS_Source/sierrachart.h
and so on
thnx
[2016-06-04 22:37:09]
ganz - Posts: 1048
SC Support
try set it as an option pls
thnx
[2016-06-05 01:44:55]
FTP is a highly insecure service. There is no chance we would ever make that available.
[2016-06-05 02:08:01]
ganz - Posts: 1048
SC Support
This kind of the answer has not make any sense.
ftp is not so secure for you using ro mode? no problem.
give us a chance to get it file by file using wget/curl and choose a way you like
so it might be automated on a user's side.
thnx.
[2016-06-06 09:55:56]
If you look at the installer log file which is contained in the Logs folder in the folder where the installer is run from, you can see the location of the files and can create your own installer using HTTP.
The installer has now been updated to solve the problem with WINE. There was a particular function being used in one version of the installer which was not functioning right on WINE. That has now been removed.
[2016-06-06 14:41:36]
ganz - Posts: 1048
SC Support
yes. it would be very cool. :)
is it mean there will be two parts: a major part and a minor version specific?
if so let us know in case you change it.
thnx.
[2016-06-06 17:26:49]
https://www.sierrachart.com/downloads/1423/FilesToDownload.txt (These are version specific files)
https://www.sierrachart.com/downloads/Common1410/FilesToDownload.txt (These are files common between many versions)
[2016-06-06 21:39:11]
Thank you very much, it does work now!
The only small taint (but not a real problem): the directory /DownloadedInstallationFiles/ remains in the main SierraChart directory after installation. But it is empty (no files, only empty subdirectories) - so no space is taken...
Thank you once again!
Date Time Of Last Edit: 2016-06-06 21:39:28
[2016-06-06 22:38:48]
Yes, we know those folders remain. They are left there for safety reasons. As a general rule, we do not like to delete files and folders.
[2016-06-07 01:50:55]
ganz - Posts: 1048
SC Support
this is puzzled a bit
upgrading from 1421 to 1423 should I update Common1410/* to get new 1423 version?
thnx.
[2016-06-07 01:58:45]
No because the common files did not change between those versions. They changed at version 1410.
Date Time Of Last Edit: 2016-06-07 01:58:57
