Date/Time: Fri, 27 Dec 2024 16:15:43 +0000
cant connect to server
View Count: 887
[2016-04-01 05:48:15]
User326667 - Posts: 2
HI
I cant connect to cqg - why?
Software version: 1220 | 2016-04-01 05:42:31
Uses New Spreadsheets | 2016-04-01 05:42:31
Enabled for: Advanced Features. | 2016-04-01 05:42:31
Enabled for: Sierra Chart Historical Data Service. | 2016-04-01 05:42:31
Allow Support for Sierra Chart Data Feeds is enabled. | 2016-04-01 05:42:31
Active service: CQG FIX Trading | 2016-04-01 05:42:31
Data/Trade Service Settings automatically set. | 2016-04-01 05:42:31
Time Zone: +00:00:00 (UTC+00) | 2016-04-01 05:42:31
2016-04-01 08:42:31 Local computer clock time | 2016-04-01 05:42:31
2016-04-01 05:42:31 GMT time | 2016-04-01 05:42:31
2016-04-01 05:42:31 Time zone adjusted time | 2016-04-01 05:42:31
Time difference to server time: 55 seconds. | 2016-04-01 05:42:31
WARNING: Your computer's clock is off by 55 seconds. For help with this Date-Time issue, press the Send for Analysis button. | 2016-04-01 05:42:31
Program path: C:\SierraChart\ | 2016-04-01 05:42:31
Data Files path: C:\SierraChart\Data\ | 2016-04-01 05:42:31
OS Version Number: 6.1 | 2016-04-01 05:42:31
Locale Information: C | 2016-04-01 05:42:31
Checking for new symbol settings for cqg | 2016-04-01 05:42:31
HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2016-04-01 05:42:31
HTTP connection to www.sierrachart.com:80 (1) | Connected. | 2016-04-01 05:42:31
Symbol settings are up-to-date for cqg | 2016-04-01 05:42:31
CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-04-01 05:42:36
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-04-01 05:42:36
socket (2) | Connected. | 2016-04-01 05:42:36
HTTP connection to www.sierrachart.com:80 (1) | Closed. No error. | 2016-04-01 05:42:36
HTTP connection to www.sierrachart.com:80 (1) | Shutdown and closed. | 2016-04-01 05:42:36
CQG FIX Trading FIX: Sending the Logon message. | 2016-04-01 05:42:36
CQG FIX Trading FIX: Received a Logout message. Text = UserName does not exist. Contact Customer Support for assistance. | 2016-04-01 05:42:37
CQG FIX Trading FIX: Sending a Logout message. Text = Received Logout message. | 2016-04-01 05:42:37
socket (2) | Shutdown and closed. | 2016-04-01 05:42:37
CQG FIX Trading FIX: Logged out and disconnected. | 2016-04-01 05:42:37
CQG FIX Trading FIX: Disconnected. | 2016-04-01 05:42:37
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-01 05:42:37
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-01 05:42:37
CQG FIX Trading FIX: DisconnectFIX called. | 2016-04-01 05:42:37
CQG FIX Trading | Disconnected. | 2016-04-01 05:42:37
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-01 05:42:37
CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-04-01 05:42:42
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-04-01 05:42:42
socket (3) | Connected. | 2016-04-01 05:42:42
CQG FIX Trading FIX: Sending the Logon message. | 2016-04-01 05:42:42
CQG FIX Trading FIX: Received a Logout message. Text = UserName does not exist. Contact Customer Support for assistance. | 2016-04-01 05:42:42
CQG FIX Trading FIX: Sending a Logout message. Text = Received Logout message. | 2016-04-01 05:42:42
socket (3) | Shutdown and closed. | 2016-04-01 05:42:42
CQG FIX Trading FIX: Logged out and disconnected. | 2016-04-01 05:42:42
CQG FIX Trading FIX: Disconnected. | 2016-04-01 05:42:42
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-01 05:42:42
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-01 05:42:42
CQG FIX Trading FIX: DisconnectFIX called. | 2016-04-01 05:42:42
CQG FIX Trading | Disconnected. | 2016-04-01 05:42:42
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-01 05:42:42
CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-04-01 05:42:47
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-04-01 05:42:47
socket (4) | Connected. | 2016-04-01 05:42:47
CQG FIX Trading FIX: Sending the Logon message. | 2016-04-01 05:42:48
CQG FIX Trading FIX: Received a Logout message. Text = UserName does not exist. Contact Customer Support for assistance. | 2016-04-01 05:42:48
CQG FIX Trading FIX: Sending a Logout message. Text = Received Logout message. | 2016-04-01 05:42:48
socket (4) | Shutdown and closed. | 2016-04-01 05:42:48
CQG FIX Trading FIX: Logged out and disconnected. | 2016-04-01 05:42:48
CQG FIX Trading FIX: Disconnected. | 2016-04-01 05:42:48
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-01 05:42:48
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-01 05:42:48
CQG FIX Trading FIX: DisconnectFIX called. | 2016-04-01 05:42:48
CQG FIX Trading | Disconnected. | 2016-04-01 05:42:48
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-01 05:42:48
CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-04-01 05:42:53
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-04-01 05:42:53
socket (5) | Connected. | 2016-04-01 05:42:53
CQG FIX Trading FIX: Sending the Logon message. | 2016-04-01 05:42:53
CQG FIX Trading FIX: Received a Logout message. Text = UserName does not exist. Contact Customer Support for assistance. | 2016-04-01 05:42:53
CQG FIX Trading FIX: Sending a Logout message. Text = Received Logout message. | 2016-04-01 05:42:53
socket (5) | Shutdown and closed. | 2016-04-01 05:42:53
CQG FIX Trading FIX: Logged out and disconnected. | 2016-04-01 05:42:53
CQG FIX Trading FIX: Disconnected. | 2016-04-01 05:42:53
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-01 05:42:53
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-01 05:42:53
CQG FIX Trading FIX: DisconnectFIX called. | 2016-04-01 05:42:53
CQG FIX Trading | Disconnected. | 2016-04-01 05:42:53
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-01 05:42:53
CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-04-01 05:42:59
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-04-01 05:42:59
socket (6) | Connected. | 2016-04-01 05:42:59
CQG FIX Trading FIX: Sending the Logon message. | 2016-04-01 05:42:59
CQG FIX Trading FIX: Received a Logout message. Text = UserName does not exist. Contact Customer Support for assistance. | 2016-04-01 05:42:59
CQG FIX Trading FIX: Sending a Logout message. Text = Received Logout message. | 2016-04-01 05:42:59
socket (6) | Shutdown and closed. | 2016-04-01 05:42:59
CQG FIX Trading FIX: Logged out and disconnected. | 2016-04-01 05:42:59
CQG FIX Trading FIX: Disconnected. | 2016-04-01 05:42:59
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-01 05:42:59
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-01 05:42:59
CQG FIX Trading FIX: DisconnectFIX called. | 2016-04-01 05:42:59
CQG FIX Trading | Disconnected. | 2016-04-01 05:42:59
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-01 05:42:59
CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-04-01 05:43:04
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-04-01 05:43:04
socket (7) | Connected. | 2016-04-01 05:43:04
CQG FIX Trading FIX: Sending the Logon message. | 2016-04-01 05:43:05
CQG FIX Trading FIX: Received a Logout message. Text = UserName does not exist. Contact Customer Support for assistance. | 2016-04-01 05:43:05
CQG FIX Trading FIX: Sending a Logout message. Text = Received Logout message. | 2016-04-01 05:43:05
socket (7) | Shutdown and closed. | 2016-04-01 05:43:05
CQG FIX Trading FIX: Logged out and disconnected. | 2016-04-01 05:43:05
CQG FIX Trading FIX: Disconnected. | 2016-04-01 05:43:05
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-01 05:43:05
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-01 05:43:05
CQG FIX Trading FIX: DisconnectFIX called. | 2016-04-01 05:43:05
CQG FIX Trading | Disconnected. | 2016-04-01 05:43:05
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-01 05:43:05
CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-04-01 05:43:10
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-04-01 05:43:10
socket (8) | Connected. | 2016-04-01 05:43:10
CQG FIX Trading FIX: Sending the Logon message. | 2016-04-01 05:43:10
CQG FIX Trading FIX: Received a Logout message. Text = UserName does not exist. Contact Customer Support for assistance. | 2016-04-01 05:43:10
CQG FIX Trading FIX: Sending a Logout message. Text = Received Logout message. | 2016-04-01 05:43:10
socket (8) | Shutdown and closed. | 2016-04-01 05:43:10
CQG FIX Trading FIX: Logged out and disconnected. | 2016-04-01 05:43:10
CQG FIX Trading FIX: Disconnected. | 2016-04-01 05:43:10
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-01 05:43:10
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-01 05:43:10
CQG FIX Trading FIX: DisconnectFIX called. | 2016-04-01 05:43:10
CQG FIX Trading | Disconnected. | 2016-04-01 05:43:10
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-01 05:43:10
CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-04-01 05:43:15
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-04-01 05:43:15
socket (9) | Connected. | 2016-04-01 05:43:16
CQG FIX Trading FIX: Sending the Logon message. | 2016-04-01 05:43:16
CQG FIX Trading FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-04-01 05:43:16
CQG FIX Trading FIX: Sending a Logout message. Text = Received Logout message. | 2016-04-01 05:43:16
socket (9) | Shutdown and closed. | 2016-04-01 05:43:16
CQG FIX Trading FIX: Logged out and disconnected. | 2016-04-01 05:43:16
CQG FIX Trading FIX: Disconnected. | 2016-04-01 05:43:16
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-01 05:43:16
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-01 05:43:16
CQG FIX Trading FIX: DisconnectFIX called. | 2016-04-01 05:43:16
CQG FIX Trading | Disconnected. | 2016-04-01 05:43:16
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-01 05:43:16
CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-04-01 05:43:21
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-04-01 05:43:21
socket (10) | Connected. | 2016-04-01 05:43:21
CQG FIX Trading FIX: Sending the Logon message. | 2016-04-01 05:43:22
CQG FIX Trading FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-04-01 05:43:22
CQG FIX Trading FIX: Sending a Logout message. Text = Received Logout message. | 2016-04-01 05:43:22
socket (10) | Shutdown and closed. | 2016-04-01 05:43:22
CQG FIX Trading FIX: Logged out and disconnected. | 2016-04-01 05:43:22
CQG FIX Trading FIX: Disconnected. | 2016-04-01 05:43:22
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-01 05:43:22
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-01 05:43:22
CQG FIX Trading FIX: DisconnectFIX called. | 2016-04-01 05:43:22
CQG FIX Trading | Disconnected. | 2016-04-01 05:43:22
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-01 05:43:22
CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-04-01 05:43:27
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-04-01 05:43:27
socket (11) | Connected. | 2016-04-01 05:43:27
CQG FIX Trading FIX: Sending the Logon message. | 2016-04-01 05:43:27
CQG FIX Trading FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-04-01 05:43:27
CQG FIX Trading FIX: Sending a Logout message. Text = Received Logout message. | 2016-04-01 05:43:27
socket (11) | Shutdown and closed. | 2016-04-01 05:43:27
CQG FIX Trading FIX: Logged out and disconnected. | 2016-04-01 05:43:27
CQG FIX Trading FIX: Disconnected. | 2016-04-01 05:43:27
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-01 05:43:27
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-01 05:43:27
CQG FIX Trading FIX: DisconnectFIX called. | 2016-04-01 05:43:27
CQG FIX Trading | Disconnected. | 2016-04-01 05:43:27
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-01 05:43:27
CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-04-01 05:43:32
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-04-01 05:43:32
socket (12) | Connected. | 2016-04-01 05:43:33
CQG FIX Trading FIX: Sending the Logon message. | 2016-04-01 05:43:33
CQG FIX Trading FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-04-01 05:43:33
CQG FIX Trading FIX: Sending a Logout message. Text = Received Logout message. | 2016-04-01 05:43:33
socket (12) | Shutdown and closed. | 2016-04-01 05:43:33
CQG FIX Trading FIX: Logged out and disconnected. | 2016-04-01 05:43:33
CQG FIX Trading FIX: Disconnected. | 2016-04-01 05:43:33
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-01 05:43:33
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-01 05:43:33
CQG FIX Trading FIX: DisconnectFIX called. | 2016-04-01 05:43:33
CQG FIX Trading | Disconnected. | 2016-04-01 05:43:33
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-01 05:43:33
CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-04-01 05:43:38
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-04-01 05:43:38
socket (13) | Connected. | 2016-04-01 05:43:38
CQG FIX Trading FIX: Sending the Logon message. | 2016-04-01 05:43:38
CQG FIX Trading FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-04-01 05:43:39
CQG FIX Trading FIX: Sending a Logout message. Text = Received Logout message. | 2016-04-01 05:43:39
socket (13) | Shutdown and closed. | 2016-04-01 05:43:39
CQG FIX Trading FIX: Logged out and disconnected. | 2016-04-01 05:43:39
CQG FIX Trading FIX: Disconnected. | 2016-04-01 05:43:39
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-01 05:43:39
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-01 05:43:39
CQG FIX Trading FIX: DisconnectFIX called. | 2016-04-01 05:43:39
CQG FIX Trading | Disconnected. | 2016-04-01 05:43:39
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-01 05:43:39
CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-04-01 05:43:44
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-04-01 05:43:44
socket (14) | Connected. | 2016-04-01 05:43:44
CQG FIX Trading FIX: Sending the Logon message. | 2016-04-01 05:43:44
CQG FIX Trading FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-04-01 05:43:44
CQG FIX Trading FIX: Sending a Logout message. Text = Received Logout message. | 2016-04-01 05:43:44
socket (14) | Shutdown and closed. | 2016-04-01 05:43:44
CQG FIX Trading FIX: Logged out and disconnected. | 2016-04-01 05:43:44
CQG FIX Trading FIX: Disconnected. | 2016-04-01 05:43:44
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-01 05:43:44
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-01 05:43:44
CQG FIX Trading FIX: DisconnectFIX called. | 2016-04-01 05:43:44
CQG FIX Trading | Disconnected. | 2016-04-01 05:43:44
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-01 05:43:44
CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-04-01 05:43:49
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-04-01 05:43:49
socket (15) | Connected. | 2016-04-01 05:43:49
CQG FIX Trading FIX: Sending the Logon message. | 2016-04-01 05:43:50
CQG FIX Trading FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-04-01 05:43:50
CQG FIX Trading FIX: Sending a Logout message. Text = Received Logout message. | 2016-04-01 05:43:50
socket (15) | Shutdown and closed. | 2016-04-01 05:43:50
CQG FIX Trading FIX: Logged out and disconnected. | 2016-04-01 05:43:50
CQG FIX Trading FIX: Disconnected. | 2016-04-01 05:43:50
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-01 05:43:50
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-01 05:43:50
CQG FIX Trading FIX: DisconnectFIX called. | 2016-04-01 05:43:50
CQG FIX Trading | Disconnected. | 2016-04-01 05:43:50
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-01 05:43:50
CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-04-01 05:43:55
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-04-01 05:43:55
socket (16) | Connected. | 2016-04-01 05:43:55
CQG FIX Trading FIX: Sending the Logon message. | 2016-04-01 05:43:55
CQG FIX Trading FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-04-01 05:43:56
CQG FIX Trading FIX: Sending a Logout message. Text = Received Logout message. | 2016-04-01 05:43:56
socket (16) | Shutdown and closed. | 2016-04-01 05:43:56
CQG FIX Trading FIX: Logged out and disconnected. | 2016-04-01 05:43:56
CQG FIX Trading FIX: Disconnected. | 2016-04-01 05:43:56
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-01 05:43:56
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-01 05:43:56
CQG FIX Trading FIX: DisconnectFIX called. | 2016-04-01 05:43:56
CQG FIX Trading | Disconnected. | 2016-04-01 05:43:56
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-01 05:43:56
CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-04-01 05:44:01
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-04-01 05:44:01
socket (17) | Connected. | 2016-04-01 05:44:01
CQG FIX Trading FIX: Sending the Logon message. | 2016-04-01 05:44:01
CQG FIX Trading FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-04-01 05:44:01
CQG FIX Trading FIX: Sending a Logout message. Text = Received Logout message. | 2016-04-01 05:44:01
socket (17) | Shutdown and closed. | 2016-04-01 05:44:01
CQG FIX Trading FIX: Logged out and disconnected. | 2016-04-01 05:44:01
CQG FIX Trading FIX: Disconnected. | 2016-04-01 05:44:01
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-01 05:44:01
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-01 05:44:01
CQG FIX Trading FIX: DisconnectFIX called. | 2016-04-01 05:44:01
CQG FIX Trading | Disconnected. | 2016-04-01 05:44:01
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-01 05:44:01
CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-04-01 05:44:06
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-04-01 05:44:06
socket (18) | Connected. | 2016-04-01 05:44:07
CQG FIX Trading FIX: Sending the Logon message. | 2016-04-01 05:44:07
CQG FIX Trading FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-04-01 05:44:07
CQG FIX Trading FIX: Sending a Logout message. Text = Received Logout message. | 2016-04-01 05:44:07
socket (18) | Shutdown and closed. | 2016-04-01 05:44:07
CQG FIX Trading FIX: Logged out and disconnected. | 2016-04-01 05:44:07
CQG FIX Trading FIX: Disconnected. | 2016-04-01 05:44:07
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-01 05:44:07
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-01 05:44:07
CQG FIX Trading FIX: DisconnectFIX called. | 2016-04-01 05:44:07
CQG FIX Trading | Disconnected. | 2016-04-01 05:44:07
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-01 05:44:07
CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-04-01 05:44:12
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-04-01 05:44:12
socket (19) | Connected. | 2016-04-01 05:44:12
CQG FIX Trading FIX: Sending the Logon message. | 2016-04-01 05:44:12
CQG FIX Trading FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-04-01 05:44:13
CQG FIX Trading FIX: Sending a Logout message. Text = Received Logout message. | 2016-04-01 05:44:13
socket (19) | Shutdown and closed. | 2016-04-01 05:44:13
CQG FIX Trading FIX: Logged out and disconnected. | 2016-04-01 05:44:13
CQG FIX Trading FIX: Disconnected. | 2016-04-01 05:44:13
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-01 05:44:13
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-01 05:44:13
CQG FIX Trading FIX: DisconnectFIX called. | 2016-04-01 05:44:13
CQG FIX Trading | Disconnected. | 2016-04-01 05:44:13
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-01 05:44:13
CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-04-01 05:44:18
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-04-01 05:44:18
socket (20) | Connected. | 2016-04-01 05:44:18
CQG FIX Trading FIX: Sending the Logon message. | 2016-04-01 05:44:18
CQG FIX Trading FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-04-01 05:44:18
CQG FIX Trading FIX: Sending a Logout message. Text = Received Logout message. | 2016-04-01 05:44:18
socket (20) | Shutdown and closed. | 2016-04-01 05:44:18
CQG FIX Trading FIX: Logged out and disconnected. | 2016-04-01 05:44:18
CQG FIX Trading FIX: Disconnected. | 2016-04-01 05:44:18
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-01 05:44:18
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-01 05:44:18
CQG FIX Trading FIX: DisconnectFIX called. | 2016-04-01 05:44:18
CQG FIX Trading | Disconnected. | 2016-04-01 05:44:18
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-01 05:44:18
CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-04-01 05:44:23
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-04-01 05:44:23
socket (21) | Connected. | 2016-04-01 05:44:23
CQG FIX Trading FIX: Sending the Logon message. | 2016-04-01 05:44:24
CQG FIX Trading FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-04-01 05:44:24
CQG FIX Trading FIX: Sending a Logout message. Text = Received Logout message. | 2016-04-01 05:44:24
socket (21) | Shutdown and closed. | 2016-04-01 05:44:24
CQG FIX Trading FIX: Logged out and disconnected. | 2016-04-01 05:44:24
CQG FIX Trading FIX: Disconnected. | 2016-04-01 05:44:24
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-01 05:44:24
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-01 05:44:24
CQG FIX Trading FIX: DisconnectFIX called. | 2016-04-01 05:44:24
CQG FIX Trading | Disconnected. | 2016-04-01 05:44:24
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-01 05:44:24
CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-04-01 05:44:29
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-04-01 05:44:29
socket (22) | Connected. | 2016-04-01 05:44:29
CQG FIX Trading FIX: Sending the Logon message. | 2016-04-01 05:44:29
CQG FIX Trading FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-04-01 05:44:29
CQG FIX Trading FIX: Sending a Logout message. Text = Received Logout message. | 2016-04-01 05:44:29
socket (22) | Shutdown and closed. | 2016-04-01 05:44:29
CQG FIX Trading FIX: Logged out and disconnected. | 2016-04-01 05:44:29
CQG FIX Trading FIX: Disconnected. | 2016-04-01 05:44:29
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-01 05:44:29
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-01 05:44:29
CQG FIX Trading FIX: DisconnectFIX called. | 2016-04-01 05:44:29
CQG FIX Trading | Disconnected. | 2016-04-01 05:44:29
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-01 05:44:29
CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-04-01 05:44:34
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-04-01 05:44:34
socket (23) | Connected. | 2016-04-01 05:44:35
CQG FIX Trading FIX: Sending the Logon message. | 2016-04-01 05:44:35
CQG FIX Trading FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-04-01 05:44:35
CQG FIX Trading FIX: Sending a Logout message. Text = Received Logout message. | 2016-04-01 05:44:35
socket (23) | Shutdown and closed. | 2016-04-01 05:44:35
CQG FIX Trading FIX: Logged out and disconnected. | 2016-04-01 05:44:35
CQG FIX Trading FIX: Disconnected. | 2016-04-01 05:44:35
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-01 05:44:35
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-01 05:44:35
CQG FIX Trading FIX: DisconnectFIX called. | 2016-04-01 05:44:35
CQG FIX Trading | Disconnected. | 2016-04-01 05:44:35
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-01 05:44:35
CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-04-01 05:44:40
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-04-01 05:44:40
socket (24) | Connected. | 2016-04-01 05:44:40
CQG FIX Trading FIX: Sending the Logon message. | 2016-04-01 05:44:40
CQG FIX Trading FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-04-01 05:44:41
CQG FIX Trading FIX: Sending a Logout message. Text = Received Logout message. | 2016-04-01 05:44:41
socket (24) | Shutdown and closed. | 2016-04-01 05:44:41
CQG FIX Trading FIX: Logged out and disconnected. | 2016-04-01 05:44:41
CQG FIX Trading FIX: Disconnected. | 2016-04-01 05:44:41
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-01 05:44:41
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-01 05:44:41
CQG FIX Trading FIX: DisconnectFIX called. | 2016-04-01 05:44:41
CQG FIX Trading | Disconnected. | 2016-04-01 05:44:41
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-01 05:44:41
CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-04-01 05:44:46
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-04-01 05:44:46
socket (25) | Connected. | 2016-04-01 05:44:46
CQG FIX Trading FIX: Sending the Logon message. | 2016-04-01 05:44:46
CQG FIX Trading FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-04-01 05:44:46
CQG FIX Trading FIX: Sending a Logout message. Text = Received Logout message. | 2016-04-01 05:44:46
socket (25) | Shutdown and closed. | 2016-04-01 05:44:46
CQG FIX Trading FIX: Logged out and disconnected. | 2016-04-01 05:44:46
CQG FIX Trading FIX: Disconnected. | 2016-04-01 05:44:46
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-01 05:44:46
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-01 05:44:46
CQG FIX Trading FIX: DisconnectFIX called. | 2016-04-01 05:44:46
CQG FIX Trading | Disconnected. | 2016-04-01 05:44:46
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-01 05:44:46
CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-04-01 05:44:51
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-04-01 05:44:51
socket (26) | Connected. | 2016-04-01 05:44:51
CQG FIX Trading FIX: Sending the Logon message. | 2016-04-01 05:44:52
CQG FIX Trading FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-04-01 05:44:52
CQG FIX Trading FIX: Sending a Logout message. Text = Received Logout message. | 2016-04-01 05:44:52
socket (26) | Shutdown and closed. | 2016-04-01 05:44:52
CQG FIX Trading FIX: Logged out and disconnected. | 2016-04-01 05:44:52
CQG FIX Trading FIX: Disconnected. | 2016-04-01 05:44:52
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-01 05:44:52
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-01 05:44:52
CQG FIX Trading FIX: DisconnectFIX called. | 2016-04-01 05:44:52
CQG FIX Trading | Disconnected. | 2016-04-01 05:44:52
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-01 05:44:52
CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-04-01 05:44:57
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-04-01 05:44:57
socket (27) | Connected. | 2016-04-01 05:44:57
CQG FIX Trading FIX: Sending the Logon message. | 2016-04-01 05:44:57
CQG FIX Trading FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-04-01 05:44:57
CQG FIX Trading FIX: Sending a Logout message. Text = Received Logout message. | 2016-04-01 05:44:57
socket (27) | Shutdown and closed. | 2016-04-01 05:44:57
CQG FIX Trading FIX: Logged out and disconnected. | 2016-04-01 05:44:57
CQG FIX Trading FIX: Disconnected. | 2016-04-01 05:44:57
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-01 05:44:57
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-01 05:44:57
CQG FIX Trading FIX: DisconnectFIX called. | 2016-04-01 05:44:57
CQG FIX Trading | Disconnected. | 2016-04-01 05:44:57
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-01 05:44:57
CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-04-01 05:45:02
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-04-01 05:45:02
socket (28) | Connected. | 2016-04-01 05:45:03
CQG FIX Trading FIX: Sending the Logon message. | 2016-04-01 05:45:03
CQG FIX Trading FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-04-01 05:45:03
CQG FIX Trading FIX: Sending a Logout message. Text = Received Logout message. | 2016-04-01 05:45:03
socket (28) | Shutdown and closed. | 2016-04-01 05:45:03
CQG FIX Trading FIX: Logged out and disconnected. | 2016-04-01 05:45:03
CQG FIX Trading FIX: Disconnected. | 2016-04-01 05:45:03
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-01 05:45:03
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-01 05:45:03
CQG FIX Trading FIX: DisconnectFIX called. | 2016-04-01 05:45:03
CQG FIX Trading | Disconnected. | 2016-04-01 05:45:03
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-01 05:45:03
CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-04-01 05:45:08
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-04-01 05:45:08
socket (29) | Connected. | 2016-04-01 05:45:08
CQG FIX Trading FIX: Sending the Logon message. | 2016-04-01 05:45:08
CQG FIX Trading FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-04-01 05:45:09
CQG FIX Trading FIX: Sending a Logout message. Text = Received Logout message. | 2016-04-01 05:45:09
socket (29) | Shutdown and closed. | 2016-04-01 05:45:09
CQG FIX Trading FIX: Logged out and disconnected. | 2016-04-01 05:45:09
CQG FIX Trading FIX: Disconnected. | 2016-04-01 05:45:09
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-01 05:45:09
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-01 05:45:09
CQG FIX Trading FIX: DisconnectFIX called. | 2016-04-01 05:45:09
CQG FIX Trading | Disconnected. | 2016-04-01 05:45:09
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-01 05:45:09
CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-04-01 05:45:14
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-04-01 05:45:14
socket (30) | Connected. | 2016-04-01 05:45:14
CQG FIX Trading FIX: Sending the Logon message. | 2016-04-01 05:45:14
CQG FIX Trading FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-04-01 05:45:14
CQG FIX Trading FIX: Sending a Logout message. Text = Received Logout message. | 2016-04-01 05:45:14
socket (30) | Shutdown and closed. | 2016-04-01 05:45:14
CQG FIX Trading FIX: Logged out and disconnected. | 2016-04-01 05:45:14
CQG FIX Trading FIX: Disconnected. | 2016-04-01 05:45:14
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-01 05:45:14
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-01 05:45:14
CQG FIX Trading FIX: DisconnectFIX called. | 2016-04-01 05:45:14
CQG FIX Trading | Disconnected. | 2016-04-01 05:45:14
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-01 05:45:14
CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-04-01 05:45:19
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-04-01 05:45:19
socket (31) | Connected. | 2016-04-01 05:45:20
CQG FIX Trading FIX: Sending the Logon message. | 2016-04-01 05:45:20
CQG FIX Trading FIX: Received a Logout message. Text = UserName does not exist. Contact Customer Support for assistance. | 2016-04-01 05:45:20
CQG FIX Trading FIX: Sending a Logout message. Text = Received Logout message. | 2016-04-01 05:45:20
socket (31) | Shutdown and closed. | 2016-04-01 05:45:20
CQG FIX Trading FIX: Logged out and disconnected. | 2016-04-01 05:45:20
CQG FIX Trading FIX: Disconnected. | 2016-04-01 05:45:20
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-01 05:45:20
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-01 05:45:20
CQG FIX Trading FIX: DisconnectFIX called. | 2016-04-01 05:45:20
CQG FIX Trading | Disconnected. | 2016-04-01 05:45:20
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-01 05:45:20
[2016-04-01 05:56:29]
Not sure if this is the problem but you are running a very old version of Sierra Chart. Update following the instructions here:
https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate
This is also the relevant message from the Message Log:
If you still encounter the above message contact your broker for assistance.
[2016-04-01 06:58:02]
stil , after download it doesnt connect ~ it only try to..
what can i do?
Software version: 1389 | 2016-04-01 06:48:29
Uses New Spreadsheets | 2016-04-01 06:48:29
Enabled for: Advanced Features. | 2016-04-01 06:48:29
Enabled for: Sierra Chart Historical Data Service. | 2016-04-01 06:48:29
Allow Support for Sierra Chart Data Feeds is enabled. | 2016-04-01 06:48:29
Current selected Data/Trading service: CQG FIX Trading | 2016-04-01 06:48:29
Chart Update Interval: 500 | 2016-04-01 06:48:29
Data/Trade Service Settings automatically set. | 2016-04-01 06:48:29
Time Zone: +00:00:00 (UTC+00) | 2016-04-01 06:48:29
2016-04-01 09:48:32 Local computer time | 2016-04-01 06:48:29
2016-04-01 06:48:32 Local computer time in UTC | 2016-04-01 06:48:29
2016-04-01 06:48:32 Local computer time in SC Time Zone | 2016-04-01 06:48:29
2016-04-01 06:49:29 Server time in UTC | 2016-04-01 06:48:29
Local computer UTC time and Server UTC time difference: 57 seconds. | 2016-04-01 06:48:29
Notice: Your computer's clock is off by 57 seconds. For help with this, press the 'Send for Analysis' button. | 2016-04-01 06:48:29
Program path: C:\SierraChart\ | 2016-04-01 06:48:29
Data Files path: C:\SierraChart\Data\ | 2016-04-01 06:48:29
OS Version Number: 6.1 | 2016-04-01 06:48:29
Locale Information: C | 2016-04-01 06:48:29
Checking for new symbol settings for cqg | 2016-04-01 06:48:29
HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-04-01 06:48:29
HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-04-01 06:48:33
HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-04-01 06:48:33
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-04-01 06:48:34
Symbol settings are up-to-date for cqg | 2016-04-01 06:48:34
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-04-01 06:48:37
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-04-01 06:48:37
socket (4) | Connected. | 2016-04-01 06:48:38
CQG FIX: Sending the Logon message. | 2016-04-01 06:48:38
CQG FIX: Received a Logout message. Text = UserName does not exist. Contact Customer Support for assistance. | 2016-04-01 06:48:38
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-04-01 06:48:38
socket (4) | Shutdown and closed. | 2016-04-01 06:48:38
CQG FIX: Disconnected. | 2016-04-01 06:48:38
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-01 06:48:38
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-01 06:48:38
CQG FIX Trading | Disconnected. | 2016-04-01 06:48:38
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-01 06:48:38
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-04-01 06:48:39
HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-04-01 06:48:39
HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-04-01 06:48:39
HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-04-01 06:48:39
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-04-01 06:55:51
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-04-01 06:55:51
socket (58) | Connected. | 2016-04-01 06:55:52
CQG FIX: Sending the Logon message. | 2016-04-01 06:55:52
CQG FIX: Received a Logout message. Text = UserName does not exist. Contact Customer Support for assistance. | 2016-04-01 06:55:52
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-04-01 06:55:52
socket (58) | Shutdown and closed. | 2016-04-01 06:55:52
CQG FIX: Disconnected. | 2016-04-01 06:55:52
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-01 06:55:52
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-01 06:55:52
CQG FIX Trading | Disconnected. | 2016-04-01 06:55:52
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-01 06:55:52
Date Time Of Last Edit: 2016-04-01 07:27:35
[2016-04-01 07:28:07]
Contact AMP your broker and let them know you are getting this message:
CQG FIX: Received a Logout message. Text = UserName does not exist. Contact Customer Support for assistance. | 2016-04-01 06:53:51
