Date/Time: Mon, 13 Jan 2025 08:42:30 +0000
Numbers bars study
View Count: 1338
[2016-03-15 22:28:27]
@sstfrederik - Posts: 405
I am working for a client on replicating some features of the numbers bars study. I am having a hard time finding out how to do certain things. As it is highly unlikely the source code can be made available on that study, can you tell me if I should at least be able to do the following with the available documented tools in ACSIL:
- divide the bar in three columns?
- Highlight a box?
- open and close markers - vertical bar on price - open to close boxes?
With subgraph DRAWSTYLE_FILLRECTTOP and BOTTOM I can draw the rectangle boxes, with the UseTool I can put text in them. It is unclear to me how to draw the highlight and a vertical bar. Any pointers would be appreciated.
Thanks in advance.
Date Time Of Last Edit: 2016-03-16 03:12:13
[2016-03-16 19:25:30]
This is not possible.
- Highlight a box?
There is no Draw Style for this but we might be able to add this.
We could create a Draw Style to create open to close boxes.
Date Time Of Last Edit: 2016-03-16 19:25:52
[2016-03-16 21:16:38]
That would be great if these drawstyles can be added.
Would it be possible to also have a drawstyle that draws a dot, triangle etc on the edge of a numbersbar box. A box being wider than a candle bar, width like the fillrecttop and bottom style. On the left and the right.
Any timeline in mind for these additions?
Many thanks for considering this.
Kind regards
Frederik
[2016-03-17 04:56:30]
We will be looking this over in about two weeks.
[2017-04-16 08:48:20]
Do you still have a need for what you are looking for that is not currently being met with existing Draw Styles?
[2017-04-16 19:55:31]
One that I would still like to see is the box top and bottom covering the whole nr bar body. Combination of the "right and left offset box top/bottom".
a top and bottom offset box.
Thanks.
Date Time Of Last Edit: 2017-04-16 19:57:26
[2017-04-18 04:16:27]
We will see about this.
