Date/Time: Sun, 29 Dec 2024 15:37:41 +0000
Draw Profile Tool Error
View Count: 1309
[2016-05-14 12:13:32]
User787778 - Posts: 142
I have created a single Volume Profile Study collection, and saved this, with Prompt to Remove Existing Studies, and called it "Entry". If I open "Entry", using the "Analysis" tab, the Volume Graph Period is correctly set to "From start time to End".
I then, via the tool configuration, "draw volume profile" , set the "Chart Study Collection" to "Entry".
When I use the "Draw Profile from a tool drop down menu, the "Volume Graph Period" has changed to "From start date time to End date time".
I have deleted the study collections and recreated them, but still get the same result. Please note that I am using replay.
[2016-05-16 00:00:00]
We are checking on this.
We think we have an idea why this is happening and if it is what we suspect it will be solved in the next release.
[2016-05-18 10:50:22]
Now that we have looked at this closer, you must use one of the following in the Study Collection:
Start Date Time to End Date Time
From Start Date Time to End.
