Date/Time: Mon, 28 Oct 2024 11:16:57 +0000
Notice: NASDAQ and other Equities Data Feed Interruption Morning of 2016-02-08
View Count: 884
[2016-02-09 02:03:35] |
For the first hour starting at 9:30 AM US Eastern time on 2016-02-08, the NASDAQ stocks part of US equities data feed was not transmitting any data. Also the BATS data feed was affected as well. Historical data was not affected. Only real-time data. We have not had an issue like this previously and the problem has been discovered this evening and we are working to resolve it. Basically it was a timing issue affecting a sequence of events causing a table of symbols to get cleared after the symbols were received from our source data feed. Once this problem is fixed, which will be before morning, this issue cannot happen again. We were not aware of the problem until users started reporting it because our normal server monitoring processes could not detect this kind of issue plus the NYSE was not affected making it less obvious. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-09 06:23:50] |
Our conclusion as to what the cause of the problem is might not be correct upon further analysis. However, changes have been implemented which have a good chance of preventing it again. Also, the conditions which led to it are not common to begin with. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-09 06:25:01
[2016-02-12 11:24:48] |
This problem occurred again for the Toronto Stock exchange on one of our servers on February 10. We have now definitively determined the reason for the problem and we are fixing it. This change will be deployed before the open today. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
