Date/Time: Sun, 29 Dec 2024 15:59:24 +0000
Blank lower time frame ( Eg hourly, minute ) historical chart for $HSI.
View Count: 963
[2016-01-27 15:25:13]
User474034 - Posts: 3
Currently I am using the trial version of Sierra Chart and are encountering the following issues :
1) Whenever I tried to open the historical chart for $HSI of a lower time frame ( Eg hourly ; minute ), the chart window stays blank after the command for loading is complete.
http://www.sierrachart.com/image.php?l=1453907691797.png
2) When I add the Volume and Ask/Bid Volume Difference Bars studies to the historical $HSI daily chart, nothing are reflected for both the studies added.
http://www.sierrachart.com/image.php?l=1453907740566.png
Both the screenshots are uploaded for your reference and understanding of the issues I am facing while using Sierra Chart.
Need your kind assistance and advise.
Thank you.
Sincerely,
Darren
[2016-01-27 16:45:23]
1. This means there is not Intraday data available for that symbol.
2. This means there is not volume data for that symbol.
[2016-01-29 10:54:46]
Thank you for your reply.
Just to highlight, in my past experience while trying Sierra Chart, I was able to access the Intraday data for $HSI and the Volume Studies data as well.
Is there any service/data provider which I can subscribe for their data feeds or do I need to open a live account in order to access the $HSI symbol and the volume studies.
Kindly advise.
[2016-01-29 11:06:27]
What you are referring to probably is the HSI CFD symbol through the SC Forex Data service. Refer to the instructions here:
Sierra Chart Real Time and Historical Forex and CFD Data Service
The symbol is:
HKG33
Date Time Of Last Edit: 2016-01-29 11:06:50
[2016-01-29 14:08:07]
Thank you very much for your precise reply.
Cheers
