Date/Time: Tue, 04 Nov 2025 14:57:40 +0000
Renko Bars
View Count: 2519
|   [2013-03-28 17:01:24]     |
                 I purchased a subscription to Sierra Charts ($27/month package) and I want to use Renko Charts but when I go to Chart settings, Renko charts is grayed out. How do I get it to work if I want to set up a Renko Chart?
Renko Bars will only work with Intraday charts. Open an Intraday chart and then refer to the documentation here for Bar Period Type >> Renko in Ticks in Chart Settings: http://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#RenkoInTicks Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-03-28 17:02:07
