Date/Time: Tue, 04 Nov 2025 14:57:38 +0000
Graph Draw Types; Stair Step On Close
View Count: 3726
[2013-03-28 06:53:08]
Carl71 - Posts: 125
Please tell me if there is a way to eliminate the gap bar at open using the stair step draw chart
See the image attached
Date Time Of Last Edit: 2013-03-28 06:53:38
image1.jpg / V - Attached On 2013-03-28 06:53:04 UTC - Size: 168.45 KB - 1181 views
[2013-03-29 02:40:13]
The method to accomplish this would be to use something like a Moving Average study set to a Length of 1 and then set it to Display As Main Price Graph.
[2013-03-29 07:32:58]
Carl71 - Posts: 125
No, it doesn't work
[2013-03-29 08:41:02]
We failed to say that you also need to set the Draw Style for the Moving Average to Dash.
[2013-03-29 14:21:19]
Carl71 - Posts: 125
Please see the image attached
In the first picture the moving average draw style is set to stair step- Line stile: dash, and in the second image draw style: dash Line stile solid
image1.jpg / V - Attached On 2013-03-29 14:21:04 UTC - Size: 146.61 KB - 1166 views
image2.jpg / V - Attached On 2013-03-29 14:21:16 UTC - Size: 136.52 KB - 1162 views
[2013-03-29 18:11:28]
These are the results we expect. If they provide a suitable visual display that is what you are looking for, then that is good. Otherwise, we are out of suggestions.
