Date/Time: Fri, 18 Sep 2026 05:07:22 +0000
mini Hang Seng Index Historical Data not Populating Properly
View Count: 3151
| [2016-03-31 03:21:51] |
| User9482 - Posts: 13 |
Hello, I appreciate the one week extension on my account! As suggested in a previous post, I matched my sierra charts settings up with the instructions provided in the link below: Tick by Tick Data Configuration: Services That Support Bid Volume and Ask Volume Still no luck with loading historical data for the mini Hang Seng Index. It was suggested that in this particular instance the problem is stemming from the CQG data itself. I'm wondering if it's a solvable issue, or if I'll need a different data feed provider? In the tick by tick data configuration link it mentions that CQG supports bid volume and ask volume, so I'm not sure if there is something they need to activate on their end or if it's just not possible? Also possibly worth mentioning, but I do have CQG's "Level 2 HKFE data" which is referenced from the link below. http://www.cqg.com/partners/exchanges/hkfe Please let me know if you think this is something that can be resolved with CQG, or if you think I will need to find a new data feed provider entirely in order to have complete mini Hang Seng Index data. Thank you in advance! |
| [2016-03-31 03:24:13] |
Did you re-download the data in the chart as explained?
| [2016-03-31 03:29:31] |
As per this instruction: "6. If you made any changes, then you will need to re-download the data in the Intraday charts by going to an Intraday chart for a symbol and selecting Edit >> Delete All Data And Download." I did not, because I didn't have to make any changes, the settings were already adjusted properly. |
| [2016-03-31 03:37:08] |
To follow up on your response, I just re-downloaded the data as instructed with no such luck!
| [2016-03-31 04:39:39] |
We need to test this. Please allow us one day.
| [2016-03-31 05:09:15] |
Thanks a million, I'll keep an eye open for your reply!
| [2016-04-01 18:22:58] |
We are now finally able to test this and Sierra Chart is able to create the bid volume and ask volume from the CQG historical tick data: http://www.sierrachart.com/image.php?l=1459534785747.png Those bars were created from historical data. What we want you to do is to go to your HSI chart and re-download the data with Edit >> Delete All Data and Download. After this we need to see the Message Log. Provide a copy of the Message Log by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-04-01 19:09:53] |
I probably should've been more specific when describing my issue, so I apologize. My problem is that I can't go very far back into the historical data. The only historical data that I can see is that which has been populated from the real time data. Is there a solution for pulling up more extensive historical data beyond what's populated from the live data, or is that the only way to track historical data? I will also post a message log if that would be helpful to the solution of this issue. Thanks! |
| [2016-04-01 19:32:01] |
We will be able to see the problem when we get the Message Log. Most likely your CQG account is not authorized for historical data. What we want you to do is to go to your HSI chart and re-download the data with Edit >> Delete All Data and Download. After this we need to see the Message Log. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-04-01 19:38:35] |
Software version: 1369 | 2016-04-01 19:35:01 Uses New Spreadsheets | 2016-04-01 19:35:01 Usage end date: 2016-04-07 | 2016-04-01 19:35:01 Enabled for: Advanced Features. | 2016-04-01 19:35:01 Enabled for: Advanced Features 2. | 2016-04-01 19:35:01 Enabled for: Sierra Chart Historical Data Service. | 2016-04-01 19:35:01 Allow Support for Sierra Chart Data Feeds is enabled. | 2016-04-01 19:35:01 Current selected Data/Trading service: CQG FIX Trading | 2016-04-01 19:35:01 Chart Update Interval: 500 | 2016-04-01 19:35:01 Time Zone: +00:00:00 (UTC+00) | 2016-04-01 19:35:01 2016-04-01 14:35:05 Local computer time | 2016-04-01 19:35:01 2016-04-01 19:35:05 Local computer time in UTC | 2016-04-01 19:35:01 2016-04-01 19:35:05 Local computer time in SC Time Zone | 2016-04-01 19:35:01 2016-04-01 19:35:04 Server time in UTC | 2016-04-01 19:35:01 Local computer UTC time and Server UTC time difference: 0 seconds. | 2016-04-01 19:35:01 Program path: C:\SierraChart\ | 2016-04-01 19:35:01 Data Files path: C:\SierraChart\Data\ | 2016-04-01 19:35:01 OS Version Number: 6.2 | 2016-04-01 19:35:01 Locale Information: C | 2016-04-01 19:35:01 Checking for new symbol settings for cqg | 2016-04-01 19:35:01 HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2016-04-01 19:35:01 HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-04-01 19:35:01 HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-04-01 19:35:01 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-04-01 19:35:01 Requesting symbol settings for cqg. Overwrite = on. | 2016-04-01 19:35:06 Symbol settings received. | 2016-04-01 19:35:07 Processed received symbol settings | 2016-04-01 19:35:07 HD Request # 16 | Downloading Intraday chart data for F.US.MHIJ16 to the file F.US.MHIJ16.scid. Service: cqg | 2016-04-01 19:36:35 HD Request # 16 | Download start Date-Time: 2015-09-28 19:36:35.000 | 2016-04-01 19:36:35 HD Request # 16 | Error downloading historical Intraday data for F.US.MHIJ16. Time and sales data for instrument F.US.MHI (corresponding to ID = 1) is not allowed. | 2016-04-01 19:36:35 HD Request # 16 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.MHIJ16 | 2016-04-01 19:36:35 HD Request # 16 | Intraday download COMPLETE for F.US.MHIJ16. Completion time: 0s. Unique request ID: 5 | 2016-04-01 19:36:35 Removed historical data download ID 5 | 2016-04-01 19:36:35 Real-time Intraday chart data file updates started for F.US.MHIJ16 | 2016-04-01 19:36:35 Opened cached Intraday file: C:\SierraChart\Data\F.US.MHIJ16.scid | 2016-04-01 19:36:35 Intraday chart data file opened for F.US.MHIJ16 | 2016-04-01 19:36:35 F.US.MHIJ16 1 Min #1 | Reloading chart. | 2016-04-01 19:36:40 CQG FIX Trading | Using primary service for historical data. | 2016-04-01 19:36:40 F.US.MHIJ16 10 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.MHIJ16.scid | 2016-04-01 19:36:40 Logged off Reason: Your session was closed due to a concurrent session. | 2016-04-01 19:36:51 CQG WebAPI websocket (8) | SSL shutdown indicates not able to send 'close notify'. | 2016-04-01 19:36:51 CQG WebAPI websocket (8) | SSL has been shut down. | 2016-04-01 19:36:51 CQG WebAPI websocket (8) | SSL object has been freed. SSL state is now disconnected. | 2016-04-01 19:36:51 CQG WebAPI websocket (8) | Shutdown and closed. | 2016-04-01 19:36:51 CQG FIX Trading | Websocket closed. | 2016-04-01 19:36:51 Connection to the external service has been lost. | 2016-04-01 19:36:51 CQG FIX Trading | Disconnected. | 2016-04-01 19:36:51 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-01 19:36:51 CQG FIX: Not connecting to trading server because Username is not specified. | 2016-04-01 19:36:54 CQG FIX Trading | Connecting to market data server api.cqg.com | 2016-04-01 19:36:54 CQG WebAPI | Connecting to websocket server. | 2016-04-01 19:36:54 CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35 | 2016-04-01 19:36:54 CQG WebAPI websocket (9) | Connected. | 2016-04-01 19:36:54 CQG WebAPI websocket (9) | Starting SSL 3/2 connection. | 2016-04-01 19:36:54 CQG WebAPI websocket (9) | SSL connection established. | 2016-04-01 19:36:54 CQG WebAPI | Opening websocket. | 2016-04-01 19:36:54 CQG WebAPI | Sending websocket handshake. | 2016-04-01 19:36:54 CQG WebAPI | Received websocket handshake acknowledgment. | 2016-04-01 19:36:54 CQG WebAPI | Web socket state is now open. | 2016-04-01 19:36:54 CQG FIX Trading | Websocket connected. | 2016-04-01 19:36:54 CQG FIX Trading | Sending market data logon message. | 2016-04-01 19:36:54 CQG FIX Trading | Logon successful. Session Token = xOLa4lSgzhWM0xZQ94vFlf+4w/MFRVR2r2Ur9m4ZHRM | 2016-04-01 19:36:54 CQG FIX Trading | Connected to data and trading server. | 2016-04-01 19:36:54 CQG FIX Trading | Starting real-time market data updates for: F.US.MHIJ16. ID: 1 | 2016-04-01 19:36:55 CQG FIX Trading | Sending symbol resolution request for F.US.MHIJ16. ID: 715239 | 2016-04-01 19:36:55 CQG FIX Trading | Using primary service for historical data. | 2016-04-01 19:36:55 Intraday data recording state for symbol F.US.MHIJ16 is set to download 'Pending'. | 2016-04-01 19:36:55 HD Request # 17 | Downloading Intraday chart data for F.US.MHIJ16 to the file F.US.MHIJ16.scid. Service: cqg | 2016-04-01 19:36:55 HD Request # 17 | Download start Date-Time: 2015-09-28 19:36:54.000 | 2016-04-01 19:36:55 CQG FIX Trading | Received symbol resolution report for symbol F.US.MHIJ16. Request ID: 715239. Contract ID: 1. | 2016-04-01 19:36:55 CQG FIX Trading | Requesting market data for F.US.MHIJ16 | 2016-04-01 19:36:55 HD Request # 17 | Error downloading historical Intraday data for F.US.MHIJ16. Time and sales data for instrument F.US.MHI (corresponding to ID = 1) is not allowed. | 2016-04-01 19:36:55 HD Request # 17 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.MHIJ16 | 2016-04-01 19:36:55 HD Request # 18 | Downloading Intraday chart data for F.US.MHIJ16 to the file F.US.MHIJ16.scid. Service: cqg | 2016-04-01 19:36:55 HD Request # 18 | Download start Date-Time: 2015-09-28 19:36:55.000 | 2016-04-01 19:36:55 HD Request # 18 | Error downloading historical Intraday data for F.US.MHIJ16. Time and sales data for instrument F.US.MHI (corresponding to ID = 1) is not allowed. | 2016-04-01 19:36:55 HD Request # 18 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.MHIJ16 | 2016-04-01 19:36:55 HD Request # 19 | Downloading Intraday chart data for F.US.MHIJ16 to the file F.US.MHIJ16.scid. Service: cqg | 2016-04-01 19:36:55 HD Request # 19 | Download start Date-Time: 2015-09-28 19:36:55.000 | 2016-04-01 19:36:55 HD Request # 19 | Error downloading historical Intraday data for F.US.MHIJ16. Time and sales data for instrument F.US.MHI (corresponding to ID = 1) is not allowed. | 2016-04-01 19:36:55 HD Request # 19 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.MHIJ16 | 2016-04-01 19:36:55 HD Request # 19 | Intraday download COMPLETE for F.US.MHIJ16. Completion time: 0s. Unique request ID: 6 | 2016-04-01 19:36:55 Removed historical data download ID 6 | 2016-04-01 19:36:55 Real-time Intraday chart data file updates started for F.US.MHIJ16 | 2016-04-01 19:36:55 Opened cached Intraday file: C:\SierraChart\Data\F.US.MHIJ16.scid | 2016-04-01 19:36:55 Intraday chart data file opened for F.US.MHIJ16 | 2016-04-01 19:36:55 Date Time Of Last Edit: 2016-04-01 20:35:14
| [2016-04-01 20:34:37] |
We have confirmed the problem is your CQG account is not authorized for historical data: HD Request # 8 | Error downloading historical Intraday data for F.US.MHIJ16. Time and sales data for instrument F.US.MHI (corresponding to ID = 1) is not allowed. | 2016-04-01 19:36:15 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-04-01 22:08:02] |
I very much appreciate the help and insight! I'll post again once I'm able to confirm things are working with historical data.
| [2016-04-04 18:17:05] |
Software version: 1369 | 2016-04-04 18:12:25 Uses New Spreadsheets | 2016-04-04 18:12:25 Usage end date: 2016-04-11 | 2016-04-04 18:12:25 Enabled for: Advanced Features. | 2016-04-04 18:12:25 Enabled for: Advanced Features 2. | 2016-04-04 18:12:25 Enabled for: Sierra Chart Historical Data Service. | 2016-04-04 18:12:25 Allow Support for Sierra Chart Data Feeds is enabled. | 2016-04-04 18:12:25 Current selected Data/Trading service: CQG FIX Trading | 2016-04-04 18:12:25 Chart Update Interval: 500 | 2016-04-04 18:12:25 Time Zone: +00:00:00 (UTC+00) | 2016-04-04 18:12:25 2016-04-04 13:14:25 Local computer time | 2016-04-04 18:12:25 2016-04-04 18:14:25 Local computer time in UTC | 2016-04-04 18:12:25 2016-04-04 18:14:25 Local computer time in SC Time Zone | 2016-04-04 18:12:25 2016-04-04 18:14:23 Server time in UTC | 2016-04-04 18:12:25 Local computer UTC time and Server UTC time difference: 0 seconds. | 2016-04-04 18:12:25 Program path: C:\SierraChart\ | 2016-04-04 18:12:25 Data Files path: C:\SierraChart\Data\ | 2016-04-04 18:12:25 OS Version Number: 6.2 | 2016-04-04 18:12:25 Locale Information: C | 2016-04-04 18:12:25 Checking for new symbol settings for cqg | 2016-04-04 18:12:25 HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2016-04-04 18:12:25 HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-04-04 18:12:25 HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-04-04 18:12:25 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-04-04 18:12:25 Symbol settings are up-to-date for cqg | 2016-04-04 18:14:26 CQG FIX: Not connecting to trading server because Username is not specified. | 2016-04-04 18:14:30 CQG FIX Trading | Connecting to market data server api.cqg.com | 2016-04-04 18:14:30 CQG WebAPI | Connecting to websocket server. | 2016-04-04 18:14:30 CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35 | 2016-04-04 18:14:30 CQG WebAPI websocket (4) | Connected. | 2016-04-04 18:14:30 CQG WebAPI websocket (4) | Starting SSL 3/2 connection. | 2016-04-04 18:14:30 CQG WebAPI websocket (4) | SSL connection established. | 2016-04-04 18:14:30 CQG WebAPI | Opening websocket. | 2016-04-04 18:14:30 CQG WebAPI | Sending websocket handshake. | 2016-04-04 18:14:30 CQG WebAPI | Received websocket handshake acknowledgment. | 2016-04-04 18:14:30 CQG WebAPI | Web socket state is now open. | 2016-04-04 18:14:30 CQG FIX Trading | Websocket connected. | 2016-04-04 18:14:30 CQG FIX Trading | Sending market data logon message. | 2016-04-04 18:14:30 CQG FIX Trading | Logon successful. Session Token = crSjaKiZh2MuH6F+OiVMwUXlvDaYOm6toTAH2LNZvFs | 2016-04-04 18:14:30 CQG FIX Trading | Connected to data and trading server. | 2016-04-04 18:14:30 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-04-04 18:14:31 HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-04-04 18:14:31 HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-04-04 18:14:31 CQG FIX Trading | Using primary service for historical data. | 2016-04-04 18:14:42 F.US.MHIJ16 1 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.MHIJ16.scid | 2016-04-04 18:14:42 CQG FIX Trading | Starting real-time market data updates for: F.US.MHIJ16. ID: 1 | 2016-04-04 18:14:42 CQG FIX Trading | Sending symbol resolution request for F.US.MHIJ16. ID: 779182 | 2016-04-04 18:14:42 CQG FIX Trading | Using primary service for historical data. | 2016-04-04 18:14:42 Intraday data recording state for symbol F.US.MHIJ16 is set to download 'Pending'. | 2016-04-04 18:14:42 HD Request # 2 | Downloading Intraday chart data for F.US.MHIJ16 to the file F.US.MHIJ16.scid. Service: cqg | 2016-04-04 18:14:42 HD Request # 2 | Download start Date-Time: 2015-10-01 18:14:42.000 | 2016-04-04 18:14:42 CQG FIX Trading | Received symbol resolution report for symbol F.US.MHIJ16. Request ID: 779182. Contract ID: 1. | 2016-04-04 18:14:42 CQG FIX Trading | Requesting market data for F.US.MHIJ16 | 2016-04-04 18:14:42 HD Request # 2 | Error downloading historical Intraday data for F.US.MHIJ16. Time and sales data for instrument F.US.MHI (corresponding to ID = 1) is not allowed. | 2016-04-04 18:14:42 HD Request # 2 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.MHIJ16 | 2016-04-04 18:14:42 HD Request # 3 | Downloading Intraday chart data for F.US.MHIJ16 to the file F.US.MHIJ16.scid. Service: cqg | 2016-04-04 18:14:42 HD Request # 3 | Download start Date-Time: 2015-10-01 18:14:42.000 | 2016-04-04 18:14:42 HD Request # 3 | Error downloading historical Intraday data for F.US.MHIJ16. Time and sales data for instrument F.US.MHI (corresponding to ID = 1) is not allowed. | 2016-04-04 18:14:42 HD Request # 3 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.MHIJ16 | 2016-04-04 18:14:42 HD Request # 4 | Downloading Intraday chart data for F.US.MHIJ16 to the file F.US.MHIJ16.scid. Service: cqg | 2016-04-04 18:14:42 HD Request # 4 | Download start Date-Time: 2015-10-01 18:14:42.000 | 2016-04-04 18:14:42 HD Request # 4 | Error downloading historical Intraday data for F.US.MHIJ16. Time and sales data for instrument F.US.MHI (corresponding to ID = 1) is not allowed. | 2016-04-04 18:14:42 HD Request # 4 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.MHIJ16 | 2016-04-04 18:14:42 HD Request # 4 | Intraday download COMPLETE for F.US.MHIJ16. Completion time: 0s. Unique request ID: 1 | 2016-04-04 18:14:42 Removed historical data download ID 1 | 2016-04-04 18:14:42 Real-time Intraday chart data file updates started for F.US.MHIJ16 | 2016-04-04 18:14:42 Opened cached Intraday file: C:\SierraChart\Data\F.US.MHIJ16.scid | 2016-04-04 18:14:42 Intraday chart data file opened for F.US.MHIJ16 | 2016-04-04 18:14:42 F.US.MHIJ16 1 Min #1 | Reloading chart. | 2016-04-04 18:14:52 HD Request # 5 | Downloading Historical Daily chart data for F.US.MHIJ16. Starting date: 2016-03-31. Service: cqg | 2016-04-04 18:14:53 HD Request # 5 | Requesting historical Daily data for HKJ16 starting at 2016-03-30 | 2016-04-04 18:14:53 HTTP connection to ds01.ddfplus.com:80 (0) | Resolved address ds01.ddfplus.com to IP 8.18.161.123 | 2016-04-04 18:14:53 HTTP connection to ds01.ddfplus.com:80 (5) | Connected. | 2016-04-04 18:14:53 HD Request # 5 | Receiving historical Daily data for F.US.MHIJ16 starting at 2016-03-31 | 2016-04-04 18:14:53 Writing historical Daily data for F.US.MHIJ16 to the file F.US.MHIJ16.dly | 2016-04-04 18:14:53 HD Request # 5 | Received 3 records from 2016-03-31 00:00:00 to 2016-04-01 00:00:00 (2.0 days) and wrote 2 records for F.US.MHIJ16 | 2016-04-04 18:14:53 HD Request # 5 | Daily download COMPLETE for F.US.MHIJ16. Completion time: 0s. Unique request ID: 2 | 2016-04-04 18:14:53 Removed historical data download ID 2 | 2016-04-04 18:14:53 F.US.MHIJ16 Daily #1 | Reloading chart. | 2016-04-04 18:14:53 F.US.MHIJ16 Daily #1 | Reloading chart. | 2016-04-04 18:15:02 CQG FIX Trading | Using primary service for historical data. | 2016-04-04 18:15:02 F.US.MHIJ16 5 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.MHIJ16.scid | 2016-04-04 18:15:02 F.US.MHIJ16 5 Min #1 | Reloading chart. | 2016-04-04 18:15:05 F.US.MHIJ16 Daily #1 | Reloading chart. | 2016-04-04 18:15:06 CQG FIX Trading | Using primary service for historical data. | 2016-04-04 18:15:06 F.US.MHIJ16 5 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.MHIJ16.scid | 2016-04-04 18:15:06 F.US.MHIJ16 5 Min #1 | Reloading chart. | 2016-04-04 18:15:07 CQG FIX Trading | Using primary service for historical data. | 2016-04-04 18:15:07 F.US.MHIJ16 10 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.MHIJ16.scid | 2016-04-04 18:15:07 CQG FIX Trading | Using primary service for historical data. | 2016-04-04 18:15:20 Intraday data recording state for symbol F.US.MHIJ16 is set to download 'Pending'. | 2016-04-04 18:15:20 Reloading all charts with filename: F.US.MHIJ16.scid | 2016-04-04 18:15:20 HD Request # 6 | Downloading Intraday chart data for F.US.MHIJ16 to the file F.US.MHIJ16.scid. Service: cqg | 2016-04-04 18:15:20 HD Request # 6 | Download start Date-Time: 2015-10-01 18:15:19.000 | 2016-04-04 18:15:20 HD Request # 6 | Error downloading historical Intraday data for F.US.MHIJ16. Time and sales data for instrument F.US.MHI (corresponding to ID = 1) is not allowed. | 2016-04-04 18:15:20 HD Request # 6 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.MHIJ16 | 2016-04-04 18:15:20 HD Request # 7 | Downloading Intraday chart data for F.US.MHIJ16 to the file F.US.MHIJ16.scid. Service: cqg | 2016-04-04 18:15:20 HD Request # 7 | Download start Date-Time: 2015-10-01 18:15:19.000 | 2016-04-04 18:15:20 HD Request # 7 | Error downloading historical Intraday data for F.US.MHIJ16. Time and sales data for instrument F.US.MHI (corresponding to ID = 1) is not allowed. | 2016-04-04 18:15:20 HD Request # 7 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.MHIJ16 | 2016-04-04 18:15:20 HD Request # 8 | Downloading Intraday chart data for F.US.MHIJ16 to the file F.US.MHIJ16.scid. Service: cqg | 2016-04-04 18:15:20 HD Request # 8 | Download start Date-Time: 2015-10-01 18:15:20.000 | 2016-04-04 18:15:20 HD Request # 8 | Error downloading historical Intraday data for F.US.MHIJ16. Time and sales data for instrument F.US.MHI (corresponding to ID = 1) is not allowed. | 2016-04-04 18:15:20 HD Request # 8 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.MHIJ16 | 2016-04-04 18:15:20 HD Request # 8 | Intraday download COMPLETE for F.US.MHIJ16. Completion time: 0s. Unique request ID: 3 | 2016-04-04 18:15:20 Removed historical data download ID 3 | 2016-04-04 18:15:20 Real-time Intraday chart data file updates started for F.US.MHIJ16 | 2016-04-04 18:15:20 Opened cached Intraday file: C:\SierraChart\Data\F.US.MHIJ16.scid | 2016-04-04 18:15:20 Intraday chart data file opened for F.US.MHIJ16 | 2016-04-04 18:15:20 F.US.MHIJ16 10 Min #1 | Reloading chart. | 2016-04-04 18:15:20 CQG FIX Trading | Using primary service for historical data. | 2016-04-04 18:15:20 F.US.MHIJ16 10 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.MHIJ16.scid | 2016-04-04 18:15:20 |
| [2016-04-04 18:18:16] |
It looks like I'm having the same issue although the FCM just said that the historical data has been turned on.
| [2016-04-04 18:37:38] |
Yes, the problem is the same: HD Request # 2 | Error downloading historical Intraday data for F.US.MHIJ16. Time and sales data for instrument F.US.MHI (corresponding to ID = 1) is not allowed. | 2016-04-04 18:14:42
Try reconnecting to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After that re-download the data following the instructions here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is Data in the Chart If you still do not get the historical data you need to contact the FCM about this again. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-04-04 18:39:13
| [2016-04-05 18:40:26] |
Problem solved, the FCM turned on the historical data!
