Date/Time: Tue, 22 Sep 2026 19:05:30 +0000
Sierra Charts constantly saying "Connecting" but won't connect
View Count: 1287
[2016-03-20 14:17:42]
User463662 - Posts: 50
My charts won't connect. They keep saying "Connecting" in the top right corner with the yellow rectangle. I posted the log in here. I'd appreciate any help with this issue!
Software version: 1307 | 2016-03-20 09:13:26
Uses Old Spreadsheets | 2016-03-20 09:13:26
Usage end date: 2016-04-14 | 2016-03-20 09:13:26
Enabled for: Advanced Features. | 2016-03-20 09:13:26
Enabled for: Advanced Features 2. | 2016-03-20 09:13:26
Enabled for: Sierra Chart Historical Data Service. | 2016-03-20 09:13:26
Allow Support for Sierra Chart Data Feeds is enabled. | 2016-03-20 09:13:26
Current selected Data/Trading service: Rithmic Trading | 2016-03-20 09:13:26
Chart Update Interval: 500 | 2016-03-20 09:13:26
Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-03-20 09:13:26
2016-03-20 09:13:26 Local computer time | 2016-03-20 09:13:26
2016-03-20 14:13:26 Local computer time in UTC | 2016-03-20 09:13:26
2016-03-20 09:13:26 Local computer time in SC Time Zone | 2016-03-20 09:13:26
2016-03-20 14:13:26 Server time in UTC | 2016-03-20 09:13:26
Local computer UTC time and Server UTC time difference: 1 seconds. | 2016-03-20 09:13:26
Program path: C:\SierraChart\ | 2016-03-20 09:13:26
Data Files path: C:\SierraChart\Data\ | 2016-03-20 09:13:26
OS Version Number: 6.2 | 2016-03-20 09:13:26
Locale Information: C | 2016-03-20 09:13:26
Checking for new symbol settings for rim | 2016-03-20 09:13:26
Symbol settings are up-to-date for rim | 2016-03-20 09:13:28
Rithmic Trading | Port for executable: 50116 | 2016-03-20 09:13:31
Listening socket (1228), port 50116 | Closed. | 2016-03-20 09:13:31
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-03-20 09:13:31
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50116 | 2016-03-20 09:13:33
Socket (4) | Connected. | 2016-03-20 09:13:33
Rithmic Trading | Connected to server. | 2016-03-20 09:13:33
Rithmic Trading | Sending logon request message. | 2016-03-20 09:13:33
Rithmic Trading | Starting the connection process to data and trading service. | 2016-03-20 09:13:33
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-03-20 09:13:33
Rithmic Trading | Connecting to Rithmic 01 US server. | 2016-03-20 09:13:33
Rithmic Trading | Server Alert: Market Data Connection Opened | 2016-03-20 09:13:34
Rithmic Trading | Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-03-20 09:13:34
Rithmic Trading | Server Alert: Trading System Connection Opened | 2016-03-20 09:13:35
Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-03-20 09:13:35
Rithmic Trading | Server Alert: PnL Connection Opened | 2016-03-20 09:13:35
Rithmic Trading | Server Alert: PnL Connection Login Failed. Result text: "permission denied" | 2016-03-20 09:13:35
Rithmic Trading | Server Name: DTC Bridge. | 2016-03-20 09:13:35
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-03-20 09:13:35
Rithmic Trading | Logon error from server | 2016-03-20 09:13:35
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-20 09:13:35
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-20 09:13:35
Socket (4) | Shutdown and closed. | 2016-03-20 09:13:35
Rithmic Trading | Disconnected from the server. | 2016-03-20 09:13:35
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-20 09:13:35
Rithmic Trading | Port for executable: 50133 | 2016-03-20 09:13:37
Listening socket (1352), port 50133 | Closed. | 2016-03-20 09:13:37
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-03-20 09:13:37
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50133 | 2016-03-20 09:13:39
Socket (5) | Connected. | 2016-03-20 09:13:39
Rithmic Trading | Connected to server. | 2016-03-20 09:13:39
Rithmic Trading | Sending logon request message. | 2016-03-20 09:13:39
Rithmic Trading | Starting the connection process to data and trading service. | 2016-03-20 09:13:39
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-03-20 09:13:39
Rithmic Trading | Connecting to Rithmic 01 US server. | 2016-03-20 09:13:39
Rithmic Trading | Server Alert: Market Data Connection Opened | 2016-03-20 09:13:40
Rithmic Trading | Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-03-20 09:13:40
Rithmic Trading | Server Alert: Trading System Connection Opened | 2016-03-20 09:13:41
Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-03-20 09:13:41
Rithmic Trading | Server Alert: PnL Connection Opened | 2016-03-20 09:13:41
Rithmic Trading | Server Alert: PnL Connection Login Failed. Result text: "permission denied" | 2016-03-20 09:13:41
Rithmic Trading | Server Name: DTC Bridge. | 2016-03-20 09:13:41
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-03-20 09:13:41
Rithmic Trading | Logon error from server | 2016-03-20 09:13:41
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-20 09:13:41
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-20 09:13:41
Socket (5) | Shutdown and closed. | 2016-03-20 09:13:41
Rithmic Trading | Disconnected from the server. | 2016-03-20 09:13:41
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-20 09:13:41
Rithmic Trading | Port for executable: 50153 | 2016-03-20 09:13:43
Listening socket (1372), port 50153 | Closed. | 2016-03-20 09:13:43
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-03-20 09:13:43
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50153 | 2016-03-20 09:13:45
Socket (6) | Connected. | 2016-03-20 09:13:45
Rithmic Trading | Connected to server. | 2016-03-20 09:13:45
Rithmic Trading | Sending logon request message. | 2016-03-20 09:13:45
Rithmic Trading | Starting the connection process to data and trading service. | 2016-03-20 09:13:45
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-03-20 09:13:45
Rithmic Trading | Connecting to Rithmic 01 US server. | 2016-03-20 09:13:45
Rithmic Trading | Server Alert: Market Data Connection Opened | 2016-03-20 09:13:46
Rithmic Trading | Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-03-20 09:13:46
Rithmic Trading | Server Alert: Trading System Connection Opened | 2016-03-20 09:13:47
Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-03-20 09:13:47
Rithmic Trading | Server Alert: PnL Connection Opened | 2016-03-20 09:13:47
Rithmic Trading | Server Alert: PnL Connection Login Failed. Result text: "permission denied" | 2016-03-20 09:13:47
Rithmic Trading | Server Name: DTC Bridge. | 2016-03-20 09:13:47
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-03-20 09:13:47
Rithmic Trading | Logon error from server | 2016-03-20 09:13:47
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-20 09:13:47
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-20 09:13:47
Socket (6) | Shutdown and closed. | 2016-03-20 09:13:47
Rithmic Trading | Disconnected from the server. | 2016-03-20 09:13:47
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-20 09:13:47
Rithmic Trading | Port for executable: 50169 | 2016-03-20 09:13:49
Listening socket (1372), port 50169 | Closed. | 2016-03-20 09:13:49
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-03-20 09:13:49
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50169 | 2016-03-20 09:13:51
Socket (7) | Connected. | 2016-03-20 09:13:51
Rithmic Trading | Connected to server. | 2016-03-20 09:13:51
Rithmic Trading | Sending logon request message. | 2016-03-20 09:13:51
Rithmic Trading | Starting the connection process to data and trading service. | 2016-03-20 09:13:51
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-03-20 09:13:51
Rithmic Trading | Connecting to Rithmic 01 US server. | 2016-03-20 09:13:51
Rithmic Trading | Server Alert: Market Data Connection Opened | 2016-03-20 09:13:52
Rithmic Trading | Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-03-20 09:13:52
Rithmic Trading | Server Alert: Trading System Connection Opened | 2016-03-20 09:13:53
Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-03-20 09:13:53
Rithmic Trading | Server Alert: PnL Connection Opened | 2016-03-20 09:13:53
Rithmic Trading | Server Alert: PnL Connection Login Failed. Result text: "permission denied" | 2016-03-20 09:13:53
Rithmic Trading | Server Name: DTC Bridge. | 2016-03-20 09:13:53
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-03-20 09:13:53
Rithmic Trading | Logon error from server | 2016-03-20 09:13:53
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-20 09:13:53
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-20 09:13:53
Socket (7) | Shutdown and closed. | 2016-03-20 09:13:53
Rithmic Trading | Disconnected from the server. | 2016-03-20 09:13:53
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-20 09:13:53
Rithmic Trading | Port for executable: 50183 | 2016-03-20 09:13:55
Listening socket (1312), port 50183 | Closed. | 2016-03-20 09:13:55
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-03-20 09:13:55
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50183 | 2016-03-20 09:13:57
Socket (8) | Connected. | 2016-03-20 09:13:57
Rithmic Trading | Connected to server. | 2016-03-20 09:13:57
Rithmic Trading | Sending logon request message. | 2016-03-20 09:13:57
Rithmic Trading | Starting the connection process to data and trading service. | 2016-03-20 09:13:57
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-03-20 09:13:57
Rithmic Trading | Connecting to Rithmic 01 US server. | 2016-03-20 09:13:57
Rithmic Trading | Server Alert: Market Data Connection Opened | 2016-03-20 09:13:58
Rithmic Trading | Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-03-20 09:13:58
Rithmic Trading | Server Alert: Trading System Connection Opened | 2016-03-20 09:13:59
Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-03-20 09:13:59
Rithmic Trading | Server Alert: PnL Connection Opened | 2016-03-20 09:13:59
Rithmic Trading | Server Alert: PnL Connection Login Failed. Result text: "permission denied" | 2016-03-20 09:13:59
Rithmic Trading | Server Name: DTC Bridge. | 2016-03-20 09:13:59
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-03-20 09:13:59
Rithmic Trading | Logon error from server | 2016-03-20 09:13:59
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-20 09:13:59
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-20 09:13:59
Socket (8) | Shutdown and closed. | 2016-03-20 09:13:59
Rithmic Trading | Disconnected from the server. | 2016-03-20 09:13:59
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-20 09:13:59
Rithmic Trading | Port for executable: 50197 | 2016-03-20 09:14:01
Listening socket (1372), port 50197 | Closed. | 2016-03-20 09:14:01
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-03-20 09:14:01
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50197 | 2016-03-20 09:14:03
Socket (9) | Connected. | 2016-03-20 09:14:03
Rithmic Trading | Connected to server. | 2016-03-20 09:14:03
Rithmic Trading | Sending logon request message. | 2016-03-20 09:14:03
Rithmic Trading | Starting the connection process to data and trading service. | 2016-03-20 09:14:03
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-03-20 09:14:03
Rithmic Trading | Connecting to Rithmic 01 US server. | 2016-03-20 09:14:03
Rithmic Trading | Server Alert: Market Data Connection Opened | 2016-03-20 09:14:04
Rithmic Trading | Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-03-20 09:14:04
Rithmic Trading | Server Alert: Trading System Connection Opened | 2016-03-20 09:14:05
Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-03-20 09:14:05
Rithmic Trading | Server Alert: PnL Connection Opened | 2016-03-20 09:14:05
Rithmic Trading | Server Alert: PnL Connection Login Failed. Result text: "permission denied" | 2016-03-20 09:14:05
Rithmic Trading | Server Name: DTC Bridge. | 2016-03-20 09:14:05
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-03-20 09:14:05
Rithmic Trading | Logon error from server | 2016-03-20 09:14:05
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-20 09:14:05
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-20 09:14:05
Socket (9) | Shutdown and closed. | 2016-03-20 09:14:05
Rithmic Trading | Disconnected from the server. | 2016-03-20 09:14:05
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-20 09:14:05
Rithmic Trading | Port for executable: 50215 | 2016-03-20 09:14:07
Listening socket (1312), port 50215 | Closed. | 2016-03-20 09:14:07
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-03-20 09:14:07
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50215 | 2016-03-20 09:14:09
Socket (10) | Connected. | 2016-03-20 09:14:09
Rithmic Trading | Connected to server. | 2016-03-20 09:14:09
Rithmic Trading | Sending logon request message. | 2016-03-20 09:14:09
Rithmic Trading | Starting the connection process to data and trading service. | 2016-03-20 09:14:09
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-03-20 09:14:09
Rithmic Trading | Connecting to Rithmic 01 US server. | 2016-03-20 09:14:09
Rithmic Trading | Server Alert: Market Data Connection Opened | 2016-03-20 09:14:10
Rithmic Trading | Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-03-20 09:14:10
Rithmic Trading | Server Alert: Trading System Connection Opened | 2016-03-20 09:14:10
Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-03-20 09:14:10
Rithmic Trading | Server Alert: PnL Connection Opened | 2016-03-20 09:14:11
Rithmic Trading | Server Alert: PnL Connection Login Failed. Result text: "permission denied" | 2016-03-20 09:14:11
Rithmic Trading | Server Name: DTC Bridge. | 2016-03-20 09:14:11
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-03-20 09:14:11
Rithmic Trading | Logon error from server | 2016-03-20 09:14:11
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-20 09:14:11
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-20 09:14:11
Socket (10) | Shutdown and closed. | 2016-03-20 09:14:11
Rithmic Trading | Disconnected from the server. | 2016-03-20 09:14:11
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-20 09:14:11
Rithmic Trading | Port for executable: 50232 | 2016-03-20 09:14:13
Listening socket (1388), port 50232 | Closed. | 2016-03-20 09:14:13
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-03-20 09:14:13
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50232 | 2016-03-20 09:14:15
Socket (11) | Connected. | 2016-03-20 09:14:15
Rithmic Trading | Connected to server. | 2016-03-20 09:14:15
Rithmic Trading | Sending logon request message. | 2016-03-20 09:14:15
Rithmic Trading | Starting the connection process to data and trading service. | 2016-03-20 09:14:15
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-03-20 09:14:15
Rithmic Trading | Connecting to Rithmic 01 US server. | 2016-03-20 09:14:15
Rithmic Trading | Server Alert: Market Data Connection Opened | 2016-03-20 09:14:16
Rithmic Trading | Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-03-20 09:14:16
Rithmic Trading | Server Alert: Trading System Connection Opened | 2016-03-20 09:14:16
Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-03-20 09:14:16
Rithmic Trading | Server Alert: PnL Connection Opened | 2016-03-20 09:14:17
Rithmic Trading | Server Alert: PnL Connection Login Failed. Result text: "permission denied" | 2016-03-20 09:14:17
Rithmic Trading | Server Name: DTC Bridge. | 2016-03-20 09:14:17
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-03-20 09:14:17
Rithmic Trading | Logon error from server | 2016-03-20 09:14:17
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-20 09:14:17
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-20 09:14:17
Socket (11) | Shutdown and closed. | 2016-03-20 09:14:17
Rithmic Trading | Disconnected from the server. | 2016-03-20 09:14:17
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-20 09:14:17
Rithmic Trading | Port for executable: 50251 | 2016-03-20 09:14:19
Listening socket (1276), port 50251 | Closed. | 2016-03-20 09:14:19
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-03-20 09:14:19
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50251 | 2016-03-20 09:14:21
Socket (12) | Connected. | 2016-03-20 09:14:21
Rithmic Trading | Connected to server. | 2016-03-20 09:14:21
Rithmic Trading | Sending logon request message. | 2016-03-20 09:14:21
Rithmic Trading | Starting the connection process to data and trading service. | 2016-03-20 09:14:21
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-03-20 09:14:21
Rithmic Trading | Connecting to Rithmic 01 US server. | 2016-03-20 09:14:21
Rithmic Trading | Server Alert: Market Data Connection Opened | 2016-03-20 09:14:22
Rithmic Trading | Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-03-20 09:14:22
Rithmic Trading | Server Alert: Trading System Connection Opened | 2016-03-20 09:14:22
Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-03-20 09:14:22
Rithmic Trading | Server Alert: PnL Connection Opened | 2016-03-20 09:14:22
Rithmic Trading | Server Alert: PnL Connection Login Failed. Result text: "permission denied" | 2016-03-20 09:14:22
Rithmic Trading | Server Name: DTC Bridge. | 2016-03-20 09:14:22
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-03-20 09:14:22
Rithmic Trading | Logon error from server | 2016-03-20 09:14:22
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-20 09:14:22
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-20 09:14:22
Socket (12) | Shutdown and closed. | 2016-03-20 09:14:22
Rithmic Trading | Disconnected from the server. | 2016-03-20 09:14:22
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-20 09:14:22
Rithmic Trading | Port for executable: 50267 | 2016-03-20 09:14:24
Listening socket (1296), port 50267 | Closed. | 2016-03-20 09:14:25
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-03-20 09:14:25
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50267 | 2016-03-20 09:14:27
Socket (13) | Connected. | 2016-03-20 09:14:27
Rithmic Trading | Connected to server. | 2016-03-20 09:14:27
Rithmic Trading | Sending logon request message. | 2016-03-20 09:14:27
Rithmic Trading | Starting the connection process to data and trading service. | 2016-03-20 09:14:27
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-03-20 09:14:27
Rithmic Trading | Connecting to Rithmic 01 US server. | 2016-03-20 09:14:27
Rithmic Trading | Server Alert: Market Data Connection Opened | 2016-03-20 09:14:28
Rithmic Trading | Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-03-20 09:14:28
Rithmic Trading | Server Alert: Trading System Connection Opened | 2016-03-20 09:14:28
Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-03-20 09:14:28
Rithmic Trading | Server Alert: PnL Connection Opened | 2016-03-20 09:14:28
Rithmic Trading | Server Alert: PnL Connection Login Failed. Result text: "permission denied" | 2016-03-20 09:14:28
Rithmic Trading | Server Name: DTC Bridge. | 2016-03-20 09:14:28
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-03-20 09:14:28
Rithmic Trading | Logon error from server | 2016-03-20 09:14:28
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-20 09:14:28
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-20 09:14:28
Socket (13) | Shutdown and closed. | 2016-03-20 09:14:28
Rithmic Trading | Disconnected from the server. | 2016-03-20 09:14:28
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-20 09:14:28
Rithmic Trading | Port for executable: 50282 | 2016-03-20 09:14:30
Listening socket (824), port 50282 | Closed. | 2016-03-20 09:14:30
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-03-20 09:14:30
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50282 | 2016-03-20 09:14:32
Socket (14) | Connected. | 2016-03-20 09:14:32
Rithmic Trading | Connected to server. | 2016-03-20 09:14:32
Rithmic Trading | Sending logon request message. | 2016-03-20 09:14:32
Rithmic Trading | Starting the connection process to data and trading service. | 2016-03-20 09:14:32
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-03-20 09:14:32
Rithmic Trading | Connecting to Rithmic 01 US server. | 2016-03-20 09:14:32
Rithmic Trading | Server Alert: Market Data Connection Opened | 2016-03-20 09:14:33
Rithmic Trading | Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-03-20 09:14:34
Rithmic Trading | Server Alert: Trading System Connection Opened | 2016-03-20 09:14:34
Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-03-20 09:14:34
Rithmic Trading | Server Alert: PnL Connection Opened | 2016-03-20 09:14:34
Rithmic Trading | Server Alert: PnL Connection Login Failed. Result text: "permission denied" | 2016-03-20 09:14:34
Rithmic Trading | Server Name: DTC Bridge. | 2016-03-20 09:14:34
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-03-20 09:14:34
Rithmic Trading | Logon error from server | 2016-03-20 09:14:34
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-20 09:14:34
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-20 09:14:34
Socket (14) | Shutdown and closed. | 2016-03-20 09:14:34
Rithmic Trading | Disconnected from the server. | 2016-03-20 09:14:34
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-20 09:14:34
Rithmic Trading | Port for executable: 50303 | 2016-03-20 09:14:36
Listening socket (824), port 50303 | Closed. | 2016-03-20 09:14:36
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-03-20 09:14:36
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50303 | 2016-03-20 09:14:38
Socket (15) | Connected. | 2016-03-20 09:14:38
Rithmic Trading | Connected to server. | 2016-03-20 09:14:38
Rithmic Trading | Sending logon request message. | 2016-03-20 09:14:38
Rithmic Trading | Starting the connection process to data and trading service. | 2016-03-20 09:14:38
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-03-20 09:14:38
Rithmic Trading | Connecting to Rithmic 01 US server. | 2016-03-20 09:14:38
Rithmic Trading | Server Alert: Market Data Connection Opened | 2016-03-20 09:14:39
Rithmic Trading | Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-03-20 09:14:39
Rithmic Trading | Server Alert: Trading System Connection Opened | 2016-03-20 09:14:40
Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-03-20 09:14:40
Rithmic Trading | Server Alert: PnL Connection Opened | 2016-03-20 09:14:40
Rithmic Trading | Server Alert: PnL Connection Login Failed. Result text: "permission denied" | 2016-03-20 09:14:40
Rithmic Trading | Server Name: DTC Bridge. | 2016-03-20 09:14:40
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-03-20 09:14:40
Rithmic Trading | Logon error from server | 2016-03-20 09:14:40
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-20 09:14:40
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-20 09:14:40
Socket (15) | Shutdown and closed. | 2016-03-20 09:14:40
Rithmic Trading | Disconnected from the server. | 2016-03-20 09:14:40
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-20 09:14:40
Rithmic Trading | Port for executable: 50321 | 2016-03-20 09:14:42
Listening socket (1264), port 50321 | Closed. | 2016-03-20 09:14:42
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-03-20 09:14:42
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50321 | 2016-03-20 09:14:44
Socket (16) | Connected. | 2016-03-20 09:14:44
Rithmic Trading | Connected to server. | 2016-03-20 09:14:44
Rithmic Trading | Sending logon request message. | 2016-03-20 09:14:44
Rithmic Trading | Starting the connection process to data and trading service. | 2016-03-20 09:14:44
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-03-20 09:14:44
Rithmic Trading | Connecting to Rithmic 01 US server. | 2016-03-20 09:14:44
Rithmic Trading | Server Alert: Market Data Connection Opened | 2016-03-20 09:14:45
Rithmic Trading | Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-03-20 09:14:45
Rithmic Trading | Server Alert: Trading System Connection Opened | 2016-03-20 09:14:46
Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-03-20 09:14:46
Rithmic Trading | Server Alert: PnL Connection Opened | 2016-03-20 09:14:46
Rithmic Trading | Server Alert: PnL Connection Login Failed. Result text: "permission denied" | 2016-03-20 09:14:46
Rithmic Trading | Server Name: DTC Bridge. | 2016-03-20 09:14:46
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-03-20 09:14:46
Rithmic Trading | Logon error from server | 2016-03-20 09:14:46
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-20 09:14:46
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-20 09:14:46
Socket (16) | Shutdown and closed. | 2016-03-20 09:14:46
Rithmic Trading | Disconnected from the server. | 2016-03-20 09:14:46
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-20 09:14:46
Rithmic Trading | Port for executable: 50336 | 2016-03-20 09:14:48
Listening socket (1256), port 50336 | Closed. | 2016-03-20 09:14:48
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-03-20 09:14:48
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50336 | 2016-03-20 09:14:50
Socket (17) | Connected. | 2016-03-20 09:14:50
Rithmic Trading | Connected to server. | 2016-03-20 09:14:50
Rithmic Trading | Sending logon request message. | 2016-03-20 09:14:50
Rithmic Trading | Starting the connection process to data and trading service. | 2016-03-20 09:14:50
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-03-20 09:14:50
Rithmic Trading | Connecting to Rithmic 01 US server. | 2016-03-20 09:14:50
Rithmic Trading | Server Alert: Market Data Connection Opened | 2016-03-20 09:14:51
Rithmic Trading | Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-03-20 09:14:51
Rithmic Trading | Server Alert: Trading System Connection Opened | 2016-03-20 09:14:52
Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-03-20 09:14:52
Rithmic Trading | Server Alert: PnL Connection Opened | 2016-03-20 09:14:52
Rithmic Trading | Server Alert: PnL Connection Login Failed. Result text: "permission denied" | 2016-03-20 09:14:52
Rithmic Trading | Server Name: DTC Bridge. | 2016-03-20 09:14:52
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-03-20 09:14:52
Rithmic Trading | Logon error from server | 2016-03-20 09:14:52
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-20 09:14:52
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-20 09:14:52
Socket (17) | Shutdown and closed. | 2016-03-20 09:14:52
Rithmic Trading | Disconnected from the server. | 2016-03-20 09:14:52
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-20 09:14:52
Rithmic Trading | Port for executable: 50350 | 2016-03-20 09:14:54
Listening socket (1208), port 50350 | Closed. | 2016-03-20 09:14:54
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-03-20 09:14:54
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50350 | 2016-03-20 09:14:56
Socket (18) | Connected. | 2016-03-20 09:14:56
Rithmic Trading | Connected to server. | 2016-03-20 09:14:56
Rithmic Trading | Sending logon request message. | 2016-03-20 09:14:56
Rithmic Trading | Starting the connection process to data and trading service. | 2016-03-20 09:14:56
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-03-20 09:14:56
Rithmic Trading | Connecting to Rithmic 01 US server. | 2016-03-20 09:14:56
Rithmic Trading | Server Alert: Market Data Connection Opened | 2016-03-20 09:14:57
Rithmic Trading | Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-03-20 09:14:57
Rithmic Trading | Server Alert: Trading System Connection Opened | 2016-03-20 09:14:57
Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-03-20 09:14:57
Rithmic Trading | Server Alert: PnL Connection Opened | 2016-03-20 09:14:58
Rithmic Trading | Server Alert: PnL Connection Login Failed. Result text: "permission denied" | 2016-03-20 09:14:58
Rithmic Trading | Server Name: DTC Bridge. | 2016-03-20 09:14:58
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-03-20 09:14:58
Rithmic Trading | Logon error from server | 2016-03-20 09:14:58
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-20 09:14:58
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-20 09:14:58
Socket (18) | Shutdown and closed. | 2016-03-20 09:14:58
Rithmic Trading | Disconnected from the server. | 2016-03-20 09:14:58
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-20 09:14:58
Rithmic Trading | Port for executable: 50364 | 2016-03-20 09:15:00
Listening socket (1120), port 50364 | Closed. | 2016-03-20 09:15:00
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-03-20 09:15:00
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50364 | 2016-03-20 09:15:02
Socket (19) | Connected. | 2016-03-20 09:15:02
Rithmic Trading | Connected to server. | 2016-03-20 09:15:02
Rithmic Trading | Sending logon request message. | 2016-03-20 09:15:02
Rithmic Trading | Starting the connection process to data and trading service. | 2016-03-20 09:15:02
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-03-20 09:15:02
Rithmic Trading | Connecting to Rithmic 01 US server. | 2016-03-20 09:15:02
Rithmic Trading | Server Alert: Market Data Connection Opened | 2016-03-20 09:15:03
Rithmic Trading | Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-03-20 09:15:03
Rithmic Trading | Server Alert: Trading System Connection Opened | 2016-03-20 09:15:03
Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-03-20 09:15:03
Rithmic Trading | Server Alert: PnL Connection Opened | 2016-03-20 09:15:04
Rithmic Trading | Server Alert: PnL Connection Login Failed. Result text: "permission denied" | 2016-03-20 09:15:04
Rithmic Trading | Server Name: DTC Bridge. | 2016-03-20 09:15:04
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-03-20 09:15:04
Rithmic Trading | Logon error from server | 2016-03-20 09:15:04
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-20 09:15:04
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-20 09:15:04
Socket (19) | Shutdown and closed. | 2016-03-20 09:15:04
Rithmic Trading | Disconnected from the server. | 2016-03-20 09:15:04
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-20 09:15:04
Rithmic Trading | Port for executable: 50381 | 2016-03-20 09:15:06
Listening socket (1208), port 50381 | Closed. | 2016-03-20 09:15:06
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-03-20 09:15:06
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50381 | 2016-03-20 09:15:08
Socket (20) | Connected. | 2016-03-20 09:15:08
Rithmic Trading | Connected to server. | 2016-03-20 09:15:08
Rithmic Trading | Sending logon request message. | 2016-03-20 09:15:08
Rithmic Trading | Starting the connection process to data and trading service. | 2016-03-20 09:15:08
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-03-20 09:15:08
Rithmic Trading | Connecting to Rithmic 01 US server. | 2016-03-20 09:15:08
Rithmic Trading | Server Alert: Market Data Connection Opened | 2016-03-20 09:15:09
Rithmic Trading | Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-03-20 09:15:09
Rithmic Trading | Server Alert: Trading System Connection Opened | 2016-03-20 09:15:09
Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-03-20 09:15:09
Rithmic Trading | Server Alert: PnL Connection Opened | 2016-03-20 09:15:10
Rithmic Trading | Server Alert: PnL Connection Login Failed. Result text: "permission denied" | 2016-03-20 09:15:10
Rithmic Trading | Server Name: DTC Bridge. | 2016-03-20 09:15:10
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-03-20 09:15:10
Rithmic Trading | Logon error from server | 2016-03-20 09:15:10
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-20 09:15:10
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-20 09:15:10
Socket (20) | Shutdown and closed. | 2016-03-20 09:15:10
Rithmic Trading | Disconnected from the server. | 2016-03-20 09:15:10
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-20 09:15:10
Rithmic Trading | Port for executable: 50395 | 2016-03-20 09:15:12
Listening socket (1264), port 50395 | Closed. | 2016-03-20 09:15:12
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-03-20 09:15:12
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50395 | 2016-03-20 09:15:14
Socket (21) | Connected. | 2016-03-20 09:15:14
Rithmic Trading | Connected to server. | 2016-03-20 09:15:14
Rithmic Trading | Sending logon request message. | 2016-03-20 09:15:14
Rithmic Trading | Starting the connection process to data and trading service. | 2016-03-20 09:15:14
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-03-20 09:15:14
Rithmic Trading | Connecting to Rithmic 01 US server. | 2016-03-20 09:15:14
Rithmic Trading | Server Alert: Market Data Connection Opened | 2016-03-20 09:15:15
Rithmic Trading | Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-03-20 09:15:15
Rithmic Trading | Server Alert: Trading System Connection Opened | 2016-03-20 09:15:15
Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-03-20 09:15:15
Rithmic Trading | Server Alert: PnL Connection Opened | 2016-03-20 09:15:15
Rithmic Trading | Server Alert: PnL Connection Login Failed. Result text: "permission denied" | 2016-03-20 09:15:15
Rithmic Trading | Server Name: DTC Bridge. | 2016-03-20 09:15:15
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-03-20 09:15:15
Rithmic Trading | Logon error from server | 2016-03-20 09:15:15
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-20 09:15:15
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-20 09:15:15
Socket (21) | Shutdown and closed. | 2016-03-20 09:15:15
Rithmic Trading | Disconnected from the server. | 2016-03-20 09:15:15
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-20 09:15:15
Rithmic Trading | Port for executable: 50411 | 2016-03-20 09:15:17
Listening socket (1384), port 50411 | Closed. | 2016-03-20 09:15:17
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-03-20 09:15:17
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50411 | 2016-03-20 09:15:19
Socket (22) | Connected. | 2016-03-20 09:15:19
Rithmic Trading | Connected to server. | 2016-03-20 09:15:19
Rithmic Trading | Sending logon request message. | 2016-03-20 09:15:19
Rithmic Trading | Starting the connection process to data and trading service. | 2016-03-20 09:15:19
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-03-20 09:15:19
Rithmic Trading | Connecting to Rithmic 01 US server. | 2016-03-20 09:15:19
Rithmic Trading | Server Alert: Market Data Connection Opened | 2016-03-20 09:15:20
Rithmic Trading | Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-03-20 09:15:21
Rithmic Trading | Server Alert: Trading System Connection Opened | 2016-03-20 09:15:21
Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-03-20 09:15:21
Rithmic Trading | Server Alert: PnL Connection Opened | 2016-03-20 09:15:21
Rithmic Trading | Server Alert: PnL Connection Login Failed. Result text: "permission denied" | 2016-03-20 09:15:21
Rithmic Trading | Server Name: DTC Bridge. | 2016-03-20 09:15:21
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-03-20 09:15:21
Rithmic Trading | Logon error from server | 2016-03-20 09:15:21
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-20 09:15:21
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-20 09:15:21
Socket (22) | Shutdown and closed. | 2016-03-20 09:15:21
Rithmic Trading | Disconnected from the server. | 2016-03-20 09:15:21
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-20 09:15:21
Rithmic Trading | Port for executable: 50433 | 2016-03-20 09:15:23
Listening socket (1224), port 50433 | Closed. | 2016-03-20 09:15:23
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-03-20 09:15:23
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50433 | 2016-03-20 09:15:25
Socket (23) | Connected. | 2016-03-20 09:15:25
Rithmic Trading | Connected to server. | 2016-03-20 09:15:25
Rithmic Trading | Sending logon request message. | 2016-03-20 09:15:25
Rithmic Trading | Starting the connection process to data and trading service. | 2016-03-20 09:15:25
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-03-20 09:15:25
Rithmic Trading | Connecting to Rithmic 01 US server. | 2016-03-20 09:15:25
Rithmic Trading | Server Alert: Market Data Connection Opened | 2016-03-20 09:15:26
Rithmic Trading | Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-03-20 09:15:26
Rithmic Trading | Server Alert: Trading System Connection Opened | 2016-03-20 09:15:27
Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-03-20 09:15:27
Rithmic Trading | Server Alert: PnL Connection Opened | 2016-03-20 09:15:27
Rithmic Trading | Server Alert: PnL Connection Login Failed. Result text: "permission denied" | 2016-03-20 09:15:27
Rithmic Trading | Server Name: DTC Bridge. | 2016-03-20 09:15:27
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-03-20 09:15:27
Rithmic Trading | Logon error from server | 2016-03-20 09:15:27
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-20 09:15:27
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-20 09:15:27
Socket (23) | Shutdown and closed. | 2016-03-20 09:15:27
Rithmic Trading | Disconnected from the server. | 2016-03-20 09:15:27
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-20 09:15:27
Rithmic Trading | Port for executable: 50450 | 2016-03-20 09:15:29
Listening socket (1352), port 50450 | Closed. | 2016-03-20 09:15:29
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-03-20 09:15:29
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50450 | 2016-03-20 09:15:31
Socket (25) | Connected. | 2016-03-20 09:15:31
Rithmic Trading | Connected to server. | 2016-03-20 09:15:31
Rithmic Trading | Sending logon request message. | 2016-03-20 09:15:31
Rithmic Trading | Starting the connection process to data and trading service. | 2016-03-20 09:15:31
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-03-20 09:15:31
Rithmic Trading | Connecting to Rithmic 01 US server. | 2016-03-20 09:15:31
Rithmic Trading | Server Alert: Market Data Connection Opened | 2016-03-20 09:15:32
Rithmic Trading | Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-03-20 09:15:32
Rithmic Trading | Server Alert: Trading System Connection Opened | 2016-03-20 09:15:33
Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-03-20 09:15:33
Rithmic Trading | Server Alert: PnL Connection Opened | 2016-03-20 09:15:33
Rithmic Trading | Server Alert: PnL Connection Login Failed. Result text: "permission denied" | 2016-03-20 09:15:33
Rithmic Trading | Server Name: DTC Bridge. | 2016-03-20 09:15:33
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-03-20 09:15:33
Rithmic Trading | Logon error from server | 2016-03-20 09:15:33
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-20 09:15:33
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-20 09:15:33
Socket (25) | Shutdown and closed. | 2016-03-20 09:15:33
Rithmic Trading | Disconnected from the server. | 2016-03-20 09:15:33
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-20 09:15:33
Rithmic Trading | Port for executable: 50466 | 2016-03-20 09:15:35
Listening socket (1264), port 50466 | Closed. | 2016-03-20 09:15:35
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-03-20 09:15:35
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50466 | 2016-03-20 09:15:37
Socket (26) | Connected. | 2016-03-20 09:15:37
Rithmic Trading | Connected to server. | 2016-03-20 09:15:37
Rithmic Trading | Sending logon request message. | 2016-03-20 09:15:37
Rithmic Trading | Starting the connection process to data and trading service. | 2016-03-20 09:15:37
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-03-20 09:15:37
Rithmic Trading | Connecting to Rithmic 01 US server. | 2016-03-20 09:15:37
Rithmic Trading | Server Alert: Market Data Connection Opened | 2016-03-20 09:15:38
Rithmic Trading | Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-03-20 09:15:38
Rithmic Trading | Server Alert: Trading System Connection Opened | 2016-03-20 09:15:38
Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-03-20 09:15:38
Rithmic Trading | Server Alert: PnL Connection Opened | 2016-03-20 09:15:39
Rithmic Trading | Server Alert: PnL Connection Login Failed. Result text: "permission denied" | 2016-03-20 09:15:39
Rithmic Trading | Server Name: DTC Bridge. | 2016-03-20 09:15:39
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-03-20 09:15:39
Rithmic Trading | Logon error from server | 2016-03-20 09:15:39
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-20 09:15:39
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-20 09:15:39
Socket (26) | Shutdown and closed. | 2016-03-20 09:15:39
Rithmic Trading | Disconnected from the server. | 2016-03-20 09:15:39
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-20 09:15:39
Rithmic Trading | Port for executable: 50480 | 2016-03-20 09:15:41
Listening socket (1364), port 50480 | Closed. | 2016-03-20 09:15:41
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-03-20 09:15:41
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50480 | 2016-03-20 09:15:43
Socket (27) | Connected. | 2016-03-20 09:15:43
Rithmic Trading | Connected to server. | 2016-03-20 09:15:43
Rithmic Trading | Sending logon request message. | 2016-03-20 09:15:43
Rithmic Trading | Starting the connection process to data and trading service. | 2016-03-20 09:15:43
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-03-20 09:15:43
Rithmic Trading | Connecting to Rithmic 01 US server. | 2016-03-20 09:15:43
Rithmic Trading | Server Alert: Market Data Connection Opened | 2016-03-20 09:15:44
Rithmic Trading | Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-03-20 09:15:44
Rithmic Trading | Server Alert: Trading System Connection Opened | 2016-03-20 09:15:44
Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-03-20 09:15:44
Rithmic Trading | Server Alert: PnL Connection Opened | 2016-03-20 09:15:45
Rithmic Trading | Server Alert: PnL Connection Login Failed. Result text: "permission denied" | 2016-03-20 09:15:45
Rithmic Trading | Server Name: DTC Bridge. | 2016-03-20 09:15:45
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-03-20 09:15:45
Rithmic Trading | Logon error from server | 2016-03-20 09:15:45
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-20 09:15:45
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-20 09:15:45
Socket (27) | Shutdown and closed. | 2016-03-20 09:15:45
Rithmic Trading | Disconnected from the server. | 2016-03-20 09:15:45
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-20 09:15:45
Rithmic Trading | Port for executable: 50494 | 2016-03-20 09:15:47
Listening socket (952), port 50494 | Closed. | 2016-03-20 09:15:47
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-03-20 09:15:47
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50494 | 2016-03-20 09:15:49
Socket (28) | Connected. | 2016-03-20 09:15:49
Rithmic Trading | Connected to server. | 2016-03-20 09:15:49
Rithmic Trading | Sending logon request message. | 2016-03-20 09:15:49
Rithmic Trading | Starting the connection process to data and trading service. | 2016-03-20 09:15:49
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-03-20 09:15:49
Rithmic Trading | Connecting to Rithmic 01 US server. | 2016-03-20 09:15:49
Rithmic Trading | Server Alert: Market Data Connection Opened | 2016-03-20 09:15:50
Rithmic Trading | Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-03-20 09:15:50
Rithmic Trading | Server Alert: Trading System Connection Opened | 2016-03-20 09:15:50
Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-03-20 09:15:50
Rithmic Trading | Server Alert: PnL Connection Opened | 2016-03-20 09:15:51
Rithmic Trading | Server Alert: PnL Connection Login Failed. Result text: "permission denied" | 2016-03-20 09:15:51
Rithmic Trading | Server Name: DTC Bridge. | 2016-03-20 09:15:51
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-03-20 09:15:51
Rithmic Trading | Logon error from server | 2016-03-20 09:15:51
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-20 09:15:51
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-20 09:15:51
Socket (28) | Shutdown and closed. | 2016-03-20 09:15:51
Rithmic Trading | Disconnected from the server. | 2016-03-20 09:15:51
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-20 09:15:51
Rithmic Trading | Port for executable: 50508 | 2016-03-20 09:15:53
Listening socket (1372), port 50508 | Closed. | 2016-03-20 09:15:53
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-03-20 09:15:53
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50508 | 2016-03-20 09:15:55
Socket (29) | Connected. | 2016-03-20 09:15:55
Rithmic Trading | Connected to server. | 2016-03-20 09:15:55
Rithmic Trading | Sending logon request message. | 2016-03-20 09:15:55
Rithmic Trading | Starting the connection process to data and trading service. | 2016-03-20 09:15:55
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-03-20 09:15:55
Rithmic Trading | Connecting to Rithmic 01 US server. | 2016-03-20 09:15:55
Rithmic Trading | Server Alert: Market Data Connection Opened | 2016-03-20 09:15:56
Rithmic Trading | Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-03-20 09:15:56
Rithmic Trading | Server Alert: Trading System Connection Opened | 2016-03-20 09:15:56
Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-03-20 09:15:56
Rithmic Trading | Server Alert: PnL Connection Opened | 2016-03-20 09:15:57
Rithmic Trading | Server Alert: PnL Connection Login Failed. Result text: "permission denied" | 2016-03-20 09:15:57
Rithmic Trading | Server Name: DTC Bridge. | 2016-03-20 09:15:57
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-03-20 09:15:57
Rithmic Trading | Logon error from server | 2016-03-20 09:15:57
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-20 09:15:57
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-20 09:15:57
Socket (29) | Shutdown and closed. | 2016-03-20 09:15:57
Rithmic Trading | Disconnected from the server. | 2016-03-20 09:15:57
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-20 09:15:57
Rithmic Trading | Port for executable: 50522 | 2016-03-20 09:15:59
Listening socket (1404), port 50522 | Closed. | 2016-03-20 09:15:59
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-03-20 09:15:59
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50522 | 2016-03-20 09:16:01
Socket (30) | Connected. | 2016-03-20 09:16:01
Rithmic Trading | Connected to server. | 2016-03-20 09:16:01
Rithmic Trading | Sending logon request message. | 2016-03-20 09:16:01
Rithmic Trading | Starting the connection process to data and trading service. | 2016-03-20 09:16:01
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-03-20 09:16:01
Rithmic Trading | Connecting to Rithmic 01 US server. | 2016-03-20 09:16:01
Rithmic Trading | Server Alert: Market Data Connection Opened | 2016-03-20 09:16:02
Rithmic Trading | Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-03-20 09:16:02
Rithmic Trading | Server Alert: Trading System Connection Opened | 2016-03-20 09:16:02
Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-03-20 09:16:02
Rithmic Trading | Server Alert: PnL Connection Opened | 2016-03-20 09:16:03
Rithmic Trading | Server Alert: PnL Connection Login Failed. Result text: "permission denied" | 2016-03-20 09:16:03
Rithmic Trading | Server Name: DTC Bridge. | 2016-03-20 09:16:03
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-03-20 09:16:03
Rithmic Trading | Logon error from server | 2016-03-20 09:16:03
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-20 09:16:03
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-20 09:16:03
Socket (30) | Shutdown and closed. | 2016-03-20 09:16:03
Rithmic Trading | Disconnected from the server. | 2016-03-20 09:16:03
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-20 09:16:03
Rithmic Trading | Port for executable: 50536 | 2016-03-20 09:16:05
Listening socket (1388), port 50536 | Closed. | 2016-03-20 09:16:05
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-03-20 09:16:05
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50536 | 2016-03-20 09:16:07
Socket (31) | Connected. | 2016-03-20 09:16:07
Rithmic Trading | Connected to server. | 2016-03-20 09:16:07
Rithmic Trading | Sending logon request message. | 2016-03-20 09:16:07
Rithmic Trading | Starting the connection process to data and trading service. | 2016-03-20 09:16:07
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-03-20 09:16:07
Rithmic Trading | Connecting to Rithmic 01 US server. | 2016-03-20 09:16:07
Rithmic Trading | Server Alert: Market Data Connection Opened | 2016-03-20 09:16:08
Rithmic Trading | Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-03-20 09:16:08
Rithmic Trading | Server Alert: Trading System Connection Opened | 2016-03-20 09:16:08
Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-03-20 09:16:08
Rithmic Trading | Server Alert: PnL Connection Opened | 2016-03-20 09:16:08
Rithmic Trading | Server Alert: PnL Connection Login Failed. Result text: "permission denied" | 2016-03-20 09:16:08
Rithmic Trading | Server Name: DTC Bridge. | 2016-03-20 09:16:08
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-03-20 09:16:08
Rithmic Trading | Logon error from server | 2016-03-20 09:16:08
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-20 09:16:08
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-20 09:16:08
Socket (31) | Shutdown and closed. | 2016-03-20 09:16:08
Rithmic Trading | Disconnected from the server. | 2016-03-20 09:16:08
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-20 09:16:08
Rithmic Trading | Port for executable: 50550 | 2016-03-20 09:16:10
Listening socket (824), port 50550 | Closed. | 2016-03-20 09:16:11
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-03-20 09:16:11
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50550 | 2016-03-20 09:16:13
Socket (32) | Connected. | 2016-03-20 09:16:13
Rithmic Trading | Connected to server. | 2016-03-20 09:16:13
Rithmic Trading | Sending logon request message. | 2016-03-20 09:16:13
Rithmic Trading | Starting the connection process to data and trading service. | 2016-03-20 09:16:13
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-03-20 09:16:13
Rithmic Trading | Connecting to Rithmic 01 US server. | 2016-03-20 09:16:13
Rithmic Trading | Server Alert: Market Data Connection Opened | 2016-03-20 09:16:14
Rithmic Trading | Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-03-20 09:16:14
Rithmic Trading | Server Alert: Trading System Connection Opened | 2016-03-20 09:16:14
Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-03-20 09:16:14
Rithmic Trading | Server Alert: PnL Connection Opened | 2016-03-20 09:16:14
Rithmic Trading | Server Alert: PnL Connection Login Failed. Result text: "permission denied" | 2016-03-20 09:16:14
Rithmic Trading | Server Name: DTC Bridge. | 2016-03-20 09:16:14
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-03-20 09:16:14
Rithmic Trading | Logon error from server | 2016-03-20 09:16:14
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-20 09:16:14
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-20 09:16:14
Socket (32) | Shutdown and closed. | 2016-03-20 09:16:14
Rithmic Trading | Disconnected from the server. | 2016-03-20 09:16:14
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-20 09:16:14
Rithmic Trading | Port for executable: 50564 | 2016-03-20 09:16:16
Listening socket (1372), port 50564 | Closed. | 2016-03-20 09:16:16
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-03-20 09:16:16
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50564 | 2016-03-20 09:16:18
Socket (33) | Connected. | 2016-03-20 09:16:18
Rithmic Trading | Connected to server. | 2016-03-20 09:16:18
Rithmic Trading | Sending logon request message. | 2016-03-20 09:16:18
Rithmic Trading | Starting the connection process to data and trading service. | 2016-03-20 09:16:18
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-03-20 09:16:18
Rithmic Trading | Connecting to Rithmic 01 US server. | 2016-03-20 09:16:18
Rithmic Trading | Server Alert: Market Data Connection Opened | 2016-03-20 09:16:19
Rithmic Trading | Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-03-20 09:16:19
Rithmic Trading | Server Alert: Trading System Connection Opened | 2016-03-20 09:16:20
Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-03-20 09:16:20
Rithmic Trading | Server Alert: PnL Connection Opened | 2016-03-20 09:16:20
Rithmic Trading | Server Alert: PnL Connection Login Failed. Result text: "permission denied" | 2016-03-20 09:16:20
Rithmic Trading | Server Name: DTC Bridge. | 2016-03-20 09:16:20
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-03-20 09:16:20
Rithmic Trading | Logon error from server | 2016-03-20 09:16:20
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-20 09:16:20
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-20 09:16:20
Socket (33) | Shutdown and closed. | 2016-03-20 09:16:20
Rithmic Trading | Disconnected from the server. | 2016-03-20 09:16:20
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-20 09:16:20
Rithmic Trading | Port for executable: 50578 | 2016-03-20 09:16:22
Listening socket (824), port 50578 | Closed. | 2016-03-20 09:16:22
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-03-20 09:16:22
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50578 | 2016-03-20 09:16:24
Socket (34) | Connected. | 2016-03-20 09:16:24
Rithmic Trading | Connected to server. | 2016-03-20 09:16:24
Rithmic Trading | Sending logon request message. | 2016-03-20 09:16:24
Rithmic Trading | Starting the connection process to data and trading service. | 2016-03-20 09:16:24
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-03-20 09:16:24
Rithmic Trading | Connecting to Rithmic 01 US server. | 2016-03-20 09:16:24
Rithmic Trading | Server Alert: Market Data Connection Opened | 2016-03-20 09:16:25
Rithmic Trading | Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-03-20 09:16:25
Rithmic Trading | Server Alert: Trading System Connection Opened | 2016-03-20 09:16:26
Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-03-20 09:16:26
Rithmic Trading | Server Alert: PnL Connection Opened | 2016-03-20 09:16:26
Rithmic Trading | Server Alert: PnL Connection Login Failed. Result text: "permission denied" | 2016-03-20 09:16:26
Rithmic Trading | Server Name: DTC Bridge. | 2016-03-20 09:16:26
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-03-20 09:16:26
Rithmic Trading | Logon error from server | 2016-03-20 09:16:26
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-20 09:16:26
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-20 09:16:26
Socket (34) | Shutdown and closed. | 2016-03-20 09:16:26
Rithmic Trading | Disconnected from the server. | 2016-03-20 09:16:26
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-20 09:16:26
[2016-03-20 18:56:53]
This is the relevant message:
Based upon the particular connection which is getting a permission denied error, we think the Rithmic server is not completely available at this time.
See if you can connect before the open of the market. If not, then follow the instructions here:
Rithmic Trading Platform Service: Permission Denied Resolution Procedure
