Date/Time: Thu, 26 Dec 2024 12:18:32 +0000
Unknown Symbol
View Count: 1449
[2016-02-17 19:10:03] |
User389267 - Posts: 7 |
Hello, I am trying to start a Topstep Trader combine using CTS data. I believe that you will have to enable my CME feed for me. I get the unknown symbol error and no live feed. Thank you! |
[2016-02-17 19:27:50] |
Enabling the data feed is done by your broker/trading service. Not by us.
[2016-02-17 19:32:37] |
Hi, I am not sure you have to do that, but that is what a different thread in your support forum said. I am getting "Symbol is Unknown". Topstep said that I should contact you guys to figure it out. They made sure I was enabled on everything.
[2016-02-17 19:51:23] |
Provide a copy of the Message Log by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-17 19:54:31] |
Software version: 1366 | 2016-02-17 13:54:05 Uses New Spreadsheets | 2016-02-17 13:54:05 Usage end date: 2016-03-30 | 2016-02-17 13:54:05 Enabled for: Advanced Features. | 2016-02-17 13:54:05 Enabled for: Sierra Chart Historical Data Service. | 2016-02-17 13:54:05 Allow Support for Sierra Chart Data Feeds is enabled. | 2016-02-17 13:54:05 Current selected Data/Trading service: CTS T4 FIX | 2016-02-17 13:54:05 Chart Update Interval: 500 | 2016-02-17 13:54:05 Time Zone: -06:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-02-17 13:54:05 2016-02-17 13:54:10 Local computer time | 2016-02-17 13:54:05 2016-02-17 19:54:10 Local computer time in UTC | 2016-02-17 13:54:05 2016-02-17 13:54:10 Local computer time in SC Time Zone | 2016-02-17 13:54:05 2016-02-17 19:54:12 Server time in UTC | 2016-02-17 13:54:05 Local computer UTC time and Server UTC time difference: 4 seconds. | 2016-02-17 13:54:05 Program path: C:\SierraChart\ | 2016-02-17 13:54:05 Data Files path: C:\SierraChart\Data\ | 2016-02-17 13:54:05 OS Version Number: 6.2 | 2016-02-17 13:54:05 Locale Information: C | 2016-02-17 13:54:05 Checking for new symbol settings for cts | 2016-02-17 13:54:05 HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2016-02-17 13:54:05 HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-02-17 13:54:05 HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-02-17 13:54:05 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-02-17 13:54:05 Symbol settings are up-to-date for cts | 2016-02-17 13:54:11 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2016-02-17 13:54:15 CTS FIX - Firm: PTP | 2016-02-17 13:54:15 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2016-02-17 13:54:15 CTS FIX socket (4) | Connected. | 2016-02-17 13:54:15 CTS FIX socket (4) | Starting TLS 1.0 connection. | 2016-02-17 13:54:15 CTS FIX socket (4) | SSL connection established. | 2016-02-17 13:54:15 CTS FIX: Sending the Logon message. | 2016-02-17 13:54:15 CTS FIX | FIX version: 4.3.47.1 | 2016-02-17 13:54:16 CTS T4 FIX | Connected to data and trading server. | 2016-02-17 13:54:16 CTS FIX: Received Account List collateral report. | 2016-02-17 13:54:16 CTS FIX: Subscribing to account: Mr* | 2016-02-17 13:54:16 Supported exchange: CME_CO (SIM:COMEX Futures) | 2016-02-17 13:54:16 Supported exchange: CME_EqOp (SIM:CME Equity Options) | 2016-02-17 13:54:16 Supported exchange: CME_NYOp (SIM:NYMEX Options) | 2016-02-17 13:54:16 Supported exchange: CME_AgOp (SIM:CME Agricultural Options) | 2016-02-17 13:54:16 Supported exchange: CME_Eq (SIM:CME Equity Futures) | 2016-02-17 13:54:16 Supported exchange: CME_In (SIM:CME Interest Rate Futures) | 2016-02-17 13:54:16 Supported exchange: CME_C (SIM:CBOT Commodity Futures) | 2016-02-17 13:54:16 Supported exchange: CME_KOp (SIM:KCBT Options) | 2016-02-17 13:54:16 Supported exchange: CME_F (SIM:CBOT Financial Futures) | 2016-02-17 13:54:16 Supported exchange: CME_E (SIM:CBOT Equity Futures) | 2016-02-17 13:54:16 Supported exchange: CME_COp (SIM:CBOT Commodity Options) | 2016-02-17 13:54:16 Supported exchange: CME_K (SIM:KCBT Futures) | 2016-02-17 13:54:16 Supported exchange: CME_EOp (SIM:CBOT Equity Options) | 2016-02-17 13:54:16 Supported exchange: CME_NY (SIM:NYMEX Futures) | 2016-02-17 13:54:16 Supported exchange: CME_Fo (SIM:CME Foreign Exchange Futures) | 2016-02-17 13:54:16 Supported exchange: CME_Ag (SIM:CME Agricultural Futures) | 2016-02-17 13:54:16 Supported exchange: CME_FoOp (SIM:CME Foreign Exchange Options) | 2016-02-17 13:54:16 Supported exchange: CME_FOp (SIM:CBOT Financial Options) | 2016-02-17 13:54:16 Supported exchange: CME_InOp (SIM:CME Interest Rate Options) | 2016-02-17 13:54:16 Supported exchange: CME_COOp (SIM:COMEX Options) | 2016-02-17 13:54:16 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-02-17 13:54:16 HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-02-17 13:54:16 HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-02-17 13:54:16 Using Bid/Ask average for last trade price for USDCAD | 2016-02-17 13:54:17 SC DTC Data | Starting real-time market data updates for: USDCAD. ID: 1 | 2016-02-17 13:54:17 SC DTC Data | Connecting to the server ds5.sierracharts.com. Port 443 | 2016-02-17 13:54:17 CTS FIX: Received 'Account Update/Balance Data' collateral report. | 2016-02-17 13:54:17 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2016-02-17 13:54:17 Socket (5) | Connected. | 2016-02-17 13:54:17 SC DTC Data | Connected to server. | 2016-02-17 13:54:17 SC DTC Data | Sending Encoding Request to server | 2016-02-17 13:54:17 SC DTC Data | Setting DTC Encoding to Binary VLS | 2016-02-17 13:54:17 SC DTC Data | Sending logon request message. | 2016-02-17 13:54:17 SC DTC Data | Received logon response. | 2016-02-17 13:54:17 SC DTC Data | Server Name: SC Real-Time Server. | 2016-02-17 13:54:17 SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2016-02-17 13:54:17 SC DTC Data | Successfully connected. | 2016-02-17 13:54:17 SC DTC Data | Restarting real-time data updates for symbol: USDCAD | 2016-02-17 13:54:17 |
[2016-02-17 20:10:39] |
This is the log after I try to open my chartbook Software version: 1366 | 2016-02-17 13:54:05 Uses New Spreadsheets | 2016-02-17 13:54:05 Usage end date: 2016-03-30 | 2016-02-17 13:54:05 Enabled for: Advanced Features. | 2016-02-17 13:54:05 Enabled for: Sierra Chart Historical Data Service. | 2016-02-17 13:54:05 Allow Support for Sierra Chart Data Feeds is enabled. | 2016-02-17 13:54:05 Current selected Data/Trading service: CTS T4 FIX | 2016-02-17 13:54:05 Chart Update Interval: 500 | 2016-02-17 13:54:05 Time Zone: -06:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-02-17 13:54:05 2016-02-17 13:54:10 Local computer time | 2016-02-17 13:54:05 2016-02-17 19:54:10 Local computer time in UTC | 2016-02-17 13:54:05 2016-02-17 13:54:10 Local computer time in SC Time Zone | 2016-02-17 13:54:05 2016-02-17 19:54:12 Server time in UTC | 2016-02-17 13:54:05 Local computer UTC time and Server UTC time difference: 4 seconds. | 2016-02-17 13:54:05 Program path: C:\SierraChart\ | 2016-02-17 13:54:05 Data Files path: C:\SierraChart\Data\ | 2016-02-17 13:54:05 OS Version Number: 6.2 | 2016-02-17 13:54:05 Locale Information: C | 2016-02-17 13:54:05 Checking for new symbol settings for cts | 2016-02-17 13:54:05 HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2016-02-17 13:54:05 HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-02-17 13:54:05 HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-02-17 13:54:05 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-02-17 13:54:05 Symbol settings are up-to-date for cts | 2016-02-17 13:54:11 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2016-02-17 13:54:15 CTS FIX - Firm: PTP | 2016-02-17 13:54:15 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2016-02-17 13:54:15 CTS FIX socket (4) | Connected. | 2016-02-17 13:54:15 CTS FIX socket (4) | Starting TLS 1.0 connection. | 2016-02-17 13:54:15 CTS FIX socket (4) | SSL connection established. | 2016-02-17 13:54:15 CTS FIX: Sending the Logon message. | 2016-02-17 13:54:15 CTS FIX | FIX version: 4.3.47.1 | 2016-02-17 13:54:16 CTS T4 FIX | Connected to data and trading server. | 2016-02-17 13:54:16 CTS FIX: Received Account List collateral report. | 2016-02-17 13:54:16 CTS FIX: Subscribing to account: Mr* | 2016-02-17 13:54:16 Supported exchange: CME_CO (SIM:COMEX Futures) | 2016-02-17 13:54:16 Supported exchange: CME_EqOp (SIM:CME Equity Options) | 2016-02-17 13:54:16 Supported exchange: CME_NYOp (SIM:NYMEX Options) | 2016-02-17 13:54:16 Supported exchange: CME_AgOp (SIM:CME Agricultural Options) | 2016-02-17 13:54:16 Supported exchange: CME_Eq (SIM:CME Equity Futures) | 2016-02-17 13:54:16 Supported exchange: CME_In (SIM:CME Interest Rate Futures) | 2016-02-17 13:54:16 Supported exchange: CME_C (SIM:CBOT Commodity Futures) | 2016-02-17 13:54:16 Supported exchange: CME_KOp (SIM:KCBT Options) | 2016-02-17 13:54:16 Supported exchange: CME_F (SIM:CBOT Financial Futures) | 2016-02-17 13:54:16 Supported exchange: CME_E (SIM:CBOT Equity Futures) | 2016-02-17 13:54:16 Supported exchange: CME_COp (SIM:CBOT Commodity Options) | 2016-02-17 13:54:16 Supported exchange: CME_K (SIM:KCBT Futures) | 2016-02-17 13:54:16 Supported exchange: CME_EOp (SIM:CBOT Equity Options) | 2016-02-17 13:54:16 Supported exchange: CME_NY (SIM:NYMEX Futures) | 2016-02-17 13:54:16 Supported exchange: CME_Fo (SIM:CME Foreign Exchange Futures) | 2016-02-17 13:54:16 Supported exchange: CME_Ag (SIM:CME Agricultural Futures) | 2016-02-17 13:54:16 Supported exchange: CME_FoOp (SIM:CME Foreign Exchange Options) | 2016-02-17 13:54:16 Supported exchange: CME_FOp (SIM:CBOT Financial Options) | 2016-02-17 13:54:16 Supported exchange: CME_InOp (SIM:CME Interest Rate Options) | 2016-02-17 13:54:16 Supported exchange: CME_COOp (SIM:COMEX Options) | 2016-02-17 13:54:16 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-02-17 13:54:16 HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-02-17 13:54:16 HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-02-17 13:54:16 Using Bid/Ask average for last trade price for USDCAD | 2016-02-17 13:54:17 SC DTC Data | Starting real-time market data updates for: USDCAD. ID: 1 | 2016-02-17 13:54:17 SC DTC Data | Connecting to the server ds5.sierracharts.com. Port 443 | 2016-02-17 13:54:17 CTS FIX: Received 'Account Update/Balance Data' collateral report. | 2016-02-17 13:54:17 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2016-02-17 13:54:17 Socket (5) | Connected. | 2016-02-17 13:54:17 SC DTC Data | Connected to server. | 2016-02-17 13:54:17 SC DTC Data | Sending Encoding Request to server | 2016-02-17 13:54:17 SC DTC Data | Setting DTC Encoding to Binary VLS | 2016-02-17 13:54:17 SC DTC Data | Sending logon request message. | 2016-02-17 13:54:17 SC DTC Data | Received logon response. | 2016-02-17 13:54:17 SC DTC Data | Server Name: SC Real-Time Server. | 2016-02-17 13:54:17 SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2016-02-17 13:54:17 SC DTC Data | Successfully connected. | 2016-02-17 13:54:17 SC DTC Data | Restarting real-time data updates for symbol: USDCAD | 2016-02-17 13:54:17 CTS FIX: Requesting Open Orders for account: Mr* | 2016-02-17 13:54:21 CTS FIX: Received Account List collateral report. | 2016-02-17 13:54:21 CTS FIX: Received Account List collateral report. | 2016-02-17 13:54:31 CTS T4 FIX | Using primary service for historical data. | 2016-02-17 14:10:01 CTS T4 FIX | Using primary service for historical data. | 2016-02-17 14:10:01 CTS T4 FIX | Using primary service for historical data. | 2016-02-17 14:10:01 CTS T4 FIX | Using primary service for historical data. | 2016-02-17 14:10:01 CTS T4 FIX | Using primary service for historical data. | 2016-02-17 14:10:01 CTS T4 FIX | Using primary service for historical data. | 2016-02-17 14:10:01 CTS T4 FIX | Using primary service for historical data. | 2016-02-17 14:10:01 CTS T4 FIX | Using primary service for historical data. | 2016-02-17 14:10:01 CTS T4 FIX | Using primary service for historical data. | 2016-02-17 14:10:01 CTS T4 FIX | Using primary service for historical data. | 2016-02-17 14:10:01 CTS T4 FIX | Using primary service for historical data. | 2016-02-17 14:10:01 Chart #11 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:01 Chart #11 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:01 CTS T4 FIX | Using primary service for historical data. | 2016-02-17 14:10:01 Chart #12 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:01 Chart #12 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:01 CTS T4 FIX | Using primary service for historical data. | 2016-02-17 14:10:01 Chart #13 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:01 Chart #13 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:01 CTS T4 FIX | Using primary service for historical data. | 2016-02-17 14:10:01 Chart #14 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:01 Chart #14 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:01 CTS T4 FIX | Using primary service for historical data. | 2016-02-17 14:10:01 Chart #15 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:01 Chart #15 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:01 Chart #16 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:01 Chart #16 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:01 Chart #17 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:01 Chart #17 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:01 CTS T4 FIX | Starting real-time market data updates for: F.US.EPH16. ID: 2 | 2016-02-17 14:10:02 CTS T4 FIX | Using primary service for historical data. | 2016-02-17 14:10:02 Intraday data recording state for symbol F.US.EPH16 is set to download 'Pending'. | 2016-02-17 14:10:02 HD Request # 2 | Downloading Intraday chart data for F.US.EPH16 to the file F.US.EPH16.scid. Service: cts | 2016-02-17 14:10:02 HD Request # 2 | Download start Date-Time: 2016-02-17 09:10:37.000 | 2016-02-17 14:10:02 CTS FIX Historical Data - Connecting to Historical data server fix-chart-sim.t4login.com:10443 | 2016-02-17 14:10:02 CTS T4 FIX | Starting real-time market data updates for: F.US.CLEH16. ID: 3 | 2016-02-17 14:10:02 CTS T4 FIX | Using primary service for historical data. | 2016-02-17 14:10:02 Intraday data recording state for symbol F.US.CLEH16 is set to download 'Pending'. | 2016-02-17 14:10:02 Symbol Error - F.US.EPH16 is unknown, unavailable, or improperly formatted. CTS FIX: Received market data reject: (3) Exchange is not allowed for User | 2016-02-17 14:10:02 Symbol Error - F.US.CLEH16 is unknown, unavailable, or improperly formatted. CTS FIX: Received market data reject: (3) Exchange is not allowed for User | 2016-02-17 14:10:02 CTS FIX Historical Data socket (0) | Resolved address fix-chart-sim.t4login.com to IP 74.201.6.229 | 2016-02-17 14:10:02 CTS T4 FIX | Starting real-time market data updates for: F.US.TFEH16. ID: 4 | 2016-02-17 14:10:02 CTS T4 FIX | Using primary service for historical data. | 2016-02-17 14:10:02 Intraday data recording state for symbol F.US.TFEH16 is set to download 'Pending'. | 2016-02-17 14:10:02 Chart #1 has tagged chart #2 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:02 Chart #1 has tagged chart #2 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:02 CTS FIX Historical Data socket (13) | Connected. | 2016-02-17 14:10:02 CTS FIX Historical Data socket (13) | Starting TLS 1.0 connection. | 2016-02-17 14:10:02 CTS T4 FIX | Starting real-time market data updates for: F.US.ENQH16. ID: 5 | 2016-02-17 14:10:02 CTS T4 FIX | Using primary service for historical data. | 2016-02-17 14:10:02 Intraday data recording state for symbol F.US.ENQH16 is set to download 'Pending'. | 2016-02-17 14:10:02 CTS T4 FIX | Starting real-time market data updates for: F.US.YMH16. ID: 6 | 2016-02-17 14:10:02 CTS T4 FIX | Using primary service for historical data. | 2016-02-17 14:10:02 Intraday data recording state for symbol F.US.YMH16 is set to download 'Pending'. | 2016-02-17 14:10:02 CTS T4 FIX | Using primary service for historical data. | 2016-02-17 14:10:02 Symbol Error - F.US.TFEH16 is unknown, unavailable, or improperly formatted. CTS FIX: Received market data reject: (3) Exchange is not allowed for User | 2016-02-17 14:10:02 CTS T4 FIX | Using primary service for historical data. | 2016-02-17 14:10:02 CTS T4 FIX | Using primary service for historical data. | 2016-02-17 14:10:02 CTS T4 FIX | Starting real-time market data updates for: F.US.TYAH16. ID: 7 | 2016-02-17 14:10:02 F.US.EPH16 Daily #10 | Performing a full recalculation because it has been tagged. Chartbook: SPOO.cht | 2016-02-17 14:10:02 Symbol Error - F.US.YMH16 is unknown, unavailable, or improperly formatted. CTS FIX: Received market data reject: (3) Exchange is not allowed for User | 2016-02-17 14:10:02 CTS T4 FIX | Using primary service for historical data. | 2016-02-17 14:10:02 CTS T4 FIX | Using primary service for historical data. | 2016-02-17 14:10:02 CTS T4 FIX | Starting real-time market data updates for: F.US.GCEJ16. ID: 8 | 2016-02-17 14:10:02 CTS T4 FIX | Using primary service for historical data. | 2016-02-17 14:10:02 CTS FIX Historical Data socket (13) | SSL connection established. | 2016-02-17 14:10:02 Symbol Error - F.US.TYAH16 is unknown, unavailable, or improperly formatted. CTS FIX: Received market data reject: (3) Exchange is not allowed for User | 2016-02-17 14:10:02 CTS T4 FIX | Using primary service for historical data. | 2016-02-17 14:10:02 CTS T4 FIX | Starting real-time market data updates for: F.US.DXEH16. ID: 9 | 2016-02-17 14:10:02 CTS T4 FIX | Using primary service for historical data. | 2016-02-17 14:10:02 F.US.EPH16 20000 Volume #2 | Performing a full recalculation because it has been tagged. Chartbook: SPOO.cht | 2016-02-17 14:10:02 Symbol Error - F.US.GCEJ16 is unknown, unavailable, or improperly formatted. CTS FIX: Received market data reject: (3) Exchange is not allowed for User | 2016-02-17 14:10:02 Using Bid/Ask average for last trade price for EURUSD | 2016-02-17 14:10:02 SC DTC Data | Starting real-time market data updates for: EURUSD. ID: 10 | 2016-02-17 14:10:02 HD Request # 3 | Downloading Historical Daily chart data for EURUSD. Starting date: 2016-02-16. Service: fxcm | 2016-02-17 14:10:02 HD Request # 3 | Using server: ds4.sierracharts.com port 10149 | 2016-02-17 14:10:02 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2016-02-17 14:10:03 Using Bid/Ask average for last trade price for USDJPY | 2016-02-17 14:10:03 SC DTC Data | Starting real-time market data updates for: USDJPY. ID: 11 | 2016-02-17 14:10:03 Symbol Error - F.US.DXEH16 is unknown, unavailable, or improperly formatted. CTS FIX: Received market data reject: (3) Exchange is not allowed for User | 2016-02-17 14:10:03 Socket (14) | Connected. | 2016-02-17 14:10:03 HD Request # 3 | Sending historical data logon request message. | 2016-02-17 14:10:03 CTS FIX Historical Data: Sending the Logon message. | 2016-02-17 14:10:03 CTS FIX Historical Data: Connected to Historical data server. | 2016-02-17 14:10:03 HD Request # 2 | Requesting historical Second data for F.US.EPH16 from 2016-02-17 00:00:00 to 2016-02-17 00:00:00 (US Central Time). | 2016-02-17 14:10:03 HD Request # 2 | Total records received: 0 | 2016-02-17 14:10:03 HD Request # 2 | Requesting historical Second data for F.US.EPH16 from 2016-02-18 00:00:00 to 2016-02-18 00:00:00 (US Central Time). | 2016-02-17 14:10:03 HD Request # 2 | Total records received: 0 | 2016-02-17 14:10:03 HD Request # 2 | Requesting historical Second data for F.US.EPH16 from 2016-02-19 00:00:00 to 2016-02-19 00:00:00 (US Central Time). | 2016-02-17 14:10:03 HD Request # 2 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.EPH16 | 2016-02-17 14:10:03 HD Request # 2 | Intraday download COMPLETE for F.US.EPH16. Completion time: 0s. Unique request ID: 1 | 2016-02-17 14:10:03 Removed historical data download ID 1 | 2016-02-17 14:10:03 Real-time Intraday chart data file updates started for F.US.EPH16 | 2016-02-17 14:10:03 Intraday chart data file opened for F.US.EPH16 | 2016-02-17 14:10:03 HD Request # 4 | Downloading Intraday chart data for F.US.CLEH16 to the file F.US.CLEH16.scid. Service: cts | 2016-02-17 14:10:03 HD Request # 4 | Download start Date-Time: 2016-02-17 09:10:37.000 | 2016-02-17 14:10:03 HD Request # 4 | Requesting historical Second data for F.US.CLEH16 from 2016-02-17 00:00:00 to 2016-02-17 00:00:00 (US Central Time). | 2016-02-17 14:10:03 Chart #1 has tagged chart #2 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:03 HD Request # 4 | Total records received: 0 | 2016-02-17 14:10:03 HD Request # 4 | Requesting historical Second data for F.US.CLEH16 from 2016-02-18 00:00:00 to 2016-02-18 00:00:00 (US Central Time). | 2016-02-17 14:10:03 HD Request # 4 | Total records received: 0 | 2016-02-17 14:10:03 HD Request # 4 | Requesting historical Second data for F.US.CLEH16 from 2016-02-19 00:00:00 to 2016-02-19 00:00:00 (US Central Time). | 2016-02-17 14:10:03 HD Request # 4 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.CLEH16 | 2016-02-17 14:10:03 HD Request # 3 | Requesting historical Daily data starting at 2016-02-16. | 2016-02-17 14:10:03 HD Request # 4 | Intraday download COMPLETE for F.US.CLEH16. Completion time: 0s. Unique request ID: 2 | 2016-02-17 14:10:03 Removed historical data download ID 2 | 2016-02-17 14:10:03 Real-time Intraday chart data file updates started for F.US.CLEH16 | 2016-02-17 14:10:03 Intraday chart data file opened for F.US.CLEH16 | 2016-02-17 14:10:03 HD Request # 5 | Downloading Intraday chart data for F.US.TFEH16 to the file F.US.TFEH16.scid. Service: cts | 2016-02-17 14:10:03 HD Request # 5 | Download start Date-Time: 2016-02-17 09:10:36.000 | 2016-02-17 14:10:03 HD Request # 5 | Requesting historical Second data for F.US.TFEH16 from 2016-02-17 00:00:00 to 2016-02-17 00:00:00 (US Central Time). | 2016-02-17 14:10:03 F.US.EPH16 20000 Volume #2 | Performing a full recalculation because it has been tagged. Chartbook: SPOO.cht | 2016-02-17 14:10:03 HD Request # 3 | Decompressing data. | 2016-02-17 14:10:03 HD Request # 3 | Receiving historical Daily data for EURUSD starting at 2016-02-16 | 2016-02-17 14:10:03 Writing historical Daily data for EURUSD to the file EURUSD.dly | 2016-02-17 14:10:03 HD Request # 5 | Total records received: 0 | 2016-02-17 14:10:03 HD Request # 5 | Requesting historical Second data for F.US.TFEH16 from 2016-02-18 00:00:00 to 2016-02-18 00:00:00 (US Central Time). | 2016-02-17 14:10:03 HD Request # 5 | Total records received: 0 | 2016-02-17 14:10:03 HD Request # 5 | Requesting historical Second data for F.US.TFEH16 from 2016-02-19 00:00:00 to 2016-02-19 00:00:00 (US Central Time). | 2016-02-17 14:10:03 Socket (14) | Shutdown and closed. | 2016-02-17 14:10:03 The network socket for historical data has been closed. | 2016-02-17 14:10:03 HD Request # 3 | Received 2 records from 2016-02-16 00:00:00 to 2016-02-17 00:00:00 (2.0 days) and wrote 2 records for EURUSD | 2016-02-17 14:10:03 HD Request # 3 | Daily download COMPLETE for EURUSD. Completion time: 0s. Unique request ID: 14 | 2016-02-17 14:10:03 Removed historical data download ID 14 | 2016-02-17 14:10:03 HD Request # 6 | Downloading Historical Daily chart data for USDJPY. Starting date: 2016-02-16. Service: fxcm | 2016-02-17 14:10:03 HD Request # 6 | Using server: ds3.sierracharts.com port 10149 | 2016-02-17 14:10:03 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2016-02-17 14:10:03 HD Request # 5 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.TFEH16 | 2016-02-17 14:10:03 HD Request # 5 | Intraday download COMPLETE for F.US.TFEH16. Completion time: 0s. Unique request ID: 3 | 2016-02-17 14:10:03 Removed historical data download ID 3 | 2016-02-17 14:10:03 Real-time Intraday chart data file updates started for F.US.TFEH16 | 2016-02-17 14:10:03 Intraday chart data file opened for F.US.TFEH16 | 2016-02-17 14:10:03 HD Request # 7 | Downloading Intraday chart data for F.US.ENQH16 to the file F.US.ENQH16.scid. Service: cts | 2016-02-17 14:10:03 HD Request # 7 | Download start Date-Time: 2016-02-17 09:10:37.000 | 2016-02-17 14:10:03 HD Request # 7 | Requesting historical Second data for F.US.ENQH16 from 2016-02-17 00:00:00 to 2016-02-17 00:00:00 (US Central Time). | 2016-02-17 14:10:03 Socket (15) | Connected. | 2016-02-17 14:10:03 HD Request # 6 | Sending historical data logon request message. | 2016-02-17 14:10:03 HD Request # 7 | Total records received: 0 | 2016-02-17 14:10:03 HD Request # 7 | Requesting historical Second data for F.US.ENQH16 from 2016-02-18 00:00:00 to 2016-02-18 00:00:00 (US Central Time). | 2016-02-17 14:10:03 HD Request # 6 | Requesting historical Daily data starting at 2016-02-16. | 2016-02-17 14:10:03 HD Request # 6 | Decompressing data. | 2016-02-17 14:10:03 HD Request # 7 | Total records received: 0 | 2016-02-17 14:10:03 HD Request # 7 | Requesting historical Second data for F.US.ENQH16 from 2016-02-19 00:00:00 to 2016-02-19 00:00:00 (US Central Time). | 2016-02-17 14:10:03 HD Request # 6 | Receiving historical Daily data for USDJPY starting at 2016-02-16 | 2016-02-17 14:10:03 Writing historical Daily data for USDJPY to the file USDJPY.dly | 2016-02-17 14:10:03 HD Request # 7 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.ENQH16 | 2016-02-17 14:10:03 HD Request # 7 | Intraday download COMPLETE for F.US.ENQH16. Completion time: 0s. Unique request ID: 4 | 2016-02-17 14:10:03 Removed historical data download ID 4 | 2016-02-17 14:10:03 Real-time Intraday chart data file updates started for F.US.ENQH16 | 2016-02-17 14:10:03 Intraday chart data file opened for F.US.ENQH16 | 2016-02-17 14:10:03 HD Request # 8 | Downloading Intraday chart data for F.US.YMH16 to the file F.US.YMH16.scid. Service: cts | 2016-02-17 14:10:03 HD Request # 8 | Download start Date-Time: 2016-02-17 09:10:37.000 | 2016-02-17 14:10:03 HD Request # 8 | Requesting historical Second data for F.US.YMH16 from 2016-02-17 00:00:00 to 2016-02-17 00:00:00 (US Central Time). | 2016-02-17 14:10:03 Socket (15) | Shutdown and closed. | 2016-02-17 14:10:03 The network socket for historical data has been closed. | 2016-02-17 14:10:03 HD Request # 6 | Received 2 records from 2016-02-16 00:00:00 to 2016-02-17 00:00:00 (2.0 days) and wrote 2 records for USDJPY | 2016-02-17 14:10:03 HD Request # 6 | Daily download COMPLETE for USDJPY. Completion time: 0s. Unique request ID: 15 | 2016-02-17 14:10:03 Removed historical data download ID 15 | 2016-02-17 14:10:03 HD Request # 8 | Total records received: 0 | 2016-02-17 14:10:03 HD Request # 8 | Requesting historical Second data for F.US.YMH16 from 2016-02-18 00:00:00 to 2016-02-18 00:00:00 (US Central Time). | 2016-02-17 14:10:03 HD Request # 8 | Total records received: 0 | 2016-02-17 14:10:03 HD Request # 8 | Requesting historical Second data for F.US.YMH16 from 2016-02-19 00:00:00 to 2016-02-19 00:00:00 (US Central Time). | 2016-02-17 14:10:03 HD Request # 8 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.YMH16 | 2016-02-17 14:10:03 HD Request # 8 | Intraday download COMPLETE for F.US.YMH16. Completion time: 0s. Unique request ID: 5 | 2016-02-17 14:10:03 Removed historical data download ID 5 | 2016-02-17 14:10:03 Real-time Intraday chart data file updates started for F.US.YMH16 | 2016-02-17 14:10:03 Intraday chart data file opened for F.US.YMH16 | 2016-02-17 14:10:03 HD Request # 9 | Downloading Historical Daily chart data for F.US.EPH16. Starting date: 2016-02-16. Service: cts | 2016-02-17 14:10:03 HD Request # 9 | Requesting historical Daily data for F.US.EPH16 from date 2016-02-16 to date 2016-02-18 | 2016-02-17 14:10:03 EURUSD [M] Daily #16 | Reloading chart. | 2016-02-17 14:10:03 Chart #16 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:03 Chart #16 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:03 Chart #16 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:03 HD Request # 9 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.EPH16 | 2016-02-17 14:10:03 HD Request # 9 | Daily download COMPLETE for F.US.EPH16. Completion time: 0s. Unique request ID: 6 | 2016-02-17 14:10:03 Removed historical data download ID 6 | 2016-02-17 14:10:03 HD Request # 10 | Downloading Historical Daily chart data for F.US.YMH16. Starting date: 2016-02-16. Service: cts | 2016-02-17 14:10:03 HD Request # 10 | Requesting historical Daily data for F.US.YMH16 from date 2016-02-16 to date 2016-02-18 | 2016-02-17 14:10:03 HD Request # 10 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.YMH16 | 2016-02-17 14:10:04 HD Request # 10 | Daily download COMPLETE for F.US.YMH16. Completion time: 0s. Unique request ID: 7 | 2016-02-17 14:10:04 Removed historical data download ID 7 | 2016-02-17 14:10:04 HD Request # 11 | Downloading Historical Daily chart data for F.US.TYAH16. Starting date: 2016-02-16. Service: cts | 2016-02-17 14:10:04 HD Request # 11 | Requesting historical Daily data for F.US.TYAH16 from date 2016-02-16 to date 2016-02-18 | 2016-02-17 14:10:04 USDJPY [M] Daily #17 | Reloading chart. | 2016-02-17 14:10:04 Chart #17 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:04 Chart #17 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:04 Chart #17 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:04 HD Request # 11 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.TYAH16 | 2016-02-17 14:10:04 HD Request # 11 | Daily download COMPLETE for F.US.TYAH16. Completion time: 0s. Unique request ID: 8 | 2016-02-17 14:10:04 Removed historical data download ID 8 | 2016-02-17 14:10:04 HD Request # 12 | Downloading Historical Daily chart data for F.US.TFEH16. Starting date: 2016-02-16. Service: cts | 2016-02-17 14:10:04 HD Request # 12 | Requesting historical Daily data for F.US.TFEH16 from date 2016-02-16 to date 2016-02-18 | 2016-02-17 14:10:04 F.US.EPH16 Daily #7 | Reloading chart. | 2016-02-17 14:10:04 CTS T4 FIX | Using primary service for historical data. | 2016-02-17 14:10:04 Chart #7 has tagged chart #1 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:04 Chart #7 has tagged chart #2 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:04 Chart #7 has tagged chart #1 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:04 Chart #7 has tagged chart #2 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:04 Chart #7 has tagged chart #1 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:04 Chart #7 has tagged chart #2 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:04 HD Request # 12 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.TFEH16 | 2016-02-17 14:10:04 HD Request # 12 | Daily download COMPLETE for F.US.TFEH16. Completion time: 1s. Unique request ID: 9 | 2016-02-17 14:10:04 Removed historical data download ID 9 | 2016-02-17 14:10:04 HD Request # 13 | Downloading Historical Daily chart data for F.US.GCEJ16. Starting date: 2016-02-16. Service: cts | 2016-02-17 14:10:04 HD Request # 13 | Requesting historical Daily data for F.US.GCEJ16 from date 2016-02-16 to date 2016-02-18 | 2016-02-17 14:10:04 F.US.YMH16 Daily #8 | Reloading chart. | 2016-02-17 14:10:04 CTS T4 FIX | Using primary service for historical data. | 2016-02-17 14:10:04 Chart #8 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:04 Chart #8 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:04 Chart #8 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:04 F.US.TYAH16 Daily #9 | Reloading chart. | 2016-02-17 14:10:04 CTS T4 FIX | Using primary service for historical data. | 2016-02-17 14:10:04 Chart #9 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:04 Chart #9 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:04 Chart #9 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:04 F.US.EPH16 Daily #10 | Reloading chart. | 2016-02-17 14:10:04 CTS T4 FIX | Using primary service for historical data. | 2016-02-17 14:10:04 HD Request # 13 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.GCEJ16 | 2016-02-17 14:10:04 HD Request # 13 | Daily download COMPLETE for F.US.GCEJ16. Completion time: 0s. Unique request ID: 10 | 2016-02-17 14:10:04 Removed historical data download ID 10 | 2016-02-17 14:10:04 HD Request # 14 | Downloading Historical Daily chart data for F.US.ENQH16. Starting date: 2016-02-16. Service: cts | 2016-02-17 14:10:04 HD Request # 14 | Requesting historical Daily data for F.US.ENQH16 from date 2016-02-16 to date 2016-02-18 | 2016-02-17 14:10:04 F.US.EPH16 250000 Volume #1 | Performing a full recalculation because it has been tagged. Chartbook: SPOO.cht | 2016-02-17 14:10:04 Chart #1 has tagged chart #2 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:04 F.US.TFEH16 Daily #11 | Reloading chart. | 2016-02-17 14:10:04 CTS T4 FIX | Using primary service for historical data. | 2016-02-17 14:10:04 Chart #11 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:04 Chart #11 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:04 Chart #11 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:04 HD Request # 14 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.ENQH16 | 2016-02-17 14:10:04 HD Request # 14 | Daily download COMPLETE for F.US.ENQH16. Completion time: 0s. Unique request ID: 11 | 2016-02-17 14:10:04 Removed historical data download ID 11 | 2016-02-17 14:10:04 HD Request # 15 | Downloading Historical Daily chart data for F.US.DXEH16. Starting date: 2016-02-16. Service: cts | 2016-02-17 14:10:04 HD Request # 15 | Requesting historical Daily data for F.US.DXEH16 from date 2016-02-16 to date 2016-02-18 | 2016-02-17 14:10:04 F.US.GCEJ16 Daily #12 | Reloading chart. | 2016-02-17 14:10:04 CTS T4 FIX | Using primary service for historical data. | 2016-02-17 14:10:04 Chart #12 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:04 Chart #12 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:04 Chart #12 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:04 F.US.ENQH16 Daily #13 | Reloading chart. | 2016-02-17 14:10:04 CTS T4 FIX | Using primary service for historical data. | 2016-02-17 14:10:04 Chart #13 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:04 Chart #13 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:04 Chart #13 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:04 HD Request # 15 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.DXEH16 | 2016-02-17 14:10:04 HD Request # 15 | Daily download COMPLETE for F.US.DXEH16. Completion time: 0s. Unique request ID: 12 | 2016-02-17 14:10:04 Removed historical data download ID 12 | 2016-02-17 14:10:04 HD Request # 16 | Downloading Historical Daily chart data for F.US.CLEH16. Starting date: 2016-02-16. Service: cts | 2016-02-17 14:10:04 HD Request # 16 | Requesting historical Daily data for F.US.CLEH16 from date 2016-02-16 to date 2016-02-18 | 2016-02-17 14:10:04 HD Request # 16 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.CLEH16 | 2016-02-17 14:10:04 HD Request # 16 | Daily download COMPLETE for F.US.CLEH16. Completion time: 0s. Unique request ID: 13 | 2016-02-17 14:10:04 Removed historical data download ID 13 | 2016-02-17 14:10:04 F.US.EPH16 20000 Volume #2 | Performing a full recalculation because it has been tagged. Chartbook: SPOO.cht | 2016-02-17 14:10:04 USDJPY [M] Daily #17 | Reloading chart. | 2016-02-17 14:10:04 Chart #17 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:04 Chart #17 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:04 F.US.EPH16 Daily #10 | Performing a full recalculation because it has been tagged. Chartbook: SPOO.cht | 2016-02-17 14:10:04 F.US.DXEH16 Daily #14 | Reloading chart. | 2016-02-17 14:10:04 CTS T4 FIX | Using primary service for historical data. | 2016-02-17 14:10:04 Chart #14 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:04 Chart #14 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:04 Chart #14 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:04 F.US.CLEH16 Daily #15 | Reloading chart. | 2016-02-17 14:10:04 CTS T4 FIX | Using primary service for historical data. | 2016-02-17 14:10:04 Chart #15 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:04 Chart #15 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:04 Chart #15 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:04 F.US.EPH16 Daily #10 | Performing a full recalculation because it has been tagged. Chartbook: SPOO.cht | 2016-02-17 14:10:05 EURUSD [M] Daily #16 | Reloading chart. | 2016-02-17 14:10:07 Chart #16 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:07 Chart #16 has tagged chart #10 for full recalculation. Chartbook: SPOO.cht | 2016-02-17 14:10:07 F.US.EPH16 Daily #10 | Performing a full recalculation because it has been tagged. Chartbook: SPOO.cht | 2016-02-17 14:10:08 |
[2016-02-17 20:32:16] |
The problem is you are not using CTS symbols. You are using CQG symbols: Symbol Error - F.US.EPH16 is unknown, unavailable, or improperly formatted. CTS FIX: Received market data reject: (3) Exchange is not allowed for User | 2016-02-17 14:10:02 Follow the instructions here: https://www.sierrachart.com/index.php?l=doc/helpdetails1.php#h1.3 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
