Date/Time: Tue, 04 Nov 2025 11:33:56 +0000
Issues with connections to CQG demo account
View Count: 2244
[2016-03-08 11:15:24]
User249425 - Posts: 1
do you have any information from CQG if they have any issues with their servers?
LOG:
CQG WebAPI | Connecting to market data server demoapi.cqg.com | 2016-03-08 06:11:24
CQG WebAPI | Connecting to websocket server. | 2016-03-08 06:11:24
CQG WebAPI websocket (0) | Resolved address demoapi.cqg.com to IP 208.48.16.32. | 2016-03-08 06:11:24
CQG WebAPI websocket (51) | Connected. | 2016-03-08 06:11:24
CQG WebAPI websocket (51) | Starting SSL 3/2 connection. | 2016-03-08 06:11:24
CQG WebAPI websocket (51) | Ignored Write event based on current socket state. | 2016-03-08 06:11:24
CQG WebAPI websocket (51) | SSL connection established. | 2016-03-08 06:11:24
CQG WebAPI | Opening websocket. | 2016-03-08 06:11:24
CQG WebAPI | Sending websocket handshake. | 2016-03-08 06:11:24
CQG WebAPI | Received websocket handshake acknowledgment. | 2016-03-08 06:11:25
CQG WebAPI | Web socket state is now open. | 2016-03-08 06:11:25
CQG WebAPI | Websocket connected. | 2016-03-08 06:11:25
CQG WebAPI | Sending market data logon message. | 2016-03-08 06:11:25
Service connection timed out. Will disconnect and retry. | 2016-03-08 06:12:24 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-08 06:12:24
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-08 06:12:24
CQG WebAPI websocket (51) | SSL shutdown indicates not able to send 'close notify'. | 2016-03-08 06:12:24
CQG WebAPI websocket (51) | SSL has been shut down. | 2016-03-08 06:12:24
CQG WebAPI websocket (51) | SSL object has been freed. SSL state is now disconnected. | 2016-03-08 06:12:24
CQG WebAPI websocket (51) | Shutdown and closed. | 2016-03-08 06:12:24
CQG WebAPI | Websocket closed. | 2016-03-08 06:12:24
CQG WebAPI | Disconnected. | 2016-03-08 06:12:24
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-08 06:12:24
It's fixed - short CQG outage
Date Time Of Last Edit: 2016-03-08 12:43:11
[2016-03-08 17:20:09]
User475503 - Posts: 1
I'm not able to connect to the CQG demo server as well.
Are there any issues/outages?
[2016-03-08 17:42:41]
We do not know. Only CQG would be aware of that.
Provide a copy of the Message Log by following these instructions:
http://www.sierrachart.com/index.php?l=PostingInformation.php#MessageLog
