Date/Time: Sat, 28 Dec 2024 08:46:29 +0000
lock fill space becomes too big
View Count: 660
[2016-04-28 15:36:21]
User144295 - Posts: 70
Hi Sierra Chart support board,
It happened to me few times during the past month that when I set my charts with certain space and lock fill space, the next day I open them the lock fill space is much bigger that it was set initially. For example, I set lock fill space for 4 bars, and next day I open charts the space is corresponding to 10 bars.
I don't know why this happens as I am sure I did not do that change when I log off from sierra.
Would you please advise if you experience such behavior from other users and if so what would you recommend to do to eliminate this undesired excessive lock fill space.
Thank you very much
Branislav
[2016-04-28 16:19:37]
Are you using Chart Linking and on the charts that have fill space changing do you have Chart >> Chart Settings >> Advanced Settings 2 >> Chart Linking >> Scroll Position enabled?
So does this happen when you open the Chartbook? If so, update to the current version and let us know if you still see the problem.
[2016-04-28 16:50:25]
Yes it happens when I open chart-book and yes this is enabled on those lined charts: Chart >> Chart Settings >> Advanced Settings 2 >> Chart Linking >> Scroll Position
I upgraded to version 1400 just now. I will follow up if the issue still persists unless you have another advise.
[2016-04-28 17:08:59]
OK we are going to be releasing version 1401 later which also has another change which may solve this.
