Date/Time: Sat, 28 Dec 2024 23:02:51 +0000
DATA NOT AUTOMATICALLY / CONTINUALLY UPDATING
View Count: 775
[2016-05-04 14:55:41] |
User269483 - Posts: 5 |
Hi Guys, I updated Siera and followed the necessary steps however now the system isnt updating automatically. Everytime i click download and delete data new data arrives but doesnt continue to update. it just sits at the same price. Could you advise me on this? Joe |
[2016-05-04 15:23:33] |
Tell us one of the symbols that is not updating. Update the Symbol Settings as explained here: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettingsSteps Provide a copy of the Message Log by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-05-05 08:21:16] |
Hi Guys, Its for Brent Crude Oil - All brent calendar spreads & spot months. details below. "Software version: 1405 | 2016-05-05 09:16:05 Uses New Spreadsheets | 2016-05-05 09:16:05 Enabled for: Advanced Features. | 2016-05-05 09:16:05 Enabled for: Advanced Features 2. | 2016-05-05 09:16:05 Enabled for: Sierra Chart Historical Data Service. | 2016-05-05 09:16:05 Allow Support for Sierra Chart Data Feeds is enabled. | 2016-05-05 09:16:05 Current selected Data/Trading service: Easy Screen | 2016-05-05 09:16:05 Chart Update Interval: 500 | 2016-05-05 09:16:05 Time Zone: +01:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) | 2016-05-05 09:16:05 2016-05-05 09:16:07 Local computer time | 2016-05-05 09:16:05 2016-05-05 08:16:07 Local computer time in UTC | 2016-05-05 09:16:05 2016-05-05 09:16:07 Local computer time in SC Time Zone | 2016-05-05 09:16:05 2016-05-05 08:15:49 Server time in UTC | 2016-05-05 09:16:05 Local computer UTC time and Server UTC time difference: 18 seconds. | 2016-05-05 09:16:05 Program path: C:\SierraChart\ | 2016-05-05 09:16:05 Data Files path: C:\SierraChart\Data\ | 2016-05-05 09:16:05 OS Version Number: 6.1 | 2016-05-05 09:16:05 Locale Setting: C | 2016-05-05 09:16:05 Checking for new symbol settings for easyscreen.dtc | 2016-05-05 09:16:05 HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-05-05 09:16:05 HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-05-05 09:16:05 HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-05-05 09:16:05 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-05-05 09:16:05 Symbol settings are up-to-date for easyscreen.dtc | 2016-05-05 09:16:05 Easy Screen | Connecting to the server easyscreen.sierracharts.com. Port 443 | 2016-05-05 09:16:12 Socket (0) | Resolved address ds9.sierracharts.com to IP 194.50.31.205. | 2016-05-05 09:16:12 Socket (4) | Connected. | 2016-05-05 09:16:12 Easy Screen | Connected to server. | 2016-05-05 09:16:12 Easy Screen | Sending Encoding Request to server | 2016-05-05 09:16:12 Easy Screen | Setting DTC Encoding to Binary VLS | 2016-05-05 09:16:12 Easy Screen | Sending logon request message. | 2016-05-05 09:16:12 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-05-05 09:16:13 HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-05-05 09:16:13 HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-05-05 09:16:13 HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-05-05 09:16:13 Easy Screen | Received logon response. | 2016-05-05 09:16:13 Easy Screen | Server Name: SC Realtime Server. | 2016-05-05 09:16:13 Easy Screen | Server protocol version: 7. Client protocol version: 7 | 2016-05-05 09:16:13 Easy Screen | Successfully connected. | 2016-05-05 09:16:13 Easy Screen | Connected to data server. | 2016-05-05 09:16:13 Requesting symbol settings for easyscreen.dtc. Overwrite = on. | 2016-05-05 09:16:42 HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-05-05 09:16:42 HTTPS connection to www.sierrachart.com:443 (5) | Connected. | 2016-05-05 09:16:42 HTTPS connection to www.sierrachart.com:443 (5) | Starting TLS 1.2 connection. | 2016-05-05 09:16:42 HTTPS connection to www.sierrachart.com:443 (5) | SSL connection established. | 2016-05-05 09:16:42 Symbol settings received. | 2016-05-05 09:16:42 Processed received symbol settings | 2016-05-05 09:16:42 It is recommended to reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed' | 2016-05-05 09:16:42 HTTPS connection to www.sierrachart.com:443 (5) | SSL connection closed by remote side. | 2016-05-05 09:16:47 HTTPS connection to www.sierrachart.com:443 (5) | Connection gracefully closed by remote side. | 2016-05-05 09:16:47 HTTPS connection to www.sierrachart.com:443 (5) | SSL object has been freed. SSL state is now disconnected. | 2016-05-05 09:16:47 HTTPS connection to www.sierrachart.com:443 (5) | Shutdown and closed. | 2016-05-05 09:16:47 File >> Disconnect selected. | 2016-05-05 09:17:01 Socket (4) | Shutdown and closed. | 2016-05-05 09:17:01 Easy Screen | Disconnected. | 2016-05-05 09:17:01 Easy Screen | Connecting to the server easyscreen.sierracharts.com. Port 10048 | 2016-05-05 09:17:02 Socket (0) | Resolved address ds9.sierracharts.com to IP 194.50.31.205. | 2016-05-05 09:17:02 Socket (6) | Connected. | 2016-05-05 09:17:02 Easy Screen | Connected to server. | 2016-05-05 09:17:02 Easy Screen | Sending Encoding Request to server | 2016-05-05 09:17:02 Easy Screen | Setting DTC Encoding to Binary VLS | 2016-05-05 09:17:02 Easy Screen | Sending logon request message. | 2016-05-05 09:17:02 Easy Screen | Received logon response. | 2016-05-05 09:17:03 Easy Screen | Server Name: SC Realtime Server. | 2016-05-05 09:17:03 Easy Screen | Server protocol version: 7. Client protocol version: 7 | 2016-05-05 09:17:03 Easy Screen | Successfully connected. | 2016-05-05 09:17:03 Easy Screen | Connected to data server. | 2016-05-05 09:17:03 REF:B Dec 16 15 Min #3 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 07:45:00. Next Bar Date Time: 2016-04-15 07:30:00. Filename: REF~B Dec 16.scid | 2016-05-05 09:18:15 REF:B Dec 16 15 Min #3 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 08:00:00. Next Bar Date Time: 2016-04-15 07:45:00. Filename: REF~B Dec 16.scid | 2016-05-05 09:18:15 REF:B Jul 16 Aug 16 Calendar Spread 10 Min #5 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 09:00:00. Next Bar Date Time: 2016-04-15 08:50:00. Filename: REF~B Jul 16 Aug 16 Calendar Spread.scid | 2016-05-05 09:18:15 REF:B Jul 16 Aug 16 Calendar Spread 10 Min #5 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 10:00:00. Next Bar Date Time: 2016-04-15 09:50:00. Filename: REF~B Jul 16 Aug 16 Calendar Spread.scid | 2016-05-05 09:18:15 REF:B Jun 17 Dec 17 Calendar Spread 15 Min #9 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 08:45:00. Next Bar Date Time: 2016-04-15 08:00:00. Filename: REF~B Jun 17 Dec 17 Calendar Spread.scid | 2016-05-05 09:18:15 REF:B Jul 16 10 Min #2 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 07:10:00. Next Bar Date Time: 2016-04-15 07:00:00. Filename: REF~B Jul 16.scid | 2016-05-05 09:18:15 REF:B Jul 16 10 Min #2 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 07:50:00. Next Bar Date Time: 2016-04-15 07:40:00. Filename: REF~B Jul 16.scid | 2016-05-05 09:18:15 REF:B Jul 16 Aug 16 Calendar Spread 10 Min #7 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 09:00:00. Next Bar Date Time: 2016-04-15 08:50:00. Filename: REF~B Jul 16 Aug 16 Calendar Spread.scid | 2016-05-05 09:18:15 REF:B Jul 16 Aug 16 Calendar Spread 10 Min #7 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 10:00:00. Next Bar Date Time: 2016-04-15 09:50:00. Filename: REF~B Jul 16 Aug 16 Calendar Spread.scid | 2016-05-05 09:18:15 REF:B Nov 16 15 Min #18 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 07:00:00. Next Bar Date Time: 2016-04-15 06:45:00. Filename: REF~B Nov 16.scid | 2016-05-05 09:18:15 REF:B Nov 16 15 Min #18 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 10:00:00. Next Bar Date Time: 2016-04-15 09:45:00. Filename: REF~B Nov 16.scid | 2016-05-05 09:18:15 REF:B Oct 16 15 Min #17 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 07:00:00. Next Bar Date Time: 2016-04-15 06:30:00. Filename: REF~B Oct 16.scid | 2016-05-05 09:18:15 REF:B Oct 16 15 Min #17 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 07:30:00. Next Bar Date Time: 2016-04-15 07:15:00. Filename: REF~B Oct 16.scid | 2016-05-05 09:18:15 REF:B Aug 16 15 Min #12 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 10:00:00. Next Bar Date Time: 2016-04-15 09:45:00. Filename: REF~B Aug 16.scid | 2016-05-05 09:18:15 REF:B Dec 16 Dec 17 Calendar Spread 15 Min #20 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 06:45:00. Next Bar Date Time: 2016-04-15 06:30:00. Filename: REF~B Dec 16 Dec 17 Calendar Spread.scid | 2016-05-05 09:18:15 REF:B Dec 16 Dec 17 Calendar Spread 15 Min #20 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 07:00:00. Next Bar Date Time: 2016-04-15 06:45:00. Filename: REF~B Dec 16 Dec 17 Calendar Spread.scid | 2016-05-05 09:18:15 REF:B Dec 16 Dec 17 Calendar Spread 15 Min #20 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 08:45:00. Next Bar Date Time: 2016-04-15 08:30:00. Filename: REF~B Dec 16 Dec 17 Calendar Spread.scid | 2016-05-05 09:18:15 REF:B Dec 16 Dec 17 Calendar Spread 15 Min #20 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 10:30:00. Next Bar Date Time: 2016-04-15 10:15:00. Filename: REF~B Dec 16 Dec 17 Calendar Spread.scid | 2016-05-05 09:18:15 REF:B Jun 17 Dec 17 Calendar Spread 30 Min #22 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 08:30:00. Next Bar Date Time: 2016-04-15 08:00:00. Filename: REF~B Jun 17 Dec 17 Calendar Spread.scid | 2016-05-05 09:18:15 REF:B dec 16 jun 17 Calendar Spread #23 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 06:58:00. Next Bar Date Time: 2016-04-15 06:49:00. Filename: REF~B dec 16 jun 17 Calendar Spread.scid | 2016-05-05 09:18:15 REF:B Jun 16 Jul 16 Calendar Spread 10 Min #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 07:10:00. Next Bar Date Time: 2016-04-15 07:00:00. Filename: REF~B Jun 16 Jul 16 Calendar Spread.scid | 2016-05-05 09:18:15 REF:B Jun 16 Jul 16 Calendar Spread 10 Min #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 07:20:00. Next Bar Date Time: 2016-04-15 07:10:00. Filename: REF~B Jun 16 Jul 16 Calendar Spread.scid | 2016-05-05 09:18:15 REF:B Jun 16 Jul 16 Calendar Spread 10 Min #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 08:10:00. Next Bar Date Time: 2016-04-15 08:00:00. Filename: REF~B Jun 16 Jul 16 Calendar Spread.scid | 2016-05-05 09:18:15 REF:B Jun 16 Jul 16 Calendar Spread 10 Min #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 09:50:00. Next Bar Date Time: 2016-04-15 09:40:00. Filename: REF~B Jun 16 Jul 16 Calendar Spread.scid | 2016-05-05 09:18:15 RXF:DX Jun 16 10 Min #21 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 06:50:00. Next Bar Date Time: 2016-04-15 06:40:00. Filename: RXF~DX Jun 16.scid | 2016-05-05 09:18:15 REF:B Jun 17 Dec 17 Calendar Spread #29 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 08:48:00. Next Bar Date Time: 2016-04-15 08:03:00. Filename: REF~B Jun 17 Dec 17 Calendar Spread.scid | 2016-05-05 09:18:15 REF:B Jun 17 Dec 17 Calendar Spread 10 Min #25 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 08:40:00. Next Bar Date Time: 2016-04-15 08:00:00. Filename: REF~B Jun 17 Dec 17 Calendar Spread.scid | 2016-05-05 09:18:15 REF:B Jul 16 Dec 16 Calendar Spread 30 Min #34 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 09:00:00. Next Bar Date Time: 2016-04-15 08:30:00. Filename: REF~B Jul 16 Dec 16 Calendar Spread.scid | 2016-05-05 09:18:15 REF:B Jul 16 Dec 16 Calendar Spread 30 Min #34 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 10:00:00. Next Bar Date Time: 2016-04-15 09:30:00. Filename: REF~B Jul 16 Dec 16 Calendar Spread.scid | 2016-05-05 09:18:15 REF:B Jul 16 Dec 16 Calendar Spread 30 Min #34 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 10:30:00. Next Bar Date Time: 2016-04-15 10:00:00. Filename: REF~B Jul 16 Dec 16 Calendar Spread.scid | 2016-05-05 09:18:15 REF:B Jul 16 Dec 16 Calendar Spread #36 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 06:59:00. Next Bar Date Time: 2016-04-15 06:32:00. Filename: REF~B Jul 16 Dec 16 Calendar Spread.scid | 2016-05-05 09:18:15 REF:B Jul 16 Dec 16 Calendar Spread #36 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 09:03:00. Next Bar Date Time: 2016-04-15 08:46:00. Filename: REF~B Jul 16 Dec 16 Calendar Spread.scid | 2016-05-05 09:18:15 REF:B Jul 16 Dec 16 Calendar Spread #36 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 10:02:00. Next Bar Date Time: 2016-04-15 09:53:00. Filename: REF~B Jul 16 Dec 16 Calendar Spread.scid | 2016-05-05 09:18:15 REF:B Jul 16 Aug 16 Calendar Spread 60 Min #13 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 09:00:00. Next Bar Date Time: 2016-04-15 08:00:00. Filename: REF~B Jul 16 Aug 16 Calendar Spread.scid | 2016-05-05 09:18:15 REF:B Jul 16 Aug 16 Calendar Spread 60 Min #13 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 10:00:00. Next Bar Date Time: 2016-04-15 09:00:00. Filename: REF~B Jul 16 Aug 16 Calendar Spread.scid | 2016-05-05 09:18:15 REF:B Oct 16 Nov 16 Calendar Spread 30 Min #41 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 09:30:00. Next Bar Date Time: 2016-04-15 09:00:00. Filename: REF~B Oct 16 Nov 16 Calendar Spread.scid | 2016-05-05 09:18:15 REF:B Nov 16 Dec 16 Calendar Spread 30 Min #42 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 09:00:00. Next Bar Date Time: 2016-04-15 08:30:00. Filename: REF~B Nov 16 Dec 16 Calendar Spread.scid | 2016-05-05 09:18:15 REF:B Nov 16 Dec 16 Calendar Spread 30 Min #42 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 09:30:00. Next Bar Date Time: 2016-04-15 09:00:00. Filename: REF~B Nov 16 Dec 16 Calendar Spread.scid | 2016-05-05 09:18:15 Chart #26 has tagged chart #10 for full recalculation. Chartbook: JOEBROWN - OIL6.cht | 2016-05-05 09:18:15 Chart #26 has tagged chart #10 for full recalculation. Chartbook: JOEBROWN - OIL6.cht | 2016-05-05 09:18:15 Chart #30 has tagged chart #13 for full recalculation. Chartbook: JOEBROWN - OIL6.cht | 2016-05-05 09:18:15 Chart #30 has tagged chart #13 for full recalculation. Chartbook: JOEBROWN - OIL6.cht | 2016-05-05 09:18:15 Easy Screen | Starting real-time market data updates for: REF:B Dec 16. ID: 1 | 2016-05-05 09:18:16 Intraday data recording state for symbol REF:B Dec 16 is set to download 'Pending'. | 2016-05-05 09:18:16 Delaying start of download for REF:B Dec 16 | 2016-05-05 09:18:16 Symbol Error - REF:B Dec 16 is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2016-05-05 09:18:16 Easy Screen | Starting real-time market data updates for: REF:B Jul 16. ID: 2 | 2016-05-05 09:18:16 Intraday data recording state for symbol REF:B Jul 16 is set to download 'Pending'. | 2016-05-05 09:18:16 Symbol Error - REF:B Jul 16 is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2016-05-05 09:18:16 HD Request # 2 | Downloading Intraday chart data for REF:B Dec 16 to the file REF~B Dec 16.scid. Service: iceeurope.easyscreen | 2016-05-05 09:18:16 HD Request # 2 | Download start Date-Time: 2016-05-05 09:13:51.000 | 2016-05-05 09:18:16 HD Request # 2 | Using server: easyscreen.sierracharts.com port 10149 | 2016-05-05 09:18:16 Easy Screen | Starting real-time market data updates for: REF:B Jun 16 Dec 16 Calendar Spread. ID: 3 | 2016-05-05 09:18:16 Socket (0) | Resolved address ds9.sierracharts.com to IP 194.50.31.205. | 2016-05-05 09:18:16 Socket (8) | Connected. | 2016-05-05 09:18:16 HD Request # 2 | Sending historical data logon request message. | 2016-05-05 09:18:16 Intraday data recording state for symbol REF:B Jun 16 Dec 16 Calendar Spread is set to download 'Pending'. | 2016-05-05 09:18:16 Symbol Error - REF:B Jun 16 Dec 16 Calendar Spread is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2016-05-05 09:18:16 Easy Screen | Starting real-time market data updates for: REF:B Jul 16 Aug 16 Calendar Spread. ID: 4 | 2016-05-05 09:18:16 Intraday data recording state for symbol REF:B Jul 16 Aug 16 Calendar Spread is set to download 'Pending'. | 2016-05-05 09:18:16 Symbol Error - REF:B Jul 16 Aug 16 Calendar Spread is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2016-05-05 09:18:16 Easy Screen | Starting real-time market data updates for: REF:B Jun 16 Jul 16 Calendar Spread. ID: 5 | 2016-05-05 09:18:16 Intraday data recording state for symbol REF:B Jun 16 Jul 16 Calendar Spread is set to download 'Pending'. | 2016-05-05 09:18:16 Symbol Error - REF:B Jun 16 Jul 16 Calendar Spread is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2016-05-05 09:18:16 Easy Screen | Starting real-time market data updates for: REF:B Aug 16 Sep 16 Calendar Spread. ID: 6 | 2016-05-05 09:18:16 Intraday data recording state for symbol REF:B Aug 16 Sep 16 Calendar Spread is set to download 'Pending'. | 2016-05-05 09:18:16 REF:B Aug 16 Sep 16 Calendar Spread 10 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: JOEBROWN - OIL6.cht | 2016-05-05 09:18:16 Symbol Error - REF:B Aug 16 Sep 16 Calendar Spread is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2016-05-05 09:18:16 Easy Screen | Starting real-time market data updates for: REF:B Jun 17 Dec 17 Calendar Spread. ID: 7 | 2016-05-05 09:18:16 Intraday data recording state for symbol REF:B Jun 17 Dec 17 Calendar Spread is set to download 'Pending'. | 2016-05-05 09:18:16 Symbol Error - REF:B Jun 17 Dec 17 Calendar Spread is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2016-05-05 09:18:16 Easy Screen | Starting real-time market data updates for: REF:B Jun 16 Sep 16 Calendar Spread. ID: 8 | 2016-05-05 09:18:16 Intraday data recording state for symbol REF:B Jun 16 Sep 16 Calendar Spread is set to download 'Pending'. | 2016-05-05 09:18:16 Symbol Error - REF:B Jun 16 Sep 16 Calendar Spread is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2016-05-05 09:18:16 Easy Screen | Starting real-time market data updates for: REF:B Dec 16 Jun 17 Calendar Spread. ID: 9 | 2016-05-05 09:18:16 Intraday data recording state for symbol REF:B Dec 16 Jun 17 Calendar Spread is set to download 'Pending'. | 2016-05-05 09:18:16 Symbol Error - REF:B Dec 16 Jun 17 Calendar Spread is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2016-05-05 09:18:16 Easy Screen | Starting real-time market data updates for: REF:B Aug 16. ID: 10 | 2016-05-05 09:18:16 Intraday data recording state for symbol REF:B Aug 16 is set to download 'Pending'. | 2016-05-05 09:18:16 Symbol Error - REF:B Aug 16 is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2016-05-05 09:18:16 Easy Screen | Starting real-time market data updates for: REF:B Sep 16. ID: 11 | 2016-05-05 09:18:16 Intraday data recording state for symbol REF:B Sep 16 is set to download 'Pending'. | 2016-05-05 09:18:16 Symbol Error - REF:B Sep 16 is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2016-05-05 09:18:16 Easy Screen | Starting real-time market data updates for: REF:B Oct 16. ID: 12 | 2016-05-05 09:18:16 Intraday data recording state for symbol REF:B Oct 16 is set to download 'Pending'. | 2016-05-05 09:18:16 Symbol Error - REF:B Oct 16 is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2016-05-05 09:18:16 Easy Screen | Starting real-time market data updates for: REF:B Nov 16. ID: 13 | 2016-05-05 09:18:16 Intraday data recording state for symbol REF:B Nov 16 is set to download 'Pending'. | 2016-05-05 09:18:16 Easy Screen | Starting real-time market data updates for: REF:B Dec 16 Dec 17 Calendar Spread. ID: 14 | 2016-05-05 09:18:16 Intraday data recording state for symbol REF:B Dec 16 Dec 17 Calendar Spread is set to download 'Pending'. | 2016-05-05 09:18:16 Symbol Error - REF:B Nov 16 is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2016-05-05 09:18:16 Symbol Error - REF:B Dec 16 Dec 17 Calendar Spread is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2016-05-05 09:18:16 Easy Screen | Starting real-time market data updates for: REF:B Sep 16 Oct 16 Calendar Spread. ID: 15 | 2016-05-05 09:18:16 Intraday data recording state for symbol REF:B Sep 16 Oct 16 Calendar Spread is set to download 'Pending'. | 2016-05-05 09:18:16 Symbol Error - REF:B Sep 16 Oct 16 Calendar Spread is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2016-05-05 09:18:16 Easy Screen | Starting real-time market data updates for: RXF:DX Jun 16. ID: 16 | 2016-05-05 09:18:16 Intraday data recording state for symbol RXF:DX Jun 16 is set to download 'Pending'. | 2016-05-05 09:18:16 Easy Screen | Starting real-time market data updates for: REF:B Jun 16. ID: 17 | 2016-05-05 09:18:16 HD Request # 3 | Downloading Historical Daily chart data for REF:B Jun 16. Starting date: 2016-04-28. Service: iceeurope.easyscreen | 2016-05-05 09:18:16 HD Request # 3 | Requesting historical Daily data for CBM16 starting at 2016-04-27 | 2016-05-05 09:18:16 Symbol Error - RXF:DX Jun 16 is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2016-05-05 09:18:16 Symbol Error - REF:B Jun 16 is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2016-05-05 09:18:16 HTTP connection to ds01.ddfplus.com:80 (0) | Resolved address ds01.ddfplus.com to IP 8.18.161.123. | 2016-05-05 09:18:16 Easy Screen | Starting real-time market data updates for: REF:B Dec 16 Mar 17 Calendar Spread. ID: 18 | 2016-05-05 09:18:16 Intraday data recording state for symbol REF:B Dec 16 Mar 17 Calendar Spread is set to download 'Pending'. | 2016-05-05 09:18:16 Symbol Error - REF:B Dec 16 Mar 17 Calendar Spread is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2016-05-05 09:18:16 REF:B Jul 16 Aug 16 Calendar Spread 60 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: JOEBROWN - OIL6.cht | 2016-05-05 09:18:16 Easy Screen | Starting real-time market data updates for: REF:B Jul 16 Dec 16 Calendar Spread. ID: 19 | 2016-05-05 09:18:16 Intraday data recording state for symbol REF:B Jul 16 Dec 16 Calendar Spread is set to download 'Pending'. | 2016-05-05 09:18:16 Symbol Error - REF:B Jul 16 Dec 16 Calendar Spread is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2016-05-05 09:18:16 Easy Screen | Starting real-time market data updates for: REF:B Sep 16 Dec 16 Calendar Spread. ID: 20 | 2016-05-05 09:18:16 Intraday data recording state for symbol REF:B Sep 16 Dec 16 Calendar Spread is set to download 'Pending'. | 2016-05-05 09:18:16 Symbol Error - REF:B Sep 16 Dec 16 Calendar Spread is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2016-05-05 09:18:16 Easy Screen | Starting real-time market data updates for: REF:B Jul 16 Sep 16 Calendar Spread. ID: 21 | 2016-05-05 09:18:16 Intraday data recording state for symbol REF:B Jul 16 Sep 16 Calendar Spread is set to download 'Pending'. | 2016-05-05 09:18:16 Symbol Error - REF:B Jul 16 Sep 16 Calendar Spread is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2016-05-05 09:18:16 HTTP connection to ds01.ddfplus.com:80 (9) | Connected. | 2016-05-05 09:18:16 Easy Screen | Starting real-time market data updates for: REF:B Oct 16 Nov 16 Calendar Spread. ID: 22 | 2016-05-05 09:18:16 Intraday data recording state for symbol REF:B Oct 16 Nov 16 Calendar Spread is set to download 'Pending'. | 2016-05-05 09:18:16 Symbol Error - REF:B Oct 16 Nov 16 Calendar Spread is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2016-05-05 09:18:16 Easy Screen | Starting real-time market data updates for: REF:B Nov 16 Dec 16 Calendar Spread. ID: 23 | 2016-05-05 09:18:17 Intraday data recording state for symbol REF:B Nov 16 Dec 16 Calendar Spread is set to download 'Pending'. | 2016-05-05 09:18:17 Symbol Error - REF:B Nov 16 Dec 16 Calendar Spread is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2016-05-05 09:18:17 Easy Screen | Starting real-time market data updates for: EXF:FESX Jun 16. ID: 24 | 2016-05-05 09:18:17 Intraday data recording state for symbol EXF:FESX Jun 16 is set to download 'Pending'. | 2016-05-05 09:18:17 Easy Screen | Starting real-time market data updates for: CGEF:ES Jun 16. ID: 25 | 2016-05-05 09:18:17 Intraday data recording state for symbol CGEF:ES Jun 16 is set to download 'Pending'. | 2016-05-05 09:18:17 HD Request # 2 | Requesting Intraday data. Start Date-Time: 2016-05-05 09:13:51. Record interval: 0. Symbol: REF:B Dec 16 | 2016-05-05 09:18:17 HD Request # 2 | Decompressing data. | 2016-05-05 09:18:17 HD Request # 2 | Receiving Intraday data for REF:B Dec 16 starting at 2016-05-05 09:13:51 | 2016-05-05 09:18:17 HD Request # 2 | Timestamp of first Intraday data file record written: 2016-05-05 09:14:07 | 2016-05-05 09:18:17 Socket (8) | Shutdown and closed. | 2016-05-05 09:18:17 The network socket for historical data has been closed. | 2016-05-05 09:18:17 HD Request # 2 | Received 37 records from 2016-05-05 09:13:51 to 2016-05-05 09:17:19 (3.5 minutes) and wrote 36 records for REF:B Dec 16 | 2016-05-05 09:18:17 HD Request # 2 | Intraday download COMPLETE for REF:B Dec 16. Completion time: 0s. Unique request ID: 1 | 2016-05-05 09:18:17 Removed historical data download ID 1 | 2016-05-05 09:18:17 Real-time Intraday chart data file updates started for REF:B Dec 16 | 2016-05-05 09:18:17 Opened cached Intraday file: C:\SierraChart\Data\REF~B Dec 16.scid | 2016-05-05 09:18:17 Intraday chart data file opened for REF:B Dec 16 | 2016-05-05 09:18:17 HD Request # 4 | Downloading Intraday chart data for REF:B Jul 16 to the file REF~B Jul 16.scid. Service: iceeurope.easyscreen | 2016-05-05 09:18:17 HD Request # 4 | Download start Date-Time: 2016-05-05 09:13:52.000 | 2016-05-05 09:18:17 HD Request # 4 | Using server: easyscreen.sierracharts.com port 10149 | 2016-05-05 09:18:17 Socket (0) | Resolved address ds9.sierracharts.com to IP 194.50.31.205. | 2016-05-05 09:18:17 Socket (10) | Connected. | 2016-05-05 09:18:17 HD Request # 4 | Sending historical data logon request message. | 2016-05-05 09:18:17 HD Request # 4 | Requesting Intraday data. Start Date-Time: 2016-05-05 09:13:52. Record interval: 0. Symbol: REF:B Jul 16 | 2016-05-05 09:18:17 HD Request # 4 | Decompressing data. | 2016-05-05 09:18:17 HD Request # 4 | Receiving Intraday data for REF:B Jul 16 starting at 2016-05-05 09:13:52 | 2016-05-05 09:18:17 HD Request # 4 | Timestamp of first Intraday data file record written: 2016-05-05 09:13:58 | 2016-05-05 09:18:17 Socket (10) | Shutdown and closed. | 2016-05-05 09:18:17 The network socket for historical data has been closed. | 2016-05-05 09:18:17 HD Request # 4 | Received 272 records from 2016-05-05 09:13:52 to 2016-05-05 09:17:56 (4.1 minutes) and wrote 271 records for REF:B Jul 16 | 2016-05-05 09:18:17 HD Request # 4 | Intraday download COMPLETE for REF:B Jul 16. Completion time: 0s. Unique request ID: 2 | 2016-05-05 09:18:17 Removed historical data download ID 2 | 2016-05-05 09:18:17 Real-time Intraday chart data file updates started for REF:B Jul 16 | 2016-05-05 09:18:17 Opened cached Intraday file: C:\SierraChart\Data\REF~B Jul 16.scid | 2016-05-05 09:18:17 Intraday chart data file opened for REF:B Jul 16 | 2016-05-05 09:18:17 HD Request # 5 | Downloading Intraday chart data for REF:B Jun 16 Dec 16 Calendar Spread to the file REF~B Jun 16 Dec 16 Calendar Spread.scid. Service: iceeurope.easyscreen | 2016-05-05 09:18:17 HD Request # 5 | Download start Date-Time: 2016-04-29 15:16:03.000 | 2016-05-05 09:18:17 HD Request # 5 | Using server: easyscreen.sierracharts.com port 10149 | 2016-05-05 09:18:17 Socket (0) | Resolved address ds9.sierracharts.com to IP 194.50.31.205. | 2016-05-05 09:18:17 Socket (11) | Connected. | 2016-05-05 09:18:17 HD Request # 5 | Sending historical data logon request message. | 2016-05-05 09:18:17 HD Request # 3 | Receiving historical Daily data for REF:B Jun 16 starting at 2016-04-28 | 2016-05-05 09:18:17 HD Request # 3 | Writing historical Daily data to the file REF~B Jun 16.dly | 2016-05-05 09:18:17 HD Request # 3 | Received 3 records from 2016-04-28 00:00:00 to 2016-04-29 00:00:00 (2.0 days) and wrote 2 records for REF:B Jun 16 | 2016-05-05 09:18:17 HD Request # 3 | Daily download COMPLETE for REF:B Jun 16. Completion time: 1s. Unique request ID: 17 | 2016-05-05 09:18:17 Removed historical data download ID 17 | 2016-05-05 09:18:17 HD Request # 5 | Requesting Intraday data. Start Date-Time: 2016-04-29 15:16:03. Record interval: 0. Symbol: REF:B Jun 16 Dec 16 Calendar Spread | 2016-05-05 09:18:17 HD Request # 5 | Decompressing data. | 2016-05-05 09:18:17 HD Request # 5 | Receiving Intraday data for REF:B Jun 16 Dec 16 Calendar Spread starting at 2016-04-29 15:16:03 | 2016-05-05 09:18:17 Socket (11) | Shutdown and closed. | 2016-05-05 09:18:17 The network socket for historical data has been closed. | 2016-05-05 09:18:17 HD Request # 5 | Received 1 record from 2016-04-29 15:16:03 to 2016-04-29 15:16:03 (0.0 seconds) and wrote 0 records for REF:B Jun 16 Dec 16 Calendar Spread | 2016-05-05 09:18:17 HD Request # 5 | Intraday download COMPLETE for REF:B Jun 16 Dec 16 Calendar Spread. Completion time: 1s. Unique request ID: 3 | 2016-05-05 09:18:17 Removed historical data download ID 3 | 2016-05-05 09:18:17 Real-time Intraday chart data file updates started for REF:B Jun 16 Dec 16 Calendar Spread | 2016-05-05 09:18:17 Opened cached Intraday file: C:\SierraChart\Data\REF~B Jun 16 Dec 16 Calendar Spread.scid | 2016-05-05 09:18:17 Intraday chart data file opened for REF:B Jun 16 Dec 16 Calendar Spread | 2016-05-05 09:18:17 HD Request # 6 | Downloading Intraday chart data for REF:B Jul 16 Aug 16 Calendar Spread to the file REF~B Jul 16 Aug 16 Calendar Spread.scid. Service: iceeurope.easyscreen | 2016-05-05 09:18:17 HD Request # 6 | Download start Date-Time: 2016-05-05 09:13:31.000 | 2016-05-05 09:18:17 HD Request # 6 | Using server: easyscreen.sierracharts.com port 10149 | 2016-05-05 09:18:17 Socket (0) | Resolved address ds9.sierracharts.com to IP 194.50.31.205. | 2016-05-05 09:18:17 Socket (12) | Connected. | 2016-05-05 09:18:17 HD Request # 6 | Sending historical data logon request message. | 2016-05-05 09:18:17 REF:B Jun 16 Daily #28 | Reloading chart. | 2016-05-05 09:18:17 HD Request # 6 | Requesting Intraday data. Start Date-Time: 2016-05-05 09:13:31. Record interval: 0. Symbol: REF:B Jul 16 Aug 16 Calendar Spread | 2016-05-05 09:18:17 HD Request # 6 | Decompressing data. | 2016-05-05 09:18:17 HD Request # 6 | Receiving Intraday data for REF:B Jul 16 Aug 16 Calendar Spread starting at 2016-05-05 09:13:31 | 2016-05-05 09:18:17 HD Request # 6 | Timestamp of first Intraday data file record written: 2016-05-05 09:14:07 | 2016-05-05 09:18:17 Socket (12) | Shutdown and closed. | 2016-05-05 09:18:17 The network socket for historical data has been closed. | 2016-05-05 09:18:17 HD Request # 6 | Received 43 records from 2016-05-05 09:13:31 to 2016-05-05 09:16:59 (3.5 minutes) and wrote 42 records for REF:B Jul 16 Aug 16 Calendar Spread | 2016-05-05 09:18:17 HD Request # 6 | Intraday download COMPLETE for REF:B Jul 16 Aug 16 Calendar Spread. Completion time: 0s. Unique request ID: 4 | 2016-05-05 09:18:17 Removed historical data download ID 4 | 2016-05-05 09:18:17 Real-time Intraday chart data file updates started for REF:B Jul 16 Aug 16 Calendar Spread | 2016-05-05 09:18:17 Opened cached Intraday file: C:\SierraChart\Data\REF~B Jul 16 Aug 16 Calendar Spread.scid | 2016-05-05 09:18:17 Intraday chart data file opened for REF:B Jul 16 Aug 16 Calendar Spread | 2016-05-05 09:18:17 HD Request # 7 | Downloading Intraday chart data for REF:B Jun 16 Jul 16 Calendar Spread to the file REF~B Jun 16 Jul 16 Calendar Spread.scid. Service: iceeurope.easyscreen | 2016-05-05 09:18:17 HD Request # 7 | Download start Date-Time: 2016-04-29 19:29:25.000 | 2016-05-05 09:18:17 HD Request # 7 | Using server: easyscreen.sierracharts.com port 10149 | 2016-05-05 09:18:17 Socket (0) | Resolved address ds9.sierracharts.com to IP 194.50.31.205. | 2016-05-05 09:18:17 Socket (13) | Connected. | 2016-05-05 09:18:17 HD Request # 7 | Sending historical data logon request message. | 2016-05-05 09:18:17 Chart #3 has tagged chart #37 for full recalculation. Chartbook: JOEBROWN - OIL6.cht | 2016-05-05 09:18:17 HD Request # 7 | Requesting Intraday data. Start Date-Time: 2016-04-29 19:29:25. Record interval: 0. Symbol: REF:B Jun 16 Jul 16 Calendar Spread | 2016-05-05 09:18:17 HD Request # 7 | Decompressing data. | 2016-05-05 09:18:17 HD Request # 7 | Receiving Intraday data for REF:B Jun 16 Jul 16 Calendar Spread starting at 2016-04-29 19:29:25 | 2016-05-05 09:18:17 Socket (13) | Shutdown and closed. | 2016-05-05 09:18:17 The network socket for historical data has been closed. | 2016-05-05 09:18:17 HD Request # 7 | Received 5 records from 2016-04-29 19:29:25 to 2016-04-29 19:29:25 (0.0 seconds) and wrote 0 records for REF:B Jun 16 Jul 16 Calendar Spread | 2016-05-05 09:18:17 HD Request # 7 | Intraday download COMPLETE for REF:B Jun 16 Jul 16 Calendar Spread. Completion time: 0s. Unique request ID: 5 | 2016-05-05 09:18:17 Removed historical data download ID 5 | 2016-05-05 09:18:17 Real-time Intraday chart data file updates started for REF:B Jun 16 Jul 16 Calendar Spread | 2016-05-05 09:18:17 Opened cached Intraday file: C:\SierraChart\Data\REF~B Jun 16 Jul 16 Calendar Spread.scid | 2016-05-05 09:18:17 Intraday chart data file opened for REF:B Jun 16 Jul 16 Calendar Spread | 2016-05-05 09:18:17 HD Request # 8 | Downloading Intraday chart data for REF:B Aug 16 Sep 16 Calendar Spread to the file REF~B Aug 16 Sep 16 Calendar Spread.scid. Service: iceeurope.easyscreen | 2016-05-05 09:18:17 HD Request # 8 | Download start Date-Time: 2016-05-05 09:12:58.000 | 2016-05-05 09:18:17 HD Request # 8 | Using server: easyscreen.sierracharts.com port 10149 | 2016-05-05 09:18:17 Socket (0) | Resolved address ds9.sierracharts.com to IP 194.50.31.205. | 2016-05-05 09:18:17 Socket (14) | Connected. | 2016-05-05 09:18:17 HD Request # 8 | Sending historical data logon request message. | 2016-05-05 09:18:17 HD Request # 8 | Requesting Intraday data. Start Date-Time: 2016-05-05 09:12:58. Record interval: 0. Symbol: REF:B Aug 16 Sep 16 Calendar Spread | 2016-05-05 09:18:17 HD Request # 8 | Decompressing data. | 2016-05-05 09:18:17 HD Request # 8 | Receiving Intraday data for REF:B Aug 16 Sep 16 Calendar Spread starting at 2016-05-05 09:12:58 | 2016-05-05 09:18:17 HD Request # 8 | Timestamp of first Intraday data file record written: 2016-05-05 09:15:49 | 2016-05-05 09:18:17 Socket (14) | Shutdown and closed. | 2016-05-05 09:18:17 The network socket for historical data has been closed. | 2016-05-05 09:18:17 HD Request # 8 | Received 17 records from 2016-05-05 09:12:58 to 2016-05-05 09:16:59 (4.0 minutes) and wrote 16 records for REF:B Aug 16 Sep 16 Calendar Spread | 2016-05-05 09:18:17 HD Request # 8 | Intraday download COMPLETE for REF:B Aug 16 Sep 16 Calendar Spread. Completion time: 0s. Unique request ID: 6 | 2016-05-05 09:18:17 Removed historical data download ID 6 | 2016-05-05 09:18:17 Real-time Intraday chart data file updates started for REF:B Aug 16 Sep 16 Calendar Spread | 2016-05-05 09:18:17 Opened cached Intraday file: C:\SierraChart\Data\REF~B Aug 16 Sep 16 Calendar Spread.scid | 2016-05-05 09:18:17 Intraday chart data file opened for REF:B Aug 16 Sep 16 Calendar Spread | 2016-05-05 09:18:17 HD Request # 9 | Downloading Intraday chart data for REF:B Jun 17 Dec 17 Calendar Spread to the file REF~B Jun 17 Dec 17 Calendar Spread.scid. Service: iceeurope.easyscreen | 2016-05-05 09:18:17 HD Request # 9 | Download start Date-Time: 2016-05-05 09:08:30.000 | 2016-05-05 09:18:17 HD Request # 9 | Using server: easyscreen.sierracharts.com port 10149 | 2016-05-05 09:18:17 Chart #7 has tagged chart #19 for full recalculation. Chartbook: JOEBROWN - OIL6.cht | 2016-05-05 09:18:17 Socket (0) | Resolved address ds9.sierracharts.com to IP 194.50.31.205. | 2016-05-05 09:18:17 REF:B Jul 16 15 Min #37 | Performing a full recalculation because it has been tagged. Chartbook: JOEBROWN - OIL6.cht | 2016-05-05 09:18:17 Socket (15) | Connected. | 2016-05-05 09:18:17 HD Request # 9 | Sending historical data logon request message. | 2016-05-05 09:18:17 HD Request # 9 | Requesting Intraday data. Start Date-Time: 2016-05-05 09:08:30. Record interval: 0. Symbol: REF:B Jun 17 Dec 17 Calendar Spread | 2016-05-05 09:18:17 HD Request # 9 | Decompressing data. | 2016-05-05 09:18:17 HD Request # 9 | Receiving Intraday data for REF:B Jun 17 Dec 17 Calendar Spread starting at 2016-05-05 09:08:30 | 2016-05-05 09:18:17 HD Request # 9 | Timestamp of first Intraday data file record written: 2016-05-05 09:14:07 | 2016-05-05 09:18:17 Socket (15) | Shutdown and closed. | 2016-05-05 09:18:17 The network socket for historical data has been closed. | 2016-05-05 09:18:17 HD Request # 9 | Received 6 records from 2016-05-05 09:08:30 to 2016-05-05 09:16:52 (8.4 minutes) and wrote 5 records for REF:B Jun 17 Dec 17 Calendar Spread | 2016-05-05 09:18:17 HD Request # 9 | Intraday download COMPLETE for REF:B Jun 17 Dec 17 Calendar Spread. Completion time: 0s. Unique request ID: 7 | 2016-05-05 09:18:17 Removed historical data download ID 7 | 2016-05-05 09:18:17 Real-time Intraday chart data file updates started for REF:B Jun 17 Dec 17 Calendar Spread | 2016-05-05 09:18:17 Opened cached Intraday file: C:\SierraChart\Data\REF~B Jun 17 Dec 17 Calendar Spread.scid | 2016-05-05 09:18:17 Intraday chart data file opened for REF:B Jun 17 Dec 17 Calendar Spread | 2016-05-05 09:18:17 HD Request # 10 | Downloading Intraday chart data for REF:B Jun 16 Sep 16 Calendar Spread to the file REF~B Jun 16 Sep 16 Calendar Spread.scid. Service: iceeurope.easyscreen | 2016-05-05 09:18:17 HD Request # 10 | Download start Date-Time: 2016-04-29 15:49:25.000 | 2016-05-05 09:18:17 HD Request # 10 | Using server: easyscreen.sierracharts.com port 10149 | 2016-05-05 09:18:17 Socket (0) | Resolved address ds9.sierracharts.com to IP 194.50.31.205. | 2016-05-05 09:18:17 REF:B Jun 16 Jul 16 Calendar Spread 10 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: JOEBROWN - OIL6.cht | 2016-05-05 09:18:18 Socket (16) | Connected. | 2016-05-05 09:18:18 HD Request # 10 | Sending historical data logon request message. | 2016-05-05 09:18:18 HD Request # 10 | Requesting Intraday data. Start Date-Time: 2016-04-29 15:49:25. Record interval: 0. Symbol: REF:B Jun 16 Sep 16 Calendar Spread | 2016-05-05 09:18:18 HD Request # 10 | Decompressing data. | 2016-05-05 09:18:18 HD Request # 10 | Receiving Intraday data for REF:B Jun 16 Sep 16 Calendar Spread starting at 2016-04-29 15:49:25 | 2016-05-05 09:18:18 Socket (16) | Shutdown and closed. | 2016-05-05 09:18:18 The network socket for historical data has been closed. | 2016-05-05 09:18:18 HD Request # 10 | Received 1 record from 2016-04-29 15:49:25 to 2016-04-29 15:49:25 (0.0 seconds) and wrote 0 records for REF:B Jun 16 Sep 16 Calendar Spread | 2016-05-05 09:18:18 HD Request # 10 | Intraday download COMPLETE for REF:B Jun 16 Sep 16 Calendar Spread. Completion time: 0s. Unique request ID: 8 | 2016-05-05 09:18:18 Removed historical data download ID 8 | 2016-05-05 09:18:18 Real-time Intraday chart data file updates started for REF:B Jun 16 Sep 16 Calendar Spread | 2016-05-05 09:18:18 Opened cached Intraday file: C:\SierraChart\Data\REF~B Jun 16 Sep 16 Calendar Spread.scid | 2016-05-05 09:18:18 Intraday chart data file opened for REF:B Jun 16 Sep 16 Calendar Spread | 2016-05-05 09:18:18 HD Request # 11 | Downloading Intraday chart data for REF:B Dec 16 Jun 17 Calendar Spread to the file REF~B Dec 16 Jun 17 Calendar Spread.scid. Service: iceeurope.easyscreen | 2016-05-05 09:18:18 HD Request # 11 | Download start Date-Time: 2016-05-05 09:13:42.000 | 2016-05-05 09:18:18 HD Request # 11 | Using server: easyscreen.sierracharts.com port 10149 | 2016-05-05 09:18:18 Socket (0) | Resolved address ds9.sierracharts.com to IP 194.50.31.205. | 2016-05-05 09:18:18 Socket (17) | Connected. | 2016-05-05 09:18:18 HD Request # 11 | Sending historical data logon request message. | 2016-05-05 09:18:18 Chart #30 has tagged chart #13 for full recalculation. Chartbook: JOEBROWN - OIL6.cht | 2016-05-05 09:18:18 REF:B Jul 16 Aug 16 Calendar Spread 60 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: JOEBROWN - OIL6.cht | 2016-05-05 09:18:18 HD Request # 11 | Requesting Intraday data. Start Date-Time: 2016-05-05 09:13:42. Record interval: 0. Symbol: REF:B Dec 16 Jun 17 Calendar Spread | 2016-05-05 09:18:18 HD Request # 11 | Decompressing data. | 2016-05-05 09:18:18 HD Request # 11 | Receiving Intraday data for REF:B Dec 16 Jun 17 Calendar Spread starting at 2016-05-05 09:13:42 | 2016-05-05 09:18:18 HD Request # 11 | Timestamp of first Intraday data file record written: 2016-05-05 09:14:20 | 2016-05-05 09:18:18 Socket (17) | Shutdown and closed. | 2016-05-05 09:18:18 The network socket for historical data has been closed. | 2016-05-05 09:18:18 HD Request # 11 | Received 7 records from 2016-05-05 09:13:42 to 2016-05-05 09:16:52 (3.2 minutes) and wrote 4 records for REF:B Dec 16 Jun 17 Calendar Spread | 2016-05-05 09:18:18 HD Request # 11 | Intraday download COMPLETE for REF:B Dec 16 Jun 17 Calendar Spread. Completion time: 0s. Unique request ID: 9 | 2016-05-05 09:18:18 Removed historical data download ID 9 | 2016-05-05 09:18:18 Real-time Intraday chart data file updates started for REF:B Dec 16 Jun 17 Calendar Spread | 2016-05-05 09:18:18 Opened cached Intraday file: C:\SierraChart\Data\REF~B Dec 16 Jun 17 Calendar Spread.scid | 2016-05-05 09:18:18 Intraday chart data file opened for REF:B Dec 16 Jun 17 Calendar Spread | 2016-05-05 09:18:18 HD Request # 12 | Downloading Intraday chart data for REF:B Aug 16 to the file REF~B Aug 16.scid. Service: iceeurope.easyscreen | 2016-05-05 09:18:18 HD Request # 12 | Download start Date-Time: 2016-05-05 09:13:52.000 | 2016-05-05 09:18:18 HD Request # 12 | Using server: easyscreen.sierracharts.com port 10149 | 2016-05-05 09:18:18 Socket (0) | Resolved address ds9.sierracharts.com to IP 194.50.31.205. | 2016-05-05 09:18:18 Socket (18) | Connected. | 2016-05-05 09:18:18 HD Request # 12 | Sending historical data logon request message. | 2016-05-05 09:18:18 Chart #14 has tagged chart #15 for full recalculation. Chartbook: JOEBROWN - OIL6.cht | 2016-05-05 09:18:18 HD Request # 12 | Requesting Intraday data. Start Date-Time: 2016-05-05 09:13:52. Record interval: 0. Symbol: REF:B Aug 16 | 2016-05-05 09:18:18 HD Request # 12 | Decompressing data. | 2016-05-05 09:18:18 HD Request # 12 | Receiving Intraday data for REF:B Aug 16 starting at 2016-05-05 09:13:52 | 2016-05-05 09:18:18 HD Request # 12 | Timestamp of first Intraday data file record written: 2016-05-05 09:14:06 | 2016-05-05 09:18:18 Socket (18) | Shutdown and closed. | 2016-05-05 09:18:18 The network socket for historical data has been closed. | 2016-05-05 09:18:18 HD Request # 12 | Received 168 records from 2016-05-05 09:13:52 to 2016-05-05 09:17:56 (4.1 minutes) and wrote 167 records for REF:B Aug 16 | 2016-05-05 09:18:18 HD Request # 12 | Intraday download COMPLETE for REF:B Aug 16. Completion time: 0s. Unique request ID: 10 | 2016-05-05 09:18:18 Removed historical data download ID 10 | 2016-05-05 09:18:18 Real-time Intraday chart data file updates started for REF:B Aug 16 | 2016-05-05 09:18:18 Opened cached Intraday file: C:\SierraChart\Data\REF~B Aug 16.scid | 2016-05-05 09:18:18 Intraday chart data file opened for REF:B Aug 16 | 2016-05-05 09:18:18 HD Request # 13 | Downloading Intraday chart data for REF:B Sep 16 to the file REF~B Sep 16.scid. Service: iceeurope.easyscreen | 2016-05-05 09:18:18 HD Request # 13 | Download start Date-Time: 2016-05-05 09:12:51.000 | 2016-05-05 09:18:18 HD Request # 13 | Using server: easyscreen.sierracharts.com port 10149 | 2016-05-05 09:18:18 Socket (0) | Resolved address ds9.sierracharts.com to IP 194.50.31.205. | 2016-05-05 09:18:18 Socket (19) | Connected. | 2016-05-05 09:18:18 HD Request # 13 | Sending historical data logon request message. | 2016-05-05 09:18:18 REF:B Jun 16 Dec 16 Calendar Spread 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: JOEBROWN - OIL6.cht | 2016-05-05 09:18:18 HD Request # 13 | Requesting Intraday data. Start Date-Time: 2016-05-05 09:12:51. Record interval: 0. Symbol: REF:B Sep 16 | 2016-05-05 09:18:18 HD Request # 13 | Decompressing data. | 2016-05-05 09:18:18 HD Request # 13 | Receiving Intraday data for REF:B Sep 16 starting at 2016-05-05 09:12:51 | 2016-05-05 09:18:18 HD Request # 13 | Timestamp of first Intraday data file record written: 2016-05-05 09:14:07 | 2016-05-05 09:18:18 Socket (19) | Shutdown and closed. | 2016-05-05 09:18:18 The network socket for historical data has been closed. | 2016-05-05 09:18:18 HD Request # 13 | Received 49 records from 2016-05-05 09:12:51 to 2016-05-05 09:17:32 (4.7 minutes) and wrote 48 records for REF:B Sep 16 | 2016-05-05 09:18:18 HD Request # 13 | Intraday download COMPLETE for REF:B Sep 16. Completion time: 0s. Unique request ID: 11 | 2016-05-05 09:18:18 Removed historical data download ID 11 | 2016-05-05 09:18:18 Real-time Intraday chart data file updates started for REF:B Sep 16 | 2016-05-05 09:18:18 Opened cached Intraday file: C:\SierraChart\Data\REF~B Sep 16.scid | 2016-05-05 09:18:18 Intraday chart data file opened for REF:B Sep 16 | 2016-05-05 09:18:18 HD Request # 14 | Downloading Intraday chart data for REF:B Oct 16 to the file REF~B Oct 16.scid. Service: iceeurope.easyscreen | 2016-05-05 09:18:18 HD Request # 14 | Download start Date-Time: 2016-05-05 09:13:44.000 | 2016-05-05 09:18:18 HD Request # 14 | Using server: easyscreen.sierracharts.com port 10149 | 2016-05-05 09:18:18 Socket (0) | Resolved address ds9.sierracharts.com to IP 194.50.31.205. | 2016-05-05 09:18:18 Socket (20) | Connected. | 2016-05-05 09:18:18 HD Request # 14 | Sending historical data logon request message. | 2016-05-05 09:18:18 HD Request # 14 | Requesting Intraday data. Start Date-Time: 2016-05-05 09:13:44. Record interval: 0. Symbol: REF:B Oct 16 | 2016-05-05 09:18:18 HD Request # 14 | Decompressing data. | 2016-05-05 09:18:18 HD Request # 14 | Receiving Intraday data for REF:B Oct 16 starting at 2016-05-05 09:13:44 | 2016-05-05 09:18:18 HD Request # 14 | Timestamp of first Intraday data file record written: 2016-05-05 09:14:07 | 2016-05-05 09:18:18 Socket (20) | Shutdown and closed. | 2016-05-05 09:18:18 The network socket for historical data has been closed. | 2016-05-05 09:18:18 HD Request # 14 | Received 38 records from 2016-05-05 09:13:44 to 2016-05-05 09:17:32 (3.8 minutes) and wrote 37 records for REF:B Oct 16 | 2016-05-05 09:18:18 HD Request # 14 | Intraday download COMPLETE for REF:B Oct 16. Completion time: 0s. Unique request ID: 12 | 2016-05-05 09:18:18 Removed historical data download ID 12 | 2016-05-05 09:18:18 Real-time Intraday chart data file updates started for REF:B Oct 16 | 2016-05-05 09:18:18 Opened cached Intraday file: C:\SierraChart\Data\REF~B Oct 16.scid | 2016-05-05 09:18:18 Intraday chart data file opened for REF:B Oct 16 | 2016-05-05 09:18:18 HD Request # 15 | Downloading Intraday chart data for REF:B Nov 16 to the file REF~B Nov 16.scid. Service: iceeurope.easyscreen | 2016-05-05 09:18:18 HD Request # 15 | Download start Date-Time: 2016-05-05 09:04:24.000 | 2016-05-05 09:18:18 HD Request # 15 | Using server: easyscreen.sierracharts.com port 10149 | 2016-05-05 09:18:18 Socket (0) | Resolved address ds9.sierracharts.com to IP 194.50.31.205. | 2016-05-05 09:18:18 Socket (21) | Connected. | 2016-05-05 09:18:18 HD Request # 15 | Sending historical data logon request message. | 2016-05-05 09:18:18 HD Request # 15 | Requesting Intraday data. Start Date-Time: 2016-05-05 09:04:24. Record interval: 0. Symbol: REF:B Nov 16 | 2016-05-05 09:18:18 HD Request # 15 | Decompressing data. | 2016-05-05 09:18:18 HD Request # 15 | Receiving Intraday data for REF:B Nov 16 starting at 2016-05-05 09:04:24 | 2016-05-05 09:18:18 HD Request # 15 | Timestamp of first Intraday data file record written: 2016-05-05 09:14:07 | 2016-05-05 09:18:18 Socket (21) | Shutdown and closed. | 2016-05-05 09:18:18 The network socket for historical data has been closed. | 2016-05-05 09:18:18 HD Request # 15 | Received 12 records from 2016-05-05 09:04:24 to 2016-05-05 09:16:38 (12.2 minutes) and wrote 11 records for REF:B Nov 16 | 2016-05-05 09:18:18 HD Request # 15 | Intraday download COMPLETE for REF:B Nov 16. Completion time: 0s. Unique request ID: 13 | 2016-05-05 09:18:18 Removed historical data download ID 13 | 2016-05-05 09:18:18 Real-time Intraday chart data file updates started for REF:B Nov 16 | 2016-05-05 09:18:18 Opened cached Intraday file: C:\SierraChart\Data\REF~B Nov 16.scid | 2016-05-05 09:18:18 Intraday chart data file opened for REF:B Nov 16 | 2016-05-05 09:18:18 HD Request # 16 | Downloading Intraday chart data for REF:B Dec 16 Dec 17 Calendar Spread to the file REF~B Dec 16 Dec 17 Calendar Spread.scid. Service: iceeurope.easyscreen | 2016-05-05 09:18:18 HD Request # 16 | Download start Date-Time: 2016-05-05 09:13:56.000 | 2016-05-05 09:18:18 HD Request # 16 | Using server: easyscreen.sierracharts.com port 10149 | 2016-05-05 09:18:18 Socket (0) | Resolved address ds9.sierracharts.com to IP 194.50.31.205. | 2016-05-05 09:18:18 Socket (22) | Connected. | 2016-05-05 09:18:18 HD Request # 16 | Sending historical data logon request message. | 2016-05-05 09:18:18 HD Request # 16 | Requesting Intraday data. Start Date-Time: 2016-05-05 09:13:56. Record interval: 0. Symbol: REF:B Dec 16 Dec 17 Calendar Spread | 2016-05-05 09:18:18 HD Request # 16 | Decompressing data. | 2016-05-05 09:18:18 HD Request # 16 | Receiving Intraday data for REF:B Dec 16 Dec 17 Calendar Spread starting at 2016-05-05 09:13:56 | 2016-05-05 09:18:18 HD Request # 16 | Timestamp of first Intraday data file record written: 2016-05-05 09:14:05 | 2016-05-05 09:18:18 Socket (22) | Shutdown and closed. | 2016-05-05 09:18:18 The network socket for historical data has been closed. | 2016-05-05 09:18:18 HD Request # 16 | Received 12 records from 2016-05-05 09:13:56 to 2016-05-05 09:16:52 (2.9 minutes) and wrote 11 records for REF:B Dec 16 Dec 17 Calendar Spread | 2016-05-05 09:18:18 HD Request # 16 | Intraday download COMPLETE for REF:B Dec 16 Dec 17 Calendar Spread. Completion time: 0s. Unique request ID: 14 | 2016-05-05 09:18:18 Removed historical data download ID 14 | 2016-05-05 09:18:18 Real-time Intraday chart data file updates started for REF:B Dec 16 Dec 17 Calendar Spread | 2016-05-05 09:18:18 Opened cached Intraday file: C:\SierraChart\Data\REF~B Dec 16 Dec 17 Calendar Spread.scid | 2016-05-05 09:18:18 Intraday chart data file opened for REF:B Dec 16 Dec 17 Calendar Spread | 2016-05-05 09:18:18 HD Request # 17 | Downloading Intraday chart data for REF:B Sep 16 Oct 16 Calendar Spread to the file REF~B Sep 16 Oct 16 Calendar Spread.scid. Service: iceeurope.easyscreen | 2016-05-05 09:18:18 HD Request # 17 | Download start Date-Time: 2016-05-05 09:04:24.000 | 2016-05-05 09:18:18 HD Request # 17 | Using server: easyscreen.sierracharts.com port 10149 | 2016-05-05 09:18:18 Socket (0) | Resolved address ds9.sierracharts.com to IP 194.50.31.205. | 2016-05-05 09:18:18 Socket (23) | Connected. | 2016-05-05 09:18:18 HD Request # 17 | Sending historical data logon request message. | 2016-05-05 09:18:18 HD Request # 17 | Requesting Intraday data. Start Date-Time: 2016-05-05 09:04:24. Record interval: 0. Symbol: REF:B Sep 16 Oct 16 Calendar Spread | 2016-05-05 09:18:18 HD Request # 17 | Decompressing data. | 2016-05-05 09:18:18 HD Request # 17 | Receiving Intraday data for REF:B Sep 16 Oct 16 Calendar Spread starting at 2016-05-05 09:04:24 | 2016-05-05 09:18:18 HD Request # 17 | Timestamp of first Intraday data file record written: 2016-05-05 09:14:07 | 2016-05-05 09:18:18 Socket (23) | Shutdown and closed. | 2016-05-05 09:18:18 The network socket for historical data has been closed. | 2016-05-05 09:18:18 HD Request # 17 | Received 47 records from 2016-05-05 09:04:24 to 2016-05-05 09:17:32 (13.1 minutes) and wrote 45 records for REF:B Sep 16 Oct 16 Calendar Spread | 2016-05-05 09:18:18 HD Request # 17 | Intraday download COMPLETE for REF:B Sep 16 Oct 16 Calendar Spread. Completion time: 0s. Unique request ID: 15 | 2016-05-05 09:18:18 Removed historical data download ID 15 | 2016-05-05 09:18:18 Real-time Intraday chart data file updates started for REF:B Sep 16 Oct 16 Calendar Spread | 2016-05-05 09:18:18 Opened cached Intraday file: C:\SierraChart\Data\REF~B Sep 16 Oct 16 Calendar Spread.scid | 2016-05-05 09:18:18 Intraday chart data file opened for REF:B Sep 16 Oct 16 Calendar Spread | 2016-05-05 09:18:18 HD Request # 18 | Downloading Intraday chart data for RXF:DX Jun 16 to the file RXF~DX Jun 16.scid. Service: iceus.easyscreen | 2016-05-05 09:18:18 HD Request # 18 | Download start Date-Time: 2016-05-05 09:13:00.000 | 2016-05-05 09:18:18 HD Request # 18 | Using server: easyscreen.sierracharts.com port 10149 | 2016-05-05 09:18:18 Socket (0) | Resolved address ds9.sierracharts.com to IP 194.50.31.205. | 2016-05-05 09:18:18 Socket (24) | Connected. | 2016-05-05 09:18:18 HD Request # 18 | Sending historical data logon request message. | 2016-05-05 09:18:18 HD Request # 18 | Requesting Intraday data. Start Date-Time: 2016-05-05 09:13:00. Record interval: 0. Symbol: RXF:DX Jun 16 | 2016-05-05 09:18:18 HD Request # 18 | Decompressing data. | 2016-05-05 09:18:18 HD Request # 18 | Receiving Intraday data for RXF:DX Jun 16 starting at 2016-05-05 09:13:00 | 2016-05-05 09:18:18 HD Request # 18 | Timestamp of first Intraday data file record written: 2016-05-05 09:13:58 | 2016-05-05 09:18:18 Socket (24) | Shutdown and closed. | 2016-05-05 09:18:18 The network socket for historical data has been closed. | 2016-05-05 09:18:18 HD Request # 18 | Received 37 records from 2016-05-05 09:13:00 to 2016-05-05 09:17:55 (4.9 minutes) and wrote 32 records for RXF:DX Jun 16 | 2016-05-05 09:18:18 HD Request # 18 | Intraday download COMPLETE for RXF:DX Jun 16. Completion time: 0s. Unique request ID: 16 | 2016-05-05 09:18:18 Removed historical data download ID 16 | 2016-05-05 09:18:18 Real-time Intraday chart data file updates started for RXF:DX Jun 16 | 2016-05-05 09:18:18 Opened cached Intraday file: C:\SierraChart\Data\RXF~DX Jun 16.scid | 2016-05-05 09:18:18 Intraday chart data file opened for RXF:DX Jun 16 | 2016-05-05 09:18:18 HD Request # 19 | Downloading Intraday chart data for REF:B Dec 16 Mar 17 Calendar Spread to the file REF~B Dec 16 Mar 17 Calendar Spread.scid. Service: iceeurope.easyscreen | 2016-05-05 09:18:18 HD Request # 19 | Download start Date-Time: 2016-05-05 09:09:03.000 | 2016-05-05 09:18:18 HD Request # 19 | Using server: easyscreen.sierracharts.com port 10149 | 2016-05-05 09:18:18 Socket (0) | Resolved address ds9.sierracharts.com to IP 194.50.31.205. | 2016-05-05 09:18:18 Socket (25) | Connected. | 2016-05-05 09:18:19 HD Request # 19 | Sending historical data logon request message. | 2016-05-05 09:18:19 HD Request # 19 | Requesting Intraday data. Start Date-Time: 2016-05-05 09:09:03. Record interval: 0. Symbol: REF:B Dec 16 Mar 17 Calendar Spread | 2016-05-05 09:18:19 HD Request # 19 | Decompressing data. | 2016-05-05 09:18:19 HD Request # 19 | Receiving Intraday data for REF:B Dec 16 Mar 17 Calendar Spread starting at 2016-05-05 09:09:03 | 2016-05-05 09:18:19 Socket (25) | Shutdown and closed. | 2016-05-05 09:18:19 The network socket for historical data has been closed. | 2016-05-05 09:18:19 HD Request # 19 | Received 1 record from 2016-05-05 09:09:03 to 2016-05-05 09:09:03 (0.0 seconds) and wrote 0 records for REF:B Dec 16 Mar 17 Calendar Spread | 2016-05-05 09:18:19 HD Request # 19 | Intraday download COMPLETE for REF:B Dec 16 Mar 17 Calendar Spread. Completion time: 0s. Unique request ID: 18 | 2016-05-05 09:18:19 Removed historical data download ID 18 | 2016-05-05 09:18:19 Real-time Intraday chart data file updates started for REF:B Dec 16 Mar 17 Calendar Spread | 2016-05-05 09:18:19 Opened cached Intraday file: C:\SierraChart\Data\REF~B Dec 16 Mar 17 Calendar Spread.scid | 2016-05-05 09:18:19 Intraday chart data file opened for REF:B Dec 16 Mar 17 Calendar Spread | 2016-05-05 09:18:19 HD Request # 20 | Downloading Intraday chart data for REF:B Jul 16 Dec 16 Calendar Spread to the file REF~B Jul 16 Dec 16 Calendar Spread.scid. Service: iceeurope.easyscreen | 2016-05-05 09:18:19 HD Request # 20 | Download start Date-Time: 2016-05-05 09:13:51.000 | 2016-05-05 09:18:19 HD Request # 20 | Using server: easyscreen.sierracharts.com port 10149 | 2016-05-05 09:18:19 Socket (0) | Resolved address ds9.sierracharts.com to IP 194.50.31.205. | 2016-05-05 09:18:19 Socket (26) | Connected. | 2016-05-05 09:18:19 HD Request # 20 | Sending historical data logon request message. | 2016-05-05 09:18:19 Chart #26 has tagged chart #10 for full recalculation. Chartbook: JOEBROWN - OIL6.cht | 2016-05-05 09:18:19 Chart #21 has tagged chart #44 for full recalculation. Chartbook: JOEBROWN - OIL6.cht | 2016-05-05 09:18:19 HD Request # 20 | Requesting Intraday data. Start Date-Time: 2016-05-05 09:13:51. Record interval: 0. Symbol: REF:B Jul 16 Dec 16 Calendar Spread | 2016-05-05 09:18:19 HD Request # 20 | Decompressing data. | 2016-05-05 09:18:19 HD Request # 20 | Receiving Intraday data for REF:B Jul 16 Dec 16 Calendar Spread starting at 2016-05-05 09:13:51 | 2016-05-05 09:18:19 HD Request # 20 | Timestamp of first Intraday data file record written: 2016-05-05 09:14:07 | 2016-05-05 09:18:19 Socket (26) | Shutdown and closed. | 2016-05-05 09:18:19 The network socket for historical data has been closed. | 2016-05-05 09:18:19 HD Request # 20 | Received 28 records from 2016-05-05 09:13:51 to 2016-05-05 09:16:14 (2.4 minutes) and wrote 27 records for REF:B Jul 16 Dec 16 Calendar Spread | 2016-05-05 09:18:19 HD Request # 20 | Intraday download COMPLETE for REF:B Jul 16 Dec 16 Calendar Spread. Completion time: 0s. Unique request ID: 19 | 2016-05-05 09:18:19 Removed historical data download ID 19 | 2016-05-05 09:18:19 Real-time Intraday chart data file updates started for REF:B Jul 16 Dec 16 Calendar Spread | 2016-05-05 09:18:19 Opened cached Intraday file: C:\SierraChart\Data\REF~B Jul 16 Dec 16 Calendar Spread.scid | 2016-05-05 09:18:19 Intraday chart data file opened for REF:B Jul 16 Dec 16 Calendar Spread | 2016-05-05 09:18:19 HD Request # 21 | Downloading Intraday chart data for REF:B Sep 16 Dec 16 Calendar Spread to the file REF~B Sep 16 Dec 16 Calendar Spread.scid. Service: iceeurope.easyscreen | 2016-05-05 09:18:19 HD Request # 21 | Download start Date-Time: 2016-05-05 09:12:51.000 | 2016-05-05 09:18:19 HD Request # 21 | Using server: easyscreen.sierracharts.com port 10149 | 2016-05-05 09:18:19 Socket (0) | Resolved address ds9.sierracharts.com to IP 194.50.31.205. | 2016-05-05 09:18:19 Socket (27) | Connected. | 2016-05-05 09:18:19 HD Request # 21 | Sending historical data logon request message. | 2016-05-05 09:18:19 Chart #24 has tagged chart #39 for full recalculation. Chartbook: JOEBROWN - OIL6.cht | 2016-05-05 09:18:19 HD Request # 21 | Requesting Intraday data. Start Date-Time: 2016-05-05 09:12:51. Record interval: 0. Symbol: REF:B Sep 16 Dec 16 Calendar Spread | 2016-05-05 09:18:19 HD Request # 21 | Decompressing data. | 2016-05-05 09:18:19 HD Request # 21 | Receiving Intraday data for REF:B Sep 16 Dec 16 Calendar Spread starting at 2016-05-05 09:12:51 | 2016-05-05 09:18:19 HD Request # 21 | Timestamp of first Intraday data file record written: 2016-05-05 09:14:11 | 2016-05-05 09:18:19 Socket (27) | Shutdown and closed. | 2016-05-05 09:18:19 The network socket for historical data has been closed. | 2016-05-05 09:18:19 HD Request # 21 | Received 9 records from 2016-05-05 09:12:51 to 2016-05-05 09:17:19 (4.5 minutes) and wrote 8 records for REF:B Sep 16 Dec 16 Calendar Spread | 2016-05-05 09:18:19 HD Request # 21 | Intraday download COMPLETE for REF:B Sep 16 Dec 16 Calendar Spread. Completion time: 0s. Unique request ID: 20 | 2016-05-05 09:18:19 Removed historical data download ID 20 | 2016-05-05 09:18:19 Real-time Intraday chart data file updates started for REF:B Sep 16 Dec 16 Calendar Spread | 2016-05-05 09:18:19 Opened cached Intraday file: C:\SierraChart\Data\REF~B Sep 16 Dec 16 Calendar Spread.scid | 2016-05-05 09:18:19 Intraday chart data file opened for REF:B Sep 16 Dec 16 Calendar Spread | 2016-05-05 09:18:19 HD Request # 22 | Downloading Intraday chart data for REF:B Jul 16 Sep 16 Calendar Spread to the file REF~B Jul 16 Sep 16 Calendar Spread.scid. Service: iceeurope.easyscreen | 2016-05-05 09:18:19 HD Request # 22 | Download start Date-Time: 2016-05-05 09:13:31.000 | 2016-05-05 09:18:19 HD Request # 22 | Using server: easyscreen.sierracharts.com port 10149 | 2016-05-05 09:18:19 Socket (0) | Resolved address ds9.sierracharts.com to IP 194.50.31.205. | 2016-05-05 09:18:19 Socket (28) | Connected. | 2016-05-05 09:18:19 HD Request # 22 | Sending historical data logon request message. | 2016-05-05 09:18:19 REF:B Aug 16 Sep 16 Calendar Spread 10 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: JOEBROWN - OIL6.cht | 2016-05-05 09:18:19 HD Request # 22 | Requesting Intraday data. Start Date-Time: 2016-05-05 09:13:31. Record interval: 0. Symbol: REF:B Jul 16 Sep 16 Calendar Spread | 2016-05-05 09:18:19 HD Request # 22 | Decompressing data. | 2016-05-05 09:18:19 HD Request # 22 | Receiving Intraday data for REF:B Jul 16 Sep 16 Calendar Spread starting at 2016-05-05 09:13:31 | 2016-05-05 09:18:19 HD Request # 22 | Timestamp of first Intraday data file record written: 2016-05-05 09:14:07 | 2016-05-05 09:18:19 Socket (28) | Shutdown and closed. | 2016-05-05 09:18:19 The network socket for historical data has been closed. | 2016-05-05 09:18:19 HD Request # 22 | Received 82 records from 2016-05-05 09:13:31 to 2016-05-05 09:16:59 (3.5 minutes) and wrote 81 records for REF:B Jul 16 Sep 16 Calendar Spread | 2016-05-05 09:18:19 HD Request # 22 | Intraday download COMPLETE for REF:B Jul 16 Sep 16 Calendar Spread. Completion time: 0s. Unique request ID: 21 | 2016-05-05 09:18:19 Removed historical data download ID 21 | 2016-05-05 09:18:19 Real-time Intraday chart data file updates started for REF:B Jul 16 Sep 16 Calendar Spread | 2016-05-05 09:18:19 Opened cached Intraday file: C:\SierraChart\Data\REF~B Jul 16 Sep 16 Calendar Spread.scid | 2016-05-05 09:18:19 Intraday chart data file opened for REF:B Jul 16 Sep 16 Calendar Spread | 2016-05-05 09:18:19 HD Request # 23 | Downloading Intraday chart data for REF:B Oct 16 Nov 16 Calendar Spread to the file REF~B Oct 16 Nov 16 Calendar Spread.scid. Service: iceeurope.easyscreen | 2016-05-05 09:18:19 HD Request # 23 | Download start Date-Time: 2016-05-05 09:13:53.000 | 2016-05-05 09:18:19 HD Request # 23 | Using server: easyscreen.sierracharts.com port 10149 | 2016-05-05 09:18:19 Socket (0) | Resolved address ds9.sierracharts.com to IP 194.50.31.205. | 2016-05-05 09:18:19 Socket (29) | Connected. | 2016-05-05 09:18:19 HD Request # 23 | Sending historical data logon request message. | 2016-05-05 09:18:19 REF:B Sep 16 Dec 16 Calendar Spread 30 Min #39 | Performing a full recalculation because it has been tagged. Chartbook: JOEBROWN - OIL6.cht | 2016-05-05 09:18:19 HD Request # 23 | Requesting Intraday data. Start Date-Time: 2016-05-05 09:13:53. Record interval: 0. Symbol: REF:B Oct 16 Nov 16 Calendar Spread | 2016-05-05 09:18:19 HD Request # 23 | Decompressing data. | 2016-05-05 09:18:19 HD Request # 23 | Receiving Intraday data for REF:B Oct 16 Nov 16 Calendar Spread starting at 2016-05-05 09:13:53 | 2016-05-05 09:18:19 HD Request # 23 | Timestamp of first Intraday data file record written: 2016-05-05 09:14:07 | 2016-05-05 09:18:19 Socket (29) | Shutdown and closed. | 2016-05-05 09:18:19 The network socket for historical data has been closed. | 2016-05-05 09:18:19 HD Request # 23 | Received 11 records from 2016-05-05 09:13:53 to 2016-05-05 09:15:47 (114.0 seconds) and wrote 10 records for REF:B Oct 16 Nov 16 Calendar Spread | 2016-05-05 09:18:19 HD Request # 23 | Intraday download COMPLETE for REF:B Oct 16 Nov 16 Calendar Spread. Completion time: 1s. Unique request ID: 22 | 2016-05-05 09:18:19 Removed historical data download ID 22 | 2016-05-05 09:18:19 Real-time Intraday chart data file updates started for REF:B Oct 16 Nov 16 Calendar Spread | 2016-05-05 09:18:19 Opened cached Intraday file: C:\SierraChart\Data\REF~B Oct 16 Nov 16 Calendar Spread.scid | 2016-05-05 09:18:19 Intraday chart data file opened for REF:B Oct 16 Nov 16 Calendar Spread | 2016-05-05 09:18:19 HD Request # 24 | Downloading Intraday chart data for REF:B Nov 16 Dec 16 Calendar Spread to the file REF~B Nov 16 Dec 16 Calendar Spread.scid. Service: iceeurope.easyscreen | 2016-05-05 09:18:19 HD Request # 24 | Download start Date-Time: 2016-05-05 09:12:32.000 | 2016-05-05 09:18:19 HD Request # 24 | Using server: easyscreen.sierracharts.com port 10149 | 2016-05-05 09:18:19 Socket (0) | Resolved address ds9.sierracharts.com to IP 194.50.31.205. | 2016-05-05 09:18:19 Socket (30) | Connected. | 2016-05-05 09:18:19 HD Request # 24 | Sending historical data logon request message. | 2016-05-05 09:18:19 CGEF:ES Jun 16 10 Min #44 | Performing a full recalculation because it has been tagged. Chartbook: JOEBROWN - OIL6.cht | 2016-05-05 09:18:19 HD Request # 24 | Requesting Intraday data. Start Date-Time: 2016-05-05 09:12:32. Record interval: 0. Symbol: REF:B Nov 16 Dec 16 Calendar Spread | 2016-05-05 09:18:19 HD Request # 24 | Decompressing data. | 2016-05-05 09:18:19 HD Request # 24 | Receiving Intraday data for REF:B Nov 16 Dec 16 Calendar Spread starting at 2016-05-05 09:12:32 | 2016-05-05 09:18:19 HD Request # 24 | Timestamp of first Intraday data file record written: 2016-05-05 09:14:36 | 2016-05-05 09:18:19 Socket (30) | Shutdown and closed. | 2016-05-05 09:18:19 The network socket for historical data has been closed. | 2016-05-05 09:18:19 HD Request # 24 | Received 6 records from 2016-05-05 09:12:32 to 2016-05-05 09:14:39 (2.1 minutes) and wrote 5 records for REF:B Nov 16 Dec 16 Calendar Spread | 2016-05-05 09:18:19 HD Request # 24 | Intraday download COMPLETE for REF:B Nov 16 Dec 16 Calendar Spread. Completion time: 0s. Unique request ID: 23 | 2016-05-05 09:18:19 Removed historical data download ID 23 | 2016-05-05 09:18:19 Real-time Intraday chart data file updates started for REF:B Nov 16 Dec 16 Calendar Spread | 2016-05-05 09:18:19 Opened cached Intraday file: C:\SierraChart\Data\REF~B Nov 16 Dec 16 Calendar Spread.scid | 2016-05-05 09:18:19 Intraday chart data file opened for REF:B Nov 16 Dec 16 Calendar Spread | 2016-05-05 09:18:19 Delaying start of download for EXF:FESX Jun 16 | 2016-05-05 09:18:19 HD Request # 25 | Downloading Intraday chart data for EXF:FESX Jun 16 to the file EXF~FESX Jun 16.scid. Service: eurex.easyscreen | 2016-05-05 09:18:22 HD Request # 25 | Download start Date-Time: 2016-05-05 09:15:30.000 | 2016-05-05 09:18:22 HD Request # 25 | Using server: easyscreen.sierracharts.com port 10149 | 2016-05-05 09:18:22 Socket (0) | Resolved address ds9.sierracharts.com to IP 194.50.31.205. | 2016-05-05 09:18:22 Socket (31) | Connected. | 2016-05-05 09:18:22 HD Request # 25 | Sending historical data logon request message. | 2016-05-05 09:18:22 HD Request # 25 | Requesting Intraday data. Start Date-Time: 2016-05-05 09:15:30. Record interval: 0. Symbol: EXF:FESX Jun 16 | 2016-05-05 09:18:22 HD Request # 25 | Decompressing data. | 2016-05-05 09:18:22 HD Request # 25 | Receiving Intraday data for EXF:FESX Jun 16 starting at 2016-05-05 09:15:30 | 2016-05-05 09:18:22 HD Request # 25 | Timestamp of first Intraday data file record written: 2016-05-05 09:15:31 | 2016-05-05 09:18:22 Socket (31) | Shutdown and closed. | 2016-05-05 09:18:22 The network socket for historical data has been closed. | 2016-05-05 09:18:22 HD Request # 25 | Received 159 records from 2016-05-05 09:15:30 to 2016-05-05 09:18:01 (2.5 minutes) and wrote 153 records for EXF:FESX Jun 16 | 2016-05-05 09:18:22 HD Request # 25 | Intraday download COMPLETE for EXF:FESX Jun 16. Completion time: 1s. Unique request ID: 24 | 2016-05-05 09:18:22 Removed historical data download ID 24 | 2016-05-05 09:18:22 Real-time Intraday chart data file updates started for EXF:FESX Jun 16 | 2016-05-05 09:18:22 Opened cached Intraday file: C:\SierraChart\Data\EXF~FESX Jun 16.scid | 2016-05-05 09:18:22 Intraday chart data file opened for EXF:FESX Jun 16 | 2016-05-05 09:18:22 Delaying start of download for CGEF:ES Jun 16 | 2016-05-05 09:18:22 Chart #45 has tagged chart #44 for full recalculation. Chartbook: JOEBROWN - OIL6.cht | 2016-05-05 09:18:22 CGEF:ES Jun 16 10 Min #44 | Performing a full recalculation because it has been tagged. Chartbook: JOEBROWN - OIL6.cht | 2016-05-05 09:18:22 HD Request # 26 | Downloading Intraday chart data for CGEF:ES Jun 16 to the file CGEF~ES Jun 16.scid. Service: cme.easyscreen | 2016-05-05 09:18:22 HD Request # 26 | Download start Date-Time: 2016-05-05 09:15:30.000 | 2016-05-05 09:18:22 HD Request # 26 | Using server: easyscreen.sierracharts.com port 10149 | 2016-05-05 09:18:22 Socket (0) | Resolved address ds9.sierracharts.com to IP 194.50.31.205. | 2016-05-05 09:18:22 Socket (32) | Connected. | 2016-05-05 09:18:22 HD Request # 26 | Sending historical data logon request message. | 2016-05-05 09:18:22 HD Request # 26 | Requesting Intraday data. Start Date-Time: 2016-05-05 09:15:30. Record interval: 0. Symbol: CGEF:ES Jun 16 | 2016-05-05 09:18:22 HD Request # 26 | Decompressing data. | 2016-05-05 09:18:22 HD Request # 26 | Receiving Intraday data for CGEF:ES Jun 16 starting at 2016-05-05 09:15:30 | 2016-05-05 09:18:22 HD Request # 26 | Timestamp of first Intraday data file record written: 2016-05-05 09:15:33 | 2016-05-05 09:18:22 Socket (32) | Shutdown and closed. | 2016-05-05 09:18:22 The network socket for historical data has been closed. | 2016-05-05 09:18:22 HD Request # 26 | Received 118 records from 2016-05-05 09:15:30 to 2016-05-05 09:18:00 (2.5 minutes) and wrote 117 records for CGEF:ES Jun 16 | 2016-05-05 09:18:22 HD Request # 26 | Intraday download COMPLETE for CGEF:ES Jun 16. Completion time: 0s. Unique request ID: 25 | 2016-05-05 09:18:22 Removed historical data download ID 25 | 2016-05-05 09:18:22 Real-time Intraday chart data file updates started for CGEF:ES Jun 16 | 2016-05-05 09:18:22 Opened cached Intraday file: C:\SierraChart\Data\CGEF~ES Jun 16.scid | 2016-05-05 09:18:22 Intraday chart data file opened for CGEF:ES Jun 16 | 2016-05-05 09:18:22 HTTP connection to ds01.ddfplus.com:80 (9) | Closed. No error. | 2016-05-05 09:19:22 HTTP connection to ds01.ddfplus.com:80 (9) | Shutdown and closed. | 2016-05-05 09:19:22 Intraday data recording state for symbol REF:B Jul 16 is set to download 'Pending'. | 2016-05-05 09:20:08 Reloading all charts with filename: REF~B Jul 16.scid | 2016-05-05 09:20:08 HD Request # 27 | Downloading Intraday chart data for REF:B Jul 16 to the file REF~B Jul 16.scid. Service: iceeurope.easyscreen | 2016-05-05 09:20:08 HD Request # 27 | Download start Date-Time: 2016-05-05 08:13:52.000 | 2016-05-05 09:20:08 HD Request # 27 | Using server: easyscreen.sierracharts.com port 10149 | 2016-05-05 09:20:08 Socket (0) | Resolved address ds9.sierracharts.com to IP 194.50.31.205. | 2016-05-05 09:20:08 Socket (34) | Connected. | 2016-05-05 09:20:08 HD Request # 27 | Sending historical data logon request message. | 2016-05-05 09:20:08 HD Request # 27 | Requesting Intraday data. Start Date-Time: 2016-05-05 08:13:52. Record interval: 0. Symbol: REF:B Jul 16 | 2016-05-05 09:20:08 HD Request # 27 | Decompressing data. | 2016-05-05 09:20:08 HD Request # 27 | Receiving Intraday data for REF:B Jul 16 starting at 2016-05-05 08:13:52 | 2016-05-05 09:20:08 HD Request # 27 | Timestamp of first Intraday data file record written: 2016-05-05 08:14:00 | 2016-05-05 09:20:08 Socket (34) | Shutdown and closed. | 2016-05-05 09:20:08 The network socket for historical data has been closed. | 2016-05-05 09:20:08 HD Request # 27 | Received 4373 records from 2016-05-05 08:13:52 to 2016-05-05 09:19:47 (65.9 minutes) and wrote 4371 records for REF:B Jul 16 | 2016-05-05 09:20:08 HD Request # 27 | Intraday download COMPLETE for REF:B Jul 16. Completion time: 0s. Unique request ID: 26 | 2016-05-05 09:20:08 Removed historical data download ID 26 | 2016-05-05 09:20:08 Real-time Intraday chart data file updates started for REF:B Jul 16 | 2016-05-05 09:20:08 Opened cached Intraday file: C:\SierraChart\Data\REF~B Jul 16.scid | 2016-05-05 09:20:08 Intraday chart data file opened for REF:B Jul 16 | 2016-05-05 09:20:08 REF:B Jul 16 15 Min #37 | Reloading chart. | 2016-05-05 09:20:08 REF:B Jul 16 1 Min #11 | Reloading chart. | 2016-05-05 09:20:08 REF:B Jul 16 10 Min #2 | Reloading chart. | 2016-05-05 09:20:09 REF:B Jul 16 10 Min #2 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 07:10:00. Next Bar Date Time: 2016-04-15 07:00:00. Filename: REF~B Jul 16.scid | 2016-05-05 09:20:09 REF:B Jul 16 10 Min #2 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 07:50:00. Next Bar Date Time: 2016-04-15 07:40:00. Filename: REF~B Jul 16.scid | 2016-05-05 09:20:09" |
[2016-05-05 08:37:30] |
This is the reason for not receiving real-time data: Symbol Error - REF:B Jun 16 Dec 16 Calendar Spread is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2016-05-05 09:18:16 This applies for all of the symbols. You will need to have Marex enable your account for ICE Europe real-time data. And have them contact us. Also we see a large number of these messages: REF:B Jul 16 10 Min #2 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 07:10:00. Next Bar Date Time: 2016-04-15 07:00:00. Filename: REF~B Jul 16.scid | 2016-05-05 09:20:09
REF:B Dec 16 Dec 17 Calendar Spread 15 Min #20 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2016-04-15 10:30:00. Next Bar Date Time: 2016-04-15 10:15:00. Filename: REF~B Dec 16 Dec 17 Calendar Spread.scid | 2016-05-05 09:18:15 Re-download the data in the affected charts with Edit >>Delete All Data and Download. Although in some cases that's not going to help because we do see the out of order data originating from the Easy Screen data feed itself. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-05-05 08:37:55
[2016-05-05 09:46:07] |
Marex can contact us at Support_AT_SierraChart.com regarding this.
