Date/Time: Sat, 27 Apr 2024 19:40:20 +0000
[User Discussion] - Better Momentum Indicator EMINI WATCH.com USER DISCUSSION
View Count: 7400
[2016-05-12 09:25:54] |
User15378 - Posts: 45 |
Hi there, i was wondering if anyone has made a copy or mock version of the better momentum indicator thats out there on EMINI watch.com for sierra charts? I cant seem to find one anywhere. if people are interetested in it, i have a open source Trade station version that if someone wants to change it into sierra language they can have it? Have a great day. Nic |
[2016-05-13 03:27:38] |
User52989 - Posts: 42 |
+1
[2016-05-13 06:44:58] |
User15952 - Posts: 132 |
Better Sine Wave and Better Momentum are very good.
[2016-05-13 06:49:35] |
Yes i totally agree, excellent. it is surprising that someone has not made a version for sierra charts yet, or maybe they did and just have not shared with anyone. I spoke with a coder that could do it but he is so busy he can only do it in June sometime. But i am sure that we should hopefully run across someone in here that finds the use of it like we do & can help us out. |
[2016-05-24 19:25:20] |
Blue Brazilian - Posts: 42 |
Hi, Did you make any progress on this? I would also like to use Better Momentum on Sierra. I've coded lots of indicators in Tradestation's EasyLanguage, but have only recently started using Sierra and have only coded a few indicators so far (but they all work!). If the coder you mentioned is still too busy, I'd be prepared to give it a go, but can't promise that it would be ready and fully tested before June anyway. |
[2016-05-24 19:27:59] |
Hey Blue, i have not got anyone to code just yet, if you would like to take a swing at it, awesome! invite me on Skype - nic.labuschagne1 or email me nic@growthwiseinvestments.com Would love to chat with you and we can share the results here afterwards. Cheers Nic |
[2016-07-10 00:53:11] |
any updates?
[2016-07-11 15:40:30] |
JohnR - User831573 - Posts: 300 |
Nic, I've been using SC for approx 45 days and I have coded a few things of my own. I'm still getting used to all of SC functions and ways to doing things in studies, but getting better as time goes on. If you either post the source here as an attachment, I will look at it, or I also sent you an email to the address you provided above with my email. I do not have TS, so it needs to be a source/text file I can read. John |
[2016-07-21 14:59:01] |
Hey guys Here is the coded indicator someone did it for me. CHeers P.S John. i have emailed you several times and keep getting errors so hope you see this! |
BetterMomentum.dll - Attached On 2016-07-21 14:58:26 UTC - Size: 25.5 KB - 796 views BetterMomentum2.dll - Attached On 2016-07-21 14:58:38 UTC - Size: 27 KB - 776 views |
[2016-07-22 01:30:58] |
Nic, I downloaded the files from here. Thanks John |
[2016-07-24 19:10:41] |
enemyspy - Posts: 304 |
Thank you for this. Can Anyone verify that it works properly?
Date Time Of Last Edit: 2016-07-24 19:11:19
[2016-07-25 00:14:17] |
Personally, nothing shows up.
[2018-12-18 02:07:49] |
User673902 - Posts: 4 |
Thank you for sharing. My skills are limited with SC, But I got this to work. Used this on Tradestation for a few years, and it is like seeing an old friend. I would like to load Hilbert Sinewavw SR and had not had success, also better pro-am. If you are using these in SC, I would sure like to know how you are doing it. Regards, Skidmark |
[2018-12-18 08:18:07] |
User371906 - Posts: 141 |
Hello, Wanted to ask if it is recommended if your using Heiken Ashi candles in combination of Flex Renko? Supposedly it works based of volume but not sure if it works with this combination. Thank you Kindly g |
[2019-06-18 08:15:21] |
User787778 - Posts: 139 |
Hi Please will you re compile the Better Momentum study in the 64 bit version of Sierra Charts. Thnkyou in advance |
[2019-07-03 19:50:19] |
User929084 - Posts: 60 |
+1
[2019-07-03 20:32:48] |
These versions include new routines to paint the blue and yellow Pro/Am bars.
BetterMomentum1_1_64.dll - Attached On 2019-07-03 20:32:12 UTC - Size: 840.5 KB - 550 views BetterMomentum2_1_64.dll - Attached On 2019-07-03 20:32:25 UTC - Size: 841 KB - 528 views |
[2019-07-04 01:03:20] |
Thank you very much for the upload Blue Brazilian .
Date Time Of Last Edit: 2019-07-04 01:04:19
[2020-01-21 02:29:19] |
BB, Thank you so much for the 64 bit version and also the new Pro-Am addition. I still subscribe to Barry's site and look forward to his videos. Regards, Ralph If you are going to prognosticate, prognosticate often. |
[2020-05-30 19:12:03] |
User771423 - Posts: 25 |
Thanks Blue, by the way, do you have a manual for it? What is what? How does the blue and yellow treshold work for better pro am? How is it calculated?
[2020-06-11 03:00:39] |
Ed1 - Posts: 3 |
Is the source for these studies available? Thanks!
[2020-06-11 03:30:33] |
Ed C. - Posts: 98 |
I would like to know as well if the source is available - thank you!
[2020-08-27 19:33:42] |
User845705 - Posts: 1 |
I updated to version 2158 and i get an error that these need to be recompiled. Is this something you can do? Thanks |
[2020-10-05 12:35:36] |
User881337 - Posts: 1 |
Anyone have recompiled Better Momentum? Many thanks in advance. Cheers |
