Date/Time: Fri, 27 Dec 2024 02:06:01 +0000
trouble booting program
View Count: 673
[2016-03-16 12:20:46]
User139900 - Posts: 2
When I initiate the program in the morning, It completely locks up my computer for twenty minutes before it finally completes start-up.
Jim
[2016-03-16 12:39:43]
Software version: 1379 | 2016-03-16 07:50:22
Uses New Spreadsheets | 2016-03-16 07:50:22
Usage end date: 2016-03-19 | 2016-03-16 07:50:22
Enabled for: Advanced Features. | 2016-03-16 07:50:22
Enabled for: Advanced Features 2. | 2016-03-16 07:50:22
Enabled for: Sierra Chart Historical Data Service. | 2016-03-16 07:50:22
Allow Support for Sierra Chart Data Feeds is enabled. | 2016-03-16 07:50:22
Current selected Data/Trading service: SC Forex Data (FXCM) | 2016-03-16 07:50:22
Chart Update Interval: 500 | 2016-03-16 07:50:22
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-03-16 07:50:22
2016-03-16 07:50:26 Local computer time | 2016-03-16 07:50:22
2016-03-16 11:50:26 Local computer time in UTC | 2016-03-16 07:50:22
2016-03-16 07:50:26 Local computer time in SC Time Zone | 2016-03-16 07:50:22
2016-03-16 11:49:31 Server time in UTC | 2016-03-16 07:50:22
Local computer UTC time and Server UTC time difference: 55 seconds. | 2016-03-16 07:50:22
Notice: Your computer's clock is off by 55 seconds. For help with this, press the 'Send for Analysis' button. | 2016-03-16 07:50:22
Program path: C:\SierraChart\ | 2016-03-16 07:50:22
Data Files path: C:\SierraChart\Data\ | 2016-03-16 07:50:22
OS Version Number: 6.1 | 2016-03-16 07:50:22
Locale Information: C | 2016-03-16 07:50:22
Checking for new symbol settings for fxcm | 2016-03-16 07:50:22
HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-03-16 07:50:22
HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-03-16 07:50:22
HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-03-16 07:50:22
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-03-16 07:50:22
Symbol settings are up-to-date for fxcm | 2016-03-16 07:50:27
Files to Open on Start up | Opening file: AUDJPY.cht | 2016-03-16 07:50:29
Files to Open on Start up | Opening file: AUDNZD.cht | 2016-03-16 07:50:29
Files to Open on Start up | Opening file: AUDUSD.cht | 2016-03-16 07:50:29
Files to Open on Start up | Opening file: EURAUD.cht | 2016-03-16 07:50:29
Files to Open on Start up | Opening file: EURCAD.cht | 2016-03-16 07:50:29
Files to Open on Start up | Opening file: EURCHF.cht | 2016-03-16 07:50:29
Files to Open on Start up | Opening file: EURGBP.cht | 2016-03-16 07:50:29
Files to Open on Start up | Opening file: EURJPY.cht | 2016-03-16 07:50:29
Files to Open on Start up | Opening file: EURNZD.cht | 2016-03-16 07:50:29
Files to Open on Start up | Opening file: EURUSD.cht | 2016-03-16 07:50:29
Files to Open on Start up | Opening file: GBPAUD.cht | 2016-03-16 07:50:29
Files to Open on Start up | Opening file: GBPCHF.cht | 2016-03-16 07:50:29
Files to Open on Start up | Opening file: GSPJPY.cht | 2016-03-16 07:50:29
Files to Open on Start up | Opening file: GBPNZD.cht | 2016-03-16 07:50:29
Files to Open on Start up | Opening file: GBPUSD.cht | 2016-03-16 07:50:29
Files to Open on Start up | Opening file: NZDJPY.cht | 2016-03-16 07:50:29
Files to Open on Start up | Opening file: NZDUSD.cht | 2016-03-16 07:50:29
Files to Open on Start up | Opening file: USDCAD.cht | 2016-03-16 07:50:29
Files to Open on Start up | Opening file: USDCHF.cht | 2016-03-16 07:50:29
Files to Open on Start up | Opening file: USDJPY.cht | 2016-03-16 07:50:29
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-03-16 07:50:29
HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-03-16 07:50:29
HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-03-16 07:50:29
HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-03-16 07:50:29
Using Bid/Ask average for last trade price for AUDJPY | 2016-03-16 08:11:52
HD Request # 2 | Downloading Historical Daily chart data for AUDJPY. Starting date: 2016-03-14. Service: fxcm | 2016-03-16 08:11:52
HD Request # 2 | Using server: ds3.sierracharts.com port 10149 | 2016-03-16 08:11:52
Intraday data recording state for symbol AUDJPY is set to download 'Pending'. | 2016-03-16 08:11:52
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164. | 2016-03-16 08:11:52
Socket (4) | Connected. | 2016-03-16 08:11:52
HD Request # 2 | Sending historical data logon request message. | 2016-03-16 08:11:52
HD Request # 2 | Requesting historical Daily data starting at 2016-03-14. | 2016-03-16 08:11:52
HD Request # 2 | Decompressing data. | 2016-03-16 08:11:52
HD Request # 2 | Receiving historical Daily data for AUDJPY starting at 2016-03-14 | 2016-03-16 08:11:52
HD Request # 2 | Writing historical Daily data to the file AUDJPY.dly | 2016-03-16 08:11:52
Socket (4) | Shutdown and closed. | 2016-03-16 08:11:52
The network socket for historical data has been closed. | 2016-03-16 08:11:52
HD Request # 2 | Received 3 records from 2016-03-14 00:00:00 to 2016-03-16 00:00:00 (3.0 days) and wrote 3 records for AUDJPY | 2016-03-16 08:11:52
HD Request # 2 | Daily download COMPLETE for AUDJPY. Completion time: 9s. Unique request ID: 1 | 2016-03-16 08:11:52
Removed historical data download ID 1 | 2016-03-16 08:11:52
HD Request # 3 | Downloading Intraday chart data for AUDJPY to the file AUDJPY.scid. Service: fxcm | 2016-03-16 08:11:52
HD Request # 3 | Download start Date-Time: 2016-03-15 19:42:08.000 | 2016-03-16 08:11:52
HD Request # 3 | Using server: ds4.sierracharts.com port 10149 | 2016-03-16 08:11:52
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-03-16 08:11:52
Socket (5) | Connected. | 2016-03-16 08:11:52
HD Request # 3 | Sending historical data logon request message. | 2016-03-16 08:11:52
Using Bid/Ask average for last trade price for AUDNZD | 2016-03-16 08:11:52
HD Request # 3 | Requesting Intraday data. Start Date-Time: 2016-03-15 19:42:08. Record interval: 0. Symbol: AUDJPY | 2016-03-16 08:11:52
HD Request # 3 | Decompressing data. | 2016-03-16 08:11:52
HD Request # 3 | Receiving Intraday data for AUDJPY starting at 2016-03-15 19:42:08 | 2016-03-16 08:11:52
HD Request # 3 | Timestamp of first Intraday data file record written: 2016-03-15 19:42:12 | 2016-03-16 08:11:52
Socket (5) | Shutdown and closed. | 2016-03-16 08:11:52
Intraday data recording state for symbol AUDNZD is set to download 'Pending'. | 2016-03-16 08:11:52
HD Request # 3 | Historical data for AUDJPY is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-03-16 08:11:52
HD Request # 3 | Received 155834 records from 2016-03-15 19:42:08 to 2016-03-16 08:11:19 (12.5 hours) and wrote 155832 records for AUDJPY | 2016-03-16 08:11:52
HD Request # 3 | Intraday download COMPLETE for AUDJPY. Completion time: 10s. Unique request ID: 2 | 2016-03-16 08:11:52
Removed historical data download ID 2 | 2016-03-16 08:11:52
HD Request # 4 | Downloading Historical Daily chart data for AUDNZD. Starting date: 2016-03-14. Service: fxcm | 2016-03-16 08:11:52
HD Request # 4 | Using server: ds5.sierracharts.com port 10149 | 2016-03-16 08:11:52
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-03-16 08:11:52
Socket (6) | Connected. | 2016-03-16 08:11:52
HD Request # 4 | Sending historical data logon request message. | 2016-03-16 08:11:52
HD Request # 4 | Requesting historical Daily data starting at 2016-03-14. | 2016-03-16 08:11:52
HD Request # 4 | Decompressing data. | 2016-03-16 08:11:52
HD Request # 4 | Receiving historical Daily data for AUDNZD starting at 2016-03-14 | 2016-03-16 08:11:52
HD Request # 4 | Writing historical Daily data to the file AUDNZD.dly | 2016-03-16 08:11:52
Socket (6) | Shutdown and closed. | 2016-03-16 08:11:52
HD Request # 4 | Received 3 records from 2016-03-14 00:00:00 to 2016-03-16 00:00:00 (3.0 days) and wrote 3 records for AUDNZD | 2016-03-16 08:11:52
HD Request # 4 | Daily download COMPLETE for AUDNZD. Completion time: 2s. Unique request ID: 3 | 2016-03-16 08:11:52
Removed historical data download ID 3 | 2016-03-16 08:11:52
HD Request # 5 | Downloading Intraday chart data for AUDNZD to the file AUDNZD.scid. Service: fxcm | 2016-03-16 08:11:52
HD Request # 5 | Download start Date-Time: 2016-03-15 19:42:06.000 | 2016-03-16 08:11:52
HD Request # 5 | Using server: ds3.sierracharts.com port 10149 | 2016-03-16 08:11:52
Socket (7) | Connected. | 2016-03-16 08:11:52
HD Request # 5 | Sending historical data logon request message. | 2016-03-16 08:11:52
HD Request # 5 | Requesting Intraday data. Start Date-Time: 2016-03-15 19:42:06. Record interval: 0. Symbol: AUDNZD | 2016-03-16 08:11:52
HD Request # 5 | Decompressing data. | 2016-03-16 08:11:52
HD Request # 5 | Receiving Intraday data for AUDNZD starting at 2016-03-15 19:42:06 | 2016-03-16 08:11:52
HD Request # 5 | Timestamp of first Intraday data file record written: 2016-03-15 19:42:12 | 2016-03-16 08:11:52
Socket (7) | Shutdown and closed. | 2016-03-16 08:11:52
HD Request # 5 | Historical data for AUDNZD is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-03-16 08:11:52
HD Request # 5 | Received 99910 records from 2016-03-15 19:42:06 to 2016-03-16 08:11:27 (12.5 hours) and wrote 99908 records for AUDNZD | 2016-03-16 08:11:52
HD Request # 5 | Intraday download COMPLETE for AUDNZD. Completion time: 2s. Unique request ID: 4 | 2016-03-16 08:11:52
Removed historical data download ID 4 | 2016-03-16 08:11:52
Using Bid/Ask average for last trade price for AUDUSD | 2016-03-16 08:11:52
HD Request # 6 | Downloading Historical Daily chart data for AUDUSD. Starting date: 2016-03-14. Service: fxcm | 2016-03-16 08:11:52
HD Request # 6 | Using server: ds4.sierracharts.com port 10149 | 2016-03-16 08:11:52
Socket (8) | Connected. | 2016-03-16 08:11:52
HD Request # 6 | Sending historical data logon request message. | 2016-03-16 08:11:52
HD Request # 6 | Requesting historical Daily data starting at 2016-03-14. | 2016-03-16 08:11:52
HD Request # 6 | Decompressing data. | 2016-03-16 08:11:52
HD Request # 6 | Receiving historical Daily data for AUDUSD starting at 2016-03-14 | 2016-03-16 08:11:52
HD Request # 6 | Writing historical Daily data to the file AUDUSD.dly | 2016-03-16 08:11:52
Socket (8) | Shutdown and closed. | 2016-03-16 08:11:52
HD Request # 6 | Received 3 records from 2016-03-14 00:00:00 to 2016-03-16 00:00:00 (3.0 days) and wrote 3 records for AUDUSD | 2016-03-16 08:11:52
HD Request # 6 | Daily download COMPLETE for AUDUSD. Completion time: 0s. Unique request ID: 5 | 2016-03-16 08:11:52
Removed historical data download ID 5 | 2016-03-16 08:11:52
Intraday data recording state for symbol AUDUSD is set to download 'Pending'. | 2016-03-16 08:11:52
HD Request # 7 | Downloading Intraday chart data for AUDUSD to the file AUDUSD.scid. Service: fxcm | 2016-03-16 08:11:52
HD Request # 7 | Download start Date-Time: 2016-03-15 19:42:11.000 | 2016-03-16 08:11:52
HD Request # 7 | Using server: ds5.sierracharts.com port 10149 | 2016-03-16 08:11:52
Socket (9) | Connected. | 2016-03-16 08:11:52
HD Request # 7 | Sending historical data logon request message. | 2016-03-16 08:11:52
HD Request # 7 | Requesting Intraday data. Start Date-Time: 2016-03-15 19:42:11. Record interval: 0. Symbol: AUDUSD | 2016-03-16 08:11:52
HD Request # 7 | Decompressing data. | 2016-03-16 08:11:52
HD Request # 7 | Receiving Intraday data for AUDUSD starting at 2016-03-15 19:42:11 | 2016-03-16 08:11:52
HD Request # 7 | Timestamp of first Intraday data file record written: 2016-03-15 19:42:12 | 2016-03-16 08:11:52
Socket (9) | Shutdown and closed. | 2016-03-16 08:11:52
HD Request # 7 | Historical data for AUDUSD is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-03-16 08:11:52
HD Request # 7 | Received 96596 records from 2016-03-15 19:42:11 to 2016-03-16 08:11:35 (12.5 hours) and wrote 96591 records for AUDUSD | 2016-03-16 08:11:52
HD Request # 7 | Intraday download COMPLETE for AUDUSD. Completion time: 2s. Unique request ID: 6 | 2016-03-16 08:11:52
Removed historical data download ID 6 | 2016-03-16 08:11:52
Using Bid/Ask average for last trade price for EURAUD | 2016-03-16 08:11:52
HD Request # 8 | Downloading Historical Daily chart data for EURAUD. Starting date: 2016-03-14. Service: fxcm | 2016-03-16 08:11:52
HD Request # 8 | Using server: ds3.sierracharts.com port 10149 | 2016-03-16 08:11:52
Socket (10) | Connected. | 2016-03-16 08:11:52
HD Request # 8 | Sending historical data logon request message. | 2016-03-16 08:11:52
HD Request # 8 | Requesting historical Daily data starting at 2016-03-14. | 2016-03-16 08:11:52
HD Request # 8 | Decompressing data. | 2016-03-16 08:11:52
HD Request # 8 | Receiving historical Daily data for EURAUD starting at 2016-03-14 | 2016-03-16 08:11:52
HD Request # 8 | Writing historical Daily data to the file EURAUD.dly | 2016-03-16 08:11:52
Socket (10) | Shutdown and closed. | 2016-03-16 08:11:52
HD Request # 8 | Received 3 records from 2016-03-14 00:00:00 to 2016-03-16 00:00:00 (3.0 days) and wrote 3 records for EURAUD | 2016-03-16 08:11:52
HD Request # 8 | Daily download COMPLETE for EURAUD. Completion time: 0s. Unique request ID: 7 | 2016-03-16 08:11:52
Removed historical data download ID 7 | 2016-03-16 08:11:52
EURAUD Monthly #5 | Reloading chart. | 2016-03-16 08:11:52
Intraday data recording state for symbol EURAUD is set to download 'Pending'. | 2016-03-16 08:11:52
HD Request # 9 | Downloading Intraday chart data for EURAUD to the file EURAUD.scid. Service: fxcm | 2016-03-16 08:11:52
HD Request # 9 | Download start Date-Time: 2016-03-15 19:42:10.000 | 2016-03-16 08:11:52
HD Request # 9 | Using server: ds4.sierracharts.com port 10149 | 2016-03-16 08:11:52
Socket (11) | Connected. | 2016-03-16 08:11:52
HD Request # 9 | Sending historical data logon request message. | 2016-03-16 08:11:52
HD Request # 9 | Requesting Intraday data. Start Date-Time: 2016-03-15 19:42:10. Record interval: 0. Symbol: EURAUD | 2016-03-16 08:11:52
HD Request # 9 | Decompressing data. | 2016-03-16 08:11:52
HD Request # 9 | Receiving Intraday data for EURAUD starting at 2016-03-15 19:42:10 | 2016-03-16 08:11:52
HD Request # 9 | Timestamp of first Intraday data file record written: 2016-03-15 19:42:12 | 2016-03-16 08:11:52
Using Bid/Ask average for last trade price for EURCAD | 2016-03-16 08:11:52
Socket (11) | Shutdown and closed. | 2016-03-16 08:11:52
HD Request # 9 | Historical data for EURAUD is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-03-16 08:11:52
HD Request # 9 | Received 192529 records from 2016-03-15 19:42:10 to 2016-03-16 08:11:39 (12.5 hours) and wrote 192527 records for EURAUD | 2016-03-16 08:11:52
HD Request # 9 | Intraday download COMPLETE for EURAUD. Completion time: 0s. Unique request ID: 8 | 2016-03-16 08:11:52
Removed historical data download ID 8 | 2016-03-16 08:11:52
HD Request # 10 | Downloading Historical Daily chart data for EURCAD. Starting date: 2016-03-14. Service: fxcm | 2016-03-16 08:11:52
HD Request # 10 | Using server: ds5.sierracharts.com port 10149 | 2016-03-16 08:11:52
Socket (12) | Connected. | 2016-03-16 08:11:52
HD Request # 10 | Sending historical data logon request message. | 2016-03-16 08:11:52
HD Request # 10 | Requesting historical Daily data starting at 2016-03-14. | 2016-03-16 08:11:52
HD Request # 10 | Decompressing data. | 2016-03-16 08:11:52
HD Request # 10 | Receiving historical Daily data for EURCAD starting at 2016-03-14 | 2016-03-16 08:11:52
HD Request # 10 | Writing historical Daily data to the file EURCAD.dly | 2016-03-16 08:11:52
Socket (12) | Shutdown and closed. | 2016-03-16 08:11:52
HD Request # 10 | Received 3 records from 2016-03-14 00:00:00 to 2016-03-16 00:00:00 (3.0 days) and wrote 3 records for EURCAD | 2016-03-16 08:11:52
HD Request # 10 | Daily download COMPLETE for EURCAD. Completion time: 1s. Unique request ID: 9 | 2016-03-16 08:11:52
Removed historical data download ID 9 | 2016-03-16 08:11:52
Intraday data recording state for symbol EURCAD is set to download 'Pending'. | 2016-03-16 08:11:52
HD Request # 11 | Downloading Intraday chart data for EURCAD to the file EURCAD.scid. Service: fxcm | 2016-03-16 08:11:52
HD Request # 11 | Download start Date-Time: 2016-03-15 19:42:10.000 | 2016-03-16 08:11:52
HD Request # 11 | Using server: ds3.sierracharts.com port 10149 | 2016-03-16 08:11:52
Socket (13) | Connected. | 2016-03-16 08:11:52
HD Request # 11 | Sending historical data logon request message. | 2016-03-16 08:11:52
HD Request # 11 | Requesting Intraday data. Start Date-Time: 2016-03-15 19:42:10. Record interval: 0. Symbol: EURCAD | 2016-03-16 08:11:52
HD Request # 11 | Decompressing data. | 2016-03-16 08:11:52
HD Request # 11 | Receiving Intraday data for EURCAD starting at 2016-03-15 19:42:10 | 2016-03-16 08:11:52
HD Request # 11 | Timestamp of first Intraday data file record written: 2016-03-15 19:42:15 | 2016-03-16 08:11:52
Socket (13) | Shutdown and closed. | 2016-03-16 08:11:52
HD Request # 11 | Historical data for EURCAD is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-03-16 08:11:52
HD Request # 11 | Received 136969 records from 2016-03-15 19:42:10 to 2016-03-16 08:11:43 (12.5 hours) and wrote 136968 records for EURCAD | 2016-03-16 08:11:52
HD Request # 11 | Intraday download COMPLETE for EURCAD. Completion time: 0s. Unique request ID: 10 | 2016-03-16 08:11:52
Removed historical data download ID 10 | 2016-03-16 08:11:52
Using Bid/Ask average for last trade price for EURCHF | 2016-03-16 08:11:52
HD Request # 12 | Downloading Historical Daily chart data for EURCHF. Starting date: 2016-03-14. Service: fxcm | 2016-03-16 08:11:52
HD Request # 12 | Using server: ds4.sierracharts.com port 10149 | 2016-03-16 08:11:52
Socket (14) | Connected. | 2016-03-16 08:11:52
HD Request # 12 | Sending historical data logon request message. | 2016-03-16 08:11:52
HD Request # 12 | Requesting historical Daily data starting at 2016-03-14. | 2016-03-16 08:11:52
HD Request # 12 | Decompressing data. | 2016-03-16 08:11:52
HD Request # 12 | Receiving historical Daily data for EURCHF starting at 2016-03-14 | 2016-03-16 08:11:52
HD Request # 12 | Writing historical Daily data to the file EURCHF.dly | 2016-03-16 08:11:52
Socket (14) | Shutdown and closed. | 2016-03-16 08:11:52
HD Request # 12 | Received 3 records from 2016-03-14 00:00:00 to 2016-03-16 00:00:00 (3.0 days) and wrote 3 records for EURCHF | 2016-03-16 08:11:52
HD Request # 12 | Daily download COMPLETE for EURCHF. Completion time: 1s. Unique request ID: 11 | 2016-03-16 08:11:52
Removed historical data download ID 11 | 2016-03-16 08:11:52
EURCHF Monthly #5 | Reloading chart. | 2016-03-16 08:11:52
Intraday data recording state for symbol EURCHF is set to download 'Pending'. | 2016-03-16 08:11:52
HD Request # 13 | Downloading Intraday chart data for EURCHF to the file EURCHF.scid. Service: fxcm | 2016-03-16 08:11:52
HD Request # 13 | Download start Date-Time: 2016-03-15 19:41:58.000 | 2016-03-16 08:11:52
HD Request # 13 | Using server: ds5.sierracharts.com port 10149 | 2016-03-16 08:11:52
Socket (15) | Connected. | 2016-03-16 08:11:52
HD Request # 13 | Sending historical data logon request message. | 2016-03-16 08:11:52
HD Request # 13 | Requesting Intraday data. Start Date-Time: 2016-03-15 19:41:58. Record interval: 0. Symbol: EURCHF | 2016-03-16 08:11:52
HD Request # 13 | Decompressing data. | 2016-03-16 08:11:52
HD Request # 13 | Receiving Intraday data for EURCHF starting at 2016-03-15 19:41:58 | 2016-03-16 08:11:52
HD Request # 13 | Timestamp of first Intraday data file record written: 2016-03-15 19:42:18 | 2016-03-16 08:11:52
Socket (15) | Shutdown and closed. | 2016-03-16 08:11:52
HD Request # 13 | Historical data for EURCHF is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-03-16 08:11:52
HD Request # 13 | Received 93947 records from 2016-03-15 19:41:58 to 2016-03-16 08:11:49 (12.5 hours) and wrote 93946 records for EURCHF | 2016-03-16 08:11:52
HD Request # 13 | Intraday download COMPLETE for EURCHF. Completion time: 2s. Unique request ID: 12 | 2016-03-16 08:11:52
Removed historical data download ID 12 | 2016-03-16 08:11:52
Using Bid/Ask average for last trade price for EURGBP | 2016-03-16 08:11:52
HD Request # 14 | Downloading Historical Daily chart data for EURGBP. Starting date: 2016-03-14. Service: fxcm | 2016-03-16 08:11:52
HD Request # 14 | Using server: ds3.sierracharts.com port 10149 | 2016-03-16 08:11:52
Socket (16) | Connected. | 2016-03-16 08:11:52
HD Request # 14 | Sending historical data logon request message. | 2016-03-16 08:11:52
HD Request # 14 | Requesting historical Daily data starting at 2016-03-14. | 2016-03-16 08:11:52
HD Request # 14 | Decompressing data. | 2016-03-16 08:11:52
HD Request # 14 | Receiving historical Daily data for EURGBP starting at 2016-03-14 | 2016-03-16 08:11:52
HD Request # 14 | Writing historical Daily data to the file EURGBP.dly | 2016-03-16 08:11:52
Socket (16) | Shutdown and closed. | 2016-03-16 08:11:52
HD Request # 14 | Received 3 records from 2016-03-14 00:00:00 to 2016-03-16 00:00:00 (3.0 days) and wrote 3 records for EURGBP | 2016-03-16 08:11:52
HD Request # 14 | Daily download COMPLETE for EURGBP. Completion time: 1s. Unique request ID: 13 | 2016-03-16 08:11:52
Removed historical data download ID 13 | 2016-03-16 08:11:52
EURGBP Monthly #5 | Reloading chart. | 2016-03-16 08:11:52
Intraday data recording state for symbol EURGBP is set to download 'Pending'. | 2016-03-16 08:11:52
HD Request # 15 | Downloading Intraday chart data for EURGBP to the file EURGBP.scid. Service: fxcm | 2016-03-16 08:11:52
HD Request # 15 | Download start Date-Time: 2016-03-15 19:42:09.000 | 2016-03-16 08:11:52
HD Request # 15 | Using server: ds4.sierracharts.com port 10149 | 2016-03-16 08:11:52
Socket (17) | Connected. | 2016-03-16 08:11:52
HD Request # 15 | Sending historical data logon request message. | 2016-03-16 08:11:52
HD Request # 15 | Requesting Intraday data. Start Date-Time: 2016-03-15 19:42:09. Record interval: 0. Symbol: EURGBP | 2016-03-16 08:11:52
HD Request # 15 | Decompressing data. | 2016-03-16 08:11:52
HD Request # 15 | Receiving Intraday data for EURGBP starting at 2016-03-15 19:42:09 | 2016-03-16 08:11:52
HD Request # 15 | Timestamp of first Intraday data file record written: 2016-03-15 19:42:18 | 2016-03-16 08:11:52
Socket (17) | Shutdown and closed. | 2016-03-16 08:11:52
HD Request # 15 | Historical data for EURGBP is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-03-16 08:11:52
HD Request # 15 | Received 81602 records from 2016-03-15 19:42:09 to 2016-03-16 08:11:55 (12.5 hours) and wrote 81600 records for EURGBP | 2016-03-16 08:11:52
HD Request # 15 | Intraday download COMPLETE for EURGBP. Completion time: 4s. Unique request ID: 14 | 2016-03-16 08:11:52
Removed historical data download ID 14 | 2016-03-16 08:11:52
Using Bid/Ask average for last trade price for EURJPY | 2016-03-16 08:11:52
HD Request # 16 | Downloading Historical Daily chart data for EURJPY. Starting date: 2016-03-14. Service: fxcm | 2016-03-16 08:11:52
HD Request # 16 | Using server: ds5.sierracharts.com port 10149 | 2016-03-16 08:11:52
Socket (18) | Connected. | 2016-03-16 08:11:52
HD Request # 16 | Sending historical data logon request message. | 2016-03-16 08:11:52
HD Request # 16 | Requesting historical Daily data starting at 2016-03-14. | 2016-03-16 08:11:52
HD Request # 16 | Decompressing data. | 2016-03-16 08:11:52
HD Request # 16 | Receiving historical Daily data for EURJPY starting at 2016-03-14 | 2016-03-16 08:11:52
HD Request # 16 | Writing historical Daily data to the file EURJPY.dly | 2016-03-16 08:11:52
Socket (18) | Shutdown and closed. | 2016-03-16 08:11:52
HD Request # 16 | Received 3 records from 2016-03-14 00:00:00 to 2016-03-16 00:00:00 (3.0 days) and wrote 3 records for EURJPY | 2016-03-16 08:11:52
HD Request # 16 | Daily download COMPLETE for EURJPY. Completion time: 0s. Unique request ID: 15 | 2016-03-16 08:11:52
Removed historical data download ID 15 | 2016-03-16 08:11:52
EURJPY Monthly #5 | Reloading chart. | 2016-03-16 08:11:52
Intraday data recording state for symbol EURJPY is set to download 'Pending'. | 2016-03-16 08:11:52
HD Request # 17 | Downloading Intraday chart data for EURJPY to the file EURJPY.scid. Service: fxcm | 2016-03-16 08:11:52
HD Request # 17 | Download start Date-Time: 2016-03-15 19:42:08.000 | 2016-03-16 08:11:52
HD Request # 17 | Using server: ds3.sierracharts.com port 10149 | 2016-03-16 08:11:52
Socket (19) | Connected. | 2016-03-16 08:11:52
HD Request # 17 | Sending historical data logon request message. | 2016-03-16 08:11:52
HD Request # 17 | Requesting Intraday data. Start Date-Time: 2016-03-15 19:42:08. Record interval: 0. Symbol: EURJPY | 2016-03-16 08:11:52
HD Request # 17 | Decompressing data. | 2016-03-16 08:11:52
HD Request # 17 | Receiving Intraday data for EURJPY starting at 2016-03-15 19:42:08 | 2016-03-16 08:11:52
HD Request # 17 | Timestamp of first Intraday data file record written: 2016-03-15 19:42:14 | 2016-03-16 08:11:52
Using Bid/Ask average for last trade price for EURNZD | 2016-03-16 08:11:52
Using Bid/Ask average for last trade price for EURUSD | 2016-03-16 08:11:52
Socket (19) | Shutdown and closed. | 2016-03-16 08:11:52
Intraday data recording state for symbol EURNZD is set to download 'Pending'. | 2016-03-16 08:11:52
HD Request # 17 | Historical data for EURJPY is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-03-16 08:11:52
HD Request # 17 | Received 164876 records from 2016-03-15 19:42:08 to 2016-03-16 08:12:02 (12.5 hours) and wrote 164875 records for EURJPY | 2016-03-16 08:11:52
HD Request # 17 | Intraday download COMPLETE for EURJPY. Completion time: 2s. Unique request ID: 16 | 2016-03-16 08:11:52
Removed historical data download ID 16 | 2016-03-16 08:11:52
HD Request # 18 | Downloading Historical Daily chart data for EURNZD. Starting date: 2016-03-14. Service: fxcm | 2016-03-16 08:11:52
HD Request # 18 | Using server: ds4.sierracharts.com port 10149 | 2016-03-16 08:11:52
Socket (20) | Connected. | 2016-03-16 08:11:52
HD Request # 18 | Sending historical data logon request message. | 2016-03-16 08:11:52
HD Request # 18 | Requesting historical Daily data starting at 2016-03-14. | 2016-03-16 08:11:52
HD Request # 18 | Decompressing data. | 2016-03-16 08:11:52
HD Request # 18 | Receiving historical Daily data for EURNZD starting at 2016-03-14 | 2016-03-16 08:11:52
HD Request # 18 | Writing historical Daily data to the file EURNZD.dly | 2016-03-16 08:11:52
Socket (20) | Shutdown and closed. | 2016-03-16 08:11:52
HD Request # 18 | Received 3 records from 2016-03-14 00:00:00 to 2016-03-16 00:00:00 (3.0 days) and wrote 3 records for EURNZD | 2016-03-16 08:11:52
HD Request # 18 | Daily download COMPLETE for EURNZD. Completion time: 0s. Unique request ID: 17 | 2016-03-16 08:11:52
Removed historical data download ID 17 | 2016-03-16 08:11:52
HD Request # 19 | Downloading Historical Daily chart data for EURUSD. Starting date: 2016-03-14. Service: fxcm | 2016-03-16 08:11:52
HD Request # 19 | Using server: ds5.sierracharts.com port 10149 | 2016-03-16 08:11:52
Socket (21) | Connected. | 2016-03-16 08:11:52
HD Request # 19 | Sending historical data logon request message. | 2016-03-16 08:11:52
HD Request # 19 | Requesting historical Daily data starting at 2016-03-14. | 2016-03-16 08:11:52
HD Request # 19 | Decompressing data. | 2016-03-16 08:11:52
HD Request # 19 | Receiving historical Daily data for EURUSD starting at 2016-03-14 | 2016-03-16 08:11:52
HD Request # 19 | Writing historical Daily data to the file EURUSD.dly | 2016-03-16 08:11:52
Socket (21) | Shutdown and closed. | 2016-03-16 08:11:52
HD Request # 19 | Received 3 records from 2016-03-14 00:00:00 to 2016-03-16 00:00:00 (3.0 days) and wrote 3 records for EURUSD | 2016-03-16 08:11:52
HD Request # 19 | Daily download COMPLETE for EURUSD. Completion time: 1s. Unique request ID: 18 | 2016-03-16 08:11:52
Removed historical data download ID 18 | 2016-03-16 08:11:52
HD Request # 20 | Downloading Intraday chart data for EURNZD to the file EURNZD.scid. Service: fxcm | 2016-03-16 08:11:52
HD Request # 20 | Download start Date-Time: 2016-03-15 19:42:10.000 | 2016-03-16 08:11:52
HD Request # 20 | Using server: ds3.sierracharts.com port 10149 | 2016-03-16 08:11:52
EURUSD Daily #1 | Reloading chart. | 2016-03-16 08:11:52
Socket (22) | Connected. | 2016-03-16 08:11:52
HD Request # 20 | Sending historical data logon request message. | 2016-03-16 08:11:52
HD Request # 20 | Requesting Intraday data. Start Date-Time: 2016-03-15 19:42:10. Record interval: 0. Symbol: EURNZD | 2016-03-16 08:11:52
HD Request # 20 | Decompressing data. | 2016-03-16 08:11:52
HD Request # 20 | Receiving Intraday data for EURNZD starting at 2016-03-15 19:42:10 | 2016-03-16 08:11:52
HD Request # 20 | Timestamp of first Intraday data file record written: 2016-03-15 19:42:18 | 2016-03-16 08:11:52
EURUSD Weekly #2 | Reloading chart. | 2016-03-16 08:11:52
EURUSD Monthly #3 | Reloading chart. | 2016-03-16 08:11:52
Socket (22) | Shutdown and closed. | 2016-03-16 08:11:52
Intraday data recording state for symbol EURUSD is set to download 'Pending'. | 2016-03-16 08:11:52
HD Request # 20 | Historical data for EURNZD is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-03-16 08:11:52
HD Request # 20 | Received 147668 records from 2016-03-15 19:42:10 to 2016-03-16 08:12:06 (12.5 hours) and wrote 147667 records for EURNZD | 2016-03-16 08:11:52
HD Request # 20 | Intraday download COMPLETE for EURNZD. Completion time: 4s. Unique request ID: 19 | 2016-03-16 08:11:52
Removed historical data download ID 19 | 2016-03-16 08:11:52
HD Request # 21 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm | 2016-03-16 08:11:52
HD Request # 21 | Download start Date-Time: 2016-03-15 19:41:58.000 | 2016-03-16 08:11:52
HD Request # 21 | Using server: ds4.sierracharts.com port 10149 | 2016-03-16 08:11:52
Socket (23) | Connected. | 2016-03-16 08:11:52
HD Request # 21 | Sending historical data logon request message. | 2016-03-16 08:11:52
HD Request # 21 | Requesting Intraday data. Start Date-Time: 2016-03-15 19:41:58. Record interval: 0. Symbol: EURUSD | 2016-03-16 08:11:52
HD Request # 21 | Decompressing data. | 2016-03-16 08:11:52
HD Request # 21 | Receiving Intraday data for EURUSD starting at 2016-03-15 19:41:58 | 2016-03-16 08:11:52
HD Request # 21 | Timestamp of first Intraday data file record written: 2016-03-15 19:42:19 | 2016-03-16 08:11:52
Socket (23) | Shutdown and closed. | 2016-03-16 08:11:52
HD Request # 21 | Historical data for EURUSD is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-03-16 08:11:52
HD Request # 21 | Received 85990 records from 2016-03-15 19:41:58 to 2016-03-16 08:12:08 (12.5 hours) and wrote 85989 records for EURUSD | 2016-03-16 08:11:52
HD Request # 21 | Intraday download COMPLETE for EURUSD. Completion time: 1s. Unique request ID: 20 | 2016-03-16 08:11:52
Removed historical data download ID 20 | 2016-03-16 08:11:52
Using Bid/Ask average for last trade price for GBPAUD | 2016-03-16 08:11:52
HD Request # 22 | Downloading Historical Daily chart data for GBPAUD. Starting date: 2016-03-14. Service: fxcm | 2016-03-16 08:11:52
HD Request # 22 | Using server: ds5.sierracharts.com port 10149 | 2016-03-16 08:11:52
Socket (25) | Connected. | 2016-03-16 08:11:52
HD Request # 22 | Sending historical data logon request message. | 2016-03-16 08:11:52
HD Request # 22 | Requesting historical Daily data starting at 2016-03-14. | 2016-03-16 08:11:52
HD Request # 22 | Decompressing data. | 2016-03-16 08:11:52
HD Request # 22 | Receiving historical Daily data for GBPAUD starting at 2016-03-14 | 2016-03-16 08:11:52
HD Request # 22 | Writing historical Daily data to the file GBPAUD.dly | 2016-03-16 08:11:52
Socket (25) | Shutdown and closed. | 2016-03-16 08:11:52
HD Request # 22 | Received 3 records from 2016-03-14 00:00:00 to 2016-03-16 00:00:00 (3.0 days) and wrote 3 records for GBPAUD | 2016-03-16 08:11:52
HD Request # 22 | Daily download COMPLETE for GBPAUD. Completion time: 0s. Unique request ID: 21 | 2016-03-16 08:11:52
Removed historical data download ID 21 | 2016-03-16 08:11:52
GBPAUD Monthly #5 | Reloading chart. | 2016-03-16 08:11:52
Intraday data recording state for symbol GBPAUD is set to download 'Pending'. | 2016-03-16 08:11:52
HD Request # 23 | Downloading Intraday chart data for GBPAUD to the file GBPAUD.scid. Service: fxcm | 2016-03-16 08:11:52
HD Request # 23 | Download start Date-Time: 2016-03-15 19:42:07.000 | 2016-03-16 08:11:52
HD Request # 23 | Using server: ds3.sierracharts.com port 10149 | 2016-03-16 08:11:52
Socket (26) | Connected. | 2016-03-16 08:11:52
HD Request # 23 | Sending historical data logon request message. | 2016-03-16 08:11:52
HD Request # 23 | Requesting Intraday data. Start Date-Time: 2016-03-15 19:42:07. Record interval: 0. Symbol: GBPAUD | 2016-03-16 08:11:52
Using Bid/Ask average for last trade price for GBPCHF | 2016-03-16 08:11:52
HD Request # 23 | Decompressing data. | 2016-03-16 08:11:52
HD Request # 23 | Receiving Intraday data for GBPAUD starting at 2016-03-15 19:42:07 | 2016-03-16 08:11:52
HD Request # 23 | Timestamp of first Intraday data file record written: 2016-03-15 19:42:12 | 2016-03-16 08:11:52
Intraday data recording state for symbol GBPCHF is set to download 'Pending'. | 2016-03-16 08:11:52
Socket (26) | Shutdown and closed. | 2016-03-16 08:11:52
HD Request # 23 | Historical data for GBPAUD is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-03-16 08:11:52
HD Request # 23 | Received 194451 records from 2016-03-15 19:42:07 to 2016-03-16 08:12:16 (12.5 hours) and wrote 194449 records for GBPAUD | 2016-03-16 08:11:52
HD Request # 23 | Intraday download COMPLETE for GBPAUD. Completion time: 2s. Unique request ID: 22 | 2016-03-16 08:11:52
Removed historical data download ID 22 | 2016-03-16 08:11:52
HD Request # 24 | Downloading Historical Daily chart data for GBPCHF. Starting date: 2016-03-14. Service: fxcm | 2016-03-16 08:11:52
HD Request # 24 | Using server: ds4.sierracharts.com port 10149 | 2016-03-16 08:11:52
Socket (27) | Connected. | 2016-03-16 08:11:52
HD Request # 24 | Sending historical data logon request message. | 2016-03-16 08:11:52
HD Request # 24 | Requesting historical Daily data starting at 2016-03-14. | 2016-03-16 08:11:52
HD Request # 24 | Decompressing data. | 2016-03-16 08:11:52
HD Request # 24 | Receiving historical Daily data for GBPCHF starting at 2016-03-14 | 2016-03-16 08:11:52
HD Request # 24 | Writing historical Daily data to the file GBPCHF.dly | 2016-03-16 08:11:52
Using Bid/Ask average for last trade price for GBPJPY | 2016-03-16 08:11:52
Socket (27) | Shutdown and closed. | 2016-03-16 08:11:52
HD Request # 24 | Received 3 records from 2016-03-14 00:00:00 to 2016-03-16 00:00:00 (3.0 days) and wrote 3 records for GBPCHF | 2016-03-16 08:11:52
HD Request # 24 | Daily download COMPLETE for GBPCHF. Completion time: 0s. Unique request ID: 23 | 2016-03-16 08:11:52
Removed historical data download ID 23 | 2016-03-16 08:11:52
HD Request # 25 | Downloading Intraday chart data for GBPCHF to the file GBPCHF.scid. Service: fxcm | 2016-03-16 08:11:52
HD Request # 25 | Download start Date-Time: 2016-03-15 19:42:00.000 | 2016-03-16 08:11:52
HD Request # 25 | Using server: ds5.sierracharts.com port 10149 | 2016-03-16 08:11:52
Socket (28) | Connected. | 2016-03-16 08:11:52
HD Request # 25 | Sending historical data logon request message. | 2016-03-16 08:11:52
HD Request # 25 | Requesting Intraday data. Start Date-Time: 2016-03-15 19:42:00. Record interval: 0. Symbol: GBPCHF | 2016-03-16 08:11:52
HD Request # 25 | Decompressing data. | 2016-03-16 08:11:52
HD Request # 25 | Receiving Intraday data for GBPCHF starting at 2016-03-15 19:42:00 | 2016-03-16 08:11:52
HD Request # 25 | Timestamp of first Intraday data file record written: 2016-03-15 19:42:19 | 2016-03-16 08:11:52
Intraday data recording state for symbol GBPJPY is set to download 'Pending'. | 2016-03-16 08:11:52
Socket (28) | Shutdown and closed. | 2016-03-16 08:11:52
HD Request # 25 | Historical data for GBPCHF is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-03-16 08:11:52
HD Request # 25 | Received 129829 records from 2016-03-15 19:42:00 to 2016-03-16 08:12:17 (12.5 hours) and wrote 129826 records for GBPCHF | 2016-03-16 08:11:52
HD Request # 25 | Intraday download COMPLETE for GBPCHF. Completion time: 3s. Unique request ID: 24 | 2016-03-16 08:11:52
Removed historical data download ID 24 | 2016-03-16 08:11:52
HD Request # 26 | Downloading Historical Daily chart data for GBPJPY. Starting date: 2016-03-14. Service: fxcm | 2016-03-16 08:11:52
HD Request # 26 | Using server: ds3.sierracharts.com port 10149 | 2016-03-16 08:11:52
Socket (29) | Connected. | 2016-03-16 08:11:52
HD Request # 26 | Sending historical data logon request message. | 2016-03-16 08:11:52
HD Request # 26 | Requesting historical Daily data starting at 2016-03-14. | 2016-03-16 08:11:52
HD Request # 26 | Decompressing data. | 2016-03-16 08:11:52
HD Request # 26 | Receiving historical Daily data for GBPJPY starting at 2016-03-14 | 2016-03-16 08:11:52
HD Request # 26 | Writing historical Daily data to the file GBPJPY.dly | 2016-03-16 08:11:52
Socket (29) | Shutdown and closed. | 2016-03-16 08:11:52
HD Request # 26 | Received 3 records from 2016-03-14 00:00:00 to 2016-03-16 00:00:00 (3.0 days) and wrote 3 records for GBPJPY | 2016-03-16 08:11:52
HD Request # 26 | Daily download COMPLETE for GBPJPY. Completion time: 1s. Unique request ID: 25 | 2016-03-16 08:11:52
Removed historical data download ID 25 | 2016-03-16 08:11:52
HD Request # 27 | Downloading Intraday chart data for GBPJPY to the file GBPJPY.scid. Service: fxcm | 2016-03-16 08:11:52
HD Request # 27 | Download start Date-Time: 2016-03-15 19:42:08.000 | 2016-03-16 08:11:52
HD Request # 27 | Using server: ds4.sierracharts.com port 10149 | 2016-03-16 08:11:52
Socket (30) | Connected. | 2016-03-16 08:11:52
HD Request # 27 | Sending historical data logon request message. | 2016-03-16 08:11:52
HD Request # 27 | Requesting Intraday data. Start Date-Time: 2016-03-15 19:42:08. Record interval: 0. Symbol: GBPJPY | 2016-03-16 08:11:52
Using Bid/Ask average for last trade price for GBPNZD | 2016-03-16 08:11:52
Intraday data recording state for symbol GBPNZD is set to download 'Pending'. | 2016-03-16 08:11:52
HD Request # 27 | Decompressing data. | 2016-03-16 08:11:52
HD Request # 27 | Receiving Intraday data for GBPJPY starting at 2016-03-15 19:42:08 | 2016-03-16 08:11:52
HD Request # 27 | Timestamp of first Intraday data file record written: 2016-03-15 19:42:21 | 2016-03-16 08:11:52
Using Bid/Ask average for last trade price for GBPUSD | 2016-03-16 08:11:52
Intraday data recording state for symbol GBPUSD is set to download 'Pending'. | 2016-03-16 08:11:52
Using Bid/Ask average for last trade price for NZDJPY | 2016-03-16 08:11:52
Socket (30) | Shutdown and closed. | 2016-03-16 08:11:52
Intraday data recording state for symbol NZDJPY is set to download 'Pending'. | 2016-03-16 08:11:52
HD Request # 27 | Historical data for GBPJPY is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-03-16 08:11:52
HD Request # 27 | Received 173960 records from 2016-03-15 19:42:08 to 2016-03-16 08:12:24 (12.5 hours) and wrote 173957 records for GBPJPY | 2016-03-16 08:11:52
HD Request # 27 | Intraday download COMPLETE for GBPJPY. Completion time: 8s. Unique request ID: 26 | 2016-03-16 08:11:52
Removed historical data download ID 26 | 2016-03-16 08:11:52
HD Request # 28 | Downloading Historical Daily chart data for GBPNZD. Starting date: 2016-03-14. Service: fxcm | 2016-03-16 08:11:52
HD Request # 28 | Using server: ds5.sierracharts.com port 10149 | 2016-03-16 08:11:52
Socket (31) | Connected. | 2016-03-16 08:11:52
HD Request # 28 | Sending historical data logon request message. | 2016-03-16 08:11:52
HD Request # 28 | Requesting historical Daily data starting at 2016-03-14. | 2016-03-16 08:11:52
HD Request # 28 | Decompressing data. | 2016-03-16 08:11:52
HD Request # 28 | Receiving historical Daily data for GBPNZD starting at 2016-03-14 | 2016-03-16 08:11:52
HD Request # 28 | Writing historical Daily data to the file GBPNZD.dly | 2016-03-16 08:11:52
Socket (31) | Shutdown and closed. | 2016-03-16 08:11:52
HD Request # 28 | Received 3 records from 2016-03-14 00:00:00 to 2016-03-16 00:00:00 (3.0 days) and wrote 3 records for GBPNZD | 2016-03-16 08:11:52
HD Request # 28 | Daily download COMPLETE for GBPNZD. Completion time: 1s. Unique request ID: 27 | 2016-03-16 08:11:52
Removed historical data download ID 27 | 2016-03-16 08:11:52
HD Request # 29 | Downloading Intraday chart data for GBPNZD to the file GBPNZD.scid. Service: fxcm | 2016-03-16 08:11:52
HD Request # 29 | Download start Date-Time: 2016-03-15 19:41:58.000 | 2016-03-16 08:11:52
HD Request # 29 | Using server: ds3.sierracharts.com port 10149 | 2016-03-16 08:11:52
Socket (32) | Connected. | 2016-03-16 08:11:52
HD Request # 29 | Sending historical data logon request message. | 2016-03-16 08:11:52
HD Request # 29 | Requesting Intraday data. Start Date-Time: 2016-03-15 19:41:58. Record interval: 0. Symbol: GBPNZD | 2016-03-16 08:11:52
HD Request # 29 | Decompressing data. | 2016-03-16 08:11:52
HD Request # 29 | Receiving Intraday data for GBPNZD starting at 2016-03-15 19:41:58 | 2016-03-16 08:11:52
HD Request # 29 | Timestamp of first Intraday data file record written: 2016-03-15 19:42:25 | 2016-03-16 08:11:52
Using Bid/Ask average for last trade price for NZDUSD | 2016-03-16 08:11:52
Intraday data recording state for symbol NZDUSD is set to download 'Pending'. | 2016-03-16 08:11:52
Socket (32) | Shutdown and closed. | 2016-03-16 08:11:52
HD Request # 29 | Historical data for GBPNZD is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-03-16 08:11:52
HD Request # 29 | Received 164634 records from 2016-03-15 19:41:58 to 2016-03-16 08:12:31 (12.5 hours) and wrote 164633 records for GBPNZD | 2016-03-16 08:11:52
HD Request # 29 | Intraday download COMPLETE for GBPNZD. Completion time: 0s. Unique request ID: 28 | 2016-03-16 08:11:52
Removed historical data download ID 28 | 2016-03-16 08:11:52
HD Request # 30 | Downloading Historical Daily chart data for GBPUSD. Starting date: 2016-03-14. Service: fxcm | 2016-03-16 08:11:52
HD Request # 30 | Using server: ds4.sierracharts.com port 10149 | 2016-03-16 08:11:52
Socket (33) | Connected. | 2016-03-16 08:11:52
HD Request # 30 | Sending historical data logon request message. | 2016-03-16 08:11:52
HD Request # 30 | Requesting historical Daily data starting at 2016-03-14. | 2016-03-16 08:11:52
HD Request # 30 | Decompressing data. | 2016-03-16 08:11:52
HD Request # 30 | Receiving historical Daily data for GBPUSD starting at 2016-03-14 | 2016-03-16 08:11:52
HD Request # 30 | Writing historical Daily data to the file GBPUSD.dly | 2016-03-16 08:11:52
Socket (33) | Shutdown and closed. | 2016-03-16 08:11:52
HD Request # 30 | Received 3 records from 2016-03-14 00:00:00 to 2016-03-16 00:00:00 (3.0 days) and wrote 3 records for GBPUSD | 2016-03-16 08:11:52
HD Request # 30 | Daily download COMPLETE for GBPUSD. Completion time: 0s. Unique request ID: 29 | 2016-03-16 08:11:52
Removed historical data download ID 29 | 2016-03-16 08:11:52
HD Request # 31 | Downloading Intraday chart data for GBPUSD to the file GBPUSD.scid. Service: fxcm | 2016-03-16 08:11:52
HD Request # 31 | Download start Date-Time: 2016-03-15 19:42:00.000 | 2016-03-16 08:11:52
HD Request # 31 | Using server: ds5.sierracharts.com port 10149 | 2016-03-16 08:11:52
Socket (34) | Connected. | 2016-03-16 08:11:52
HD Request # 31 | Sending historical data logon request message. | 2016-03-16 08:11:52
HD Request # 31 | Requesting Intraday data. Start Date-Time: 2016-03-15 19:42:00. Record interval: 0. Symbol: GBPUSD | 2016-03-16 08:11:52
Using Bid/Ask average for last trade price for USDCAD | 2016-03-16 08:11:52
HD Request # 31 | Decompressing data. | 2016-03-16 08:11:52
HD Request # 31 | Receiving Intraday data for GBPUSD starting at 2016-03-15 19:42:00 | 2016-03-16 08:11:52
HD Request # 31 | Timestamp of first Intraday data file record written: 2016-03-15 19:42:25 | 2016-03-16 08:11:52
Intraday data recording state for symbol USDCAD is set to download 'Pending'. | 2016-03-16 08:11:52
Socket (34) | Shutdown and closed. | 2016-03-16 08:11:52
HD Request # 31 | Historical data for GBPUSD is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-03-16 08:11:52
HD Request # 31 | Received 121801 records from 2016-03-15 19:42:00 to 2016-03-16 08:12:33 (12.5 hours) and wrote 121799 records for GBPUSD | 2016-03-16 08:11:52
HD Request # 31 | Intraday download COMPLETE for GBPUSD. Completion time: 2s. Unique request ID: 30 | 2016-03-16 08:11:52
Removed historical data download ID 30 | 2016-03-16 08:11:52
HD Request # 32 | Downloading Historical Daily chart data for NZDJPY. Starting date: 2016-03-14. Service: fxcm | 2016-03-16 08:11:52
HD Request # 32 | Using server: ds3.sierracharts.com port 10149 | 2016-03-16 08:11:52
Socket (35) | Connected. | 2016-03-16 08:11:52
HD Request # 32 | Sending historical data logon request message. | 2016-03-16 08:11:52
HD Request # 32 | Requesting historical Daily data starting at 2016-03-14. | 2016-03-16 08:11:52
HD Request # 32 | Decompressing data. | 2016-03-16 08:11:52
HD Request # 32 | Receiving historical Daily data for NZDJPY starting at 2016-03-14 | 2016-03-16 08:11:52
HD Request # 32 | Writing historical Daily data to the file NZDJPY.dly | 2016-03-16 08:11:52
Socket (35) | Shutdown and closed. | 2016-03-16 08:11:52
HD Request # 32 | Received 3 records from 2016-03-14 00:00:00 to 2016-03-16 00:00:00 (3.0 days) and wrote 3 records for NZDJPY | 2016-03-16 08:11:52
HD Request # 32 | Daily download COMPLETE for NZDJPY. Completion time: 0s. Unique request ID: 31 | 2016-03-16 08:11:52
Removed historical data download ID 31 | 2016-03-16 08:11:52
HD Request # 33 | Downloading Intraday chart data for NZDJPY to the file NZDJPY.scid. Service: fxcm | 2016-03-16 08:11:52
HD Request # 33 | Download start Date-Time: 2016-03-15 19:42:08.000 | 2016-03-16 08:11:52
HD Request # 33 | Using server: ds4.sierracharts.com port 10149 | 2016-03-16 08:11:52
Socket (36) | Connected. | 2016-03-16 08:11:52
HD Request # 33 | Sending historical data logon request message. | 2016-03-16 08:11:52
HD Request # 33 | Requesting Intraday data. Start Date-Time: 2016-03-15 19:42:08. Record interval: 0. Symbol: NZDJPY | 2016-03-16 08:11:52
Using Bid/Ask average for last trade price for USDCHF | 2016-03-16 08:11:52
HD Request # 33 | Decompressing data. | 2016-03-16 08:11:52
HD Request # 33 | Receiving Intraday data for NZDJPY starting at 2016-03-15 19:42:08 | 2016-03-16 08:11:52
HD Request # 33 | Timestamp of first Intraday data file record written: 2016-03-15 19:42:25 | 2016-03-16 08:11:52
Intraday data recording state for symbol USDCHF is set to download 'Pending'. | 2016-03-16 08:11:52
Socket (36) | Shutdown and closed. | 2016-03-16 08:11:52
HD Request # 33 | Historical data for NZDJPY is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-03-16 08:11:52
HD Request # 33 | Received 94995 records from 2016-03-15 19:42:08 to 2016-03-16 08:12:33 (12.5 hours) and wrote 94993 records for NZDJPY | 2016-03-16 08:11:52
HD Request # 33 | Intraday download COMPLETE for NZDJPY. Completion time: 0s. Unique request ID: 32 | 2016-03-16 08:11:52
Removed historical data download ID 32 | 2016-03-16 08:11:52
HD Request # 34 | Downloading Historical Daily chart data for NZDUSD. Starting date: 2016-03-14. Service: fxcm | 2016-03-16 08:11:52
HD Request # 34 | Using server: ds5.sierracharts.com port 10149 | 2016-03-16 08:11:52
Socket (37) | Connected. | 2016-03-16 08:11:52
HD Request # 34 | Sending historical data logon request message. | 2016-03-16 08:11:52
Using Bid/Ask average for last trade price for USDJPY | 2016-03-16 08:11:52
HD Request # 34 | Requesting historical Daily data starting at 2016-03-14. | 2016-03-16 08:11:52
HD Request # 34 | Decompressing data. | 2016-03-16 08:11:52
HD Request # 34 | Receiving historical Daily data for NZDUSD starting at 2016-03-14 | 2016-03-16 08:11:52
HD Request # 34 | Writing historical Daily data to the file NZDUSD.dly | 2016-03-16 08:11:52
Socket (37) | Shutdown and closed. | 2016-03-16 08:11:52
HD Request # 34 | Received 3 records from 2016-03-14 00:00:00 to 2016-03-16 00:00:00 (3.0 days) and wrote 3 records for NZDUSD | 2016-03-16 08:11:52
HD Request # 34 | Daily download COMPLETE for NZDUSD. Completion time: 0s. Unique request ID: 33 | 2016-03-16 08:11:52
Removed historical data download ID 33 | 2016-03-16 08:11:52
HD Request # 35 | Downloading Intraday chart data for NZDUSD to the file NZDUSD.scid. Service: fxcm | 2016-03-16 08:11:52
HD Request # 35 | Download start Date-Time: 2016-03-15 19:42:08.000 | 2016-03-16 08:11:52
HD Request # 35 | Using server: ds3.sierracharts.com port 10149 | 2016-03-16 08:11:52
Socket (38) | Connected. | 2016-03-16 08:11:52
HD Request # 35 | Sending historical data logon request message. | 2016-03-16 08:11:52
HD Request # 35 | Requesting Intraday data. Start Date-Time: 2016-03-15 19:42:08. Record interval: 0. Symbol: NZDUSD | 2016-03-16 08:11:52
Intraday data recording state for symbol USDJPY is set to download 'Pending'. | 2016-03-16 08:11:52
HD Request # 35 | Decompressing data. | 2016-03-16 08:11:52
HD Request # 35 | Receiving Intraday data for NZDUSD starting at 2016-03-15 19:42:08 | 2016-03-16 08:11:52
HD Request # 35 | Timestamp of first Intraday data file record written: 2016-03-15 19:42:25 | 2016-03-16 08:11:52
Socket (38) | Shutdown and closed. | 2016-03-16 08:11:52
SC Forex Data (FXCM) | Connected to data server. | 2016-03-16 08:11:52
SC DTC Data | Starting real-time market data updates for: AUDJPY. ID: 1 | 2016-03-16 08:11:52
SC DTC Data | Connecting to the server ds4.sierracharts.com. Port 443 | 2016-03-16 08:11:52
SC DTC Data | Starting real-time market data updates for: AUDNZD. ID: 2 | 2016-03-16 08:11:52
SC DTC Data | Starting real-time market data updates for: AUDUSD. ID: 3 | 2016-03-16 08:11:52
SC DTC Data | Starting real-time market data updates for: EURAUD. ID: 4 | 2016-03-16 08:11:52
SC DTC Data | Starting real-time market data updates for: EURCAD. ID: 5 | 2016-03-16 08:11:52
SC DTC Data | Starting real-time market data updates for: EURCHF. ID: 6 | 2016-03-16 08:11:52
SC DTC Data | Starting real-time market data updates for: EURGBP. ID: 7 | 2016-03-16 08:11:52
SC DTC Data | Starting real-time market data updates for: EURJPY. ID: 8 | 2016-03-16 08:11:52
SC DTC Data | Starting real-time market data updates for: EURNZD. ID: 9 | 2016-03-16 08:11:52
SC DTC Data | Starting real-time market data updates for: EURUSD. ID: 10 | 2016-03-16 08:11:52
SC DTC Data | Starting real-time market data updates for: GBPAUD. ID: 11 | 2016-03-16 08:11:52
SC DTC Data | Starting real-time market data updates for: GBPCHF. ID: 12 | 2016-03-16 08:11:52
SC DTC Data | Starting real-time market data updates for: GBPJPY. ID: 13 | 2016-03-16 08:11:52
SC DTC Data | Starting real-time market data updates for: GBPNZD. ID: 14 | 2016-03-16 08:11:52
SC DTC Data | Starting real-time market data updates for: GBPUSD. ID: 15 | 2016-03-16 08:11:52
SC DTC Data | Starting real-time market data updates for: NZDJPY. ID: 16 | 2016-03-16 08:11:52
SC DTC Data | Starting real-time market data updates for: NZDUSD. ID: 17 | 2016-03-16 08:11:52
Historical Intraday data request for NZDUSD is discarded because a matching download is in progress and the new one is not for earlier data. | 2016-03-16 08:11:52
Intraday data recording state for symbol NZDUSD has been reset to 'Downloading'. | 2016-03-16 08:11:52
SC DTC Data | Starting real-time market data updates for: USDCAD. ID: 18 | 2016-03-16 08:11:52
Historical Intraday data request for USDCAD is discarded because a matching download is already pending and the new one is not for earlier data. | 2016-03-16 08:11:52
SC DTC Data | Starting real-time market data updates for: USDCHF. ID: 19 | 2016-03-16 08:11:52
Historical Intraday data request for USDCHF is discarded because a matching download is already pending and the new one is not for earlier data. | 2016-03-16 08:11:52
SC DTC Data | Starting real-time market data updates for: USDJPY. ID: 20 | 2016-03-16 08:11:52
Historical Intraday data request for USDJPY is discarded because a matching download is already pending and the new one is not for earlier data. | 2016-03-16 08:11:52
HD Request # 35 | Re-requesting historical data for NZDUSD to get the latest data since the download was started while not connected to primary service. | 2016-03-16 08:11:52
HD Request # 35 | Received 100965 records from 2016-03-15 19:42:08 to 2016-03-16 08:12:36 (12.5 hours) and wrote 100963 records for NZDUSD | 2016-03-16 08:11:52
Delaying start of download for NZDUSD | 2016-03-16 08:11:52
AUDJPY [M] Daily #3 | Reloading chart. | 2016-03-16 08:13:31
Socket (39) | Connected. | 2016-03-16 08:13:31
SC DTC Data | Connected to server. | 2016-03-16 08:13:31
SC DTC Data | Sending Encoding Request to server | 2016-03-16 08:13:31
AUDJPY [M] Weekly #4 | Reloading chart. | 2016-03-16 08:13:31
SC DTC Data | Setting DTC Encoding to Binary VLS | 2016-03-16 08:13:31
SC DTC Data | Sending logon request message. | 2016-03-16 08:13:31
AUDJPY [M] Monthly #5 | Reloading chart. | 2016-03-16 08:13:31
SC DTC Data | Received logon response. | 2016-03-16 08:13:31
SC DTC Data | Server Name: SC Real-Time Server. | 2016-03-16 08:13:31
SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2016-03-16 08:13:31
SC DTC Data | Successfully connected. | 2016-03-16 08:13:31
SC DTC Data | Restarting real-time data updates for symbol: AUDJPY | 2016-03-16 08:13:31
SC DTC Data | Restarting real-time data updates for symbol: AUDNZD | 2016-03-16 08:13:31
SC DTC Data | Restarting real-time data updates for symbol: AUDUSD | 2016-03-16 08:13:31
SC DTC Data | Restarting real-time data updates for symbol: EURAUD | 2016-03-16 08:13:31
SC DTC Data | Restarting real-time data updates for symbol: EURCAD | 2016-03-16 08:13:31
SC DTC Data | Restarting real-time data updates for symbol: EURCHF | 2016-03-16 08:13:31
SC DTC Data | Restarting real-time data updates for symbol: EURGBP | 2016-03-16 08:13:31
SC DTC Data | Restarting real-time data updates for symbol: EURJPY | 2016-03-16 08:13:31
SC DTC Data | Restarting real-time data updates for symbol: EURNZD | 2016-03-16 08:13:31
SC DTC Data | Restarting real-time data updates for symbol: EURUSD | 2016-03-16 08:13:31
SC DTC Data | Restarting real-time data updates for symbol: GBPAUD | 2016-03-16 08:13:31
SC DTC Data | Restarting real-time data updates for symbol: GBPCHF | 2016-03-16 08:13:31
SC DTC Data | Restarting real-time data updates for symbol: GBPJPY | 2016-03-16 08:13:31
SC DTC Data | Restarting real-time data updates for symbol: GBPNZD | 2016-03-16 08:13:31
SC DTC Data | Restarting real-time data updates for symbol: GBPUSD | 2016-03-16 08:13:31
SC DTC Data | Restarting real-time data updates for symbol: NZDJPY | 2016-03-16 08:13:31
SC DTC Data | Restarting real-time data updates for symbol: NZDUSD | 2016-03-16 08:13:31
SC DTC Data | Restarting real-time data updates for symbol: USDCAD | 2016-03-16 08:13:31
SC DTC Data | Restarting real-time data updates for symbol: USDCHF | 2016-03-16 08:13:31
SC DTC Data | Restarting real-time data updates for symbol: USDJPY | 2016-03-16 08:13:31
AUDNZD [M] Daily #3 | Reloading chart. | 2016-03-16 08:13:31
AUDNZD [M] Weekly #4 | Reloading chart. | 2016-03-16 08:13:31
AUDNZD [M] Monthly #5 | Reloading chart. | 2016-03-16 08:13:31
AUDUSD [M] Daily #4 | Reloading chart. | 2016-03-16 08:13:31
AUDUSD [M] Weekly #5 | Reloading chart. | 2016-03-16 08:13:31
AUDUSD [M] Monthly #6 | Reloading chart. | 2016-03-16 08:13:31
EURAUD [M] Daily #3 | Reloading chart. | 2016-03-16 08:13:31
EURAUD [M] Weekly #4 | Reloading chart. | 2016-03-16 08:13:31
EURAUD [M] Monthly #5 | Reloading chart. | 2016-03-16 08:13:31
EURCAD [M] Daily #3 | Reloading chart. | 2016-03-16 08:13:31
EURCAD [M] Weekly #4 | Reloading chart. | 2016-03-16 08:13:31
EURCAD [M] Monthly #5 | Reloading chart. | 2016-03-16 08:13:31
EURCHF [M] Daily #3 | Reloading chart. | 2016-03-16 08:13:31
EURCHF [M] Weekly #4 | Reloading chart. | 2016-03-16 08:13:31
EURCHF [M] Monthly #5 | Reloading chart. | 2016-03-16 08:13:31
EURGBP [M] Daily #3 | Reloading chart. | 2016-03-16 08:13:31
EURGBP [M] Weekly #4 | Reloading chart. | 2016-03-16 08:13:31
EURGBP [M] Monthly #5 | Reloading chart. | 2016-03-16 08:13:31
EURJPY [M] Daily #3 | Reloading chart. | 2016-03-16 08:13:31
EURJPY [M] Weekly #4 | Reloading chart. | 2016-03-16 08:13:31
EURJPY [M] Monthly #5 | Reloading chart. | 2016-03-16 08:13:31
EURNZD [M] Daily #3 | Reloading chart. | 2016-03-16 08:13:31
EURNZD [M] Weekly #4 | Reloading chart. | 2016-03-16 08:13:31
EURUSD [M] Monthly #5 | Reloading chart. | 2016-03-16 08:13:31
EURUSD [M] Daily #1 | Reloading chart. | 2016-03-16 08:13:31
EURUSD [M] Weekly #2 | Reloading chart. | 2016-03-16 08:13:31
EURUSD [M] Monthly #3 | Reloading chart. | 2016-03-16 08:13:31
GBPAUD [M] Daily #3 | Reloading chart. | 2016-03-16 08:13:31
GBPAUD [M] Weekly #4 | Reloading chart. | 2016-03-16 08:13:31
GBPAUD [M] Monthly #5 | Reloading chart. | 2016-03-16 08:13:31
GBPCHF [M] Daily #3 | Reloading chart. | 2016-03-16 08:13:31
GBPCHF [M] Weekly #4 | Reloading chart. | 2016-03-16 08:13:31
GBPCHF [M] Monthly #5 | Reloading chart. | 2016-03-16 08:13:31
GBPJPY [M] Daily #3 | Reloading chart. | 2016-03-16 08:13:31
GBPJPY [M] Weekly #4 | Reloading chart. | 2016-03-16 08:13:31
GBPJPY [M] Monthly #5 | Reloading chart. | 2016-03-16 08:13:31
GBPNZD [M] Daily #3 | Reloading chart. | 2016-03-16 08:13:31
GBPNZD [M] Weekly #4 | Reloading chart. | 2016-03-16 08:13:31
GBPNZD [M] Monthly #5 | Reloading chart. | 2016-03-16 08:13:31
GBPUSD [M] Daily #3 | Reloading chart. | 2016-03-16 08:13:31
GBPUSD [M] Weekly #4 | Reloading chart. | 2016-03-16 08:13:31
GBPUSD [M] Monthly #5 | Reloading chart. | 2016-03-16 08:13:31
NZDJPY [M] Daily #1 | Reloading chart. | 2016-03-16 08:13:31
NZDJPY [M] Weekly #2 | Reloading chart. | 2016-03-16 08:13:31
NZDJPY [M] Monthly #3 | Reloading chart. | 2016-03-16 08:13:31
NZDUSD [M] Daily #3 | Reloading chart. | 2016-03-16 08:13:31
NZDUSD [M] Weekly #4 | Reloading chart. | 2016-03-16 08:13:31
NZDUSD [M] Monthly #5 | Reloading chart. | 2016-03-16 08:13:31
USDCAD [M] Daily #3 | Reloading chart. | 2016-03-16 08:13:31
USDCAD [M] Weekly #4 | Reloading chart. | 2016-03-16 08:13:31
USDCAD [M] Monthly #5 | Reloading chart. | 2016-03-16 08:13:31
USDCHF [M] Daily #3 | Reloading chart. | 2016-03-16 08:13:31
USDCHF [M] Weekly #4 | Reloading chart. | 2016-03-16 08:13:31
USDCHF [M] Monthly #5 | Reloading chart. | 2016-03-16 08:13:31
USDJPY [M] Daily #3 | Reloading chart. | 2016-03-16 08:13:31
USDJPY [M] Weekly #4 | Reloading chart. | 2016-03-16 08:13:31
USDJPY [M] Monthly #5 | Reloading chart. | 2016-03-16 08:13:31
AUDJPY [M] Daily #3 | Reloading chart. | 2016-03-16 08:13:47
AUDJPY [M] Weekly #4 | Reloading chart. | 2016-03-16 08:13:47
AUDJPY [M] Monthly #5 | Reloading chart. | 2016-03-16 08:13:47
HD Request # 36 | Downloading Intraday chart data for NZDUSD to the file NZDUSD.scid. Service: fxcm | 2016-03-16 08:13:47
HD Request # 36 | Download start Date-Time: 2016-03-16 08:12:36.000 | 2016-03-16 08:13:47
HD Request # 36 | Using server: ds5.sierracharts.com port 10149 | 2016-03-16 08:13:47
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-03-16 08:13:47
AUDNZD [M] Daily #3 | Reloading chart. | 2016-03-16 08:13:47
AUDNZD [M] Weekly #4 | Reloading chart. | 2016-03-16 08:13:47
AUDNZD [M] Monthly #5 | Reloading chart. | 2016-03-16 08:13:47
Socket (40) | Connected. | 2016-03-16 08:13:47
HD Request # 36 | Sending historical data logon request message. | 2016-03-16 08:13:47
AUDUSD [M] Daily #4 | Reloading chart. | 2016-03-16 08:13:47
HD Request # 36 | Requesting Intraday data. Start Date-Time: 2016-03-16 08:12:36. Record interval: 0. Symbol: NZDUSD | 2016-03-16 08:13:47
AUDUSD [M] Weekly #5 | Reloading chart. | 2016-03-16 08:13:47
AUDUSD [M] Monthly #6 | Reloading chart. | 2016-03-16 08:13:47
EURAUD [M] Daily #3 | Reloading chart. | 2016-03-16 08:13:47
HD Request # 36 | Decompressing data. | 2016-03-16 08:13:47
HD Request # 36 | Receiving Intraday data for NZDUSD starting at 2016-03-16 08:12:36 | 2016-03-16 08:13:47
HD Request # 36 | Timestamp of first Intraday data file record written: 2016-03-16 08:12:36 | 2016-03-16 08:13:47
Socket (40) | Shutdown and closed. | 2016-03-16 08:13:47
The network socket for historical data has been closed. | 2016-03-16 08:13:47
HD Request # 36 | Received 66 records from 2016-03-16 08:12:36 to 2016-03-16 08:12:50 (14.0 seconds) and wrote 60 records for NZDUSD | 2016-03-16 08:13:47
Added 1 Time and Sales records to Intraday data file for NZDUSD after download. | 2016-03-16 08:13:47
HD Request # 36 | Intraday download COMPLETE for NZDUSD. Completion time: 0s. Unique request ID: 34 | 2016-03-16 08:13:47
Removed historical data download ID 34 | 2016-03-16 08:13:47
Real-time Intraday chart data file updates started for NZDUSD | 2016-03-16 08:13:47
Opened cached Intraday file: C:\SierraChart\Data\NZDUSD.scid | 2016-03-16 08:13:47
Intraday chart data file opened for NZDUSD | 2016-03-16 08:13:47
HD Request # 37 | Downloading Historical Daily chart data for USDCAD. Starting date: 2016-03-14. Service: fxcm | 2016-03-16 08:13:47
HD Request # 37 | Using server: ds3.sierracharts.com port 10149 | 2016-03-16 08:13:47
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164. | 2016-03-16 08:13:47
EURAUD [M] Weekly #4 | Reloading chart. | 2016-03-16 08:13:47
EURCAD [M] Daily #3 | Reloading chart. | 2016-03-16 08:13:47
Socket (41) | Connected. | 2016-03-16 08:13:47
HD Request # 37 | Sending historical data logon request message. | 2016-03-16 08:13:47
EURCAD [M] Weekly #4 | Reloading chart. | 2016-03-16 08:13:47
EURCAD [M] Monthly #5 | Reloading chart. | 2016-03-16 08:13:47
HD Request # 37 | Requesting historical Daily data starting at 2016-03-14. | 2016-03-16 08:13:47
EURCHF [M] Daily #3 | Reloading chart. | 2016-03-16 08:13:47
HD Request # 37 | Decompressing data. | 2016-03-16 08:13:47
EURCHF [M] Weekly #4 | Reloading chart. | 2016-03-16 08:13:47
HD Request # 37 | Receiving historical Daily data for USDCAD starting at 2016-03-14 | 2016-03-16 08:13:47
HD Request # 37 | Writing historical Daily data to the file USDCAD.dly | 2016-03-16 08:13:47
EURGBP [M] Daily #3 | Reloading chart. | 2016-03-16 08:13:47
Socket (41) | Shutdown and closed. | 2016-03-16 08:13:47
HD Request # 37 | Received 3 records from 2016-03-14 00:00:00 to 2016-03-16 00:00:00 (3.0 days) and wrote 3 records for USDCAD | 2016-03-16 08:13:47
HD Request # 37 | Daily download COMPLETE for USDCAD. Completion time: 0s. Unique request ID: 35 | 2016-03-16 08:13:47
Removed historical data download ID 35 | 2016-03-16 08:13:47
HD Request # 38 | Downloading Intraday chart data for USDCAD to the file USDCAD.scid. Service: fxcm | 2016-03-16 08:13:47
HD Request # 38 | Download start Date-Time: 2016-03-15 19:42:12.000 | 2016-03-16 08:13:47
HD Request # 38 | Using server: ds4.sierracharts.com port 10149 | 2016-03-16 08:13:47
EURGBP [M] Weekly #4 | Reloading chart. | 2016-03-16 08:13:47
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-03-16 08:13:47
EURJPY [M] Weekly #4 | Reloading chart. | 2016-03-16 08:13:47
Socket (42) | Connected. | 2016-03-16 08:13:47
HD Request # 38 | Sending historical data logon request message. | 2016-03-16 08:13:47
EURJPY [M] Daily #3 | Reloading chart. | 2016-03-16 08:13:47
EURNZD [M] Daily #3 | Reloading chart. | 2016-03-16 08:13:47
HD Request # 38 | Requesting Intraday data. Start Date-Time: 2016-03-15 19:42:12. Record interval: 0. Symbol: USDCAD | 2016-03-16 08:13:47
EURUSD [M] Monthly #5 | Reloading chart. | 2016-03-16 08:13:47
EURNZD [M] Weekly #4 | Reloading chart. | 2016-03-16 08:13:47
GBPAUD [M] Daily #3 | Reloading chart. | 2016-03-16 08:13:47
GBPAUD [M] Weekly #4 | Reloading chart. | 2016-03-16 08:13:47
GBPCHF [M] Daily #3 | Reloading chart. | 2016-03-16 08:13:47
GBPCHF [M] Weekly #4 | Reloading chart. | 2016-03-16 08:13:47
GBPCHF [M] Monthly #5 | Reloading chart. | 2016-03-16 08:13:47
HD Request # 38 | Decompressing data. | 2016-03-16 08:13:47
GBPJPY [M] Daily #3 | Reloading chart. | 2016-03-16 08:13:47
HD Request # 38 | Receiving Intraday data for USDCAD starting at 2016-03-15 19:42:12 | 2016-03-16 08:13:47
HD Request # 38 | Timestamp of first Intraday data file record written: 2016-03-15 19:42:12 | 2016-03-16 08:13:47
GBPJPY [M] Weekly #4 | Reloading chart. | 2016-03-16 08:13:47
GBPJPY [M] Monthly #5 | Reloading chart. | 2016-03-16 08:13:47
Socket (42) | Shutdown and closed. | 2016-03-16 08:13:47
HD Request # 38 | Received 79542 records from 2016-03-15 19:42:12 to 2016-03-16 08:12:53 (12.5 hours) and wrote 79541 records for USDCAD | 2016-03-16 08:13:47
HD Request # 38 | Intraday download COMPLETE for USDCAD. Completion time: 1s. Unique request ID: 36 | 2016-03-16 08:13:47
Removed historical data download ID 36 | 2016-03-16 08:13:47
Real-time Intraday chart data file updates started for USDCAD | 2016-03-16 08:13:47
Opened cached Intraday file: C:\SierraChart\Data\USDCAD.scid | 2016-03-16 08:13:47
Intraday chart data file opened for USDCAD | 2016-03-16 08:13:47
HD Request # 39 | Downloading Historical Daily chart data for USDCHF. Starting date: 2016-03-14. Service: fxcm | 2016-03-16 08:13:47
HD Request # 39 | Using server: ds5.sierracharts.com port 10149 | 2016-03-16 08:13:47
GBPNZD [M] Daily #3 | Reloading chart. | 2016-03-16 08:13:47
GBPNZD [M] Weekly #4 | Reloading chart. | 2016-03-16 08:13:47
GBPNZD [M] Monthly #5 | Reloading chart. | 2016-03-16 08:13:47
Socket (43) | Connected. | 2016-03-16 08:13:47
HD Request # 39 | Sending historical data logon request message. | 2016-03-16 08:13:47
GBPUSD [M] Daily #3 | Reloading chart. | 2016-03-16 08:13:47
HD Request # 39 | Requesting historical Daily data starting at 2016-03-14. | 2016-03-16 08:13:47
GBPUSD [M] Weekly #4 | Reloading chart. | 2016-03-16 08:13:47
GBPUSD [M] Monthly #5 | Reloading chart. | 2016-03-16 08:13:47
NZDJPY [M] Daily #1 | Reloading chart. | 2016-03-16 08:13:47
HD Request # 39 | Decompressing data. | 2016-03-16 08:13:47
HD Request # 39 | Receiving historical Daily data for USDCHF starting at 2016-03-14 | 2016-03-16 08:13:47
HD Request # 39 | Writing historical Daily data to the file USDCHF.dly | 2016-03-16 08:13:47
NZDJPY [M] Weekly #2 | Reloading chart. | 2016-03-16 08:13:47
Socket (43) | Shutdown and closed. | 2016-03-16 08:13:47
HD Request # 39 | Received 3 records from 2016-03-14 00:00:00 to 2016-03-16 00:00:00 (3.0 days) and wrote 3 records for USDCHF | 2016-03-16 08:13:47
HD Request # 39 | Daily download COMPLETE for USDCHF. Completion time: 0s. Unique request ID: 37 | 2016-03-16 08:13:47
Removed historical data download ID 37 | 2016-03-16 08:13:47
HD Request # 40 | Downloading Intraday chart data for USDCHF to the file USDCHF.scid. Service: fxcm | 2016-03-16 08:13:47
HD Request # 40 | Download start Date-Time: 2016-03-15 19:42:00.000 | 2016-03-16 08:13:47
HD Request # 40 | Using server: ds3.sierracharts.com port 10149 | 2016-03-16 08:13:47
NZDJPY [M] Monthly #3 | Reloading chart. | 2016-03-16 08:13:47
NZDUSD [M] Daily #3 | Reloading chart. | 2016-03-16 08:13:47
NZDUSD [M] Weekly #4 | Reloading chart. | 2016-03-16 08:13:47
Socket (44) | Connected. | 2016-03-16 08:13:47
HD Request # 40 | Sending historical data logon request message. | 2016-03-16 08:13:47
NZDUSD [M] Monthly #5 | Reloading chart. | 2016-03-16 08:13:47
USDCAD [M] Daily #3 | Reloading chart. | 2016-03-16 08:13:47
HD Request # 40 | Requesting Intraday data. Start Date-Time: 2016-03-15 19:42:00. Record interval: 0. Symbol: USDCHF | 2016-03-16 08:13:47
USDCAD [M] Weekly #4 | Reloading chart. | 2016-03-16 08:13:47
HD Request # 40 | Decompressing data. | 2016-03-16 08:13:47
HD Request # 40 | Receiving Intraday data for USDCHF starting at 2016-03-15 19:42:00 | 2016-03-16 08:13:47
HD Request # 40 | Timestamp of first Intraday data file record written: 2016-03-15 19:42:19 | 2016-03-16 08:13:47
USDCAD [M] Monthly #5 | Reloading chart. | 2016-03-16 08:13:47
USDCHF [M] Daily #3 | Reloading chart. | 2016-03-16 08:13:47
USDCHF [M] Weekly #4 | Reloading chart. | 2016-03-16 08:13:47
USDCHF [M] Monthly #5 | Reloading chart. | 2016-03-16 08:13:47
Socket (44) | Shutdown and closed. | 2016-03-16 08:13:49
The network socket for historical data has been closed. | 2016-03-16 08:13:49
HD Request # 40 | Received 61194 records from 2016-03-15 19:42:00 to 2016-03-16 08:12:51 (12.5 hours) and wrote 61193 records for USDCHF | 2016-03-16 08:13:49
Added 35 Time and Sales records to Intraday data file for USDCHF after download. | 2016-03-16 08:13:49
HD Request # 40 | Intraday download COMPLETE for USDCHF. Completion time: 2s. Unique request ID: 38 | 2016-03-16 08:13:49
Removed historical data download ID 38 | 2016-03-16 08:13:49
Real-time Intraday chart data file updates started for USDCHF | 2016-03-16 08:13:49
Opened cached Intraday file: C:\SierraChart\Data\USDCHF.scid | 2016-03-16 08:13:49
Intraday chart data file opened for USDCHF | 2016-03-16 08:13:49
HD Request # 41 | Downloading Historical Daily chart data for USDJPY. Starting date: 2016-03-14. Service: fxcm | 2016-03-16 08:13:49
HD Request # 41 | Using server: ds4.sierracharts.com port 10149 | 2016-03-16 08:13:49
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-03-16 08:13:49
Socket (45) | Connected. | 2016-03-16 08:13:49
HD Request # 41 | Sending historical data logon request message. | 2016-03-16 08:13:49
HD Request # 41 | Requesting historical Daily data starting at 2016-03-14. | 2016-03-16 08:13:49
HD Request # 41 | Decompressing data. | 2016-03-16 08:13:49
HD Request # 41 | Receiving historical Daily data for USDJPY starting at 2016-03-14 | 2016-03-16 08:13:49
HD Request # 41 | Writing historical Daily data to the file USDJPY.dly | 2016-03-16 08:13:49
Socket (45) | Shutdown and closed. | 2016-03-16 08:13:49
HD Request # 41 | Received 3 records from 2016-03-14 00:00:00 to 2016-03-16 00:00:00 (3.0 days) and wrote 3 records for USDJPY | 2016-03-16 08:13:49
HD Request # 41 | Daily download COMPLETE for USDJPY. Completion time: 0s. Unique request ID: 39 | 2016-03-16 08:13:49
Removed historical data download ID 39 | 2016-03-16 08:13:49
HD Request # 42 | Downloading Intraday chart data for USDJPY to the file USDJPY.scid. Service: fxcm | 2016-03-16 08:13:49
HD Request # 42 | Download start Date-Time: 2016-03-15 19:42:11.000 | 2016-03-16 08:13:49
HD Request # 42 | Using server: ds5.sierracharts.com port 10149 | 2016-03-16 08:13:49
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-03-16 08:13:49
Socket (46) | Connected. | 2016-03-16 08:13:49
HD Request # 42 | Sending historical data logon request message. | 2016-03-16 08:13:49
HD Request # 42 | Requesting Intraday data. Start Date-Time: 2016-03-15 19:42:11. Record interval: 0. Symbol: USDJPY | 2016-03-16 08:13:49
HD Request # 42 | Decompressing data. | 2016-03-16 08:13:49
USDJPY [M] Daily #3 | Reloading chart. | 2016-03-16 08:13:49
HD Request # 42 | Receiving Intraday data for USDJPY starting at 2016-03-15 19:42:11 | 2016-03-16 08:13:49
HD Request # 42 | Timestamp of first Intraday data file record written: 2016-03-15 19:42:14 | 2016-03-16 08:13:49
USDJPY [M] Weekly #4 | Reloading chart. | 2016-03-16 08:13:49
USDJPY [M] Monthly #5 | Reloading chart. | 2016-03-16 08:13:49
Socket (46) | Shutdown and closed. | 2016-03-16 08:13:51
The network socket for historical data has been closed. | 2016-03-16 08:13:51
HD Request # 42 | Received 109002 records from 2016-03-15 19:42:11 to 2016-03-16 08:12:55 (12.5 hours) and wrote 108999 records for USDJPY | 2016-03-16 08:13:51
Added 12 Time and Sales records to Intraday data file for USDJPY after download. | 2016-03-16 08:13:51
HD Request # 42 | Intraday download COMPLETE for USDJPY. Completion time: 2s. Unique request ID: 40 | 2016-03-16 08:13:51
Removed historical data download ID 40 | 2016-03-16 08:13:51
Real-time Intraday chart data file updates started for USDJPY | 2016-03-16 08:13:51
Opened cached Intraday file: C:\SierraChart\Data\USDJPY.scid | 2016-03-16 08:13:51
Intraday chart data file opened for USDJPY | 2016-03-16 08:13:51
HD Request # 43 | Downloading Intraday chart data for AUDJPY to the file AUDJPY.scid. Service: fxcm | 2016-03-16 08:13:51
HD Request # 43 | Download start Date-Time: 2016-03-16 08:11:19.000 | 2016-03-16 08:13:51
HD Request # 43 | Using server: ds3.sierracharts.com port 10149 | 2016-03-16 08:13:51
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164. | 2016-03-16 08:13:51
Socket (47) | Connected. | 2016-03-16 08:13:51
HD Request # 43 | Sending historical data logon request message. | 2016-03-16 08:13:51
HD Request # 43 | Requesting Intraday data. Start Date-Time: 2016-03-16 08:11:19. Record interval: 0. Symbol: AUDJPY | 2016-03-16 08:13:51
HD Request # 43 | Decompressing data. | 2016-03-16 08:13:51
HD Request # 43 | Receiving Intraday data for AUDJPY starting at 2016-03-16 08:11:19 | 2016-03-16 08:13:51
HD Request # 43 | Timestamp of first Intraday data file record written: 2016-03-16 08:11:19 | 2016-03-16 08:13:51
Socket (47) | Shutdown and closed. | 2016-03-16 08:13:51
HD Request # 43 | Received 465 records from 2016-03-16 08:11:19 to 2016-03-16 08:12:58 (99.0 seconds) and wrote 458 records for AUDJPY | 2016-03-16 08:13:51
Added 7 Time and Sales records to Intraday data file for AUDJPY after download. | 2016-03-16 08:13:51
HD Request # 43 | Intraday download COMPLETE for AUDJPY. Completion time: 0s. Unique request ID: 41 | 2016-03-16 08:13:51
Removed historical data download ID 41 | 2016-03-16 08:13:51
Real-time Intraday chart data file updates started for AUDJPY | 2016-03-16 08:13:51
Opened cached Intraday file: C:\SierraChart\Data\AUDJPY.scid | 2016-03-16 08:13:51
Intraday chart data file opened for AUDJPY | 2016-03-16 08:13:51
HD Request # 44 | Downloading Intraday chart data for AUDNZD to the file AUDNZD.scid. Service: fxcm | 2016-03-16 08:13:51
HD Request # 44 | Download start Date-Time: 2016-03-16 08:11:27.000 | 2016-03-16 08:13:51
HD Request # 44 | Using server: ds4.sierracharts.com port 10149 | 2016-03-16 08:13:51
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-03-16 08:13:51
Socket (48) | Connected. | 2016-03-16 08:13:51
HD Request # 44 | Sending historical data logon request message. | 2016-03-16 08:13:51
HD Request # 44 | Requesting Intraday data. Start Date-Time: 2016-03-16 08:11:27. Record interval: 0. Symbol: AUDNZD | 2016-03-16 08:13:51
HD Request # 44 | Decompressing data. | 2016-03-16 08:13:54
HD Request # 44 | Receiving Intraday data for AUDNZD starting at 2016-03-16 08:11:27 | 2016-03-16 08:13:54
HD Request # 44 | Timestamp of first Intraday data file record written: 2016-03-16 08:11:30 | 2016-03-16 08:13:54
Socket (48) | Shutdown and closed. | 2016-03-16 08:13:54
The network socket for historical data has been closed. | 2016-03-16 08:13:54
HD Request # 44 | Received 339 records from 2016-03-16 08:11:27 to 2016-03-16 08:12:59 (92.0 seconds) and wrote 336 records for AUDNZD | 2016-03-16 08:13:54
HD Request # 44 | Intraday download COMPLETE for AUDNZD. Completion time: 0s. Unique request ID: 42 | 2016-03-16 08:13:54
Removed historical data download ID 42 | 2016-03-16 08:13:54
Real-time Intraday chart data file updates started for AUDNZD | 2016-03-16 08:13:54
Opened cached Intraday file: C:\SierraChart\Data\AUDNZD.scid | 2016-03-16 08:13:54
Intraday chart data file opened for AUDNZD | 2016-03-16 08:13:54
HD Request # 45 | Downloading Intraday chart data for AUDUSD to the file AUDUSD.scid. Service: fxcm | 2016-03-16 08:13:54
HD Request # 45 | Download start Date-Time: 2016-03-16 08:11:35.000 | 2016-03-16 08:13:54
HD Request # 45 | Using server: ds5.sierracharts.com port 10149 | 2016-03-16 08:13:54
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-03-16 08:13:54
Socket (49) | Connected. | 2016-03-16 08:13:54
HD Request # 45 | Sending historical data logon request message. | 2016-03-16 08:13:54
HD Request # 45 | Requesting Intraday data. Start Date-Time: 2016-03-16 08:11:35. Record interval: 0. Symbol: AUDUSD | 2016-03-16 08:13:54
HD Request # 45 | Decompressing data. | 2016-03-16 08:13:54
HD Request # 45 | Receiving Intraday data for AUDUSD starting at 2016-03-16 08:11:35 | 2016-03-16 08:13:54
HD Request # 45 | Timestamp of first Intraday data file record written: 2016-03-16 08:11:36 | 2016-03-16 08:13:54
Socket (49) | Shutdown and closed. | 2016-03-16 08:13:54
HD Request # 45 | Received 280 records from 2016-03-16 08:11:35 to 2016-03-16 08:12:59 (84.0 seconds) and wrote 279 records for AUDUSD | 2016-03-16 08:13:54
Added 14 Time and Sales records to Intraday data file for AUDUSD after download. | 2016-03-16 08:13:54
HD Request # 45 | Intraday download COMPLETE for AUDUSD. Completion time: 2s. Unique request ID: 43 | 2016-03-16 08:13:54
Removed historical data download ID 43 | 2016-03-16 08:13:54
Real-time Intraday chart data file updates started for AUDUSD | 2016-03-16 08:13:54
Opened cached Intraday file: C:\SierraChart\Data\AUDUSD.scid | 2016-03-16 08:13:54
Intraday chart data file opened for AUDUSD | 2016-03-16 08:13:54
HD Request # 46 | Downloading Intraday chart data for EURAUD to the file EURAUD.scid. Service: fxcm | 2016-03-16 08:13:54
HD Request # 46 | Download start Date-Time: 2016-03-16 08:11:39.000 | 2016-03-16 08:13:54
HD Request # 46 | Using server: ds3.sierracharts.com port 10149 | 2016-03-16 08:13:54
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164. | 2016-03-16 08:13:54
Socket (50) | Connected. | 2016-03-16 08:13:56
HD Request # 46 | Sending historical data logon request message. | 2016-03-16 08:13:56
HD Request # 46 | Requesting Intraday data. Start Date-Time: 2016-03-16 08:11:39. Record interval: 0. Symbol: EURAUD | 2016-03-16 08:13:56
HD Request # 46 | Decompressing data. | 2016-03-16 08:13:56
HD Request # 46 | Receiving Intraday data for EURAUD starting at 2016-03-16 08:11:39 | 2016-03-16 08:13:56
HD Request # 46 | Timestamp of first Intraday data file record written: 2016-03-16 08:11:42 | 2016-03-16 08:13:56
Socket (50) | Shutdown and closed. | 2016-03-16 08:13:56
The network socket for historical data has been closed. | 2016-03-16 08:13:56
HD Request # 46 | Received 703 records from 2016-03-16 08:11:39 to 2016-03-16 08:12:59 (80.0 seconds) and wrote 697 records for EURAUD | 2016-03-16 08:13:56
Added 48 Time and Sales records to Intraday data file for EURAUD after download. | 2016-03-16 08:13:56
HD Request # 46 | Intraday download COMPLETE for EURAUD. Completion time: 0s. Unique request ID: 44 | 2016-03-16 08:13:56
Removed historical data download ID 44 | 2016-03-16 08:13:56
Real-time Intraday chart data file updates started for EURAUD | 2016-03-16 08:13:56
Opened cached Intraday file: C:\SierraChart\Data\EURAUD.scid | 2016-03-16 08:13:56
Intraday chart data file opened for EURAUD | 2016-03-16 08:13:56
HD Request # 47 | Downloading Intraday chart data for EURCAD to the file EURCAD.scid. Service: fxcm | 2016-03-16 08:13:56
HD Request # 47 | Download start Date-Time: 2016-03-16 08:11:43.000 | 2016-03-16 08:13:56
HD Request # 47 | Using server: ds4.sierracharts.com port 10149 | 2016-03-16 08:13:56
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-03-16 08:13:56
Socket (51) | Connected. | 2016-03-16 08:13:57
HD Request # 47 | Sending historical data logon request message. | 2016-03-16 08:13:57
HD Request # 47 | Requesting Intraday data. Start Date-Time: 2016-03-16 08:11:43. Record interval: 0. Symbol: EURCAD | 2016-03-16 08:13:57
HD Request # 47 | Decompressing data. | 2016-03-16 08:13:57
HD Request # 47 | Receiving Intraday data for EURCAD starting at 2016-03-16 08:11:43 | 2016-03-16 08:13:57
HD Request # 47 | Timestamp of first Intraday data file record written: 2016-03-16 08:11:44 | 2016-03-16 08:13:57
Socket (51) | Shutdown and closed. | 2016-03-16 08:13:57
The network socket for historical data has been closed. | 2016-03-16 08:13:57
HD Request # 47 | Received 608 records from 2016-03-16 08:11:43 to 2016-03-16 08:13:01 (78.0 seconds) and wrote 606 records for EURCAD | 2016-03-16 08:13:57
Added 7 Time and Sales records to Intraday data file for EURCAD after download. | 2016-03-16 08:13:57
HD Request # 47 | Intraday download COMPLETE for EURCAD. Completion time: 0s. Unique request ID: 45 | 2016-03-16 08:13:57
Removed historical data download ID 45 | 2016-03-16 08:13:57
Real-time Intraday chart data file updates started for EURCAD | 2016-03-16 08:13:57
Opened cached Intraday file: C:\SierraChart\Data\EURCAD.scid | 2016-03-16 08:13:57
Intraday chart data file opened for EURCAD | 2016-03-16 08:13:57
HD Request # 48 | Downloading Intraday chart data for EURCHF to the file EURCHF.scid. Service: fxcm | 2016-03-16 08:13:57
HD Request # 48 | Download start Date-Time: 2016-03-16 08:11:49.000 | 2016-03-16 08:13:57
HD Request # 48 | Using server: ds5.sierracharts.com port 10149 | 2016-03-16 08:13:57
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-03-16 08:13:57
Socket (52) | Connected. | 2016-03-16 08:13:57
HD Request # 48 | Sending historical data logon request message. | 2016-03-16 08:13:57
HD Request # 48 | Requesting Intraday data. Start Date-Time: 2016-03-16 08:11:49. Record interval: 0. Symbol: EURCHF | 2016-03-16 08:13:57
HD Request # 48 | Decompressing data. | 2016-03-16 08:13:57
HD Request # 48 | Receiving Intraday data for EURCHF starting at 2016-03-16 08:11:49 | 2016-03-16 08:13:57
HD Request # 48 | Timestamp of first Intraday data file record written: 2016-03-16 08:11:50 | 2016-03-16 08:13:57
Socket (52) | Shutdown and closed. | 2016-03-16 08:13:57
HD Request # 48 | Received 321 records from 2016-03-16 08:11:49 to 2016-03-16 08:13:01 (72.0 seconds) and wrote 316 records for EURCHF | 2016-03-16 08:13:57
Added 17 Time and Sales records to Intraday data file for EURCHF after download. | 2016-03-16 08:13:57
HD Request # 48 | Intraday download COMPLETE for EURCHF. Completion time: 2s. Unique request ID: 46 | 2016-03-16 08:13:57
Removed historical data download ID 46 | 2016-03-16 08:13:57
Real-time Intraday chart data file updates started for EURCHF | 2016-03-16 08:13:57
Opened cached Intraday file: C:\SierraChart\Data\EURCHF.scid | 2016-03-16 08:13:57
Intraday chart data file opened for EURCHF | 2016-03-16 08:13:57
HD Request # 49 | Downloading Intraday chart data for EURGBP to the file EURGBP.scid. Service: fxcm | 2016-03-16 08:13:57
HD Request # 49 | Download start Date-Time: 2016-03-16 08:11:55.000 | 2016-03-16 08:13:57
HD Request # 49 | Using server: ds3.sierracharts.com port 10149 | 2016-03-16 08:13:57
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164. | 2016-03-16 08:13:57
Socket (53) | Connected. | 2016-03-16 08:13:58
HD Request # 49 | Sending historical data logon request message. | 2016-03-16 08:13:58
HD Request # 49 | Requesting Intraday data. Start Date-Time: 2016-03-16 08:11:55. Record interval: 0. Symbol: EURGBP | 2016-03-16 08:13:58
HD Request # 49 | Decompressing data. | 2016-03-16 08:13:58
HD Request # 49 | Receiving Intraday data for EURGBP starting at 2016-03-16 08:11:55 | 2016-03-16 08:13:58
HD Request # 49 | Timestamp of first Intraday data file record written: 2016-03-16 08:11:55 | 2016-03-16 08:13:58
Socket (53) | Shutdown and closed. | 2016-03-16 08:13:58
The network socket for historical data has been closed. | 2016-03-16 08:13:58
HD Request # 49 | Received 220 records from 2016-03-16 08:11:55 to 2016-03-16 08:13:03 (68.0 seconds) and wrote 216 records for EURGBP | 2016-03-16 08:13:58
HD Request # 49 | Intraday download COMPLETE for EURGBP. Completion time: 0s. Unique request ID: 47 | 2016-03-16 08:13:58
Removed historical data download ID 47 | 2016-03-16 08:13:58
Real-time Intraday chart data file updates started for EURGBP | 2016-03-16 08:13:58
Opened cached Intraday file: C:\SierraChart\Data\EURGBP.scid | 2016-03-16 08:13:58
Intraday chart data file opened for EURGBP | 2016-03-16 08:13:58
HD Request # 50 | Downloading Intraday chart data for EURJPY to the file EURJPY.scid. Service: fxcm | 2016-03-16 08:13:58
HD Request # 50 | Download start Date-Time: 2016-03-16 08:12:02.000 | 2016-03-16 08:13:58
HD Request # 50 | Using server: ds4.sierracharts.com port 10149 | 2016-03-16 08:13:58
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-03-16 08:13:58
Socket (54) | Connected. | 2016-03-16 08:13:58
HD Request # 50 | Sending historical data logon request message. | 2016-03-16 08:13:58
HD Request # 50 | Requesting Intraday data. Start Date-Time: 2016-03-16 08:12:02. Record interval: 0. Symbol: EURJPY | 2016-03-16 08:13:58
HD Request # 50 | Decompressing data. | 2016-03-16 08:13:58
HD Request # 50 | Receiving Intraday data for EURJPY starting at 2016-03-16 08:12:02 | 2016-03-16 08:13:58
HD Request # 50 | Timestamp of first Intraday data file record written: 2016-03-16 08:12:04 | 2016-03-16 08:13:58
Socket (54) | Shutdown and closed. | 2016-03-16 08:13:58
HD Request # 50 | Received 381 records from 2016-03-16 08:12:02 to 2016-03-16 08:13:03 (61.0 seconds) and wrote 374 records for EURJPY | 2016-03-16 08:13:58
Added 5 Time and Sales records to Intraday data file for EURJPY after download. | 2016-03-16 08:13:58
HD Request # 50 | Intraday download COMPLETE for EURJPY. Completion time: 1s. Unique request ID: 48 | 2016-03-16 08:13:58
Removed historical data download ID 48 | 2016-03-16 08:13:58
Real-time Intraday chart data file updates started for EURJPY | 2016-03-16 08:13:58
Opened cached Intraday file: C:\SierraChart\Data\EURJPY.scid | 2016-03-16 08:13:58
Intraday chart data file opened for EURJPY | 2016-03-16 08:13:58
HD Request # 51 | Downloading Intraday chart data for EURNZD to the file EURNZD.scid. Service: fxcm | 2016-03-16 08:13:58
HD Request # 51 | Download start Date-Time: 2016-03-16 08:12:06.000 | 2016-03-16 08:13:58
HD Request # 51 | Using server: ds5.sierracharts.com port 10149 | 2016-03-16 08:13:58
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-03-16 08:13:58
Socket (55) | Connected. | 2016-03-16 08:13:58
HD Request # 51 | Sending historical data logon request message. | 2016-03-16 08:13:58
HD Request # 51 | Requesting Intraday data. Start Date-Time: 2016-03-16 08:12:06. Record interval: 0. Symbol: EURNZD | 2016-03-16 08:13:58
HD Request # 51 | Decompressing data. | 2016-03-16 08:13:58
HD Request # 51 | Receiving Intraday data for EURNZD starting at 2016-03-16 08:12:06 | 2016-03-16 08:13:58
HD Request # 51 | Timestamp of first Intraday data file record written: 2016-03-16 08:12:08 | 2016-03-16 08:13:58
Socket (55) | Shutdown and closed. | 2016-03-16 08:13:58
HD Request # 51 | Received 744 records from 2016-03-16 08:12:06 to 2016-03-16 08:13:03 (57.0 seconds) and wrote 727 records for EURNZD | 2016-03-16 08:13:58
Added 23 Time and Sales records to Intraday data file for EURNZD after download. | 2016-03-16 08:13:58
HD Request # 51 | Intraday download COMPLETE for EURNZD. Completion time: 0s. Unique request ID: 49 | 2016-03-16 08:13:58
Removed historical data download ID 49 | 2016-03-16 08:13:58
Real-time Intraday chart data file updates started for EURNZD | 2016-03-16 08:13:58
Opened cached Intraday file: C:\SierraChart\Data\EURNZD.scid | 2016-03-16 08:13:58
Intraday chart data file opened for EURNZD | 2016-03-16 08:13:58
HD Request # 52 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm | 2016-03-16 08:13:58
HD Request # 52 | Download start Date-Time: 2016-03-16 08:12:08.000 | 2016-03-16 08:13:58
HD Request # 52 | Using server: ds3.sierracharts.com port 10149 | 2016-03-16 08:13:58
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164. | 2016-03-16 08:13:58
Socket (56) | Connected. | 2016-03-16 08:14:00
HD Request # 52 | Sending historical data logon request message. | 2016-03-16 08:14:00
HD Request # 52 | Requesting Intraday data. Start Date-Time: 2016-03-16 08:12:08. Record interval: 0. Symbol: EURUSD | 2016-03-16 08:14:00
HD Request # 52 | Decompressing data. | 2016-03-16 08:14:00
HD Request # 52 | Receiving Intraday data for EURUSD starting at 2016-03-16 08:12:08 | 2016-03-16 08:14:00
HD Request # 52 | Timestamp of first Intraday data file record written: 2016-03-16 08:12:12 | 2016-03-16 08:14:00
Socket (56) | Shutdown and closed. | 2016-03-16 08:14:00
The network socket for historical data has been closed. | 2016-03-16 08:14:00
HD Request # 52 | Received 279 records from 2016-03-16 08:12:08 to 2016-03-16 08:13:03 (55.0 seconds) and wrote 276 records for EURUSD | 2016-03-16 08:14:00
Added 2 Time and Sales records to Intraday data file for EURUSD after download. | 2016-03-16 08:14:00
HD Request # 52 | Intraday download COMPLETE for EURUSD. Completion time: 1s. Unique request ID: 50 | 2016-03-16 08:14:00
Removed historical data download ID 50 | 2016-03-16 08:14:00
Real-time Intraday chart data file updates started for EURUSD | 2016-03-16 08:14:00
Opened cached Intraday file: C:\SierraChart\Data\EURUSD.scid | 2016-03-16 08:14:00
Intraday chart data file opened for EURUSD | 2016-03-16 08:14:00
HD Request # 53 | Downloading Intraday chart data for GBPAUD to the file GBPAUD.scid. Service: fxcm | 2016-03-16 08:14:00
HD Request # 53 | Download start Date-Time: 2016-03-16 08:12:16.000 | 2016-03-16 08:14:00
HD Request # 53 | Using server: ds4.sierracharts.com port 10149 | 2016-03-16 08:14:00
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-03-16 08:14:00
Socket (57) | Connected. | 2016-03-16 08:14:00
HD Request # 53 | Sending historical data logon request message. | 2016-03-16 08:14:00
HD Request # 53 | Requesting Intraday data. Start Date-Time: 2016-03-16 08:12:16. Record interval: 0. Symbol: GBPAUD | 2016-03-16 08:14:00
HD Request # 53 | Decompressing data. | 2016-03-16 08:14:00
HD Request # 53 | Receiving Intraday data for GBPAUD starting at 2016-03-16 08:12:16 | 2016-03-16 08:14:00
HD Request # 53 | Timestamp of first Intraday data file record written: 2016-03-16 08:12:16 | 2016-03-16 08:14:00
Socket (57) | Shutdown and closed. | 2016-03-16 08:14:00
HD Request # 53 | Received 374 records from 2016-03-16 08:12:16 to 2016-03-16 08:13:05 (49.0 seconds) and wrote 371 records for GBPAUD | 2016-03-16 08:14:00
Added 14 Time and Sales records to Intraday data file for GBPAUD after download. | 2016-03-16 08:14:00
HD Request # 53 | Intraday download COMPLETE for GBPAUD. Completion time: 0s. Unique request ID: 51 | 2016-03-16 08:14:00
Removed historical data download ID 51 | 2016-03-16 08:14:00
Real-time Intraday chart data file updates started for GBPAUD | 2016-03-16 08:14:00
Opened cached Intraday file: C:\SierraChart\Data\GBPAUD.scid | 2016-03-16 08:14:00
Intraday chart data file opened for GBPAUD | 2016-03-16 08:14:00
HD Request # 54 | Downloading Intraday chart data for GBPCHF to the file GBPCHF.scid. Service: fxcm | 2016-03-16 08:14:00
HD Request # 54 | Download start Date-Time: 2016-03-16 08:12:17.000 | 2016-03-16 08:14:00
HD Request # 54 | Using server: ds5.sierracharts.com port 10149 | 2016-03-16 08:14:00
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-03-16 08:14:00
Socket (58) | Connected. | 2016-03-16 08:14:00
HD Request # 54 | Sending historical data logon request message. | 2016-03-16 08:14:00
HD Request # 54 | Requesting Intraday data. Start Date-Time: 2016-03-16 08:12:17. Record interval: 0. Symbol: GBPCHF | 2016-03-16 08:14:00
HD Request # 54 | Decompressing data. | 2016-03-16 08:14:00
HD Request # 54 | Receiving Intraday data for GBPCHF starting at 2016-03-16 08:12:17 | 2016-03-16 08:14:00
HD Request # 54 | Timestamp of first Intraday data file record written: 2016-03-16 08:12:17 | 2016-03-16 08:14:00
Socket (58) | Shutdown and closed. | 2016-03-16 08:14:00
HD Request # 54 | Received 336 records from 2016-03-16 08:12:17 to 2016-03-16 08:13:04 (47.0 seconds) and wrote 323 records for GBPCHF | 2016-03-16 08:14:00
Added 2 Time and Sales records to Intraday data file for GBPCHF after download. | 2016-03-16 08:14:00
HD Request # 54 | Intraday download COMPLETE for GBPCHF. Completion time: 0s. Unique request ID: 52 | 2016-03-16 08:14:00
Removed historical data download ID 52 | 2016-03-16 08:14:00
Real-time Intraday chart data file updates started for GBPCHF | 2016-03-16 08:14:00
Opened cached Intraday file: C:\SierraChart\Data\GBPCHF.scid | 2016-03-16 08:14:00
Intraday chart data file opened for GBPCHF | 2016-03-16 08:14:00
HD Request # 55 | Downloading Intraday chart data for GBPJPY to the file GBPJPY.scid. Service: fxcm | 2016-03-16 08:14:00
HD Request # 55 | Download start Date-Time: 2016-03-16 08:12:24.000 | 2016-03-16 08:14:00
HD Request # 55 | Using server: ds3.sierracharts.com port 10149 | 2016-03-16 08:14:00
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164. | 2016-03-16 08:14:00
Socket (59) | Connected. | 2016-03-16 08:14:02
HD Request # 55 | Sending historical data logon request message. | 2016-03-16 08:14:02
HD Request # 55 | Requesting Intraday data. Start Date-Time: 2016-03-16 08:12:24. Record interval: 0. Symbol: GBPJPY | 2016-03-16 08:14:02
HD Request # 55 | Decompressing data. | 2016-03-16 08:14:02
HD Request # 55 | Receiving Intraday data for GBPJPY starting at 2016-03-16 08:12:24 | 2016-03-16 08:14:02
HD Request # 55 | Timestamp of first Intraday data file record written: 2016-03-16 08:12:25 | 2016-03-16 08:14:02
Socket (59) | Shutdown and closed. | 2016-03-16 08:14:02
The network socket for historical data has been closed. | 2016-03-16 08:14:02
HD Request # 55 | Received 207 records from 2016-03-16 08:12:24 to 2016-03-16 08:13:06 (42.0 seconds) and wrote 201 records for GBPJPY | 2016-03-16 08:14:02
Added 9 Time and Sales records to Intraday data file for GBPJPY after download. | 2016-03-16 08:14:02
HD Request # 55 | Intraday download COMPLETE for GBPJPY. Completion time: 2s. Unique request ID: 53 | 2016-03-16 08:14:02
Removed historical data download ID 53 | 2016-03-16 08:14:02
Real-time Intraday chart data file updates started for GBPJPY | 2016-03-16 08:14:02
Opened cached Intraday file: C:\SierraChart\Data\GBPJPY.scid | 2016-03-16 08:14:02
Intraday chart data file opened for GBPJPY | 2016-03-16 08:14:02
HD Request # 56 | Downloading Intraday chart data for GBPNZD to the file GBPNZD.scid. Service: fxcm | 2016-03-16 08:14:02
HD Request # 56 | Download start Date-Time: 2016-03-16 08:12:31.000 | 2016-03-16 08:14:02
HD Request # 56 | Using server: ds4.sierracharts.com port 10149 | 2016-03-16 08:14:02
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-03-16 08:14:02
Socket (60) | Connected. | 2016-03-16 08:14:02
HD Request # 56 | Sending historical data logon request message. | 2016-03-16 08:14:02
HD Request # 56 | Requesting Intraday data. Start Date-Time: 2016-03-16 08:12:31. Record interval: 0. Symbol: GBPNZD | 2016-03-16 08:14:02
HD Request # 56 | Decompressing data. | 2016-03-16 08:14:02
HD Request # 56 | Receiving Intraday data for GBPNZD starting at 2016-03-16 08:12:31 | 2016-03-16 08:14:02
HD Request # 56 | Timestamp of first Intraday data file record written: 2016-03-16 08:12:32 | 2016-03-16 08:14:02
Socket (60) | Shutdown and closed. | 2016-03-16 08:14:02
HD Request # 56 | Received 346 records from 2016-03-16 08:12:31 to 2016-03-16 08:13:09 (38.0 seconds) and wrote 342 records for GBPNZD | 2016-03-16 08:14:02
Added 24 Time and Sales records to Intraday data file for GBPNZD after download. | 2016-03-16 08:14:02
HD Request # 56 | Intraday download COMPLETE for GBPNZD. Completion time: 2s. Unique request ID: 54 | 2016-03-16 08:14:02
Removed historical data download ID 54 | 2016-03-16 08:14:02
Real-time Intraday chart data file updates started for GBPNZD | 2016-03-16 08:14:02
Opened cached Intraday file: C:\SierraChart\Data\GBPNZD.scid | 2016-03-16 08:14:02
Intraday chart data file opened for GBPNZD | 2016-03-16 08:14:02
HD Request # 57 | Downloading Intraday chart data for GBPUSD to the file GBPUSD.scid. Service: fxcm | 2016-03-16 08:14:02
HD Request # 57 | Download start Date-Time: 2016-03-16 08:12:33.000 | 2016-03-16 08:14:02
HD Request # 57 | Using server: ds5.sierracharts.com port 10149 | 2016-03-16 08:14:02
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-03-16 08:14:02
Socket (61) | Connected. | 2016-03-16 08:14:02
HD Request # 57 | Sending historical data logon request message. | 2016-03-16 08:14:02
HD Request # 57 | Requesting Intraday data. Start Date-Time: 2016-03-16 08:12:33. Record interval: 0. Symbol: GBPUSD | 2016-03-16 08:14:02
HD Request # 57 | Decompressing data. | 2016-03-16 08:14:02
HD Request # 57 | Receiving Intraday data for GBPUSD starting at 2016-03-16 08:12:33 | 2016-03-16 08:14:02
HD Request # 57 | Timestamp of first Intraday data file record written: 2016-03-16 08:12:33 | 2016-03-16 08:14:02
Socket (61) | Shutdown and closed. | 2016-03-16 08:14:02
HD Request # 57 | Received 110 records from 2016-03-16 08:12:33 to 2016-03-16 08:13:09 (36.0 seconds) and wrote 108 records for GBPUSD | 2016-03-16 08:14:02
Added 33 Time and Sales records to Intraday data file for GBPUSD after download. | 2016-03-16 08:14:02
HD Request # 57 | Intraday download COMPLETE for GBPUSD. Completion time: 2s. Unique request ID: 55 | 2016-03-16 08:14:02
Removed historical data download ID 55 | 2016-03-16 08:14:02
Real-time Intraday chart data file updates started for GBPUSD | 2016-03-16 08:14:02
Opened cached Intraday file: C:\SierraChart\Data\GBPUSD.scid | 2016-03-16 08:14:02
Intraday chart data file opened for GBPUSD | 2016-03-16 08:14:02
HD Request # 58 | Downloading Intraday chart data for NZDJPY to the file NZDJPY.scid. Service: fxcm | 2016-03-16 08:14:02
HD Request # 58 | Download start Date-Time: 2016-03-16 08:12:33.000 | 2016-03-16 08:14:02
HD Request # 58 | Using server: ds3.sierracharts.com port 10149 | 2016-03-16 08:14:02
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164. | 2016-03-16 08:14:02
Socket (62) | Connected. | 2016-03-16 08:14:07
HD Request # 58 | Sending historical data logon request message. | 2016-03-16 08:14:07
HD Request # 58 | Requesting Intraday data. Start Date-Time: 2016-03-16 08:12:33. Record interval: 0. Symbol: NZDJPY | 2016-03-16 08:14:07
HD Request # 58 | Decompressing data. | 2016-03-16 08:14:07
HD Request # 58 | Receiving Intraday data for NZDJPY starting at 2016-03-16 08:12:33 | 2016-03-16 08:14:07
HD Request # 58 | Timestamp of first Intraday data file record written: 2016-03-16 08:12:35 | 2016-03-16 08:14:07
Socket (62) | Shutdown and closed. | 2016-03-16 08:14:07
The network socket for historical data has been closed. | 2016-03-16 08:14:07
HD Request # 58 | Received 151 records from 2016-03-16 08:12:33 to 2016-03-16 08:13:11 (38.0 seconds) and wrote 150 records for NZDJPY | 2016-03-16 08:14:07
Added 22 Time and Sales records to Intraday data file for NZDJPY after download. | 2016-03-16 08:14:07
HD Request # 58 | Intraday download COMPLETE for NZDJPY. Completion time: 9s. Unique request ID: 56 | 2016-03-16 08:14:07
Removed historical data download ID 56 | 2016-03-16 08:14:07
Real-time Intraday chart data file updates started for NZDJPY | 2016-03-16 08:14:07
Opened cached Intraday file: C:\SierraChart\Data\NZDJPY.scid | 2016-03-16 08:14:07
Intraday chart data file opened for NZDJPY | 2016-03-16 08:14:07
[2016-03-16 16:54:33]
We can see the problem is opening of Chartbooks. Most likely the issue is reading intraday data files is slow.
Refer to these help topics:
https://www.sierrachart.com/index.php?page=doc/helpdetails30.html#h30.1
https://www.sierrachart.com/index.php?page=doc/helpdetails30.html#h30.8
https://www.sierrachart.com/index.php?page=doc/helpdetails30.html#h30.11
https://www.sierrachart.com/index.php?page=doc/helpdetails30.html#h30.12
What you describe is not normal. If your whole system is freezing, you have a system problem or a very inadequate system, hardware wise.
Sierra Chart definitely should not freeze the system. This is an indication of a system problem. A Chartbook should open in just a few seconds or less than a minute.
Date Time Of Last Edit: 2016-03-16 16:55:32
