Date/Time: Tue, 04 Nov 2025 11:00:15 +0000
One intrument , two computers, different chart
View Count: 999
[2016-02-03 15:11:59]
User33743 - Posts: 83
I am using chart from infinity. I observed that in many cases chart with simillar chart settings (continous contract)looks totally different on two computer. Could you fix that bug?
Example from today at the attachment.
imageimage.png / V - Attached On 2016-02-03 15:11:18 UTC - Size: 37.09 KB - 312 views
imageimage(1).png / V - Attached On 2016-02-03 15:11:29 UTC - Size: 68.47 KB - 327 views
[2016-02-03 15:52:12]
Fresh example
imageScreenshot_8.png / V - Attached On 2016-02-03 15:51:58 UTC - Size: 76.17 KB - 322 views
imageScreenshot_9.png / V - Attached On 2016-02-03 15:52:05 UTC - Size: 160.54 KB - 300 views
[2016-02-03 18:53:42]
There currently is a missing data problem for the BRN symbol with TransAct.
Once that is solved which will be after the close, re-download the data following these instructions here:
https://www.sierrachart.com/index.php?page=doc/helpdetails2.html#h2.1.2
Date Time Of Last Edit: 2016-02-03 18:54:08
[2016-02-03 19:02:50]
We were mistaken about the missing data. We were looking at the March BRN contract.
We are not totally sure as to the reason for this problem. However, the data has been restored on the servers.
Re-download the current contract in the chart with Edit >> Delete All Data and Download.
[2016-02-04 05:06:35]
The ICE Exchange has made changes to the rollover rules for this symbol beginning with the April contract.
And that is likely the reason for this problem
Until we can figure this out, you may want to disable the Continuous Futures Contract option for this symbol.
[2016-02-04 09:23:47]
OK, but what is a reason for totally different candle on Live chart? Because this is not related to the ICE changes.
today we have an issue with DAX on 2m chart candle.
Screens at the attachment.
This is Critical guys...
imageScreenshot_10.png / V - Attached On 2016-02-04 09:23:12 UTC - Size: 54.82 KB - 312 views
imageScreenshot_12.png / V - Attached On 2016-02-04 09:23:18 UTC - Size: 89.46 KB - 322 views
[2016-02-04 09:24:36]
AS you can see VOLUME IS ALSO DIFFERENT...
[2016-02-04 09:32:15]
Sierra Chart is not the provider of the data feed. In regards to the DAX, refer to help topic 43:
Http://www.sierrachart.com/index.php?page=doc/helpdetails43.html
Consider using the Sierra Chart Exchange Data Feed:
What do you mean by this? Please be very very specific and provide an image of the chart, and restate your question completely without reliance on prior postings.
Here are instructions to provide an image of the chart and use no other method:
It is essential to understand that Sierra Chart works with numerous services, we have a very large support burden, and from our perspective we do not have much idea what is going on until something is closely looked into and understood. Our ability to solve problems with external services does not exist. And some issues are just simply routine, we have no control over them, and we will not get involved with them.
Date Time Of Last Edit: 2016-02-04 10:05:05
[2016-02-04 09:35:40]
The prior posting has been updated.
